BSH201,215
BSH201,215
    NEXPERIA(安世)
    SOT-23
    MOSFETs 60V 3.00 x 1.40mm SMT SOT23 300mA
BSH201,215 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia Philips Semiconductors Product specification P-channel enhancement mode MOS transistor FEATURES BSH201 SYMBOL • Low threshold voltage • Fast switching • Logic level compatible • Subminiature surface mount package QUICK REFERENCE DATA VDS = -60 V s ID = -0.3 A g RDS(ON) ≤ 2.5 Ω (VGS = -10 V) d GENERAL DESCRIPTION P-channel, enhancement mode, logic level, field-effect power transistor. This device has low threshold voltage and extremely fast switching making it ideal for battery powered applications and high speed digital interfacing. PINNING SOT23 PIN DESCRIPTION 1 gate 2 source 3 drain 3 Top view The BSH201 is supplied in the SOT23 subminiature surface mounting package. 1 2 LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134) SYMBOL PARAMETER CONDITIONS VDS VDGR VGS ID Drain-source voltage Drain-gate voltage Gate-source voltage Drain current (DC) RGS = 20 kΩ IDM Ptot Drain current (pulse peak value) Total power dissipation Tstg, Tj Storage & operating temperature Ta = 25 ˚C Ta = 100 ˚C Ta = 25 ˚C Ta = 25 ˚C Ta = 100 ˚C MIN. MAX. UNIT - 55 -60 -60 ± 20 -0.3 -0.19 -1.2 0.417 0.17 150 V V V A A A W W ˚C THERMAL RESISTANCES SYMBOL PARAMETER CONDITIONS TYP. MAX. UNIT Rth j-a Thermal resistance junction to ambient FR4 board, minimum footprint 300 - K/W August 1998 1 Rev 1.000 Philips Semiconductors Product specification P-channel enhancement mode MOS transistor BSH201 ELECTRICAL CHARACTERISTICS Tj= 25˚C unless otherwise specified SYMBOL PARAMETER V(BR)DSS VGS(TO) Drain-source breakdown voltage Gate threshold voltage CONDITIONS MIN. VGS = 0 V; ID = -10 µA VDS = VGS; ID = -1 mA Tj = 150˚C RDS(ON) gfs IGSS IDSS Drain-source on-state resistance VGS = -10 V; ID = -160 mA VGS = -4.5 V; ID = -80 mA VGS = -10 V; ID = -160 mA; Tj = 150˚C Forward transconductance VDS = -48 V; ID = -160 mA Gate source leakage current VGS = ±20 V; VDS = 0 V Zero gate voltage drain VDS = -48 V; VGS = 0 V; current Tj = 150˚C TYP. MAX. UNIT -60 - - V -1 -0.4 0.1 - -1.9 2.1 2.7 3.6 0.35 ±10 -50 -1.3 2.5 3.75 4.25 ±100 -100 -10 V V Ω Ω Ω S nA nA µA Qg(tot) Qgs Qgd Total gate charge Gate-source charge Gate-drain (Miller) charge ID = -0.5 A; VDD = -10 V; VGS = -10 V - 3 0.5 0.4 - nC nC nC td on tr td off tf Turn-on delay time Turn-on rise time Turn-off delay time Turn-off fall time VDD = -10 V; ID = -0.5 A; VGS = -10 V; RG = 6 Ω Resistive load - 2 4.5 45 20 - ns ns ns ns Ciss Coss Crss Input capacitance Output capacitance Feedback capacitance VGS = 0 V; VDS = -48 V; f = 1 MHz - 70 15 5 - pF pF pF MIN. TYP. MAX. UNIT REVERSE DIODE LIMITING VALUES AND CHARACTERISTICS Tj = 25˚C unless otherwise specified SYMBOL PARAMETER CONDITIONS IDR Ta = 25 ˚C - - -0.3 A IDRM VSD Continuous reverse drain current Pulsed reverse drain current Diode forward voltage IF = -0.38 A; VGS = 0 V - -0.97 -1.2 -1.3 A V trr Qrr Reverse recovery time Reverse recovery charge IF = -0.25 A; -dIF/dt = 100 A/µs; VGS = 0 V; VR = -48 V - 38 58 - ns nC August 1998 2 Rev 1.000 Philips Semiconductors Product specification P-channel enhancement mode MOS transistor BSH201 Normalised Power Dissipation, PD (%) Peak Pulsed Drain Current, IDM (A) 120 1000 100 D = 0.5 100 0.2 80 0.1 60 0.05 0.02 single pulse 10 40 P D D = tp/T tp 1 20 T 0 0 25 50 75 100 125 0.1 1E-06 150 1E-05 1E-04 Ambient Temperature, Ta (C) 1E-03 1E-02 1E-01 1E+00 1E+01 Pulse width, tp (s) Fig.1. Normalised power dissipation. PD% = 100⋅PD/PD 25 ˚C = f(Ta) Fig.4. Transient thermal impedance. Zth j-a = f(t); parameter D = tp/T Normalised Drain Current, ID (%) Drain current, ID (A) 120 -1 100 -0.8 BSH201 Tj = 25 C VGS = -10 V 80 -4.5 V -0.6 60 40 -0.4 20 -0.2 -2.5 V -2.3 V -2.1 V -1.9 V -1.7 V -1.5 V 0 0 25 50 75 100 125 0 150 0 Ambient Temperature, Ta (C) Fig.2. Normalised continuous drain current. ID% = 100⋅ID/ID 25 ˚C = f(Ta); conditions: VGS ≤ -10 V -0.5 -1 -1.5 Drain-Source Voltage, VDS (V) -2 Fig.5. Typical output characteristics, Tj = 25 ˚C. ID = f(VDS); parameter VGS Drain-Source On Resistance, RDS(on) (Ohms) 10 10 BSH201 Peak Pulsed Drain Current, IDM (A) -1.5 V 9 RDS(on) = VDS/ ID 1 0.1 tp = 10us 8 100 us 7 1 ms 6 10 ms 5 100 ms 4 Tj = 25 C -1.9 V -2.1 V -2.3 V -2.5 V -4.5 V 3 d.c. 0.01 -1.7 V VGS = -10 V 2 1 0.001 0 1 10 100 Drain-Source Voltage, VDS (V) 1000 0 Fig.3. Safe operating area. Ta = 25 ˚C ID & IDM = f(VDS); IDM single pulse; parameter tp August 1998 -0.1 -0.2 -0.3 -0.4 Drain Current, ID (A) PHP222 -0.5 Fig.6. Typical on-state resistance, Tj = 25 ˚C. RDS(ON) = f(ID); parameter VGS 3 Rev 1.000 Philips Semiconductors Product specification P-channel enhancement mode MOS transistor Drain Current, ID (A) BSH201 BSH201 Threshold Voltage, VGS(to), (V) -1 -0.9 1.8 VDS > ID X RDS(on) typical 1.6 -0.8 Tj = 25 C 1.4 -0.7 150 C -0.6 1.2 1 -0.5 minimum 0.8 -0.4 0.6 -0.3 0.4 -0.2 0.2 -0.1 0 0 0 0 -0.5 -1 -1.5 -2 -2.5 -3 -3.5 -4 Gate-Source Voltage, VGS (V) -4.5 -5 50 75 100 125 150 Junction Temperature, Tj (C) Fig.7. Typical transfer characteristics. ID = f(VGS) Transconductance, gfs (S) 25 -5.5 Fig.10. Gate threshold voltage. VGS(TO) = f(Tj); conditions: ID = 1 mA; VDS = VGS BSH201 Drain Current, ID (A) BSH201 1E-01 0.7 Tj = 25 C VDS > ID X RDS(on) 0.6 1E-02 150 C VDS = -5 V Tj = 25 C 0.5 1E-03 0.4 0.3 1E-04 0.2 1E-05 0.1 1E-06 0 0 -0.1 -0.2 -0.3 -0.4 -0.5 -0.6 -0.7 -0.8 -0.9 1E-07 -2.5 -1 Drain Current, ID (A) Fig.8. Typical transconductance, Tj = 25 ˚C. gfs = f(ID) -1 Fig.11. Sub-threshold drain current. ID = f(VGS); conditions: Tj = 25 ˚C Capacitances, Ciss, Coss, Crss (pF) Normalised Drain-Source On Resistance 2 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1 0.9 0.8 0.7 0.6 0.5 -2 -1.5 Gate-Source Voltage, VGS (V) BSH201 1000 RDS(ON) @ Tj RDS(ON) @ 25C VGS = -10 V -4.5 V Ciss 100 Coss 10 0 25 50 75 100 125 1 -0.1 150 Junction Temperature, Tj (C) Fig.9. Normalised drain-source on-state resistance. RDS(ON)/RDS(ON)25 ˚C = f(Tj) August 1998 Crss -1.0 -10.0 Drain-Source Voltage, VDS (V) -100.0 Fig.12. Typical capacitances, Ciss, Coss, Crss. C = f(VDS); conditions: VGS = 0 V; f = 1 MHz 4 Rev 1.000 Philips Semiconductors Product specification P-channel enhancement mode MOS transistor Gate-source voltage, VGS (V) BSH201 BSH201 -14 -12 -10 BSH201 Source-Drain Diode Current, IF (A) 3.5 VDD = 10 V RD = 20 Ohms Tj = 25 C 3 2.5 -8 2 -6 1.5 150 C 1 -4 Tj = 25 C 0.5 -2 0 0 0 0 1 2 3 Gate charge, (nC) 4 5 1 1.5 2 Drain-Source Voltage, VSDS (V) Fig.14. Typical reverse diode current. IF = f(VSDS); conditions: VGS = 0 V; parameter Tj Fig.13. Typical turn-on gate-charge characteristics. VGS = f(QG) August 1998 0.5 5 Rev 1.000 Philips Semiconductors Product specification P-channel enhancement mode MOS transistor BSH201 MECHANICAL DATA Plastic surface mounted package; 3 leads SOT23 D E B A X HE v M A 3 Q A A1 1 2 e1 bp c w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A mm 1.1 0.9 OUTLINE VERSION A1 max. bp c D E 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 e 1.9 e1 HE Lp Q v w 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 97-02-28 SOT23 Fig.15. SOT23 surface mounting package. Notes 1. This product is supplied in anti-static packaging. The gate-source input must be protected against static discharge during transport or handling. 2. Refer to SMD Footprint Design and Soldering Guidelines, Data Handbook SC18. 3. Epoxy meets UL94 V0 at 1/8". August 1998 6 Rev 1.000 Philips Semiconductors Product specification P-channel enhancement mode MOS transistor BSH201 DEFINITIONS Data sheet status Objective specification This data sheet contains target or goal specifications for product development. Preliminary specification This data sheet contains preliminary data; supplementary data may be published later. Product specification This data sheet contains final product specifications. Limiting values Limiting values are given in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of this specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information Where application information is given, it is advisory and does not form part of the specification.  Philips Electronics N.V. 1998 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, it is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent or other industrial or intellectual property rights. LIFE SUPPORT APPLICATIONS These products are not designed for use in life support appliances, devices or systems where malfunction of these products can be reasonably expected to result in personal injury. Philips customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips for any damages resulting from such improper use or sale. August 1998 7 Rev 1.000
BSH201,215 价格&库存
很抱歉,暂时无法提供与“BSH201,215”相匹配的价格&库存,您可以联系我们找货
BSH201,215
  • 3000+0.79458
  • 6000+0.77063
  • 30000+0.75501
库存:9960
BSH201,215
  • 1+3.49444
  • 10+2.53550
  • 50+1.82848
BSH201,215
  • 5+6.70373
  • 50+3.84426
  • 100+2.76455
  • 500+2.14757
  • 1500+1.81535
BSH201,215
  • 1+0.76439
  • 100+0.71343
  • 300+0.66247
  • 500+0.61152
  • 2000+0.58604
  • 5000+0.57075
BSH201,215
    • 3000+1.02760
    • 15000+1.01730
    库存:87000
