NZH24C,115
NZH24C,115
    NEXPERIA(安世)
    SOD-123F
    安世 SOD-123F-2 0.9V 0.5W 5mA
NZH24C,115 数据手册
NZH series Single Zener diodes Rev. 01 — 27 January 2010 Product data sheet 1. Product profile 1.1 General description General-purpose Zener diodes in a SOD123F small and flat lead Surface-Mounted Device (SMD) plastic package. 1.2 Features „ Total power dissipation: ≤ 500 mW „ Wide working voltage range „ Small plastic package suitable for surface-mounted design „ Low differential resistance 1.3 Applications „ General regulation functions 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VF forward voltage IF = 10 mA [1] - - 0.9 V Ptot total power dissipation Tamb ≤ 25 °C [2] - - 500 mW [3] - - 1 W [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. NZH series Nexperia Single Zener diodes 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline Graphic symbol [1] 1 2 2 1 006aaa152 [1] The marking bar indicates the cathode. 3. Ordering information Table 3. Ordering information Type number NZH3V0B to NZH30C[1] [1] Package Name Description Version - plastic surface-mounted package; 2 leads SOD123F The series consists of 25 types with nominal working voltages from 3.0 V to 30 V. 4. Marking Table 4. Marking codes Type number Marking code Type number Marking code NZH3V0B CH NZH10C CW NZH3V3A CJ NZH11C CX NZH3V6B CK NZH12B CY NZH3V9B CL NZH13B D9 NZH4V3B CM NZH15B D1 NZH4V7B CN NZH16C D2 NZH5V1B CP NZH18C D3 NZH5V6B CQ NZH20C D4 NZH6V2B CR NZH22C D5 NZH6V8B CS NZH24C D6 NZH7V5C CT NZH27C D7 NZH8V2B CU NZH30C DA NZH9V1B CV - - NZH_SER Product data sheet © Nexperia B.V. 2010. All rights reserved. Rev. 01 — 27 January 2010 2 of 9 NZH series Nexperia Single Zener diodes 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions IF forward current Tamb ≤ 25 °C total power dissipation Ptot Min Max Unit - 250 mA [1] - 500 mW [2] - 1 W Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [2] Device mounted on a ceramic PCB, Al2O3, standard footprint. 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) [1] thermal resistance from junction to solder point Min Typ Max Unit [1] - - 250 K/W [2] - - 125 K/W [3] - - 70 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [2] Device mounted on a ceramic PCB, Al2O3, standard footprint. [3] Soldering point of cathode tab. 7. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Conditions forward voltage VF [1] Parameter [1] IF = 10 mA Min Typ Max Unit - - 0.9 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02. Table 8. Characteristics per type; NZH3V0B to NZH10C Tj = 25 °C unless otherwise specified. NZHxxx Working voltage VZ (V); IZ = 20 mA Maximum differential resistance rdif (Ω) Min Max IZ = 1 mA IZ = 20 mA Max VR (V) Max 3V0B 2.85 3.15 1000 80 50 1 450 3V3A 3.16 3.38 1000 70 20 1 450 3V6B 3.42 3.78 1000 60 5 1 450 3V9B 3.71 4.10 1000 50 5 1 450 NZH_SER Product data sheet Reverse current IR (μA) Diode capacitance Cd (pF)[1] © Nexperia B.V. 2010. All rights reserved. Rev. 01 — 27 January 2010 3 of 9 NZH series Nexperia Single Zener diodes Table 8. Characteristics per type; NZH3V0B to NZH10C …continued Tj = 25 °C unless otherwise specified. NZHxxx Working voltage VZ (V); IZ = 20 mA Min Max IZ = 1 mA IZ = 20 mA Max VR (V) Max 4V3B 4.17 4.43 1000 40 5 1 450 4V7B 4.55 4.80 900 25 5 1 300 5V1B 4.94 5.20 800 20 5 1.5 300 5V6B 5.45 5.73 500 13 5 2.5 300 6V2B 5.96 6.27 300 10 5 3 200 6V8B 6.49 6.83 150 8 2 3.5 200 7V5C 7.29 7.67 120 8 0.5 4 150 8V2B 8.02 8.36 120 8 0.5 5 150 9V1B 8.85 9.23 120 8 0.5 6 150 10C 9.70 10.20 120 8 0.2 7 90 [1] Maximum differential resistance rdif (Ω) Reverse current IR (μA) Diode capacitance Cd (pF)[1] f = 1 MHz; VR = 0 V Table 9. Characteristics per type; NZH11C to NZH20C Tj = 25 °C unless otherwise specified. NZHxxx Working voltage VZ (V); IZ = 10 mA Maximum differential resistance rdif (Ω) Min Max IZ = 1 mA IZ = 10 mA Max VR (V) Max 10.82 11.38 120 10 0.04 8 85 12B 11.44 12.03 110 12 0.04 9 85 13B 12.35 13.65 110 14 0.04 10 80 15B 14.25 15.75 110 16 0.04 11 75 16C 15.69 16.51 150 18 0.04 12 75 18C 17.42 18.33 150 23 0.04 13 70 20C 19.23 20.22 200 28 0.04 15 60 11C [1] Reverse current IR (μA) Diode capacitance Cd (pF)[1] f = 1 MHz; VR = 0 V Table 10. Characteristics per type; NZH22C to NZH30C Tj = 25 °C unless otherwise specified. NZHxxx Working voltage VZ (V); IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Diode capacitance Cd (pF)[1] Min Max IZ = 1 mA IZ = 5 mA Max VR (V) Max 22C 21.08 22.17 200 30 0.04 17 60 24C 23.12 24.31 200 35 0.04 19 55 27C 25.63 26.95 250 45 0.04 21 50 30C 28.50 31.50 250 55 0.04 23 50 [1] f = 1 MHz; VR = 0 V NZH_SER Product data sheet © Nexperia B.V. 2010. All rights reserved. Rev. 01 — 27 January 2010 4 of 9 NZH series Nexperia Single Zener diodes mbg781 300 IF (mA) 200 100 0 0.6 0.8 1 VF (V) Tj = 25 °C Fig 1. Forward current as a function of forward voltage; typical values 006aac010 50 VZ(nom) (V) = 3.0 IZ (mA) IZ (mA) 25 3.3 3.6 3.9 40 006aac011 30 5.1 6.2 20 9.1 7.5 5.6 6.8 13 VZ(nom) (V) = 12 30 15 16 8.2 15 20 10 10 5 0 0 2 4 6 8 0 7.5 10 10.0 VZ (V) 17.5 Tj = 25 °C Working current as a function of working voltage; typical values Fig 3. Working current as a function of working voltage; typical values NZH_SER Product data sheet 15.0 VZ (V) Tj = 25 °C Fig 2. 12.5 © Nexperia B.V. 2010. All rights reserved. Rev. 01 — 27 January 2010 5 of 9 NZH series Nexperia Single Zener diodes 8. Package outline 1.7 1.5 1.2 1.0 1 0.55 0.35 3.6 3.4 2.7 2.5 2 0.70 0.55 0.25 0.10 Dimensions in mm Fig 4. 04-11-29 Package outline SOD123F 9. Packing information Table 11. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number NZH3V0B to NZH30C[2] Package SOD123F Description Packing quantity 4 mm pitch, 8 mm tape and reel [1] For further information and the availability of packing methods, see Section 13. [2] The series consists of 25 types with nominal working voltages from 3.0 V to 30 V. 3000 10000 -115 -135 10. Soldering 4.4 4 2.9 1.6 solder lands solder resist 2.1 1.6 1.1 1.2 solder paste occupied area 1.1 (2×) Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 5. Reflow soldering footprint SOD123F NZH_SER Product data sheet © Nexperia B.V. 2010. All rights reserved. Rev. 01 — 27 January 2010 6 of 9 NZH series Nexperia Single Zener diodes 11. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes NZH_SER 20100127 Product data sheet - - NZH_SER Product data sheet © Nexperia B.V. 2010. All rights reserved. Rev. 01 — 27 January 2010 7 of 9 NZH series Nexperia Single Zener diodes 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http:// www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. NZH_SER © Nexperia B.V. 2010. All rights reserved. Product data sheet Rev. 01 — 27 January 2010 8 of 9 NZH series Nexperia Single Zener diodes 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 2 2 2 3 3 3 6 6 6 7 8 8 8 8 8 9 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Nexperia B.V. 2010. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 January 2010 Document identifier: NZH_SER
NZH24C,115 价格&库存
很抱歉,暂时无法提供与“NZH24C,115”相匹配的价格&库存,您可以联系我们找货
NZH24C,115
  • 1+2.205921+0.28622
  • 10+1.3747010+0.17837
  • 50+0.9799850+0.12716
  • 100+0.85125100+0.11045
  • 500+0.62252500+0.08077
库存:230
NZH24C,115
  • 1+2.207351+0.28640
  • 10+1.3755910+0.17849
  • 100+0.85180100+0.11052
  • 500+0.62292500+0.08083
  • 1000+0.548761000+0.07120
库存:230
