BZX884-C8V2,315
BZX884-C8V2,315
    NEXPERIA(安世)
    DFN1006-2
    安世 DFN1006-2 0.9V 0.25W 5mA
BZX884-C8V2,315 数据手册
DISCRETE SEMICONDUCTORS DATA SHEET M3D891 BOTTOM VIEW BZX884 series Voltage regulator diodes Product data sheet Supersedes data of 2003 May 15 2004 Mar 26 NXP Semiconductors Product data sheet Voltage regulator diodes BZX884 series FEATURES DESCRIPTION • Two tolerance series: ±2% and ±5% Low-power voltage regulator diodes encapsulated in SOD882 leadless ultra small plastic packages. • Working voltage range: nominal 2.4 V to 75 V (E24 range) • Leadless ultra small plastic package (1 mm × 0.6 mm × 0.5 mm) • Boardspace 1.17 mm2 (approximately 10% of SOT23) handbook, halfpage • Power dissipation comparable to SOT23. APPLICATIONS Bottom view MAM472 • General regulation functions • ESD ultra high-speed switching The marking bar indicates the cathode. • High frequency applications • Mobile communication, digital (still) cameras, PDAs and PCMCIA cards. Fig.1 Simplified outline (SOD882) and symbol. MARKING TYPE NUMBER MARKING CODE TYPE NUMBER MARKING CODE TYPE NUMBER MARKING CODE TYPE NUMBER MARKING CODE Marking codes for BZX884-B2V4 to BZX884-B75 BZX884-B2V4 A1 BZX884-B6V2 AB BZX884-B16 C1 BZX884-B43 CB BZX884-B2V7 A2 BZX884-B6V8 AC BZX884-B18 C2 BZX884-B47 CC BZX884-B3V0 A3 BZX884-B7V5 AD BZX884-B20 C3 BZX884-B51 CD BZX884-B3V3 A4 BZX884-B8V2 AE BZX884-B22 C4 BZX884-B56 CE BZX884-B3V6 A5 BZX884-B9V1 AF BZX884-B24 C5 BZX884-B62 CF BZX884-B3V9 A6 BZX884-B10 AG BZX884-B27 C6 BZX884-B68 CG BZX884-B4V3 A7 BZX884-B11 AH BZX884-B30 C7 BZX884-B75 CH BZX884-B4V7 A8 BZX884-B12 AJ BZX884-B33 C8 BZX884-B5V1 A9 BZX884-B13 AK BZX884-B36 C9 BZX884-B5V6 AA BZX884-B15 AL BZX884-B39 CA Marking codes for BZX884-C2V4 to BZX884-C75 BZX884-C2V4 B1 BZX884-C6V2 BB BZX884-C16 D1 BZX884-C43 DB BZX884-C2V7 B2 BZX884-C6V8 BC BZX884-C18 D2 BZX884-C47 DC BZX884-C3V0 B3 BZX884-C7V5 BD BZX884-C20 D3 BZX884-C51 DD BZX884-C3V3 B4 BZX884-C8V2 BE BZX884-C22 D4 BZX884-C56 DE BZX884-C3V6 B5 BZX884-C9V1 BF BZX884-C24 D5 BZX884-C62 DF BZX884-C3V9 B6 BZX884-C10 BG BZX884-C27 D6 BZX884-C68 DG BZX884-C4V3 B7 BZX884-C11 BH BZX884-C30 D7 BZX884-C75 DH BZX884-C4V7 B8 BZX884-C12 BJ BZX884-C33 D8 BZX884-C5V1 B9 BZX884-C13 BK BZX884-C36 D9 BZX884-C5V6 BA BZX884-C15 BL BZX884-C39 DA 2004 Mar 26 2 NXP Semiconductors Product data sheet Voltage regulator diodes BZX884 series ORDERING INFORMATION TYPE NUMBER PACKAGE NAME DESCRIPTION VERSION BZX884-B2V4 to BZX884-B75 − Leadless ultra small plastic package;2 terminals; body 1.0 x 0.6 x 0.5 mm SOD882 BZX884-C2V4 to BZX884-C75 − Leadless ultra small plastic package;2 terminals; body 1.0 x 0.6 x 0.5 mm SOD882 LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. − MAX. 200 UNIT IF continuous forward current IZSM non-repetitive peak reverse current tp = 100 μs; square wave; Tamb = 25 °C; prior to surge see Tables 1 and 2 mA Ptot total power dissipation Tamb = 25 °C; note 1 − 250 mW Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Note 1. Refer to SOD882 standard mounting conditions (footprint), FR4 with 60 μm copper strip line. THERMAL CHARACTERISTICS SYMBOL Rth(j-a) PARAMETER CONDITIONS thermal resistance from junction to ambient note 1 Note 1. Refer to SOD882 standard mounting conditions (footprint), FR4 with 60 μm copper strip line. 2004 Mar 26 3 VALUE UNIT 500 K/W NXP Semiconductors Product data sheet Voltage regulator diodes BZX884 series ELECTRICAL CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER VF forward voltage IR reverse current 2004 Mar 26 CONDITIONS MAX. UNIT IF = 10 mA; see Fig.2 0.9 V BZX884-B/C2V4 VR = 1 V 50 μA BZX884-B/C2V7 VR = 1 V 20 μA BZX884-B/C3V0 VR = 1 V 10 μA BZX884-B/C3V3 VR = 1 V 5 μA BZX884-B/C3V6 VR = 1 V 5 μA BZX884-B/C3V9 VR = 1 V 3 μA BZX884-B/C4V3 VR = 1 V 3 μA BZX884-B/C4V7 VR = 2 V 3 μA BZX884-B/C5V1 VR = 2 V 2 μA BZX884-B/C5V6 VR = 2 V 1 μA BZX884-B/C6V2 VR = 4 V 3 μA BZX884-B/C6V8 VR = 4 V 2 μA BZX884-B/C7V5 VR = 5 V 1 μA BZX884-B/C8V2 VR = 5 V 700 nA BZX884-B/C9V1 VR = 6 V 500 nA BZX884-B/C10 VR = 7 V 200 nA BZX884-B/C11 VR = 8 V 100 nA BZX884-B/C12 VR = 8 V 100 nA BZX884-B/C13 VR = 8 V 100 nA BZX884-B/C15 to 75 VR = 0.7 VZnom 50 nA 4 DIFFERENTIAL RESISTANCE rdif (Ω) Tol. ±2% (B) Tol. ±5% (C) at IZtest = 1 mA at IZtest = 5 mA MIN. MIN. TYP. TYP. MAX. MAX. MAX. TEMP. COEFF. SZ (mV/K) at IZtest = 5 mA (see Figs 3 and 4) DIODE CAP. Cd (pF) at f = 1 MHz; VR = 0 V NON-REPETITIVE PEAK REVERSE CURRENT IZSM (A) at tp = 100 μs; Tamb = 25 °C TYP. MAX. MAX. MAX. 5 2.45 2.28 2.52 275 400 70 100 −1.3 450 6.0 2V7 2.65 2.75 2.57 2.84 300 450 75 100 −1.4 440 6.0 3V0 2.94 3.06 2.85 3.15 325 500 80 95 −1.6 425 6.0 3V3 3.23 3.37 3.14 3.47 350 500 85 95 −1.8 410 6.0 3V6 3.53 3.67 3.42 3.78 375 500 85 90 −1.9 390 6.0 3V9 3.82 3.98 3.71 4.10 400 500 85 90 −1.9 370 6.0 4V3 4.21 4.39 4.09 4.52 410 600 80 90 −1.7 350 6.0 4V7 4.61 4.79 4.47 4.94 425 500 50 80 −1.2 325 6.0 5V1 5.00 5.20 4.85 5.36 400 480 40 60 −0.5 300 6.0 5V6 5.49 5.71 5.32 5.88 80 400 15 40 1.0 275 6.0 6V2 6.08 6.32 5.89 6.51 40 150 6 10 2.2 250 6.0 6V8 6.66 6.94 6.46 7.14 30 80 6 15 3.0 215 6.0 7V5 7.35 7.65 7.13 7.88 15 80 2 10 3.6 170 4.0 8V2 8.04 8.36 7.79 8.61 20 80 2 10 4.3 150 4.0 9V1 8.92 9.28 8.65 9.56 20 100 2 10 5.2 120 3.0 10 9.80 10.20 9.50 10.50 20 150 2 10 6.0 110 3.0 11 10.78 11.22 10.45 11.55 25 150 2 10 6.9 110 2.5 12 11.76 12.24 11.40 12.60 25 150 2 10 7.9 105 2.5 13 12.74 13.26 12.35 13.65 25 170 2 10 8.8 105 2.5 15 14.70 15.30 14.25 15.75 25 200 3 15 10.7 100 2.0 16 15.68 18.32 15.20 16.80 50 200 10 40 12.4 90 1.5 18 17.64 18.36 17.10 18.90 50 225 10 45 14.4 80 1.5 20 19.60 20.40 19.00 21.00 60 225 15 55 16.4 70 1.5 22 21.56 22.44 20.90 23.10 60 250 20 55 18.4 60 1.25 24 23.52 24.48 22.80 25.20 60 250 25 70 20.4 55 1.25 Product data sheet 2.35 BZX884 series 2V4 NXP Semiconductors BZX884B or C XXX WORKING VOLTAGE VZ (V) at IZ = 5 mA Voltage regulator diodes 2004 Mar 26 Table 1 Per type BZX884-B/C2V4 to B/C24 Tj = 25 °C unless otherwise specified. DIFFERENTIAL RESISTANCE rdif (Ω) TEMP. COEFF. SZ (mV/K) at IZtest = 2 mA (see Figs 3 and 4) DIODE CAP. Cd (pF) at f = 1 MHz; VR = 0 V NON-REPETITIVE PEAK REVERSE CURRENT IZSM (A) at tp = 100 μs; Tamb = 25 °C TYP. MAX. MAX. 6 Tol. ±2% (B) Tol. ±5% (C) MIN. MAX. MIN. MAX. 27 26.46 27.54 25.65 28.35 65 300 25 80 23.4 50 1.0 30 29.40 30.60 28.50 31.50 70 300 30 80 26.6 50 1.0 33 32.34 33.66 31.35 34.65 75 325 35 80 29.7 45 0.9 36 35.28 36.72 34.20 37.80 80 350 35 90 33.0 45 0.8 39 38.22 39.78 37.05 40.95 80 350 40 130 36.4 45 0.7 43 42.14 43.86 40.85 45.15 85 375 45 150 41.2 40 0.6 47 46.06 47.94 44.65 49.35 85 375 50 170 46.1 40 0.5 51 49.98 52.02 48.45 53.55 90 400 60 180 51.0 40 0.4 56 54.88 57.12 53.20 58.80 100 425 70 200 57.0 40 0.3 62 60.76 63.24 58.90 65.10 120 450 80 215 64.4 35 0.3 68 66.64 69.36 64.60 71.40 150 475 90 240 71.7 35 0.25 75 73.50 76.50 71.25 78.75 170 500 95 255 80.2 35 0.2 at IZtest = 0.5 mA TYP. MAX. at IZtest = 2 mA TYP. MAX. NXP Semiconductors BZX884B or C XXX WORKING VOLTAGE VZ (V) at IZ = 2 mA Voltage regulator diodes 2004 Mar 26 Table 2 Per type BZX884-B/C27 to B/C75 Tj = 25 °C unless otherwise specified. Product data sheet BZX884 series NXP Semiconductors Product data sheet Voltage regulator diodes BZX884 series GRAPHICAL DATA MLD444 MBG781 0.5 300 handbook, halfpage handbook, halfpage SZ (mV/K) IF (mA) 4V7 0 4V3 200 −0.5 2V4 2V7 3V9 −1 100 3V6 −1.5 0 0.6 0.8 −2 10−1 1 VF (V) 3V3 3V0 1 Tj = 25 °C. BZX884-B/C2V4 to B/C4V7. Tj = 25 to 150 °C. Fig.2 Fig.3 Forward current as a function of forward voltage; typical values. MLD445 12 handbook, halfpage 15 SZ (mV/K) 13 12 11 10 9V1 8V2 7V5 6V8 6V2 5V6 5V1 8 4 0 −4 10−1 1 10 IZ (mA) 102 BZX884-B/C5V1 to B/C15. Tj = 25 to 150 °C. Fig.4 Temperature coefficient as a function of working current; typical values. 2004 Mar 26 7 10 IZ (mA) 102 Temperature coefficient as a function of working current; typical values. NXP Semiconductors Product data sheet Voltage regulator diodes BZX884 series PACKAGE OUTLINE Leadless ultra small plastic package; 2 terminals; body 1.0 x 0.6 x 0.5 mm L SOD882 L 1 2 b e1 A A1 E D (2) 0 0.5 1 mm scale DIMENSIONS (mm are the original dimensions) UNIT A (1) A1 max. b D E e1 L mm 0.50 0.46 0.03 0.55 0.47 0.62 0.55 1.02 0.95 0.65 0.30 0.22 Notes 1. Including plating thickness 2. The marking bar indicates the cathode OUTLINE VERSION REFERENCES IEC JEDEC JEITA ISSUE DATE 03-04-16 03-04-17 SOD882 2004 Mar 26 EUROPEAN PROJECTION 8 NXP Semiconductors Product data sheet Voltage regulator diodes BZX884 series SOLDERING Reflow soldering is the only recommended soldering method. DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings 2004 Mar 26 9 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands R76/02/pp10 Date of release: 2004 Mar 26 Document order number: 9397 750 12713 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: BZX884-B10,315 BZX884-B11,315 BZX884-B12,315 BZX884-B13,315 BZX884-B15,315 BZX884-B16,315 BZX884-B18,315 BZX884-B20,315 BZX884-B22,315 BZX884-B24,315 BZX884-B27,315 BZX884-B2V4,315 BZX884-B2V7,315 BZX884-B30,315 BZX884-B33,315 BZX884-B36,315 BZX884-B39,315 BZX884-B3V0,315 BZX884-B3V3,315 BZX884-B3V6,315 BZX884-B3V9,315 BZX884-B43,315 BZX884-B47,315 BZX884-B4V3,315 BZX884-B4V7,315 BZX884-B51,315 BZX884-B56,315 BZX884-B5V1,315 BZX884-B5V6,315 BZX884-B62,315 BZX884-B6V2,315 BZX884-B6V8,315 BZX884-B75,315 BZX884-B7V5,315 BZX884-B8V2,315 BZX884-B9V1,315 BZX884-C10,315 BZX884-C12,315 BZX884-C13,315 BZX884-C15,315 BZX884-C16,315 BZX884-C18,315 BZX884-C20,315 BZX884-C22,315 BZX884-C24,315 BZX884-C2V4,315 BZX884-C2V7,315 BZX884-C30,315 BZX884-C33,315 BZX884-C36,315 BZX884-C39,315 BZX884-C3V0,315 BZX884-C3V3,315 BZX884-C3V6,315 BZX884-C3V9,315 BZX884-C43,315 BZX884-C4V3,315 BZX884-C4V7,315 BZX884-C51,315 BZX884-C56,315 BZX884-C5V1,315 BZX884-C5V6,315 BZX884-C68,315 BZX884-C6V2,315 BZX884-C6V8,315 BZX884-C75,315 BZX884-C7V5,315 BZX884-C8V2,315 BZX884-C9V1,315
BZX884-C8V2,315 价格&库存
很抱歉,暂时无法提供与“BZX884-C8V2,315”相匹配的价格&库存,您可以联系我们找货
BZX884-C8V2,315
    • 1+4.26600
    • 10+3.55320
    • 30+3.19680
    • 100+2.84040
    • 500+2.63520
    • 1000+2.51640
    库存:38
    BZX884-C8V2,315
    • 1+2.371791+0.28394
    • 10+1.6259310+0.19465
    • 100+0.66899100+0.08009
    • 500+0.56734500+0.06792
    • 1000+0.465731000+0.05576
    库存:10
    BZX884-C8V2,315
    • 10000+0.1873510000+0.02243
    库存:10
