BZB84-C68,215
BZB84-C68,215
    NEXPERIA(安世)
    SOT-23
    双齐纳二极管SOT23-3
BZB84-C68,215 数据手册
BZB84 series Dual Zener diodes Rev. 03 — 9 June 2009 Product data sheet 1. Product profile 1.1 General description General-purpose Zener diodes in a SOT23 (TO-236AB) small Surface-Mounted Device (SMD) plastic package. 1.2 Features n Non-repetitive peak reverse power dissipation: ≤ 40 W n Total power dissipation: ≤ 300 mW n Two tolerance series: B = ±2 % and C = ±5 % n Wide working voltage range: nominal 2.4 V to 75 V (E24 range) n Small plastic package suitable for surface-mounted design n Dual common anode configuration n AEC-Q101 qualified 1.3 Applications n General regulation functions 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions forward voltage IF = 10 mA Min Typ Max Unit [1] - - 0.9 V [2] - - 40 W Per diode VF PZSM non-repetitive peak reverse power dissipation [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. [2] tp = 100 µs; square wave; Tj = 25 °C prior to surge BZB84 series Nexperia Dual Zener diodes 2. Pinning information Table 2. Pinning Pin Description 1 cathode (diode 1) 2 cathode (diode 2) 3 common anode Simplified outline Graphic symbol 3 1 3 2 1 2 006aaa154 3. Ordering information Table 3. Ordering information Type number BZB84-B2V4 to BZB84-C75[1] [1] Package Name Description Version - plastic surface-mounted package; 3 leads SOT23 The series consists of 74 types with nominal working voltages from 2.4 V to 75 V. 4. Marking Table 4. Marking codes Type number Marking code[1] Type number Marking code[1] BZB84-B2V4 V9* BZB84-C2V4 U9* BZB84-B2V7 VA* BZB84-C2V7 UA* BZB84-B3V0 VB* BZB84-C3V0 UB* BZB84-B3V3 VC* BZB84-C3V3 UC* BZB84-B3V6 VD* BZB84-C3V6 UD* BZB84-B3V9 VE* BZB84-C3V9 UE* BZB84-B4V3 VF* BZB84-C4V3 UF* BZB84-B4V7 VG* BZB84-C4V7 UG* BZB84-B5V1 VH* BZB84-C5V1 UH* BZB84-B5V6 VK* BZB84-C5V6 UK* BZB84-B6V2 VL* BZB84-C6V2 UL* BZB84-B6V8 VM* BZB84-C6V8 UM* BZB84-B7V5 VN* BZB84-C7V5 UN* BZB84-B8V2 VP* BZB84-C8V2 UP* BZB84-B9V1 VR* BZB84-C9V1 UR* BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 2 of 14 BZB84 series Nexperia Dual Zener diodes Table 4. Marking codes …continued Type number Marking code[1] Type number Marking code[1] BZB84-B10 VS* BZB84-C10 US* BZB84-B11 VT* BZB84-C11 UT* BZB84-B12 VU* BZB84-C12 UU* BZB84-B13 VV* BZB84-C13 UV* BZB84-B15 VW* BZB84-C15 UW* BZB84-B16 PT* BZB84-C16 PB* BZB84-B18 PU* BZB84-C18 PC* BZB84-B20 RP* BZB84-C20 RQ* BZB84-B22 PV* BZB84-C22 PD* BZB84-B24 PW* BZB84-C24 PE* BZB84-B27 PX* BZB84-C27 PF* BZB84-B30 PY* BZB84-C30 PG* BZB84-B33 PZ* BZB84-C33 PH* BZB84-B36 RA* BZB84-C36 PJ* BZB84-B39 RB* BZB84-C39 PK* BZB84-B43 RC* BZB84-C43 PL* BZB84-B47 RD* BZB84-C47 PM* BZB84-B51 RE* BZB84-C51 PN* BZB84-B56 RF* BZB84-C56 PP* BZB84-B62 RG* BZB84-C62 PQ* BZB84-B68 RH* BZB84-C68 PR* BZB84-B75 RJ* BZB84-C75 PS* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit mA Per diode IF forward current IZSM non-repetitive peak reverse current [1] PZSM non-repetitive peak reverse power dissipation [1] BZB84_SER Product data sheet - 200 - see Table 8, 9, 10 and 11 - 40 W © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 3 of 14 BZB84 series Nexperia Dual Zener diodes Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Ptot total power dissipation Tamb ≤ 25 °C Min Max Unit - 300 mW Per device [2] Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] tp = 100 µs; square wave; Tj = 25 °C prior to surge [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 6. Thermal characteristics Table 6. Symbol Thermal characteristics Parameter Conditions Min Typ Max Unit [1] - - 417 K/W [2] - - 100 K/W Per device; single diode loaded Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point in free air [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Soldering points at pins 1 and 2. 7. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions forward voltage IF = 10 mA Min Typ Max Unit - - 0.9 V Per diode VF [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. BZB84_SER Product data sheet [1] © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 4 of 14 BZB84 series Nexperia Dual Zener diodes Table 8. Characteristics per type; BZB84-B2V4 to BZB84-B24 Tj = 25 °C unless otherwise specified. BZB84Bxxx Working voltage VZ (V) Differential resistance Reverse current Temperature coefficient I (µA) R rdif (Ω) SZ (mV/K) Diode Non-repetitive capacitance peak reverse current C (pF)[1] d IZSM (A)[2] IZ = 5 mA IZ = 1 mA IZ = 5 mA IZ = 5 mA Min Max Max Max Max VR (V) Min Max Max Max 2V4 2.35 2.45 600 100 50 1 −3.5 0 450 6.0 2V7 2.65 2.75 600 100 20 1 −3.5 0 450 6.0 3V0 2.94 3.06 600 95 10 1 −3.5 0 450 6.0 3V3 3.23 3.37 600 95 5 1 −3.5 0 450 6.0 3V6 3.53 3.67 600 90 5 1 −3.5 0 450 6.0 3V9 3.82 3.98 600 90 3 1 −3.5 0 450 6.0 4V3 4.21 4.39 600 90 3 1 −3.5 0 450 6.0 4V7 4.61 4.79 500 80 3 2 −3.5 0.2 300 6.0 5V1 5.00 5.20 480 60 2 2 −2.7 1.2 300 6.0 5V6 5.49 5.71 400 40 1 2 −2.0 2.5 300 6.0 6V2 6.08 6.32 150 10 3 4 0.4 3.7 200 6.0 6V8 6.66 6.94 80 15 2 4 1.2 4.5 200 6.0 7V5 7.35 7.65 80 15 1 5 2.5 5.3 150 4.0 8V2 8.04 8.36 80 15 0.70 5 3.2 6.2 150 4.0 9V1 8.92 9.28 100 15 0.50 6 3.8 7.0 150 3.0 10 9.80 10.20 150 20 0.20 7 4.5 8.0 90 3.0 11 10.80 11.20 150 20 0.10 8 5.4 9.0 85 2.5 12 11.80 12.20 150 25 0.10 8 6.0 10.0 85 2.5 13 12.70 13.30 170 30 0.10 8 7.0 11.0 80 2.5 15 14.70 15.30 200 30 0.05 10.5 9.2 13.0 75 2.0 16 15.70 16.30 200 40 0.05 11.2 10.4 14.0 75 1.5 18 17.60 18.40 225 45 0.05 12.6 12.4 16.0 70 1.5 20 19.6 20.4 225 55 0.05 14.0 14.4 18.0 60 1.5 22 21.6 22.4 250 55 0.05 15.4 16.4 20.0 60 1.25 24 23.5 24.5 250 70 0.05 16.8 18.4 22.0 55 1.25 [1] f = 1 MHz; VR = 0 V [2] tp = 100 µs; square wave; Tj = 25 °C prior to surge BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 5 of 14 BZB84 series Nexperia Dual Zener diodes Table 9. Characteristics per type; BZB84-B27 to BZB84-B75 Tj = 25 °C unless otherwise specified. BZB84Bxxx Working voltage VZ (V) Differential resistance Reverse current Temperature coefficient I (µA) R rdif (Ω) SZ (mV/K) Diode Non-repetitive capacitance peak reverse current C (pF)[1] d IZSM (A)[2] IZ = 2 mA IZ = 0.5 mA IZ = 2 mA IZ = 2 mA Min Max Max Max Max VR (V) Min Max Max Max 27 26.5 27.5 300 80 0.05 18.9 21.4 25.3 50 1.00 30 29.4 30.6 300 80 0.05 21.0 24.4 29.4 50 1.00 33 32.3 33.7 325 80 0.05 23.1 27.4 33.4 45 0.90 36 35.3 36.7 350 90 0.05 25.2 30.4 37.4 45 0.80 39 38.2 39.8 350 130 0.05 27.3 33.4 41.2 45 0.70 43 42.1 43.9 375 150 0.05 30.1 37.6 46.6 40 0.60 47 46.1 47.9 375 170 0.05 32.9 42.0 51.8 40 0.50 51 50.0 52.0 400 180 0.05 35.7 46.6 57.2 40 0.40 56 54.9 57.1 425 200 0.05 39.2 52.2 63.8 40 0.30 62 60.8 63.2 450 215 0.05 43.4 58.8 71.6 35 0.30 68 66.6 69.4 475 240 0.05 47.6 65.6 79.8 35 0.25 75 73.5 76.5 500 255 0.05 52.5 73.4 88.6 35 0.20 [1] f = 1 MHz; VR = 0 V [2] tp = 100 µs; square wave; Tj = 25 °C prior to surge BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 6 of 14 BZB84 series Nexperia Dual Zener diodes Table 10. Characteristics per type; BZB84-C2V4 to BZB84-C24 Tj = 25 °C unless otherwise specified. BZB84Cxxx Working voltage VZ (V) Differential resistance Reverse current Temperature coefficient I (µA) R rdif (Ω) SZ (mV/K) Diode Non-repetitive capacitance peak reverse current C (pF)[1] d IZSM (A)[2] IZ = 5 mA IZ = 1 mA IZ = 5 mA IZ = 5 mA Min Max Max Max Max VR (V) Min Max Max Max 2V4 2.2 2.6 600 100 50 1 −3.5 0 450 6.0 2V7 2.5 2.9 600 100 20 1 −3.5 0 450 6.0 3V0 2.8 3.2 600 95 10 1 −3.5 0 450 6.0 3V3 3.1 3.5 600 95 5 1 −3.5 0 450 6.0 3V6 3.4 3.8 600 90 5 1 −3.5 0 450 6.0 3V9 3.7 4.1 600 90 3 1 −3.5 0 450 6.0 4V3 4.0 4.6 600 90 3 1 −3.5 0 450 6.0 4V7 4.4 5.0 500 80 3 2 −3.5 0.2 300 6.0 5V1 4.8 5.4 480 60 2 2 −2.7 1.2 300 6.0 5V6 5.2 6.0 400 40 1 2 −2.0 2.5 300 6.0 6V2 5.8 6.6 150 10 3 4 0.4 3.7 200 6.0 6V8 6.4 7.2 80 15 2 4 1.2 4.5 200 6.0 7V5 7.0 7.9 80 15 1 5 2.5 5.3 150 4.0 8V2 7.7 8.7 80 15 0.70 5 3.2 6.2 150 4.0 9V1 8.5 9.6 100 15 0.50 6 3.8 7.0 150 3.0 10 9.4 10.6 150 20 0.20 7 4.5 8.0 90 3.0 11 10.4 11.6 150 20 0.10 8 5.4 9.0 85 2.5 12 11.4 12.7 150 25 0.10 8 6.0 10.0 85 2.5 13 12.4 14.1 170 30 0.10 8 7.0 11.0 80 2.5 15 13.8 15.6 200 30 0.05 10.5 9.2 13.0 75 2.0 16 15.3 17.1 200 40 0.05 11.2 10.4 14.0 75 1.5 18 16.8 19.1 225 45 0.05 12.6 12.4 16.0 70 1.5 20 18.8 21.2 225 55 0.05 14.0 14.4 18.0 60 1.5 22 20.8 23.3 250 55 0.05 15.4 16.4 20.0 60 1.25 24 22.8 25.6 250 70 0.05 16.8 18.4 22.0 55 1.25 [1] f = 1 MHz; VR = 0 V [2] tp = 100 µs; square wave; Tj = 25 °C prior to surge BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 7 of 14 BZB84 series Nexperia Dual Zener diodes Table 11. Characteristics per type; BZB84-C27 to BZB84-C75 Tj = 25 °C unless otherwise specified. BZB84Cxxx Working voltage VZ (V) Differential resistance Reverse current Temperature coefficient I (µA) R rdif (Ω) SZ (mV/K) Diode Non-repetitive capacitance peak reverse current C (pF)[1] d IZSM (A)[2] IZ = 2 mA IZ = 0.5 mA IZ = 2 mA IZ = 2 mA Min Max Max Max Max VR (V) Min Max Max Max 27 25.1 28.9 300 80 0.05 18.9 21.4 25.3 50 1.00 30 28.0 32.0 300 80 0.05 21.0 24.4 29.4 50 1.00 33 31.0 35.0 325 80 0.05 23.1 27.4 33.4 45 0.90 36 34.0 38.0 350 90 0.05 25.2 30.4 37.4 45 0.80 39 37.0 41.0 350 130 0.05 27.3 33.4 41.2 45 0.70 43 40.0 46.0 375 150 0.05 30.1 37.6 46.6 40 0.60 47 44.0 50.0 375 170 0.05 32.9 42.0 51.8 40 0.50 51 48.0 54.0 400 180 0.05 35.7 46.6 57.2 40 0.40 56 52.0 60.0 425 200 0.05 39.2 52.2 63.8 40 0.30 62 58.0 66.0 450 215 0.05 43.4 58.8 71.6 35 0.30 68 64.0 72.0 475 240 0.05 47.6 65.6 79.8 35 0.25 75 70.0 79.0 500 255 0.05 52.5 73.4 88.6 35 0.20 [1] f = 1 MHz; VR = 0 V [2] tp = 100 µs; square wave; Tj = 25 °C prior to surge mbg801 103 mbg781 300 PZSM (W) IF (mA) 102 200 (1) 10 100 (2) 1 10−1 1 tp (ms) 0 0.6 10 0.8 1 VF (V) (1) Tj = 25 °C (prior to surge) Tj = 25 °C (2) Tj = 150 °C (prior to surge) Fig 1. Per diode: Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values Fig 2. Per diode: Forward current as a function of forward voltage; typical values BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 8 of 14 BZB84 series Nexperia Dual Zener diodes mbg783 0 mbg782 10 12 SZ (mV/K) SZ (mV/K) 4V3 11 10 −1 9V1 5 3V9 8V2 7V5 6V8 3V6 −2 6V2 5V6 5V1 0 3V3 4V7 3V0 2V4 2V7 −3 Fig 3. −5 0 20 40 IZ (mA) 60 0 4 8 12 16 Tj = 25 °C to 150 °C Tj = 25 °C to 150 °C BZB84-B/C2V4 to BZB84-B/C4V3 BZB84-B/C4V7 to BZB84-B/C12 Per diode: Temperature coefficient as a function of working current; typical values Fig 4. 006aaa996 50 IZ (mA) 3.9 40 006aaa997 VZ(nom) (V) = 10 IZ (mA) 25 3.3 4.7 5.6 6.8 12 20 8.2 20 Per diode: Temperature coefficient as a function of working current; typical values 30 VZ(nom) (V) = 2.7 IZ (mA) 30 15 15 20 10 18 10 22 0 33 36 0 0 2 4 6 8 10 0 10 20 Tj = 25 °C Tj = 25 °C BZB84-B/C2V7 to BZB84-B/C8V2 BZB84-B/C10 to BZB84-B/C36 Per diode: Working current as a function of working voltage; typical values Fig 6. 40 Per diode: Working current as a function of working voltage; typical values BZB84_SER Product data sheet 30 VZ (V) VZ (V) Fig 5. 27 5 © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 9 of 14 BZB84 series Nexperia Dual Zener diodes 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 Dimensions in mm Fig 7. 0.48 0.38 0.15 0.09 04-11-04 Package outline SOT23 (TO-236AB) 10. Packing information Please refer to packing information on www.nexperia.com. BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 10 of 14 BZB84 series Nexperia Dual Zener diodes 11. Soldering 3.3 2.9 1.9 solder lands solder resist 3 2 1.7 solder paste 0.6 (3×) 0.7 (3×) occupied area Dimensions in mm 0.5 (3×) 0.6 (3×) 1 Fig 8. sot023_fr Reflow soldering footprint SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 Fig 9. Wave soldering footprint SOT23 (TO-236AB) BZB84_SER Product data sheet sot023_fw © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 11 of 14 BZB84 series Nexperia Dual Zener diodes 12. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes BZB84_SER_3 20090609 Product data sheet - BZB84_SER_2 Modifications: • • • Table 5 “Limiting values”: Ptot maximum value amended Table 6: Rth maximum values amended Section 13 “Legal information”: updated BZB84_SER_2 20090223 Product data sheet - BZB84_SER_1 BZB84_SER_1 20080514 Product data sheet - - BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 12 of 14 BZB84 series Nexperia Dual Zener diodes 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/ or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http:// www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BZB84_SER Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 03 — 9 June 2009 13 of 14 BZB84 series Nexperia Dual Zener diodes 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . 10 Quality information . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information. . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Nexperia B.V. 2009. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 June 2009 Document identifier: BZB84_SER
BZB84-C68,215
物料型号:BZB84系列
器件简介:BZB84系列是通用的双Zener二极管,采用SOT23(TO-236AB)小型表面贴装塑料封装。
引脚分配:共有三个引脚,1号和2号引脚为二极管的阴极,3号引脚为两个二极管的共同阳极。
参数特性: - 正向电压(VF):在10mA正向电流下,典型值为0.9V。 - 非重复峰值反向功耗(PzSM):典型值40W。 - 总功耗(Ptot):在环境温度25°C下,典型值300mW。 - 工作电压范围:标称值从2.4V至75V(E24系列)。 - 公差系列:B系列±2%和C系列±5%。
功能详解:BZB84系列二极管适用于一般调节功能。
应用信息:适用于一般调节功能。
封装信息:SOT23(TO-236AB)小型塑料封装,适用于表面贴装设计。
BZB84-C68,215 价格&库存
很抱歉,暂时无法提供与“BZB84-C68,215”相匹配的价格&库存,您可以联系我们找货
BZB84-C68,215
  • 1+1.19461
  • 5+0.98332
  • 10+0.86955
BZB84-C68,215
    BZB84-C68,215
    • 1+2.027241+0.26234
    • 10+1.2174110+0.15754
    • 100+0.75264100+0.09740
    • 500+0.55079500+0.07128
    • 1000+0.485231000+0.06279
    库存:2980
