BSS84AKMB,315
BSS84AKMB,315
    NEXPERIA(安世)
    DFN1006B-3
    MOS管 P-Channel Id=0.23A VDS=50V DFN1006B-3
BSS84AKMB,315 数据手册
BSS84AKMB 50 V, single P-channel Trench MOSFET 27 October 2020 Product data sheet 1. General description P-channel enhancement mode Field-Effect Transistor (FET) in a leadless ultra small DFN1006B-3 (SOT883B) Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology. 2. Features and benefits • • • • • Logic-level compatible Very fast switching Trench MOSFET technology ESD protection up to 1 kV Ultra thin package profile with 0.37 mm height 3. Applications • • • • Relay driver High-speed line driver High-side load switch Switching circuits 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj = 25 °C - - -50 V VGS gate-source voltage -20 - 20 V ID drain current - - -230 mA - 4.5 7.5 Ω VGS = -10 V; Tamb = 25 °C [1] Static characteristics RDSon [1] drain-source on-state resistance VGS = -10 V; ID = -100 mA; Tj = 25 °C 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 1 cm . BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 S source 3 D drain Simplified outline Graphic symbol D 1 3 2 Transparent top view G DFN1006B-3 (SOT883B) S 017aaa259 6. Ordering information Table 3. Ordering information Type number Package BSS84AKMB Name Description Version DFN1006B-3 plastic, leadless ultra small plastic package; 3 solder lands; 0.35 mm pitch; 1.0 mm x 0.6 mm x 0.37 mm body SOT883B 7. Marking Table 4. Marking codes Type number Marking code BSS84AKMB 0000 0010 PIN 1 INDICATION READING DIRECTION READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac673 Fig. 1. DFN1006B-3 (SOT883B) binary marking code description BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 2 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - -50 V VGS gate-source voltage -20 20 V ID drain current VGS = -10 V; Tamb = 25 °C [1] - -230 mA VGS = -10 V; Tamb = 100 °C [1] - -150 mA - -0.9 A [2] - 360 mW [1] - 715 mW IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs Ptot total power dissipation Tamb = 25 °C - 2700 mW Tj junction temperature Tsp = 25 °C -55 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C Source-drain diode IS source current Tamb = 25 °C [1] - -230 mA HBM [3] - 1000 V ESD maximum rating VESD [1] [2] [3] electrostatic discharge voltage 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 1 cm . Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Measured between all pins. 001aao121 120 Pder (%) Ider (%) 80 80 40 40 0 -75 Fig. 2. 001aao122 120 -25 25 75 125 Tj (°C) Normalized total power dissipation as a function of junction temperature BSS84AKMB Product data sheet 0 -75 175 Fig. 3. -25 75 125 Tj (°C) 175 Normalized continuous drain current as a function of junction temperature All information provided in this document is subject to legal disclaimers. 27 October 2020 25 © Nexperia B.V. 2020. All rights reserved 3 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 001aao138 -10 ID (A) -1 (1) -10-1 -10-2 10-1 (2) (3) (4) (5) -1 -10 -102 VDS (V) IDM is single pulse (1) tp = 1 ms (2) DC; Tsp = 25 °C (3) tp = 10 ms (4) tp = 100 ms 2 (5) DC; Tamb = 25 °C; drain mounting pad 1 cm Fig. 4. Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 4 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from in free air junction to ambient Rth(j-sp) [1] [2] Conditions Min Typ Max Unit [1] - 305 350 K/W [2] - 150 175 K/W - - 40 K/W thermal resistance from junction to solder point Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 1 cm . 017aaa109 103 duty cycle = 1 Zth(j-a) (K/W) 0.75 0.5 102 0.33 0.25 0.2 0.1 0.05 0 0.02 0.01 10 10- 3 10- 2 10- 1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 5. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 017aaa110 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.5 0.25 0.33 0.2 0.1 0 10 10- 3 0.05 0.02 0.01 10- 2 10- 1 FR4 PCB, mounting pad for drain 1 cm Fig. 6. 1 10 102 tp (s) 2 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 5 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = -250 µA; VGS = 0 V; Tj = 25 °C -50 - - V VGSth gate-source threshold voltage ID = -250 µA; VDS=VGS; Tj = 25 °C -1.1 -1.6 -2.1 V IDSS drain leakage current VDS = -50 V; VGS = 0 V; Tj = 25 °C - - -1 µA VDS = -50 V; VGS = 0 V; Tj = 150 °C - - -2 µA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - -10 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - -10 µA VGS = -10 V; ID = -100 mA; Tj = 25 °C - 4.5 7.5 Ω VGS = -10 V; ID = -100 mA; Tj = 150 °C - 8 13.5 Ω VGS = -5 V; ID = -100 mA; Tj = 25 °C - 5.7 8.5 Ω VDS = -10 V; ID = -100 mA; Tj = 25 °C - 150 - mS VDS = -25 V; ID = -200 mA; VGS = -5 V; Tj = 25 °C - 0.26 0.35 nC IGSS RDSon gfs gate leakage current drain-source on-state resistance forward transconductance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge - 0.12 - nC QGD gate-drain charge VDS = -10 V; ID = -200 mA; VGS = -5 V; Tj = 25 °C - 0.09 - nC Ciss input capacitance - 24 36 pF Coss output capacitance VDS = -25 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C - 4.5 - pF Crss reverse transfer capacitance - 1.3 - pF td(on) turn-on delay time - 13 26 ns tr rise time - 11 - ns td(off) turn-off delay time - 48 96 ns tf fall time - 25 - ns -0.48 -0.85 -1.2 V VDS = -30 V; RL = 250 Ω; VGS = -10 V; RG(ext) = 6 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage BSS84AKMB Product data sheet IS = -115 mA; VGS = 0 V; Tj = 25 °C All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 6 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 001aao124 -0.20 VGS = -10 V -4.0 V -3.5 V ID (A) 001aao125 -10-3 ID (A) -0.15 (3) (2) (1) -10-4 -3.0 V -0.10 -10-5 -2.5 V -0.05 0 0 -1 -2 -3 VDS (V) -10-6 -4 Tj = 25 °C Fig. 7. Fig. 8. 001aao126 (1) (2) -0.5 -1.0 -1.5 -2.0 -2.5 VGS (V) Tj = 25 °C; VDS = -5 V (1) minimum values (2) typical values (3) maximum values Output characteristics; drain current as a function of drain-source voltage; typical values 12 0 Sub-threshold drain current as a function of gate-source voltage 001aao127 14 (3) RDSon ( ) RDSon ( ) 8 10 (4) (1) (5) 4 6 (2) 0 0 -0.1 -0.2 -0.3 ID (A) 2 -0.4 Tj = 25 °C (1) VGS = -3.0 V (2) VGS = -3.5 V (3) VGS = -4.0 V (4) VGS = -5.0 V (5) VGS = -10.0 V Fig. 9. 0 -2 -4 -6 -8 -10 VGS (V) ID = -200 mA (1) Tj = 150 °C (2) Tj = 25 °C Fig. 10. Drain-source on-state resistance as a function of gate-source voltage; typical values Drain-source on-state resistance as a function of drain current; typical values BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 7 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 001aao128 -0.20 ID (A) 001aao129 2.0 a (1) (2) -0.15 1.5 -0.10 1.0 -0.05 0 0.5 (2) (1) 0 -1 -2 -3 VGS (V) 0 -60 -4 VDS > ID x RDSon (1) Tj = 25 °C (2) Tj = 150 °C Fig. 11. Transfer characteristics: drain current as a function of gate-source voltage; typical values 001aao130 -3 0 60 Tj (°C) 180 Fig. 12. Normalized drain-source on-state resistance as a function of junction temperature; typical values 001aao131 102 VGS(th) (V) C (pF) -2 120 (1) (1) (2) -1 (2) 10 (3) (3) 0 -60 0 60 120 Tj (°C) 1 -10-1 180 ID = -0.25 mA; VDS = VGS (1) maximum values (2) typical values (3) minimum values Product data sheet -10 VDS (V) -102 f = 1 MHz, VGS = 0 V (1) Ciss (2) Coss (3) Crss Fig. 13. Gate-source threshold voltage as a function of junction temperature BSS84AKMB -1 Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 8 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 001aao132 -10 VGS (V) VDS -8 ID -6 VGS(pl) -4 VGS(th) VGS -2 0 QGS2 QGS1 0 0.2 0.4 QG (nC) QGS 0.6 QGD QG(tot) ID = -0.2 A; VDS = -25 V; Tamb = 25 °C 003aaa508 Fig. 16. Gate charge waveform definitions Fig. 15. Gate-source voltage as a function of gate charge; typical values 001aao133 -0.3 IS (A) -0.2 -0.1 (1) 0 0 -0.4 (2) -0.8 VSD (V) -1.2 VGS = 0 V (1) Tj = 150 °C (2) Tj = 25 °C Fig. 17. Source current as a function of source-drain voltage; typical values 11. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 18. Duty cycle definition BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 9 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 12. Package outline Leadless ultra small plastic package; 3 solder lands; body 1.0 x 0.6 x 0.37 mm L (2x) SOT883B L1 2 b (2x) 3 e b1 1 e1 A1 A E D 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b b1 D E e e1 L L1 max 0.40 0.04 0.20 0.55 0.65 1.05 0.30 0.30 nom 0.37 0.15 0.50 0.60 1.00 0.35 0.65 0.25 0.25 min 0.34 0.12 0.47 0.55 0.95 0.22 0.22 Note 1. Including plating thickness Outline version sot883b_po References IEC JEDEC JEITA European projection Issue date 11-11-02 12-01-03 SOT883B Fig. 19. Package outline DFN1006B-3 (SOT883B) BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 10 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 13. Soldering Footprint information for reflow soldering of DFN1006B-3 (SOT883B) package SOT883B 1.3 0.7 R0.05 (20x) 0.35 (2x) 0.9 0.45 0.6 0.7 0.8 0.25 (2x) 0.3 (2x) 0.3 0.4 (2x) 0.4 0.5 (2x) 0.5 occupied area solder resist solder lands solder paste Dimensions in mm Issue date 13-07-02 20-02-25 sot883b_fr Fig. 20. Reflow soldering footprint for DFN1006B-3 (SOT883B) BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 11 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BSS84AKMB v.2 20201027 Product data sheet - BSS84AKMB v.1 Modifications: • • BSS84AKMB v.1 BSS84AKMB Product data sheet The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 20120606 Product data sheet - All information provided in this document is subject to legal disclaimers. 27 October 2020 - © Nexperia B.V. 2020. All rights reserved 12 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BSS84AKMB Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 13 / 14 BSS84AKMB Nexperia 50 V, single P-channel Trench MOSFET Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 5 10. Characteristics............................................................ 6 11. Test information.......................................................... 9 12. Package outline........................................................ 10 13. Soldering................................................................... 11 14. Revision history........................................................12 15. Legal information......................................................13 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 October 2020 BSS84AKMB Product data sheet All information provided in this document is subject to legal disclaimers. 27 October 2020 © Nexperia B.V. 2020. All rights reserved 14 / 14
BSS84AKMB,315
物料型号:BSS84AKMB 器件简介:BSS84AKMB 是一款 50V 单通道 P-沟道 Trench MOSFET,采用无引脚超小型 DFN1006B-3 (SOT883B) 表面贴装塑料封装技术。
引脚分配:1号引脚为栅极(G),2号引脚为源极(S),3号引脚为漏极(D)。
参数特性:漏源电压(VDS)范围 -50V 至 20V,栅源电压(VGS)范围 -20V 至 20V,漏极电流(ID)在 VGS=-10V、环境温度 25°C 时最小值 -230mA。
功能详解:该器件具有逻辑级兼容、超快速开关、ESD 保护高达 1kV 以及超薄封装轮廓等特点。
应用信息:适用于继电器驱动器、高速线路驱动器、高侧负载开关和开关电路。
封装信息:DFN1006B-3 封装,塑料无引脚超小型封装,3个焊盘,0.35mm 间距,1.0mm x 0.6mm x 0.37mm 的封装尺寸。
BSS84AKMB,315 价格&库存
很抱歉,暂时无法提供与“BSS84AKMB,315”相匹配的价格&库存,您可以联系我们找货
BSS84AKMB,315
  • 1+3.182981+0.41231
  • 10+1.9696010+0.25514
  • 100+1.23218100+0.15961
  • 500+0.91260500+0.11822
  • 1000+0.809171000+0.10482
  • 2000+0.721952000+0.09352
  • 5000+0.627335000+0.08126
BSS84AKMB,315
  • 1000+0.80362
  • 10000+0.72325
  • 100000+0.56253
库存:5125
