NZX3V0B,133
NZX3V0B,133
    NEXPERIA(安世)
    SOD27
    稳压二极管 Vz=3V 2.9V~3.1V Izt=5mA P=500mW SOD27
NZX3V0B,133 数据手册
NZX series Single Zener diodes Rev. 4 — 28 November 2011 Product data sheet 1. Product profile 1.1 General description General-purpose Zener diodes in a SOD27 (SC-40) small hermetically sealed glass package. 1.2 Features and benefits  Total power dissipation: Ptot  500 mW  Low differential resistance  Low leakage current 1.3 Applications  General regulation functions 1.4 Quick reference data Table 1. Quick reference data Tj = 25 C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 200 mA [1] [1] Min Typ Max Unit - - 1.5 V Pulse test: tp  300 s;   0.02. 2. Pinning information Table 2. Pin Pinning Description 1 cathode 2 anode Simplified outline Graphic symbol [1] k a 1 2 006aaa152 [1] The marking band indicates the cathode. NZX series Nexperia Single Zener diodes 3. Ordering information Table 3. Ordering information Type number NZX2V1B to [1] Package NZX36X[1] Name Description Version SC-40 hermetically sealed glass package; axial leaded; 2 leads SOD27 The series consists of 112 types with nominal working voltages from 2.1 V to 36 V. 4. Marking Table 4. Marking codes Type number Marking code NZX2V1B to NZX36X the diodes are type branded 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF forward current Ptot total power dissipation Conditions Ttp  25 C Min Max Unit - 250 mA - 500 mW Tj junction temperature - 175 C Tamb ambient temperature 55 +175 C Tstg storage temperature 65 +175 C 6. Thermal characteristics Table 6. Symbol Product data sheet Parameter Conditions Rth(j-a) thermal resistance from in free air junction to ambient [1] Rth(j-t) thermal resistance from junction to tie-point [1] [1] NZX_SER Thermal characteristics Min Typ Max Unit - - 380 K/W - - 300 K/W Device mounted on an FR4 Printed-Circuit Board (PCB) without metallization pad; maximum lead length 8 mm. All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 2 of 13 NZX series Nexperia Single Zener diodes 006aab601 103 δ=1 0.75 0.50 0.33 0.20 0.10 Rth(j-a) (K/W) 102 0.05 0.02 0.01 10 ≤0.001 1 10−1 1 102 10 103 104 105 tp (ms) Fig 1. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 7. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 200 mA [1] [1] Min Typ Max Unit - - 1.5 V Pulse test: tp  300 s;   0.02. Table 8. Characteristics per type; NZX2V1B to NZX18C Tj = 25 C unless otherwise specified. NZXxxx Sel Working voltage VZ (V) Differential resistance Reverse current IR (A) rdif () IZ = 5 mA Max Max VR (V) B 2.0 2.2 100 5 0.5 2V4 A 2.3 2.5 100 50 1 B 2.4 2.6 A 2.5 2.7 100 20 1 B 2.6 2.8 C 2.7 2.9 100 10 1 100 5 1 3V0 3V3 Product data sheet Max 2V1 2V7 NZX_SER IZ = 5 mA Min A 2.8 3.0 B 2.9 3.1 C 3.0 3.2 A 3.1 3.3 B 3.2 3.4 C 3.3 3.5 All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 3 of 13 NZX series Nexperia Single Zener diodes Table 8. Characteristics per type; NZX2V1B to NZX18C …continued Tj = 25 C unless otherwise specified. NZXxxx Sel Working voltage VZ (V) Differential resistance Reverse current IR (A) rdif () IZ = 5 mA 3V6 3V9 4V3 4V7 5V1 5V6 6V2 6V8 NZX_SER Product data sheet A IZ = 5 mA Min Max Max Max VR (V) 3.4 3.6 100 5 1 100 3 1 100 3 1 100 3 2 100 2 2 40 1 2 15 3 4 15 2 4 B 3.5 3.7 C 3.6 3.8 A 3.7 3.9 B 3.8 4.0 C 3.9 4.1 A 4.0 4.2 B 4.1 4.3 C 4.2 4.4 D 4.3 4.5 A 4.4 4.6 B 4.5 4.7 C 4.6 4.8 D 4.7 4.9 A 4.8 5.0 B 4.9 5.1 C 5.0 5.2 D 5.1 5.3 A 5.2 5.5 B 5.3 5.6 C 5.4 5.7 D 5.5 5.8 E 5.6 5.9 A 5.7 6.0 B 5.8 6.1 C 6.0 6.3 D 6.1 6.4 E 6.3 6.6 A 6.4 6.7 B 6.6 6.9 C 6.7 7.0 D 6.9 7.2 All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 4 of 13 NZX series Nexperia Single Zener diodes Table 8. Characteristics per type; NZX2V1B to NZX18C …continued Tj = 25 C unless otherwise specified. NZXxxx Sel Working voltage VZ (V) Differential resistance Reverse current IR (A) rdif () IZ = 5 mA 7V5 8V2 9V1 10 11 12 13 14 NZX_SER Product data sheet A IZ = 5 mA Min Max Max Max VR (V) 7.0 7.3 15 1 5 20 0.7 5 20 0.5 6 25 0.2 7 25 0.1 8 35 0.1 8 35 0.1 8 35 0.05 9.8 B 7.2 7.6 C 7.3 7.7 D 7.5 7.9 X 7.07 7.45 A 7.7 8.1 B 7.9 8.3 C 8.1 8.5 D 8.3 8.7 A 8.5 8.9 B 8.7 9.1 C 8.9 9.3 D 9.1 9.5 E 9.3 9.7 A 9.5 9.9 B 9.7 10.1 C 9.9 10.3 D 10.2 10.6 A 10.4 10.8 B 10.7 11.1 C 10.9 11.3 D 11.1 11.6 A 11.4 11.9 B 11.6 12.1 C 11.9 12.4 D 12.2 12.7 X 11.44 12.03 A 12.4 12.9 B 12.6 13.1 C 12.9 13.4 A 13.2 13.7 B 13.5 14.0 C 13.8 14.3 All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 5 of 13 NZX series Nexperia Single Zener diodes Table 8. Characteristics per type; NZX2V1B to NZX18C …continued Tj = 25 C unless otherwise specified. NZXxxx Sel Working voltage VZ (V) Differential resistance Reverse current IR (A) rdif () IZ = 5 mA 15 16 18 NZX_SER Product data sheet IZ = 5 mA Min Max Max Max VR (V) A 14.1 14.7 40 0.05 10.5 B 14.5 15.1 C 14.9 15.5 X 14.35 15.09 A 15.3 15.9 45 0.05 11.2 B 15.7 16.5 C 16.3 17.1 A 16.9 17.7 55 0.05 12.6 B 17.5 18.3 C 18.1 19.0 All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 6 of 13 NZX series Nexperia Single Zener diodes Table 9. Characteristics per type; NZX20A to NZX36X Tj = 25 C unless otherwise specified. NZXxxx Sel Working voltage VZ (V) Differential resistance Reverse current IR (A) rdif () IZ = 2 mA 20 22 24 27 30 33 36 NZX_SER Product data sheet IZ = 2 mA Min Max Max Max VR (V) A 18.8 19.7 60 0.05 14 B 19.5 20.4 C 20.2 21.2 A 20.9 21.9 65 0.05 15.4 B 21.6 22.6 C 22.3 23.3 A 22.9 24.0 70 0.05 16.8 B 23.6 24.7 C 24.3 25.5 X 22.61 23.77 A 25.2 26.6 80 0.05 18.9 B 26.2 27.6 C 27.2 28.6 X 26.99 28.39 A 28.2 29.6 100 0.05 21 B 29.2 30.6 C 30.2 31.6 X 29.02 30.51 A 31.2 32.6 120 0.05 23.1 B 32.2 33.6 C 33.2 34.5 A 34.2 35.7 140 0.05 25.2 B 35.3 36.8 C 36.4 38.0 X 35.36 37.19 All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 7 of 13 NZX series Nexperia Single Zener diodes mbg781 300 006aac510 0 SZ (mV/K) IF (mA) 4V3 −1 200 3V9 3V6 2V1 −2 100 3V3 3V0 2V4 2V7 0 0.6 −3 0.8 1 0 20 40 60 IZ (mA) VF (V) Tj = 25 C NZX2V1 to NZX4V3 Tj = 25 C to 150 C Fig 2. Forward current as a function of forward voltage; typical values Fig 3. Temperature coefficient as a function of working current; typical values mbg782 10 12 SZ (mV/K) 11 10 9V1 5 8V2 7V5 6V8 6V2 5V6 5V1 0 4V7 −5 0 4 8 12 16 IZ (mA) 20 NZX4V7 to NZX12 Tj = 25 C to 150 C Fig 4. Temperature coefficient as a function of working current; typical values NZX_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 8 of 13 NZX series Nexperia Single Zener diodes 8. Package outline 0.56 max 25.4 min 4.25 max Dimensions in mm Fig 5. 1.85 max 25.4 min 05-12-22 Package outline SOD27 (SC-40) 9. Packing information Table 10. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number[2] Package Description Packing quantity 5000 NZX2V1B to NZX36X SOD27 NZX_SER Product data sheet 10000 26 mm tape ammopack, axial -143 - 52 mm tape ammopack, axial - -133 52 mm reel pack, axial - -113 [1] For further information and the availability of packing methods, see Section 12. [2] The series consists of 112 types with nominal working voltages from 2.1 V to 36 V. All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 9 of 13 NZX series Nexperia Single Zener diodes 10. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes NZX_SER v.4 20111128 Product data sheet - NZX_SER v.3 Modifications: • • Section 1.2: corrected. Section 11 “Legal information”: updated. NZX_SER v.3 20110121 Product data sheet - NZX_SER v.2 NZX_SER v.2 20090603 Product data sheet - NZX_SER v.1 NZX_SER v.1 20080724 Product data sheet - - NZX_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 10 of 13 NZX series Nexperia Single Zener diodes 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. NZX_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 11 of 13 NZX series Nexperia Single Zener diodes Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 12. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com NZX_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 28 November 2011 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia NZX series Single Zener diodes 13. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 11.1 11.2 11.3 11.4 12 13 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Packing information . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 November 2011
NZX3V0B,133 价格&库存
很抱歉,暂时无法提供与“NZX3V0B,133”相匹配的价格&库存,您可以联系我们找货
NZX3V0B,133
    • 1+0.20137
    库存:400
    NZX3V0B,133
    • 8265+0.399088265+0.04994
    • 10000+0.3551310000+0.04444
    • 100000+0.29799100000+0.03729
    库存:60000
    NZX3V0B,133
    库存:80000
    NZX3V0B,133
    • 10000+0.2652110000+0.03319
    库存:23648
    NZX3V0B,133
    • 1+1.581561+0.19792
    • 10+0.9914010+0.12407
    • 100+0.61182100+0.07657
    • 500+0.44520500+0.05572
    • 1000+0.391221000+0.04896
    • 2000+0.345582000+0.04325
    • 5000+0.295955000+0.03704
    库存:23648
