BZX84 series
Voltage regulator diodes
Rev. 6 — 6 March 2014
Product data sheet
1. Product profile
1.1 General description
Low-power voltage regulator diodes in a small SOT23 (TO-236AB) Surface-Mounted
Device (SMD) plastic package.
The diodes are available in the normalized E24 1 % (BZX84-A), 2 % (BZX84-B) and
approximately 5 % (BZX84-C) tolerance range. The series includes 37 breakdown
voltages with nominal working voltages from 2.4 V to 75 V.
1.2 Features and benefits
Total power dissipation: 250 mW
Working voltage range:
nominal 2.4 V to 75 V (E24 range)
Three tolerance series: 1 %, 2 % and Non-repetitive peak reverse power
approximately 5 %
dissipation: 40 W
AEC-Q101 qualified
1.3 Applications
General regulation functions
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
VF
forward voltage
IF = 10 mA
[1]
Ptot
total power dissipation
Tamb 25 °C
[2]
Min
Typ
Max
Unit
0.9
V
250
mW
[1]
Pulse test: tp 100 s; 0.02
[2]
Device mounted on a FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
BZX84 series
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Symbol
Description
1
A
anode
2
n.c.
not connected
3
K
cathode
Simplified outline
Graphic symbol
K
3
n.c.
A
1
2
aaa-006592
3. Ordering information
Table 3.
Type number
Package
Name
BZX84
[1]
series[1]
Description
Version
TO-236AB plastic surface-mounted package; 3 leads
SOT23
The series includes 37 breakdown voltages with nominal working voltages from 2.4 V to 75 V and 1 %,
2 % and 5 % tolerances.
4. Marking
Table 4.
BZX84_SER
Product data sheet
Marking codes
Type number
Marking code[1]
Type number
Marking code[1]
BZX84-A2V4
*50
BZX84-A18
KF*
BZX84-A2V7
*51
BZX84-A20
*C2
BZX84-A3V0
*52
BZX84-A22
KG*
BZX84-A3V3
*53
BZX84-A24
KH*
BZX84-A3V6
*C1
BZX84-A27
*75
BZX84-A3V9
*55
BZX84-A30
KJ*
BZX84-A4V3
*56
BZX84-A33
KK*
BZX84-A4V7
*57
BZX84-A36
*C3
BZX84-A5V1
*58
BZX84-A39
*C4
BZX84-A5V6
*59
BZX84-A43
*C5
BZX84-A6V2
*60
BZX84-A51
*C6
BZX84-A6V8
*61
BZX84-A75
*86
BZX84-A7V5
*62
BZX84-B2V4
*Z0
BZX84-A8V2
*63
BZX84-B2V7
*Z1
BZX84-A9V1
*64
BZX84-B3V0
*S1
BZX84-A10
*65
BZX84-B3V3
*S2
BZX84-A11
*04
BZX84-B3V6
*S3
BZX84-A12
*67
BZX84-B3V9
*S4
BZX84-A13
*C0
BZX84-B4V3
*S7
BZX84-A15
*69
BZX84-B4V7
*S8
BZX84-A16
KE*
BZX84-B5V1
*R1
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 16
BZX84 series
Nexperia
Table 4.
Type number
Marking code[1]
Type number
Marking code[1]
BZX84-B5V6
*R2
BZX84-C3V9
*B3
BZX84-B6V2
*R5
BZX84-C4V3
*B6
BZX84-B6V8
*R6
BZX84-C4V7
Z1*
BZX84-B7V5
*R8
BZX84-C5V1
Z2*
BZX84-B8V2
*R9
BZX84-C5V6
Z3*
BZX84-B9V1
*T1
BZX84-C6V2
Z4*
BZX84-B10
*66
BZX84-C6V8
Z5*
BZX84-B11
*Z6
BZX84-C7V5
Z6*
BZX84-B12
*Z7
BZX84-C8V2
Z7*
BZX84-B13
*Z8
BZX84-C9V1
Z8*
BZX84-B15
*Z9
BZX84-C10
Z9*
BZX84-B16
*70
BZX84-C11
Y1*
BZX84-B18
*71
BZX84-C12
Y2*
BZX84-B20
*72
BZX84-C13
Y3*
BZX84-B22
*73
BZX84-C15
Y4*
BZX84-B24
*74
BZX84-C16
Y5*
BZX84-B27
*Z5
BZX84-C18
Y6*
BZX84-B30
*Z4
BZX84-C20
Y7*
BZX84-B33
*Y1
BZX84-C22
Y8*
BZX84-B36
*Y2
BZX84-C24
Y9*
BZX84-B39
*S0
BZX84-C27
*T2
BZX84-B43
*S5
BZX84-C30
*T5
BZX84-B47
*S6
BZX84-C33
*T6
BZX84-B51
*S9
BZX84-C36
*T7
BZX84-B56
*R0
BZX84-C39
*T8
BZX84-B62
*R3
BZX84-C43
*B4
BZX84-B68
*R4
BZX84-C47
*B5
BZX84-B75
*R7
BZX84-C51
*B7
BZX84-C2V4
*T3
BZX84-C56
*B8
BZX84-C2V7
*T4
BZX84-C62
*B9
BZX84-C3V0
*T9
BZX84-C68
*B0
BZX84-C3V3
*B1
BZX84-C75
*A1
BZX84-C3V6
*B2
[1]
BZX84_SER
Product data sheet
Marking codes …continued
* = placeholder for manufacturing site code
3 of 16
BZX84 series
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
IF
forward current
Min
Max
Unit
200
mA
[1]
40
W
[2]
250
mW
PZSM
non-repetitive peak
reverse power dissipation
Ptot
Tamb
ambient temperature
150
C
Tstg
storage temperature
55
+150
C
Tj
junction temperature
65
+150
C
Tamb 25 C
[1]
tp = 100 s; square wave; Tj = 25 C before surge
[2]
Device mounted on a FR4 PCB, single-sided copper, tin-plated and standard footprint.
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from
junction to ambient
Rth(j-sp)
junction to solder point
in free air
Min
Typ
Max
Unit
[1]
500
K/W
[2]
330
K/W
[1]
[2]
Soldering point of cathode tab.
7. Characteristics
Table 7.
Characteristics
Tj = 25 C unless otherwise specified.
Symbol
VF
[1]
BZX84_SER
Product data sheet
Parameter
Conditions
forward voltage
IF = 10 mA
[1]
Min
Typ
Max
Unit
0.9
V
4 of 16
BZX84 series
Nexperia
Table 8.
Characteristics per type; BZX84-A2V4 to BZX84-C24
BZX84- Sel Working
xxx
voltage
VZ (V)
2V4
2V7
3V0
3V3
3V6
3V9
4V3
4V7
5V1
5V6
6V2
6V8
Differential resistance
rdif ()
Reverse
current
IR (A)
Temperature
coefficient
SZ (mV/K)
Diode
Non-repetitive
capacitance peak reverse
Cd (pF)[1]
current
IZSM (A)[2]
IZ = 5 mA
IZ = 1 mA
IZ = 5 mA
Min
Max
Typ
Max
Typ
Max
Max VR (V) Min
Typ
Max
Max
Max
275
600
70
100
50
1
3.5
1.6
6.0
300
600
75
100
3.5
2.0
6.0
325
600
80
95
10
1
3.5
2.1
6.0
350
600
85
95
5
1
3.5
2.4
6.0
375
600
85
90
5
1
3.5
2.4
6.0
400
600
85
90
3
1
3.5
2.5
6.0
410
600
80
90
3
1
3.5
2.5
6.0
425
500
50
80
3
2
3.5
1.4
0.2
300
6.0
400
480
40
60
2
2
2.7
0.8
1.2
300
6.0
80
400
15
40
1
2
2.0
1.2
2.5
300
6.0
40
150
6
10
3
4
0.4
2.3
3.7
200
6.0
30
80
6
15
2
4
1.2
3.0
4.5
200
6.0
A
2.37
2.43
B
2.35
2.45
C
2.2
2.6
A
2.67
2.73
B
2.65
2.75
C
2.5
2.9
A
2.97
3.03
B
2.94
3.06
C
2.8
3.2
A
3.26
3.34
B
3.23
3.37
C
3.1
3.5
A
3.56
3.64
B
3.53
3.67
C
3.4
3.8
A
3.86
3.94
B
3.82
3.98
C
3.7
4.1
A
4.25
4.35
B
4.21
4.39
C
4.0
4.6
A
4.65
4.75
B
4.61
4.79
C
4.4
5.0
A
5.04
5.16
B
5.0
5.2
C
4.8
5.4
A
5.54
5.66
B
5.49
5.71
C
5.2
6.0
A
6.13
6.27
B
6.08
6.32
C
5.8
6.6
A
6.73
6.87
B
6.66
6.94
C
6.4
7.2
BZX84_SER
Product data sheet
IZ = 5 mA
5 of 16
BZX84 series
Nexperia
Table 8.
Characteristics per type; BZX84-A2V4 to BZX84-C24 …continued
BZX84- Sel Working
xxx
voltage
VZ (V)
7V5
8V2
9V1
10
11
12
13
15
16
18
rdif ()
Reverse
current
IR (A)
Temperature
coefficient
SZ (mV/K)
Diode
Non-repetitive
Cd (pF)[1]
current
IZSM (A)[2]
IZ = 5 mA
IZ = 1 mA
IZ = 5 mA
Min
Max
Typ
Max
Typ
Max
Max VR (V) Min
Typ
Max
Max
Max
A
7.42
7.58
30
80
6
15
1
5
2.5
4.0
5.3
150
4.0
B
7.35
7.65
C
7.0
7.9
A
8.11
8.29
40
80
6
15
0.7
5
3.2
4.6
6.2
150
4.0
B
8.04
8.36
C
7.7
8.7
40
100
6
15
0.5
6
3.8
5.5
7.0
150
3.0
50
150
8
7
4.5
6.4
8.0
90
3.0
150
10
8
5.4
7.4
9.0
85
2.5
150
10
25
0.1
8
6.0
8.4
10.0
85
2.5
170
10
30
0.1
8
7.0
9.4
11.0
80
2.5
200
10
30
0.05 10.5
9.2
11.4
13.0
75
2.0
200
10
40
0.05 11.2
10.4
12.4
14.0
75
1.5
225
10
45
0.05 12.6
12.4
14.4
16.0
70
1.5
60
225
15
55
0.05 14
14.4
16.4
18.0
60
1.5
250
0.05 15.4
16.4
18.4
20.0
60
1.25
A
9
9.2
B
8.92
9.28
C
8.5
9.6
A
9.9
10.1
B
9.8
10.2
C
9.4
10.6
A
10.8
11.11 50
B
10.8
11.2
11.6
C
10.4
A
11.88 12.12 50
B
11.8
12.2
C
11.4
12.7
A
12.87 13.13 50
B
12.7
13.3
C
12.4
14.1
A
14.85 15.15 50
B
14.7
15.3
C
13.8
15.6
A
15.84 16.16 50
B
15.7
16.3
C
15.3
17.1
A
17.82 18.18 50
B
17.6
18.4
C
16.8
19.1
A
19.8
20.2
B
19.6
20.4
C
18.8
21.2
A
21.78 22.22 60
B
21.6
22.4
C
20.8
23.3
BZX84_SER
Product data sheet
IZ = 5 mA
6 of 16
BZX84 series
Nexperia
Table 8.
BZX84- Sel Working
xxx
voltage
VZ (V)
24
rdif ()
Reverse
current
IR (A)
Temperature
coefficient
SZ (mV/K)
Diode
Non-repetitive
Cd (pF)[1]
current
IZSM (A)[2]
IZ = 5 mA
IZ = 1 mA
IZ = 5 mA
Min
Typ
Max
Typ
Max
Max VR (V) Min
Typ
Max
Max
Max
250
25
70
0.05 16.8
20.4
22.0
55
1.25
Max
A
23.76 24.24 60
B
23.5
24.5
C
22.8
25.6
[1]
f = 1 MHz; VR = 0 V
[2]
IZ = 5 mA
18.4
Table 9.
Characteristics per type; BZX84-A27 to BZX84-C75
BZX84- Sel Working
xxx
voltage
VZ (V)
27
30
33
36
39
43
47
51
rdif ()
IZ = 2 mA
IZ = 0.5 mA IZ = 2 mA
Min
Typ
Max
Max VR (V) Min
Typ
Max
Max
Max
300
25
80
0.05 18.9
21.4
23.4
25.3
50
1.0
300
30
80
0.05 21
24.4
26.6
29.4
50
1.0
325
35
80
0.05 23.1
27.4
29.7
33.4
45
0.9
350
35
90
0.05 25.2
30.4
33.0
37.4
45
0.8
350
40
130
0.05 27.3
33.4
36.4
41.2
45
0.7
375
45
150
0.05 30.1
37.6
41.2
46.6
40
0.6
85
375
50
170
0.05 32.9
42.0
46.1
51.8
40
0.5
400
60
180
0.05 35.7
46.6
51.0
57.2
40
0.4
26.73 27.27 65
27.5
C
25.1
28.9
A
29.7
30.30 70
B
29.4
30.6
C
28.0
32.0
A
32.67 33.33 75
B
32.3
33.7
C
31.0
35.0
A
35.64 36.36 80
B
35.3
36.7
C
34.0
38.0
A
38.61 39.39 80
B
38.2
39.8
C
37.0
41.0
A
42.57 43.43 85
42.1
43.9
46.0
B
46.1
47.9
C
44.0
50.0
A
50.49 51.51 90
B
50.0
52.0
C
48.0
54.0
BZX84_SER
Product data sheet
IZ = 2 mA
Max
26.5
40.0
Diode
Non-repetitive
Cd (pF)[1]
current
IZSM (A)[2]
Typ
A
C
Temperature
coefficient
SZ (mV/K)
Max
B
B
Reverse
current
IR (A)
7 of 16
BZX84 series
Nexperia
Table 9.
Characteristics per type; BZX84-A27 to BZX84-C75 …continued
BZX84- Sel Working
xxx
voltage
VZ (V)
56
62
68
75
rdif ()
Reverse
current
IR (A)
Temperature
coefficient
SZ (mV/K)
Diode
Non-repetitive
Cd (pF)[1]
current
IZSM (A)[2]
IZ = 2 mA
Min
Max
Typ
Max
Typ
Max
Max VR (V) Min
Typ
Max
Max
Max
B
54.9
57.1
100
425
70
200
0.05 39.2
52.2
57.0
63.8
40
0.3
C
52.0
60.0
B
60.8
63.2
120
450
80
215
0.05 43.4
58.8
64.4
71.6
35
0.3
C
58.0
66.0
B
66.6
69.4
150
475
90
240
0.05 47.6
65.6
71.7
79.8
35
0.25
C
64.0
72.0
A
74.25 75.75 170
500
95
255
0.05 52.5
73.4
80.2
88.6
35
0.20
B
73.5
76.5
C
70.0
79.0
[1]
f = 1 MHz; VR = 0 V
[2]
BZX84_SER
Product data sheet
IZ = 2 mA
8 of 16
BZX84 series
Nexperia
mbg801
103
mbg781
300
PZSM
(W)
IF
(mA)
102
200
(1)
10
100
(2)
1
10−1
1
10
tp (ms)
0.8
1
VF (V)
(1) Tj = 25 C (before surge)
Tj = 25 C
(2) Tj = 150 C (before surge)
Fig 1.
Non-repetitive peak reverse power dissipation
as a function of pulse duration; maximum
values
Fig 2.
mbg783
Forward current as a function of forward
voltage; typical values
mbg782
10
12
SZ
(mV/K)
SZ
(mV/K)
4V3
11
10
−1
9V1
5
3V9
8V2
7V5
6V8
3V6
−2
6V2
5V6
5V1
3V3
4V7
3V0
2V4
2V7
−3
Fig 3.
IZ (mA)
−5
60
8
12
16
BZX84-A/B/C2V4 to BZX84-A/B/C4V3
BZX84-A/B/C4V7 to BZX84-A/B/C12
Tj = 25 C to 150 C
Tj = 25 C to 150 C
Temperature coefficient as a function of
working current; typical values
BZX84_SER
Product data sheet
Fig 4.
IZ (mA)
9 of 16
BZX84 series
Nexperia
IR
(A)
aaa-006665
10-1
2V4
10-2
2V7
10-3
3V0
3V3
3V6 3V9
4V3 4V7 5V1
IR
(A)
aaa-006666
10-1
7V5
10-2
10 12
15
18
22
8V2
10-3
9V1
11 13
16
10-4
10-4
10-5
10-5
10-6
6V2
5V6
6V8
10-6
10-7
10-7
10-8
10-9
10-8
4
6
8
10
15
VR (V)
VR (V)
Fig 5.
BZX84-A/B/C2V4 to BZX84-A/B/C6V8
BZX84-A/B/C7V5 to BZX84-A/B/C24
Tamb = 25 C
Tamb = 25 C
Reverse current as a function of reverse
IR
(A)
Fig 6.
25
aaa-006667
10-1
43
30 36
10-2
27
33
39
51
47
62
75
68
56
10-3
10-4
10-5
10-6
10-7
10-8
10-9
60
80
VR (V)
BZX84-A/B/C27 to BZX84-A/B/C75
Tamb = 25 C
Fig 7.
Reverse current as a function of reverse voltage; typical values
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
BZX84_SER
Product data sheet
10 of 16
BZX84 series
Nexperia
9. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
0.48
0.38
Dimensions in mm
Fig 8.
0.15
0.09
04-11-04
Package outline SOT23 (TO-236AB)
10. Packing information
Table 10. Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
BZX84
BZX84_SER
Product data sheet
series[2]
Package
SOT23
(TO-236AB)
Description
4 mm pitch, 8 mm tape and reel
Packing quantity
3000
10000
-215
-235
[1]
For further information and the availability of packing methods, see Section 14.
[2]
11 of 16
BZX84 series
Nexperia
11. Soldering
3.3
2.9
1.9
solder lands
solder resist
3
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
Fig 9.
sot023_fr
Reflow soldering footprint SOT23 (TO-236AB)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot023_fw
Fig 10. Wave soldering footprint SOT23 (TO-236AB)
BZX84_SER
Product data sheet
12 of 16
BZX84 series
Nexperia
12. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BZX84_SER v.6
20140306
Product data sheet
BZX84_SER v.5
Modifications:
Descriptive title of the document corrected
BZX84_SER v.5
20130918
Product data sheet
BZX84_SER v.4
BZX84_SER v.4
20130322
Product data sheet
BZX84_SERIES v.3
BZX84_SERIES v.3
20030410
Product data sheet
BZX84 v.2
BZX84 v.2
19990518
Product specification
BZX84 v.1
BZX84 v.1
19960426
BZX84_SER
Product data sheet
13 of 16
BZX84 series
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
BZX84_SER
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
14 of 16
BZX84 series
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
13.4 Trademarks
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BZX84_SER
Product data sheet
15 of 16
Nexperia
BZX84 series
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Test information . . . . . . . . . . . . . . . . . . . . . . . . 10
Quality information . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Packing information . . . . . . . . . . . . . . . . . . . . 11
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 06 March 2014
