Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
M3D793
BZB984 series
Voltage regulator double diodes
Product data sheet
Supersedes data of 2001 Nov 28
2002 Jun 21
NXP Semiconductors
Product data sheet
BZB984 series
FEATURES
PINNING
• Total power dissipation: max. 425 mW
PIN
DESCRIPTION
• Approx. 5% VZ tolerance
1
cathode 1
• Ultra small flat plastic SMD package
2
cathode 2
• Working voltage range nom. 2.4 to 15 V (E24 range).
3
common anode
APPLICATIONS
• General regulation functions
3
handbook, halfpage
3
• ESD and surge protection.
1
DESCRIPTION
1
Low-power voltage regulator diodes in a SOT663 ultra
small plastic SMD package.
2
Top view
Fig.1
2
MHC314
Simplified outline (SOT663) and symbol.
MARKING
TYPE
NUMBER
MARKING
CODE
TYPE
NUMBER
MARKING
CODE
TYPE
NUMBER
MARKING
CODE
TYPE
NUMBER
MARKING
CODE
BZB984-C2V4
91
BZB984-C3V9
96
BZB984-C6V2
9B
BZB984-C10
9G
BZB984-C2V7
92
BZB984-C4V3
97
BZB984-C6V8
9C
BZB984-C11
9H
BZB984-C3V0
93
BZB984-C4V7
98
BZB984-C7V5
9D
BZB984-C12
9J
BZB984-C3V3
94
BZB984-C5V1
99
BZB984-C8V2
9E
BZB984-C13
9K
BZB984-C3V6
95
BZB984-C5V6
9A
BZB984-C9V1
9F
BZB984-C15
9L
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
200
UNIT
IF
continuous forward current
mA
IZSM
non-repetitive peak reverse
current
tp = 100 μs; square wave; Tamb = 25 °C;
prior to surge
see Table 1
Ptot
total power dissipation
Tamb = 25 °C; 2 diodes loaded; note 1
425
mW
Tamb = 25 °C; 1 diode loaded; note 1
265
mW
prior to surge
40
W
PZSM
dissipation
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Note
1. Device mounted on an FR4 printed-circuit board.
2002 Jun 21
2
NXP Semiconductors
Product data sheet
BZB984 series
ELECTRICAL CHARACTERISTICS
Total BZB984-C series
Tamb = 25 °C unless otherwise specified.
SYMBOL
PARAMETER
VF
forward voltage
IR
reverse current
2002 Jun 21
CONDITIONS
MAX.
UNIT
IF = 10 mA; see Fig.2
0.9
V
BZB984-C2V4
VR = 1 V
50
μA
BZB984-C2V7
VR = 1 V
μA
BZB984-C3V0
VR = 1 V
10
μA
BZB984-C3V3
VR = 1 V
5
μA
BZB984-C3V6
VR = 1 V
5
μA
BZB984-C3V9
VR = 1 V
3
μA
BZB984-C4V3
VR = 1 V
3
μA
BZB984-C4V7
VR = 2 V
3
μA
BZB984-C5V1
VR = 2 V
2
μA
BZB984-C5V6
VR = 2 V
1
μA
BZB984-C6V2
VR = 4 V
3
μA
BZB984-C6V8
VR = 4 V
2
μA
BZB984-C7V5
VR = 5 V
1
μA
BZB984-C8V2
VR = 5 V
700
nA
BZB984-C9V1
VR = 6 V
500
nA
BZB984-C10
VR = 7 V
200
nA
BZB984-C11
VR = 8 V
100
nA
BZB984-C12
VR = 8 V
100
nA
BZB984-C13
VR = 8 V
100
nA
BZB984-C15
VR = 10.5 V
50
nA
3
MIN.
MAX.
DIFFERENTIAL RESISTANCE
rdif (Ω)
at IZ = 1 mA
TYP.
at IZ = 5 mA
MAX.
TYP.
TEMP. COEFF.
SZ (mV/K)
at IZtest = 5 mA
(see Figs 3 and 4)
DIODE CAP.
Cd (pF)
at f = 1 MHz;
VR = 0 V
NON-REPETITIVE PEAK
REVERSE CURRENT
IZSM (A) at tp = 100 μs;
Tamb = 25 °C
TYP.
MAX.
MAX.
MAX.
4
2.2
2.6
275
600
70
100
−1.3
450
6.0
2V7
2.5
2.9
300
600
75
100
−1.4
450
6.0
3V0
2.8
3.2
325
600
80
95
−1.6
450
6.0
3V3
3.1
3.5
350
600
85
95
−1.8
450
6.0
3V6
3.4
3.8
375
600
85
90
−1.9
450
6.0
3V9
3.7
4.1
400
600
85
90
−1.9
450
6.0
4V3
4.0
4.6
410
600
80
90
−1.7
450
6.0
4V7
4.4
5.0
425
500
50
80
−1.2
300
6.0
5V1
4.8
5.4
400
480
40
60
−0.5
300
6.0
5V6
5.2
6.0
80
400
15
40
1.0
300
6.0
6V2
5.8
6.6
40
150
6
10
2.2
200
6.0
6V8
6.4
7.2
30
80
6
15
3.0
200
6.0
7V5
7.0
7.9
30
80
6
15
3.6
150
4.0
8V2
7.7
8.7
40
80
6
15
4.3
150
4.0
9V1
8.5
9.6
40
100
6
15
5.2
150
3.0
10
9.4
10.6
50
150
8
90
3.0
11
10.4
11.6
50
150
10
90
2.5
12
11.4
12.7
50
150
10
25
7.9
85
2.5
13
12.4
14.1
50
170
10
30
8.8
80
2.5
15
13.8
15.6
50
200
10
30
10.7
75
2.0
Product data sheet
BZB984 series
2V4
NXP Semiconductors
WORKING VOLTAGE
VZ (V)
I
at
BZB984Z = 5 mA
Cxxx
Tol. ≈5%
2002 Jun 21
Table 1 Per type BZB984-C2V4 to C15
Tj = 25 °C unless otherwise specified.
NXP Semiconductors
Product data sheet
BZB984 series
THERMAL CHARACTERISTICS
SYMBOL
PARAMETER
Rth j-s
CONDITIONS
thermal resistance from junction to soldering point
Rth j-a
thermal resistance from junction to ambient
VALUE
UNIT
125
K/W
230
K/W
2 diodes loaded; note 2
294
K/W
1 diode loaded; note 2
472
K/W
Notes
1. Solder points on cathode tabs.
2. Device mounted on an FR4 printed-circuit board.
Soldering
The only recommended soldering method is reflow soldering.
GRAPHICAL DATA
MLD362
300
MLD363
0.5
handbook, halfpage
handbook, halfpage
SZ
(mV/K)
IF
(mA)
4V7
4V3
200
−0.5
2V4
2V7
3V9
−1
100
3V6
−1.5
0.7
0.8
0.9
VF (V)
3V3
3V0
−2
10−1
1
Tj = 25 °C.
BZB984-C2V4 to C4V7.
Tj = 25 to 150 °C.
Fig.2
Fig.3
Forward current as a function of forward
voltage; typical values.
2002 Jun 21
5
1
10
IZ (mA)
102
Temperature coefficient as a function of
working current; typical values.
NXP Semiconductors
Product data sheet
BZB984 series
MLD364
12
handbook, halfpage
15
SZ
(mV/K)
13
12
11
10
9V1
8V2
7V5
6V8
6V2
5V6
5V1
8
4
−4
10−1
1
10
IZ (mA)
102
BZB984-C5V1 to C15.
Tj = 25 to 150 °C.
Fig.4
2002 Jun 21
6
NXP Semiconductors
Product data sheet
BZB984 series
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
SOT663
D
E
B
X
Y
HE
3
A
1
c
2
e1
w M B
bp
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
bp
c
D
E
e
e1
HE
Lp
w
y
mm
0.6
0.5
0.33
0.23
0.18
0.08
1.7
1.5
1.3
1.1
1.0
0.5
1.7
1.5
0.3
0.1
0.1
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
ISSUE DATE
01-12-04
02-05-21
SOT663
2002 Jun 21
EUROPEAN
PROJECTION
7
NXP Semiconductors
Product data sheet
BZB984 series
DATA SHEET STATUS
DOCUMENT
STATUS(1)
PRODUCT
STATUS(2)
DEFINITION
Objective data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary data sheet
Qualification
This document contains data from the preliminary specification.
Product data sheet
Production
This document contains the product specification.
Notes
1. Please consult the most recently issued document before initiating or completing a design.
2. The product status of device(s) described in this document may have changed since this document was published
and may differ in case of multiple devices. The latest product status information is available on the Internet at
URL http://www.nxp.com.
above those given in the Characteristics sections of this
document is not implied. Exposure to limiting values for
extended periods may affect device reliability.
DISCLAIMERS
General ⎯ Information in this document is believed to be
accurate and reliable. However, NXP Semiconductors
does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness
of such information and shall have no liability for the
consequences of use of such information.
Terms and conditions of sale ⎯ NXP Semiconductors
products are sold subject to the general terms and
conditions of commercial sale, as published at
http://www.nxp.com/profile/terms, including those
pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by NXP Semiconductors. In
case of any inconsistency or conflict between information
in this document and such terms and conditions, the latter
will prevail.
Right to make changes ⎯ NXP Semiconductors
reserves the right to make changes to information
published in this document, including without limitation
specifications and product descriptions, at any time and
without notice. This document supersedes and replaces all
information supplied prior to the publication hereof.
No offer to sell or license ⎯ Nothing in this document
may be interpreted or construed as an offer to sell products
that is open for acceptance or the grant, conveyance or
implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use ⎯ NXP Semiconductors products are
not designed, authorized or warranted to be suitable for
use in medical, military, aircraft, space or life support
equipment, nor in applications where failure or malfunction
of an NXP Semiconductors product can reasonably be
expected to result in personal injury, death or severe
property or environmental damage. NXP Semiconductors
accepts no liability for inclusion and/or use of NXP
Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at
the customer’s own risk.
Export control ⎯ This document as well as the item(s)
described herein may be subject to export control
regulations. Export might require a prior authorization from
national authorities.
Quick reference data ⎯ The Quick reference data is an
extract of the product data given in the Limiting values and
Characteristics sections of this document, and as such is
not complete, exhaustive or legally binding.
Applications ⎯ Applications that are described herein for
any of these products are for illustrative purposes only.
NXP Semiconductors makes no representation or
warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values ⎯ Stress above one or more limiting
values (as defined in the Absolute Maximum Ratings
System of IEC 60134) may cause permanent damage to
the device. Limiting values are stress ratings only and
operation of the device at these or any other conditions
2002 Jun 21
8
NXP Semiconductors
Customer notification
This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were
made to the content, except for the legal definitions and disclaimers.
Contact information
For additional information please visit: http://www.nxp.com
For sales offices addresses send e-mail to: salesaddresses@nxp.com
© NXP B.V. 2009
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
613514/02/pp9
Date of release: 2002 Jun 21
Document order number: 9397 750 09768
很抱歉,暂时无法提供与“BZB984-C2V7,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.33748
- 50+1.05452
- 150+0.93312
- 国内价格 香港价格
- 4000+0.634054000+0.08205
- 8000+0.573218000+0.07418
- 12000+0.5421912000+0.07017
- 20000+0.5073120000+0.06565
- 28000+0.4866428000+0.06298
- 40000+0.4665640000+0.06038
- 国内价格 香港价格
- 1+3.177081+0.41113
- 10+1.9307710+0.24986
- 100+1.20793100+0.15632
- 500+0.89368500+0.11565
- 1000+0.792021000+0.10250
- 2000+0.706282000+0.09140
- 国内价格
- 1+1.82848
- 5+1.50342
- 10+1.31651
- 国内价格
- 1+0.84480
- 200+0.58300
- 2000+0.52910
- 4000+0.49500
