NZX series
Single Zener diodes
Rev. 4 — 28 November 2011
Product data sheet
1. Product profile
1.1 General description
General-purpose Zener diodes in a SOD27 (SC-40) small hermetically sealed glass
package.
1.2 Features and benefits
Total power dissipation: Ptot 500 mW
Low differential resistance
Low leakage current
1.3 Applications
General regulation functions
1.4 Quick reference data
Table 1.
Tj = 25 C unless otherwise specified.
Symbol
Parameter
Conditions
VF
forward voltage
IF = 200 mA
[1]
[1]
Min
Typ
Max
Unit
1.5
V
Pulse test: tp 300 s; 0.02.
2. Pinning information
Table 2.
Pin
Pinning
Description
1
cathode
2
anode
Simplified outline
Graphic symbol
[1]
k
a
1
2
006aaa152
[1]
The marking band indicates the cathode.
NZX series
Nexperia
Single Zener diodes
3. Ordering information
Table 3.
Type number
NZX2V1B to
[1]
Package
NZX36X[1]
Name
Description
Version
SC-40
hermetically sealed glass package; axial leaded;
2 leads
SOD27
The series consists of 112 types with nominal working voltages from 2.1 V to 36 V.
4. Marking
Table 4.
Marking codes
Type number
Marking code
NZX2V1B to NZX36X
the diodes are type branded
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
IF
forward current
Ptot
total power dissipation
Conditions
Ttp 25 C
Min
Max
Unit
250
mA
500
mW
Tj
junction temperature
175
C
Tamb
ambient temperature
55
+175
C
Tstg
storage temperature
65
+175
C
6. Thermal characteristics
Table 6.
Symbol
Product data sheet
Parameter
Conditions
Rth(j-a)
thermal resistance from in free air
junction to ambient
[1]
Rth(j-t)
junction to tie-point
[1]
[1]
NZX_SER
Min
Typ
Max
Unit
380
K/W
300
K/W
Device mounted on an FR4 Printed-Circuit Board (PCB) without metallization pad;
maximum lead length 8 mm.
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
NZX series
Nexperia
Single Zener diodes
006aab601
103
δ=1
0.75
0.50
0.33
0.20
0.10
Rth(j-a)
(K/W)
102
0.05
0.02
0.01
10
≤0.001
1
10−1
1
102
10
103
104
105
tp (ms)
Fig 1.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
7. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
VF
forward voltage
IF = 200 mA
[1]
[1]
Min
Typ
Max
Unit
1.5
V
Table 8.
Characteristics per type; NZX2V1B to NZX18C
NZXxxx
Sel
Working voltage
VZ (V)
Differential
resistance
Reverse current
IR (A)
rdif ()
IZ = 5 mA
Max
Max
VR (V)
B
2.0
2.2
100
5
0.5
2V4
A
2.3
2.5
100
50
1
B
2.4
2.6
A
2.5
2.7
100
B
2.6
2.8
C
2.7
2.9
100
10
1
100
5
1
3V0
3V3
Product data sheet
Max
2V1
2V7
NZX_SER
IZ = 5 mA
Min
A
2.8
3.0
B
2.9
3.1
C
3.0
3.2
A
3.1
3.3
B
3.2
3.4
C
3.3
3.5
3 of 13
NZX series
Nexperia
Single Zener diodes
Table 8.
Characteristics per type; NZX2V1B to NZX18C …continued
NZXxxx
Sel
Working voltage
VZ (V)
Differential
resistance
Reverse current
IR (A)
rdif ()
IZ = 5 mA
3V6
3V9
4V3
4V7
5V1
5V6
6V2
6V8
NZX_SER
Product data sheet
A
IZ = 5 mA
Min
Max
Max
Max
VR (V)
3.4
3.6
100
5
1
100
3
1
100
3
1
100
3
2
100
2
2
40
1
2
15
3
4
15
2
4
B
3.5
3.7
C
3.6
3.8
A
3.7
3.9
B
3.8
4.0
C
3.9
4.1
A
4.0
4.2
B
4.1
4.3
C
4.2
4.4
D
4.3
4.5
A
4.4
4.6
B
4.5
4.7
C
4.6
4.8
D
4.7
4.9
A
4.8
5.0
B
4.9
5.1
C
5.0
5.2
D
5.1
5.3
A
5.2
5.5
B
5.3
5.6
C
5.4
5.7
D
5.5
5.8
E
5.6
5.9
A
5.7
6.0
B
5.8
6.1
C
6.0
6.3
D
6.1
6.4
E
6.3
6.6
A
6.4
6.7
B
6.6
6.9
C
6.7
7.0
D
6.9
7.2
4 of 13
NZX series
Nexperia
Single Zener diodes
Table 8.
NZXxxx
Sel
Working voltage
VZ (V)
Differential
resistance
Reverse current
IR (A)
rdif ()
IZ = 5 mA
7V5
8V2
9V1
10
11
12
13
14
NZX_SER
Product data sheet
A
IZ = 5 mA
Min
Max
Max
Max
VR (V)
7.0
7.3
15
1
5
5
6
25
0.2
7
25
0.1
8
35
0.1
8
35
0.1
8
35
0.05
9.8
B
7.2
7.6
C
7.3
7.7
D
7.5
7.9
X
7.07
7.45
A
7.7
8.1
B
7.9
8.3
C
8.1
8.5
D
8.3
8.7
A
8.5
8.9
B
8.7
9.1
C
8.9
9.3
D
9.1
9.5
E
9.3
9.7
A
9.5
9.9
B
9.7
10.1
C
9.9
10.3
D
10.2
10.6
A
10.4
10.8
B
10.7
11.1
C
10.9
11.3
D
11.1
11.6
A
11.4
11.9
B
11.6
12.1
C
11.9
12.4
D
12.2
12.7
X
11.44
12.03
A
12.4
12.9
B
12.6
13.1
C
12.9
13.4
A
13.2
13.7
B
13.5
14.0
C
13.8
14.3
5 of 13
NZX series
Nexperia
Single Zener diodes
Table 8.
NZXxxx
Sel
Working voltage
VZ (V)
Differential
resistance
Reverse current
IR (A)
rdif ()
IZ = 5 mA
15
16
18
NZX_SER
Product data sheet
IZ = 5 mA
Min
Max
Max
Max
VR (V)
A
14.1
14.7
40
0.05
10.5
B
14.5
15.1
C
14.9
15.5
X
14.35
15.09
A
15.3
15.9
45
0.05
11.2
B
15.7
16.5
C
16.3
17.1
A
16.9
17.7
55
0.05
12.6
B
17.5
18.3
C
18.1
19.0
6 of 13
NZX series
Nexperia
Single Zener diodes
Table 9.
Characteristics per type; NZX20A to NZX36X
NZXxxx
Sel
Working voltage
VZ (V)
Differential
resistance
Reverse current
IR (A)
rdif ()
IZ = 2 mA
24
27
30
33
36
NZX_SER
Product data sheet
IZ = 2 mA
Min
Max
Max
Max
VR (V)
A
18.8
19.7
60
0.05
14
B
19.5
20.4
C
20.2
21.2
A
20.9
21.9
65
0.05
15.4
B
21.6
22.6
C
22.3
23.3
A
22.9
24.0
70
0.05
16.8
B
23.6
24.7
C
24.3
25.5
X
22.61
23.77
A
25.2
26.6
80
0.05
18.9
B
26.2
27.6
C
27.2
28.6
X
26.99
28.39
A
28.2
29.6
100
0.05
21
B
29.2
30.6
C
30.2
31.6
X
29.02
30.51
A
31.2
32.6
120
0.05
23.1
B
32.2
33.6
C
33.2
34.5
A
34.2
35.7
140
0.05
25.2
B
35.3
36.8
C
36.4
38.0
X
35.36
37.19
7 of 13
NZX series
Nexperia
Single Zener diodes
mbg781
300
006aac510
SZ
(mV/K)
IF
(mA)
4V3
−1
200
3V9
3V6
2V1
−2
100
3V3
3V0
2V4
2V7
−3
0.8
1
60
IZ (mA)
VF (V)
Tj = 25 C
NZX2V1 to NZX4V3
Tj = 25 C to 150 C
Fig 2.
Forward current as a function of forward
voltage; typical values
Fig 3.
Temperature coefficient as a function of
working current; typical values
mbg782
10
12
SZ
(mV/K)
11
10
9V1
5
8V2
7V5
6V8
6V2
5V6
5V1
4V7
−5
8
12
16
IZ (mA)
NZX4V7 to NZX12
Tj = 25 C to 150 C
Fig 4.
Temperature coefficient as a function of working current; typical values
NZX_SER
Product data sheet
8 of 13
NZX series
Nexperia
Single Zener diodes
8. Package outline
0.56
max
25.4
min
4.25
max
Dimensions in mm
Fig 5.
1.85
max
25.4
min
05-12-22
Package outline SOD27 (SC-40)
9. Packing information
Table 10. Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number[2]
Package
Description
Packing quantity
5000
NZX2V1B to NZX36X SOD27
NZX_SER
Product data sheet
10000
26 mm tape ammopack, axial
-143
52 mm tape ammopack, axial
-133
52 mm reel pack, axial
-113
[1]
For further information and the availability of packing methods, see Section 12.
[2]
9 of 13
NZX series
Nexperia
Single Zener diodes
10. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
NZX_SER v.4
20111128
Product data sheet
NZX_SER v.3
Modifications:
Section 1.2: corrected.
Section 11 “Legal information”: updated.
NZX_SER v.3
20110121
Product data sheet
NZX_SER v.2
NZX_SER v.2
20090603
Product data sheet
NZX_SER v.1
NZX_SER v.1
20080724
Product data sheet
NZX_SER
Product data sheet
10 of 13
NZX series
Nexperia
Single Zener diodes
11. Legal information
11.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
11.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
11.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
NZX_SER
Product data sheet
11 of 13
NZX series
Nexperia
Single Zener diodes
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
11.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
12. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
NZX_SER
Product data sheet
12 of 13
Nexperia
NZX series
Single Zener diodes
13. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
11.1
11.2
11.3
11.4
12
13
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 2
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Packing information . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Date of release: 28 November 2011
