PSMN2R0-30YLE,115
PSMN2R0-30YLE,115
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=100A VDS=30V SOT669
PSMN2R0-30YLE,115 数据手册
PSMN2R0-30YLE N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 18 June 2021 Product data sheet 1. General description Logic level N-channel MOSFET in LFPAK package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 2. Features and benefits • • Enhanced forward biased safe operating area for superior linear mode operation Very low Rdson for low conduction losses 3. Applications • • • • Electronic fuse Hot swap Load switch Soft start 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C ID drain current VGS = 10 V; Tmb = 100 °C; Fig. 2 Ptot total power dissipation Tmb = 25 °C; Fig. 1 Tj junction temperature Min Typ Max Unit - - 30 V - - 100 A - - 238 W -55 - 175 °C VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 12 - 1.7 2 mΩ VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 12 - 3 3.5 mΩ [1] Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge ID = 25 A; VDS = 15 V; VGS = 4.5 V; Fig. 14; Fig. 15 - 13.8 - nC QG(tot) total gate charge ID = 25 A; VDS = 15 V; VGS = 10 V; Fig. 14; Fig. 15 - 87 - nC ID = 100 A; Vsup ≤ 30 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped; Fig. 4 - - 365 mJ Avalanche ruggedness EDS(AL)S non-repetitive drainsource avalanche energy PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK Symbol Parameter Conditions Min Typ Max Unit IS = 25 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = 15 V - 49.8 - nC Simplified outline Graphic symbol Source-drain diode Qr [1] recovered charge Capped at 100A due to package 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain mb D G 1 2 3 4 LFPAK56; PowerSO8 (SOT669) mbb076 S 6. Ordering information Table 3. Ordering information Type number Package PSMN2R0-30YLE Name Description Version LFPAK56; Power-SO8 plastic, single-ended surface-mounted package; 4 terminals SOT669 7. Marking Table 4. Marking codes Type number Marking code PSMN2R0-30YLE 2R030 PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 2 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 30 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 30 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 238 W ID drain current VGS = 10 V; Tmb = 100 °C; Fig. 2 [1] - 100 A VGS = 10 V; Tmb = 25 °C; Fig. 2 [1] - 100 A - 1015 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C - 100 A - 1015 A - 365 mJ Source-drain diode IS source current Tmb = 25 °C ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C [1] Avalanche ruggedness EDS(AL)S [1] non-repetitive drainID = 100 A; Vsup ≤ 30 V; RGS = 50 Ω; source avalanche energy VGS = 10 V; Tj(init) = 25 °C; unclamped; Fig. 4 Capped at 100A due to package 03aa16 120 Pder (%) 003aah010 300 ID (A) 250 80 200 150 40 100 (1) 50 0 0 50 100 150 Tmb (°C) 0 200 0 25 50 75 100 125 150 175 Tmb (°C) 200 (1) Capped at 100A due to package VGS ≥ 10 V Fig. 1. Normalized total power dissipation as a function of mounting base temperature PSMN2R0-30YLE Product data sheet Fig. 2. Continuous drain current as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 3 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK ID (A) 003aah012 104 103 Limit RDSon = VDS / ID tp = 10 us 102 100 us 1 ms DC 10 10 ms 100 ms 1 10-1 1 10 VDS (V) 102 Tmb = 25 °C; IDM is a single pulse Fig. 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage IAL (A) 003aaj896 103 102 (1) (2) 10 1 10-3 10-2 10-1 1 tAL (ms) 10 (1) Tj (init) = 25 °C; (2) Tj (init) = 100 °C Fig. 4. Single pulse avalanche rating; avalanche current as a function of avalanche time PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 4 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-mb) Conditions thermal resistance from Fig. 5 junction to mounting base Min Typ Max Unit - 0.55 0.63 K/W aaa-018010 1 Zth(j-mb) (K/W) δ = 0.5 10-1 0.2 0.1 0.05 10-2 0.02 P δ= single shot Fig. 5. 10-5 10-4 10-3 10-2 T t tp 10-3 10-6 tp T 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 5 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 175 °C; Fig. 10 0.5 - - V ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 10; Fig. 11 1.3 1.7 2.15 V ID = 1 mA; VDS=VGS; Tj = -55 °C; Fig. 10 - - 2.45 V VDS = 30 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA VDS = 30 V; VGS = 0 V; Tj = 100 °C - - 200 µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 12 - 1.7 2 mΩ VGS = 10 V; ID = 25 A; Tj = 100 °C; Fig. 12; Fig. 13 - - 2.8 mΩ VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 12 - 3 3.5 mΩ VGS = 10 V; ID = 25 A; Tj = 175 °C; Fig. 12; Fig. 13 - - 3.8 mΩ f = 1 MHz 0.3 0.6 1.2 Ω ID = 25 A; VDS = 15 V; VGS = 10 V; Fig. 14; Fig. 15 - 87 - nC ID = 25 A; VDS = 15 V; VGS = 4.5 V; Fig. 14; Fig. 15 - 41 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 79 - nC ID = 25 A; VDS = 15 V; VGS = 4.5 V; Fig. 14; Fig. 15 - 13.3 - nC - 8.1 - nC Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon RG drain leakage current gate leakage current drain-source on-state resistance gate resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gatesource charge QGS(th-pl) post-threshold gatesource charge - 5.2 - nC QGD gate-drain charge - 13.8 - nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 15 V; Fig. 14; Fig. 15 - 2.8 - V Ciss input capacitance - 5217 - pF Coss output capacitance VDS = 15 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 16 - 1015 - pF Crss reverse transfer capacitance - 474 - pF td(on) turn-on delay time - 32.7 - ns tr rise time - 55.7 - ns td(off) turn-off delay time - 41.5 - ns tf fall time - 29.5 - ns PSMN2R0-30YLE Product data sheet VDS = 15 V; RL = 0.6 Ω; VGS = 4.5 V; RG(ext) = 4.7 Ω; Tj = 25 °C All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 6 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 17 - 0.8 1.2 V trr reverse recovery time 42.6 - ns recovered charge IS = 25 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = 15 V - Qr - 49.8 - nC 003aah014 100 ID (A) 10 003aah015 8 VGS (V) = 3.5 4.5 RDSon (mΩ ) 80 6 60 4 3 40 2.8 20 2 2.6 2.4 0 Fig. 6. 0 0.5 1 1.5 0 2 VDS(V) 0 4 8 12 VGS (V) 16 Tj = 25 °C Tj = 25 °C; ID = 25 A Output characteristics; drain current as a Fig. 7. function of drain-source voltage; typical values Drain-source on-state resistance as a function of gate-source voltage; typical values 003aah016 150 gfs (S) 003aah017 200 ID (A) 120 150 90 100 60 50 30 Tj = 175 ° C Tj = 25 ° C 0 0 20 40 60 80 ID (A) 0 100 Tj = 25 °C; VDS = 10 V Fig. 8. Product data sheet 1 2 3 4 VGS (V) 5 VDS = 10 V Forward transconductance as a function of drain current; typical values PSMN2R0-30YLE 0 Fig. 9. Transfer characteristics; drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 7 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 003aaj515 3 003aaj514 10-1 ID (A) VGS(th) (V) 10-2 max 2 typ min 10-3 max typ 10-4 min 1 10-5 0 -60 0 60 120 Tj (°C) 10-6 180 Fig. 10. Gate-source threshold voltage as a function of junction temperature 2 V GS (V) 3 Fig. 11. Sub-threshold drain current as a function of gate-source voltage 003aah020 003aag820 2 VGS (V) = 3 2.8 1 Tj = 25 °C; VDS = 5 V ID = 1 mA; VDS = VGS 30 0 a RDSon (mΩ ) 1.5 20 1 10 3.5 0.5 4.5 0 10 10 30 50 70 ID (A) 0 -60 90 0 60 120 Tj (°C) 180 Tj = 25 °C Fig. 12. Drain-source on-state resistance as a function of drain current; typical values PSMN2R0-30YLE Product data sheet Fig. 13. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 8 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 003aah022 10 VGS (V) VDS 8 ID 24 V 6 VGS(pl) VDS = 15V 4 VGS(th) 6V VGS 2 QGS2 QGS1 QGS 0 QGD QG(tot) 60 80 100 QG (nC) 003aah024 100 IS (A) Ciss C (pF) 40 Fig. 15. Gate-source voltage as a function of gate charge; typical values 003aah023 104 20 Tj = 25 °C; ID = 25 A 003aaa508 Fig. 14. Gate charge waveform definitions 0 80 60 10 3 Coss 40 Tj = 150° C Crss 20 102 10-1 1 10 VDS (V) 0 102 VGS = 0 V; f = 1 MHz Tj = 25 °C 0 0.3 0.6 0.9 VSD (V) 1.2 VGS = 0 V Fig. 16. Input, output and reverse transfer capacitances Fig. 17. Source current as a function of source-drain as a function of drain-source voltage; typical voltage; typical values values PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 9 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 11. Package outline Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads E A2 A SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w b A X c 1/2 e A (A3) A1 C q L detail X 0 y C θ 5 mm 8° scale 0° Dimensions (mm are the original dimensions) Unit(1) mm A A1 A2 A3 b b2 max 1.20 0.15 1.10 0.50 4.41 nom 0.25 min 1.01 0.00 0.95 0.35 3.62 c c2 D(1) D1(1) E(1) E1(1) b3 b4 2.2 0.9 0.25 0.30 4.10 4.20 5.0 3.3 2.0 0.7 0.19 0.24 3.80 4.8 3.1 e 1.27 H L L1 L2 6.2 0.85 1.3 1.3 5.8 0.40 0.8 0.8 Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. Outline version SOT669 References IEC JEDEC JEITA w y 0.25 0.1 sot669_po European projection Issue date 11-03-25 13-02-27 MO-235 Fig. 18. Package outline LFPAK56; Power-SO8 (SOT669) PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 10 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 12. Soldering Footprint information for reflow soldering SOT669 4.7 4.2 0.9 (3×) 0.25 (2×) 0.25 (2×) 0.6 (4×) 3.45 0.6 (3×) 2 3.5 2.55 0.25 (2×) SR opening = Cu + 0.075 1.1 2.15 3.3 SP opening = Cu - 0.050 0.7 (4×) 1.27 3.81 solder lands solder paste 125 µm stencil solder resist occupied area Dimensions in mm sot669_fr Fig. 19. Reflow soldering footprint for LFPAK56; Power-SO8 (SOT669) PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 11 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK Wave soldering footprint information for LFPAK56 package SOT669 4.826 1.78 1.72 2.1 1.4 0.6 (x4) 1.27 0.635 solder lands Dimensions in mm Issue date 15-04-13 15-04-16 sot669_fw Fig. 20. Wave soldering footprint for LFPAK56; Power-SO8 (SOT669) PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 12 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK 13. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PSMN2R0-30YLE Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 13 / 14 PSMN2R0-30YLE Nexperia N-channel 30 V 2 mΩ logic level MOSFET in LFPAK Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 5 10. Characteristics............................................................ 6 11. Package outline........................................................ 10 12. Soldering................................................................... 11 13. Legal information......................................................13 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 June 2021 PSMN2R0-30YLE Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2021 © Nexperia B.V. 2021. All rights reserved 14 / 14
PSMN2R0-30YLE,115 价格&库存
很抱歉,暂时无法提供与“PSMN2R0-30YLE,115”相匹配的价格&库存,您可以联系我们找货
PSMN2R0-30YLE,115
    • 1+7.41960
    • 10+6.66360
    • 30+6.24240
    • 100+5.77800
    • 500+5.56200
    • 1500+5.46480
    库存:1491
