BZX585 series
Voltage regulator diodes
Rev. 5 — 11 October 2016
Product data sheet
1. Product profile
1.1 General description
General-purpose Zener diodes in an SOD523 (SC-79) ultra small and flat lead
Surface-Mounted Device (SMD) plastic package.
1.2 Features and benefits
Non-repetitive peak reverse power
dissipation: 40 W
Total power dissipation: 300 mW
AEC-Q101 qualified
Wide working voltage range: nominal
2.4 V to 75 V (E24 range)
Two tolerance series: 2 % and 5 %
Low differential resistance
1.3 Applications
General regulation functions
1.4 Quick reference data
Table 1.
Symbol
Parameter
forward voltage
VF
PZSM
Conditions
IF = 100 mA
non-repetitive peak reverse
power dissipation
[1]
Pulse test: tp 300 s; 0.02.
[2]
tp = 100 s; square wave; Tj = 25 C before surge
Min
Typ
Max
Unit
[1]
1.1
V
[2]
40
W
2. Pinning information
Table 2.
Pin
Pinning
Description
1
cathode
2
anode
Simplified outline
Graphic symbol
[1]
1
1
2
2
006aaa152
[1]
The marking bar indicates the cathode.
BZX585 series
Nexperia
3. Ordering information
Table 3.
Type number
Package
BZX585-B2V4 to
BZX585-C75[1]
[1]
Name
Description
Version
SC-79
plastic surface-mounted package; 2 leads
SOD523
The series consists of 74 types with nominal working voltages from 2.4 V to 75 V.
4. Marking
Table 4.
Marking codes
Type number
Marking
code
Type number
Marking
code
Type number
Marking
code
Type number
Marking
code
BZX585-B2V4
C1
BZX585-B15
E0
BZX585-C2V4
F1
BZX585-C15
H0
BZX585-B2V7
C2
BZX585-B16
EA
BZX585-C2V7
F2
BZX585-C16
HA
BZX585-B3V0
C3
BZX585-B18
EB
BZX585-C3V0
F3
BZX585-C18
HB
BZX585-B3V3
C4
BZX585-B20
EC
BZX585-C3V3
F4
BZX585-C20
HC
BZX585-B3V6
C5
BZX585-B22
ED
BZX585-C3V6
F5
BZX585-C22
HD
BZX585-B3V9
C6
BZX585-B24
EE
BZX585-C3V9
F6
BZX585-C24
HE
BZX585-B4V3
C7
BZX585-B27
EF
BZX585-C4V3
F7
BZX585-C27
HF
BZX585-B4V7
C8
BZX585-B30
EG
BZX585-C4V7
F8
BZX585-C30
HG
BZX585-B5V1
C9
BZX585-B33
EH
BZX585-C5V1
F9
BZX585-C33
HH
BZX585-B5V6
C0
BZX585-B36
EK
BZX585-C5V6
F0
BZX585-C36
HK
BZX585-B6V2
E1
BZX585-B39
EL
BZX585-C6V2
H1
BZX585-C39
HL
BZX585-B6V8
E2
BZX585-B43
EM
BZX585-C6V8
H2
BZX585-C43
HM
BZX585-B7V5
E3
BZX585-B47
EN
BZX585-C7V5
H3
BZX585-C47
HN
BZX585-B8V2
E4
BZX585-B51
EP
BZX585-C8V2
H4
BZX585-C51
HP
BZX585-B9V1
E5
BZX585-B56
ER
BZX585-C9V1
H5
BZX585-C56
HR
BZX585-B10
E6
BZX585-B62
ES
BZX585-C10
H6
BZX585-C62
HS
BZX585-B11
E7
BZX585-B68
ET
BZX585-C11
H7
BZX585-C68
HT
BZX585-B12
E8
BZX585-B75
EU
BZX585-C12
H8
BZX585-C75
HU
BZX585-B13
E9
BZX585-C13
H9
BZX585_SERIES
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
BZX585 series
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
IF
forward current
Min
Max
Unit
mA
200
see
Table 8
and 9
IZSM
current
[1]
PZSM
power dissipation
[1]
40
W
Ptot
total power dissipation
[2]
300
mW
Tamb
ambient temperature
65
+150
C
Tj
junction temperature
65
+150
C
Tstg
storage temperature
65
+150
C
Tamb 25 C
[1]
[2]
Device mounted on an FR4 Printed-Circuit Board (PCB) with approximately 35 mm2 Cu area at cathode
tab.
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from
junction to ambient
Rth(j-sp)
junction to solder point
in free air
Min
Typ
Max
Unit
[1]
350
K/W
[2]
65
K/W
[1]
tab.
[2]
Soldering point of cathode tab.
7. Characteristics
Table 7.
Characteristics
Tj = 25 C unless otherwise specified.
Symbol
VF
[1]
BZX585_SERIES
Product data sheet
Parameter
Conditions
Min
Typ
Max
Unit
IF = 10 mA
0.9
V
IF = 100 mA
1.1
V
[1]
forward voltage
3 of 13
BZX585 series
Nexperia
Table 8.
Characteristics per type; BZX585-B2V4 to BZX585-C24
BZX585- Sel Working
xxx
voltage
Differential resistance Reverse
current
r ()
dif
VZ (V)
IR (A)
Temperature
coefficient
SZ (mV/K)
Diode
Non-repetitive
capacitance peak reverse
current
C (pF)[1]
d
IZSM (A)[2]
2V4
2V7
3V0
3V3
3V6
3V9
4V3
4V7
5V1
5V6
6V2
6V8
7V5
8V2
9V1
10
11
12
IZ = 5 mA
IZ = 1 mA
Min
Max
Typ
Max Typ
Max Max
VR (V) Min
Typ
Max
Max
Max
B
2.35
2.45
275
400
70
100
50
1
3.5
1.3
6
C
2.28
2.52
B
2.65
2.75
300
450
75
100
3.5
1.4
6
C
2.57
2.84
B
2.94
3.06
325
500
80
95
10
1
3.5
1.6
6
C
2.85
3.15
B
3.23
3.37
350
500
85
95
5
1
3.5
1.8
6
C
3.14
3.47
B
3.53
3.67
375
500
85
90
5
1
3.5
1.9
6
C
3.42
3.78
B
3.82
3.98
400
500
85
90
3
1
3.5
1.9
6
C
3.71
4.10
B
4.21
4.39
410
600
80
90
3
1
3.5
1.7
6
C
4.09
4.52
B
4.61
4.79
425
500
50
80
3
2
3.5
1.2
0.2
325
6
C
4.47
4.94
B
5.00
5.20
400
480
40
60
2
2
2.7
0.5
1.2
300
6
C
4.85
5.36
B
5.49
5.71
80
400
15
40
1
2
2
1.0
2.5
275
6
C
5.32
5.88
B
6.08
6.32
40
150
6
10
3
4
0.4
2.2
3.7
250
6
C
5.89
6.51
B
6.66
6.94
30
80
6
15
2
4
1.2
3.0
4.5
215
6
C
6.46
7.14
B
7.35
7.65
15
80
2
10
1
5
2.5
3.6
5.3
170
4
C
7.13
7.88
B
8.04
8.36
2
10
0.7
5
3.2
4.3
6.2
150
4
C
7.79
8.61
B
8.92
9.28
2
10
0.5
6
3.8
5.2
7
120
3
C
8.65
9.56
B
9.80
10.20 20
150
2
10
0.2
7
4.5
6.0
8
110
3
C
9.50
10.50
B
10.78 11.22 25
150
2
10
0.1
8
5.4
6.9
9
110
2.5
C
10.45 11.55
B
11.76 12.24 25
150
2
10
0.1
8
6
7.9
10
105
2.5
C
11.40 12.60
BZX585_SERIES
Product data sheet
IZ = 5 mA
IZ = 5 mA
4 of 13
BZX585 series
Nexperia
Table 8.
Characteristics per type; BZX585-B2V4 to BZX585-C24 …continued
BZX585- Sel Working
xxx
voltage
current
r ()
dif
VZ (V)
IR (A)
Temperature
coefficient
SZ (mV/K)
Diode
Non-repetitive
current
C (pF)[1]
d
IZSM (A)[2]
13
15
16
18
24
IZ = 5 mA
IZ = 1 mA
Min
Typ
Max
B
12.74 13.26 25
C
12.35 13.65
B
14.70 15.30 25
C
14.25 15.75
B
15.68 16.32 50
C
15.20 16.80
B
17.64 18.36 50
C
17.10 18.90
B
19.60 20.40 60
C
19.00 21.00
B
21.56 22.44 60
C
20.90 23.10
B
23.52 24.48 60
C
22.80 25.20
IZ = 5 mA
Max Typ
Max Max
VR (V) Min
Typ
Max
Max
Max
170
2
10
0.1
8
7
8.8
11
105
2.5
200
3
15
0.05
10.5
9.2
10.7
13
100
2
200
10
40
0.05
11.2
10.4
12.4
14
90
1.5
225
10
45
0.05
12.6
12.4
14.4
16
80
1.5
225
15
55
0.05
14
14.4
16.4
18
70
1.5
250
0.05
15.4
16.4
18.4
1.25
250
25
70
0.05
16.8
18.4
20.4
22
55
1.25
[1]
f = 1 MHz; VR = 0 V
[2]
BZX585_SERIES
Product data sheet
IZ = 5 mA
5 of 13
BZX585 series
Nexperia
Table 9.
Characteristics per type; BZX585-B27 to BZX585-C75
BZX585 Sel Working
-xxx
voltage
rdif ()
VZ (V)
Reverse
current
Temperature
coefficient
IR (A)
SZ (mV/K)
Diode
Non-repetitive
current
C (pF)[1]
d
IZSM (A)[2]
27
30
33
36
39
43
47
51
56
62
68
75
IZ = 2 mA
IZ = 0.5 mA IZ = 2 mA
Min
Typ
Max
B
26.46 27.54 65
C
25.65 28.35
B
29.40 30.60 70
C
28.50 31.50
B
32.34 33.66 75
C
31.35 34.65
B
35.28 36.72 80
C
34.20 37.80
B
38.22 39.78 80
C
37.05 40.95
B
42.14 43.86 85
C
40.85 45.15
B
46.06 47.94 85
C
44.65 49.35
B
49.98 52.02 90
C
48.45 53.55
B
54.88 57.12 100
C
53.20 58.80
B
60.76 63.24 120
C
58.90 65.10
B
66.64 69.36 150
C
64.60 71.40
B
73.50 76.50 170
C
71.25 78.75
Typ
Max Max
VR (V) Min
Typ
Max
Max
Max
300
25
80
0.05
18.9
21.4
23.4
25.3
50
1.0
300
30
80
0.05
21
24.4
26.6
29.4
50
1.0
325
35
80
0.05
23.1
27.4
29.7
33.4
45
0.9
350
35
90
0.05
25.2
30.4
33.0
37.4
45
0.8
350
40
130
0.05
27.3
33.4
36.4
41.2
45
0.7
375
45
150
0.05
30.1
37.6
41.2
46.6
40
0.6
375
50
170
0.05
32.9
42.0
46.1
51.8
40
0.5
400
60
180
0.05
35.7
46.6
51.0
57.2
40
0.4
425
70
200
0.05
39.2
52.2
57.0
63.8
40
0.3
450
80
215
0.05
43.4
58.8
64.4
71.6
35
0.3
475
90
240
0.05
47.6
65.6
71.7
79.8
35
0.25
500
95
255
0.05
52.5
73.4
80.2
88.6
35
0.2
[1]
f = 1 MHz; VR = 0 V
[2]
BZX585_SERIES
Product data sheet
IZ = 2 mA
Max
6 of 13
BZX585 series
Nexperia
mbg801
103
PZSM
(W)
mbg781
300
IF
(mA)
102
200
(1)
10
100
(2)
1
10−1
1
10
tp (ms)
0.8
1
VF (V)
(1) Tj = 25 C (before surge)
Tj = 25 C
(2) Tj = 150 C (before surge)
Fig 1.
Non-repetitive peak reverse power dissipation
as a function of pulse duration; maximum
values
Fig 2.
mld444
0.5
SZ
(mV/K)
Forward current as a function of forward
voltage; typical values
mld445
12
15
SZ
(mV/K)
4V7
13
12
11
10
9V1
8V2
7V5
6V8
6V2
5V6
5V1
4V3
−0.5
2V4
4
2V7
3V9
−1
3V6
−1.5
3V3
3V0
−2
10−1
1
−4
10−1
102
10
1
102
10
IZ (mA)
Fig 3.
IZ (mA)
BZX585-B/C2V4 to BZX585-B/C4V7
BZX585-B/C5V1 to BZX585-B/C15
Tj = 25 C to 150 C
Tj = 25 C to 150 C
Temperature coefficient as a function of
working current; typical values
BZX585_SERIES
Product data sheet
Fig 4.
7 of 13
BZX585 series
Nexperia
aaa-015949
50
VZ(nom) (V) = 2.7
IZ
(mA)
IZ
(mA)
25
3.3
3.6
3.9
40
30
006aaa997
VZ(nom) (V) = 10
4.7
5.6
6.8
12
30
15
15
18
10
22
27
4
6
8
10
VZ (V)
Fig 5.
33 36
5
40
VZ (V)
Tj = 25 C
Tj = 25 C
BZX585-B/C2V7 to BZX585-B/C8V2
BZX585-B/C10 to BZX585-B/C36
Working current as a function of working
Fig 6.
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
BZX585_SERIES
Product data sheet
8 of 13
BZX585 series
Nexperia
9. Package outline
0.85
0.75
0.65
0.58
1
1.65 1.25
1.55 1.15
2
0.34
0.26
0.17
0.11
Dimensions in mm
Fig 7.
02-12-13
Package outline SOD523 (SC-79)
10. Soldering
2.15
1.4
solder lands
solder resist
0.5 0.6
(2×) (2×)
1.2
solder paste
occupied area
Dimensions in mm
0.4
(2×)
0.5
(2×)
Fig 8.
BZX585_SERIES
Product data sheet
sod523_fr
Reflow soldering footprint SOD523 (SC-79)
9 of 13
BZX585 series
Nexperia
11. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BZX585_SER v.5
20161011
Product data sheet
BZX585_SER v.4
Modifications:
The format of this document has been redesigned to comply with the new identity
guidelines of NXP Semiconductors
Legal texts have been adapted to the new company name where appropriate.
Section 1 “Product profile”: enhanced.
Table 5: Tamb added.
Table 8 and Table 9: updated
Figure 1, Figure 5 and Figure 6: added
Section 8 “Test information”: added.
Figure 7: replaced by minimized package outline
Section 10 “Soldering”: added
Section 12 “Legal information”: updated
BZX585_SER v.4
20040622
Product data sheet
BZX585_SER v.3
BZX585_SER v.3
20040326
Product specification
BZX585_SER v.2
BZX585_SER v.2
20001020
BZX585_SER v.1
BZX585_SER v.1
20000606
BZX585_SERIES
Product data sheet
10 of 13
BZX585 series
Nexperia
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
BZX585_SERIES
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
11 of 13
BZX585 series
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
12.4 Trademarks
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BZX585_SERIES
Product data sheet
12 of 13
Nexperia
BZX585 series
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8
Quality information . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Date of release: 11 October 2016
很抱歉,暂时无法提供与“BZX585-C24,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.60477
- 100+0.49002
- 500+0.44151
- 国内价格
- 5+0.85461
- 50+0.67900
- 150+0.59120
- 500+0.52542
- 3000+0.47272
- 6000+0.44637
- 国内价格 香港价格
- 1+2.646031+0.34386
- 10+1.6239010+0.21103
- 50+1.1610650+0.15089
- 100+1.00934100+0.13117
- 500+0.74202500+0.09643
- 国内价格 香港价格
- 3000+0.490833000+0.06379
- 9000+0.414309000+0.05384
- 国内价格
- 1+0.54670
- 200+0.18260
- 1500+0.11440
- 3000+0.09053
- 国内价格 香港价格
- 20+0.6486920+0.08430
- 100+0.52521100+0.06826
- 500+0.47304500+0.06148
