BZX585-C4V3,135
BZX585-C4V3,135
    NEXPERIA(安世)
    SOD-523(SC-79)
    安世 SOD-523 1.1V 0.3W 5mA
BZX585-C4V3,135 数据手册
BZX585 series Voltage regulator diodes Rev. 5 — 11 October 2016 Product data sheet 1. Product profile 1.1 General description General-purpose Zener diodes in an SOD523 (SC-79) ultra small and flat lead Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits  Non-repetitive peak reverse power dissipation:  40 W  Total power dissipation:  300 mW  AEC-Q101 qualified  Wide working voltage range: nominal 2.4 V to 75 V (E24 range)  Two tolerance series: 2 % and 5 %  Low differential resistance 1.3 Applications  General regulation functions 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter forward voltage VF PZSM Conditions IF = 100 mA non-repetitive peak reverse power dissipation [1] Pulse test: tp  300 s;   0.02. [2] tp = 100 s; square wave; Tj = 25 C before surge Min Typ Max Unit [1] - - 1.1 V [2] - - 40 W 2. Pinning information Table 2. Pin Pinning Description 1 cathode 2 anode Simplified outline Graphic symbol [1] 1 1 2 2 006aaa152 [1] The marking bar indicates the cathode. BZX585 series Nexperia Voltage regulator diodes 3. Ordering information Table 3. Ordering information Type number Package BZX585-B2V4 to BZX585-C75[1] [1] Name Description Version SC-79 plastic surface-mounted package; 2 leads SOD523 The series consists of 74 types with nominal working voltages from 2.4 V to 75 V. 4. Marking Table 4. Marking codes Type number Marking code Type number Marking code Type number Marking code Type number Marking code BZX585-B2V4 C1 BZX585-B15 E0 BZX585-C2V4 F1 BZX585-C15 H0 BZX585-B2V7 C2 BZX585-B16 EA BZX585-C2V7 F2 BZX585-C16 HA BZX585-B3V0 C3 BZX585-B18 EB BZX585-C3V0 F3 BZX585-C18 HB BZX585-B3V3 C4 BZX585-B20 EC BZX585-C3V3 F4 BZX585-C20 HC BZX585-B3V6 C5 BZX585-B22 ED BZX585-C3V6 F5 BZX585-C22 HD BZX585-B3V9 C6 BZX585-B24 EE BZX585-C3V9 F6 BZX585-C24 HE BZX585-B4V3 C7 BZX585-B27 EF BZX585-C4V3 F7 BZX585-C27 HF BZX585-B4V7 C8 BZX585-B30 EG BZX585-C4V7 F8 BZX585-C30 HG BZX585-B5V1 C9 BZX585-B33 EH BZX585-C5V1 F9 BZX585-C33 HH BZX585-B5V6 C0 BZX585-B36 EK BZX585-C5V6 F0 BZX585-C36 HK BZX585-B6V2 E1 BZX585-B39 EL BZX585-C6V2 H1 BZX585-C39 HL BZX585-B6V8 E2 BZX585-B43 EM BZX585-C6V8 H2 BZX585-C43 HM BZX585-B7V5 E3 BZX585-B47 EN BZX585-C7V5 H3 BZX585-C47 HN BZX585-B8V2 E4 BZX585-B51 EP BZX585-C8V2 H4 BZX585-C51 HP BZX585-B9V1 E5 BZX585-B56 ER BZX585-C9V1 H5 BZX585-C56 HR BZX585-B10 E6 BZX585-B62 ES BZX585-C10 H6 BZX585-C62 HS BZX585-B11 E7 BZX585-B68 ET BZX585-C11 H7 BZX585-C68 HT BZX585-B12 E8 BZX585-B75 EU BZX585-C12 H8 BZX585-C75 HU BZX585-B13 E9 - - BZX585-C13 H9 - - BZX585_SERIES Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 2 of 13 BZX585 series Nexperia Voltage regulator diodes 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions IF forward current Min Max Unit mA - 200 - see Table 8 and 9 IZSM non-repetitive peak reverse current [1] PZSM non-repetitive peak reverse power dissipation [1] - 40 W Ptot total power dissipation [2] - 300 mW Tamb ambient temperature 65 +150 C Tj junction temperature 65 +150 C Tstg storage temperature 65 +150 C Tamb  25 C [1] tp = 100 s; square wave; Tj = 25 C before surge [2] Device mounted on an FR4 Printed-Circuit Board (PCB) with approximately 35 mm2 Cu area at cathode tab. 6. Thermal characteristics Table 6. Symbol Thermal characteristics Parameter Conditions Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point in free air Min Typ Max Unit [1] - - 350 K/W [2] - - 65 K/W [1] Device mounted on an FR4 Printed-Circuit Board (PCB) with approximately 35 mm2 Cu area at cathode tab. [2] Soldering point of cathode tab. 7. Characteristics Table 7. Characteristics Tj = 25 C unless otherwise specified. Symbol VF [1] BZX585_SERIES Product data sheet Parameter Conditions Min Typ Max Unit IF = 10 mA - - 0.9 V IF = 100 mA - - 1.1 V [1] forward voltage Pulse test: tp  300 s;   0.02. All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 BZX585 series Nexperia Voltage regulator diodes Table 8. Characteristics per type; BZX585-B2V4 to BZX585-C24 Tj = 25 C unless otherwise specified. BZX585- Sel Working xxx voltage Differential resistance Reverse current r () dif VZ (V) IR (A) Temperature coefficient SZ (mV/K) Diode Non-repetitive capacitance peak reverse current C (pF)[1] d IZSM (A)[2] 2V4 2V7 3V0 3V3 3V6 3V9 4V3 4V7 5V1 5V6 6V2 6V8 7V5 8V2 9V1 10 11 12 IZ = 5 mA IZ = 1 mA Min Max Typ Max Typ Max Max VR (V) Min Typ Max Max Max B 2.35 2.45 275 400 70 100 50 1 3.5 1.3 0 450 6 C 2.28 2.52 B 2.65 2.75 300 450 75 100 20 1 3.5 1.4 0 440 6 C 2.57 2.84 B 2.94 3.06 325 500 80 95 10 1 3.5 1.6 0 425 6 C 2.85 3.15 B 3.23 3.37 350 500 85 95 5 1 3.5 1.8 0 410 6 C 3.14 3.47 B 3.53 3.67 375 500 85 90 5 1 3.5 1.9 0 390 6 C 3.42 3.78 B 3.82 3.98 400 500 85 90 3 1 3.5 1.9 0 370 6 C 3.71 4.10 B 4.21 4.39 410 600 80 90 3 1 3.5 1.7 0 350 6 C 4.09 4.52 B 4.61 4.79 425 500 50 80 3 2 3.5 1.2 0.2 325 6 C 4.47 4.94 B 5.00 5.20 400 480 40 60 2 2 2.7 0.5 1.2 300 6 C 4.85 5.36 B 5.49 5.71 80 400 15 40 1 2 2 1.0 2.5 275 6 C 5.32 5.88 B 6.08 6.32 40 150 6 10 3 4 0.4 2.2 3.7 250 6 C 5.89 6.51 B 6.66 6.94 30 80 6 15 2 4 1.2 3.0 4.5 215 6 C 6.46 7.14 B 7.35 7.65 15 80 2 10 1 5 2.5 3.6 5.3 170 4 C 7.13 7.88 B 8.04 8.36 20 80 2 10 0.7 5 3.2 4.3 6.2 150 4 C 7.79 8.61 B 8.92 9.28 20 100 2 10 0.5 6 3.8 5.2 7 120 3 C 8.65 9.56 B 9.80 10.20 20 150 2 10 0.2 7 4.5 6.0 8 110 3 C 9.50 10.50 B 10.78 11.22 25 150 2 10 0.1 8 5.4 6.9 9 110 2.5 C 10.45 11.55 B 11.76 12.24 25 150 2 10 0.1 8 6 7.9 10 105 2.5 C 11.40 12.60 BZX585_SERIES Product data sheet IZ = 5 mA IZ = 5 mA All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 BZX585 series Nexperia Voltage regulator diodes Table 8. Characteristics per type; BZX585-B2V4 to BZX585-C24 …continued Tj = 25 C unless otherwise specified. BZX585- Sel Working xxx voltage Differential resistance Reverse current r () dif VZ (V) IR (A) Temperature coefficient SZ (mV/K) Diode Non-repetitive capacitance peak reverse current C (pF)[1] d IZSM (A)[2] 13 15 16 18 20 22 24 IZ = 5 mA IZ = 1 mA Min Typ Max B 12.74 13.26 25 C 12.35 13.65 B 14.70 15.30 25 C 14.25 15.75 B 15.68 16.32 50 C 15.20 16.80 B 17.64 18.36 50 C 17.10 18.90 B 19.60 20.40 60 C 19.00 21.00 B 21.56 22.44 60 C 20.90 23.10 B 23.52 24.48 60 C 22.80 25.20 IZ = 5 mA Max Typ Max Max VR (V) Min Typ Max Max Max 170 2 10 0.1 8 7 8.8 11 105 2.5 200 3 15 0.05 10.5 9.2 10.7 13 100 2 200 10 40 0.05 11.2 10.4 12.4 14 90 1.5 225 10 45 0.05 12.6 12.4 14.4 16 80 1.5 225 15 55 0.05 14 14.4 16.4 18 70 1.5 250 20 55 0.05 15.4 16.4 18.4 20 60 1.25 250 25 70 0.05 16.8 18.4 20.4 22 55 1.25 [1] f = 1 MHz; VR = 0 V [2] tp = 100 s; square wave; Tj = 25 C before surge BZX585_SERIES Product data sheet IZ = 5 mA All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 5 of 13 BZX585 series Nexperia Voltage regulator diodes Table 9. Characteristics per type; BZX585-B27 to BZX585-C75 Tj = 25 C unless otherwise specified. BZX585 Sel Working -xxx voltage Differential resistance rdif () VZ (V) Reverse current Temperature coefficient IR (A) SZ (mV/K) Diode Non-repetitive capacitance peak reverse current C (pF)[1] d IZSM (A)[2] 27 30 33 36 39 43 47 51 56 62 68 75 IZ = 2 mA IZ = 0.5 mA IZ = 2 mA Min Typ Max B 26.46 27.54 65 C 25.65 28.35 B 29.40 30.60 70 C 28.50 31.50 B 32.34 33.66 75 C 31.35 34.65 B 35.28 36.72 80 C 34.20 37.80 B 38.22 39.78 80 C 37.05 40.95 B 42.14 43.86 85 C 40.85 45.15 B 46.06 47.94 85 C 44.65 49.35 B 49.98 52.02 90 C 48.45 53.55 B 54.88 57.12 100 C 53.20 58.80 B 60.76 63.24 120 C 58.90 65.10 B 66.64 69.36 150 C 64.60 71.40 B 73.50 76.50 170 C 71.25 78.75 Typ Max Max VR (V) Min Typ Max Max Max 300 25 80 0.05 18.9 21.4 23.4 25.3 50 1.0 300 30 80 0.05 21 24.4 26.6 29.4 50 1.0 325 35 80 0.05 23.1 27.4 29.7 33.4 45 0.9 350 35 90 0.05 25.2 30.4 33.0 37.4 45 0.8 350 40 130 0.05 27.3 33.4 36.4 41.2 45 0.7 375 45 150 0.05 30.1 37.6 41.2 46.6 40 0.6 375 50 170 0.05 32.9 42.0 46.1 51.8 40 0.5 400 60 180 0.05 35.7 46.6 51.0 57.2 40 0.4 425 70 200 0.05 39.2 52.2 57.0 63.8 40 0.3 450 80 215 0.05 43.4 58.8 64.4 71.6 35 0.3 475 90 240 0.05 47.6 65.6 71.7 79.8 35 0.25 500 95 255 0.05 52.5 73.4 80.2 88.6 35 0.2 [1] f = 1 MHz; VR = 0 V [2] tp = 100 s; square wave; Tj = 25 C before surge BZX585_SERIES Product data sheet IZ = 2 mA Max All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 6 of 13 BZX585 series Nexperia Voltage regulator diodes mbg801 103 PZSM (W) mbg781 300 IF (mA) 102 200 (1) 10 100 (2) 1 10−1 1 0 0.6 10 tp (ms) 0.8 1 VF (V) (1) Tj = 25 C (before surge) Tj = 25 C (2) Tj = 150 C (before surge) Fig 1. Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values Fig 2. mld444 0.5 SZ (mV/K) Forward current as a function of forward voltage; typical values mld445 12 15 SZ (mV/K) 4V7 13 12 11 10 9V1 8V2 7V5 6V8 6V2 5V6 5V1 0 8 4V3 −0.5 2V4 4 2V7 3V9 −1 3V6 −1.5 0 3V3 3V0 −2 10−1 1 −4 10−1 102 10 1 102 10 IZ (mA) Fig 3. IZ (mA) BZX585-B/C2V4 to BZX585-B/C4V7 BZX585-B/C5V1 to BZX585-B/C15 Tj = 25 C to 150 C Tj = 25 C to 150 C Temperature coefficient as a function of working current; typical values BZX585_SERIES Product data sheet Fig 4. Temperature coefficient as a function of working current; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 7 of 13 BZX585 series Nexperia Voltage regulator diodes aaa-015949 50 VZ(nom) (V) = 2.7 IZ (mA) IZ (mA) 25 3.3 3.6 3.9 40 30 006aaa997 VZ(nom) (V) = 10 4.7 5.6 6.8 12 20 8.2 30 15 15 20 10 18 10 22 27 0 0 0 2 4 6 8 10 0 10 20 30 VZ (V) Fig 5. 33 36 5 40 VZ (V) Tj = 25 C Tj = 25 C BZX585-B/C2V7 to BZX585-B/C8V2 BZX585-B/C10 to BZX585-B/C36 Working current as a function of working voltage; typical values Fig 6. Working current as a function of working voltage; typical values 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BZX585_SERIES Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 8 of 13 BZX585 series Nexperia Voltage regulator diodes 9. Package outline 0.85 0.75 0.65 0.58 1 1.65 1.25 1.55 1.15 2 0.34 0.26 0.17 0.11 Dimensions in mm Fig 7. 02-12-13 Package outline SOD523 (SC-79) 10. Soldering 2.15 1.4 solder lands solder resist 0.5 0.6 (2×) (2×) 1.2 solder paste occupied area Dimensions in mm 0.4 (2×) 0.5 (2×) Fig 8. BZX585_SERIES Product data sheet sod523_fr Reflow soldering footprint SOD523 (SC-79) All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 9 of 13 BZX585 series Nexperia Voltage regulator diodes 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BZX585_SER v.5 20161011 Product data sheet - BZX585_SER v.4 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of NXP Semiconductors . • • • • • • • • • Legal texts have been adapted to the new company name where appropriate. Section 1 “Product profile”: enhanced. Table 5: Tamb added. Table 8 and Table 9: updated Figure 1, Figure 5 and Figure 6: added Section 8 “Test information”: added. Figure 7: replaced by minimized package outline Section 10 “Soldering”: added Section 12 “Legal information”: updated BZX585_SER v.4 20040622 Product data sheet - BZX585_SER v.3 BZX585_SER v.3 20040326 Product specification - BZX585_SER v.2 BZX585_SER v.2 20001020 Product specification - BZX585_SER v.1 BZX585_SER v.1 20000606 Product specification - - BZX585_SERIES Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 10 of 13 BZX585 series Nexperia Voltage regulator diodes 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BZX585_SERIES Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 11 of 13 BZX585 series Nexperia Voltage regulator diodes No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 12.4 Trademarks Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BZX585_SERIES Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 October 2016 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia BZX585 series Voltage regulator diodes 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Quality information . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 October 2016
BZX585-C4V3,135
1. 物料型号:文档描述的是Nexperia公司的BZX585系列电压调节二极管。
2. 器件简介:这些是通用的Zener二极管,采用SOD523 (SC-79)超小型和扁平的引脚表面贴装设备(SMD)塑料封装。
3. 引脚分配:文档中提到,标记条指示阴极,共有两个引脚,1号引脚为阴极,2号引脚为阳极。
4. 参数特性: - 脉冲测试条件下的非重复峰值反向功率耗散:不超过40W。 - 工作电压范围宽:标称电压从2.4V到75V(E24系列)。 - 总功率耗散:不超过300mW。 - 两种容差系列:±2%和±5%。 - 符合AEC-Q101标准。
5. 功能详解:文档中提到了这些二极管的一般调节功能。
6. 应用信息:适用于一般调节功能。
7. 封装信息:文档提供了SOD523 (SC-79)封装的详细信息,包括尺寸和焊接信息。
BZX585-C4V3,135 价格&库存
很抱歉,暂时无法提供与“BZX585-C4V3,135”相匹配的价格&库存,您可以联系我们找货
BZX585-C4V3,135
  • 10000+0.3417010000+0.04441
  • 30000+0.2927130000+0.03804
库存:1907
BZX585-C4V3,135
  • 1+0.49940
  • 100+0.34430
  • 500+0.31350
  • 2500+0.28930
  • 5000+0.27060
  • 10000+0.24860
库存:309
BZX585-C4V3,135
  • 1+2.560681+0.33277
  • 10+1.5524110+0.20174
  • 50+1.1117650+0.14448
  • 100+0.96698100+0.12566
  • 500+0.71010500+0.09228
库存:1907
BZX585-C4V3,135
    • 5+1.38273
    • 50+1.35195
    • 150+1.33143
    库存:183
