BSS192,135
BSS192,135
    NEXPERIA(安世)
    SOT89-3
    使用沟槽MOSFET的(SC-88)表面安装器件(SMD)塑料封装
BSS192,135 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia SO T8 9 BSS192 240 V, P-channel vertical D-MOS transistor 12 December 2014 Product data sheet 1. General description P-channel enhancement mode vertical Double-Diffused Field-Effect Transistor (DMOSFET) in a SOT89 (SC-62) medium power and flat lead Surface Mounted Device (SMD) plastic package. 2. Features and benefits • • • Direct interface to Complementary (C-MOS) transitor and Transistor-Transistor Logic (TTL) devices Very fast switching No secondary breakdown 3. Applications • • • • Relay driver High-speed line driver High-side loadswitch Switching circuits 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj = 25 °C - - -240 V VGS gate-source voltage -20 - 20 V ID drain current - - -200 mA - 10 12 Ω VGS = -10 V; Tamb = 25 °C [1] Static characteristics RDSon drain-source on-state resistance [1] VGS = -10 V; ID = -200 mA; Tj = 25 °C Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for 2 drain 1 cm . Scan or click this QR code to view the latest information for this product BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S source 2 D drain 3 G gate Simplified outline Graphic symbol D G 3 2 1 SOT89 S 017aaa257 6. Ordering information Table 3. Ordering information Type number BSS192 Package Name Description Version SOT89 plastic surface-mounted package; die pad for good heat transfer; SOT89 3 leads 7. Marking Table 4. Marking codes Type number Marking code BSS192 KB BSS192 Product data sheet All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 2 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - -240 V VGS gate-source voltage -20 20 V ID drain current VGS = -10 V; Tamb = 25 °C; t ≤ 5 s [1] - -340 mA VGS = -10 V; Tamb = 25 °C [1] - -200 mA VGS = -10 V; Tamb = 100 °C [1] - -120 mA - -800 mA [2] - 560 mW [1] - 1 W - 12.5 W IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs Ptot total power dissipation Tamb = 25 °C Tsp = 25 °C Tj junction temperature -55 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C - -200 mA Source-drain diode IS source current BSS192 Product data sheet Tamb = 25 °C [1] [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for [2] drain 1 cm . Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 3 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 017aaa123 120 Pder (%) Ider (%) 80 80 40 40 0 - 75 Fig. 1. 017aaa124 120 - 25 25 75 125 Tj (°C) 0 - 75 175 MOSFET transistor: Normalized total power dissipation as a function of junction temperature Fig. 2. - 25 25 75 125 Tj (°C) 175 MOSFET transistor: Normalized continuous drain current as a function of junction temperature aaa-014702 -1 tp = 100 µs Limit RDSon = VDS/ID ID (A) tp = 1 ms tp = 10 ms -10-1 tp = 100 ms DC; Tsp = 25 °C -10-2 DC; Tamb = 25 °C; drain mounting pad 1 cm2 -10-3 -10-1 -1 -10 -102 -103 VDS (V) IDM = single pulse Fig. 3. Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air BSS192 Product data sheet t≤5s All information provided in this document is subject to legal disclaimers. 12 December 2014 Min Typ Max Unit [1] - 194 225 K/W [2] - 108 125 K/W [2] - 37 42 K/W © NXP Semiconductors N.V. 2014. All rights reserved 4 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor Symbol Parameter Rth(j-sp) thermal resistance from junction to solder point [1] [2] Conditions Min Typ Max Unit - 4 10 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. aaa-014703 103 Zth(j-a) (K/W) 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 1 cm . duty cycle = 1 102 0.75 0.5 0.33 0.25 0.2 0.1 10 0.05 0.02 0.01 0 1 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-014704 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.33 0.2 10 0.5 0.25 0.1 0.05 0.01 0.02 0 1 10-3 10-2 10-1 FR4 PCB, mounting pad for drain 1 cm Fig. 5. 1 10 102 tp (s) 103 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BSS192 Product data sheet All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 5 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = -10 µA; VGS = 0 V; Tj = 25 °C -240 - - V VGSth gate-source threshold voltage ID = -1 mA; VDS = VGS; Tj = 25 °C -0.8 - -2.8 V IDSS drain leakage current VDS = -200 V; VGS = 0.2 V; Tj = 25 °C - -0.1 -60 µA VDS = -60 V; VGS = 0 V; Tj = 25 °C - - -200 nA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - -100 nA VGS = -10 V; ID = -200 mA; Tj = 25 °C - 10 12 Ω VGS = -10 V; ID = -200 mA; Tj = 150 °C - 21 25 Ω VGS = -4.5 V; ID = -100 mA; Tj = 25 °C - 13 18 Ω VDS = -10 V; ID = -200 mA; Tj = 25 °C - 200 - mS IGSS RDSon gfs gate leakage current drain-source on-state resistance forward transconductance Dynamic characteristics QG(tot) total gate charge VDS = -50 V; ID = -250 mA; VGS = -10 V; - 1.9 5 nC QGS gate-source charge Tj = 25 °C - 0.3 - nC QGD gate-drain charge - 0.6 - nC Ciss input capacitance VDS = -25 V; f = 1 MHz; VGS = 0 V; - 55 90 pF Coss output capacitance Tj = 25 °C - 20 30 pF Crss reverse transfer capacitance - 5 15 pF td(on) turn-on delay time VDS = -50 V; ID = -250 mA; VGS = -10 V; - 3.2 6 ns tr rise time RG(ext) = 6 Ω; Tj = 25 °C - 4.6 6 ns td(off) turn-off delay time - 11.7 20 ns tf fall time - 7 12 ns - 0.86 1.2 V Source-drain diode VSD source-drain voltage BSS192 Product data sheet IS = -200 mA; VGS = 0 V; Tj = 25 °C All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 6 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor aaa-014705 -1.0 VGS = -10 V ID (A) -0.8 aaa-014706 -10-3 ID (A) -6 V -10-4 -0.6 min -5 V -0.4 typ max -10-5 -4 V -0.2 -3 V 0 Fig. 6. 0 -4 -8 -12 -10-6 -16 -20 VDS (V) 0 -1 -2 VGS (V) -3 Tj = 25 °C Tj = 25 °C; VDS = -10 V Output characteristics: drain current as a Fig. 7. function of drain-source voltage; typical values Sub-threshold drain current as a function of gate-source voltage aaa-014707 40 RDSon aaa-014708 60 -4 V RDSon (Ω) 30 40 20 -5 V Tj = 150 °C 20 10 VGS = -10 V 0 0 -0.2 -0.4 -0.6 Tj = 25 °C -0.8 ID (A) 0 -1.0 Tj = 25 °C Fig. 8. Product data sheet -2 -4 -6 -8 -10 VGS (V) ID = -200 mA Drain-source on-state resistance as a function of drain current; typical values BSS192 0 Fig. 9. Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 7 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor aaa-014709 -1.0 aaa-014710 2.5 ID (A) a -0.8 2.0 Tj = 150 °C -0.6 1.5 Tj = 25 °C -0.4 1.0 -0.2 0.5 0 0 -2 -4 -6 -8 0 -60 -10 VGS (V) VDS > ID × RDSon Fig. 10. Transfer characteristics: drain current as a function of gate-source voltage; typical values aaa-014711 -3.2 VGS(th) (V) 0 60 120 180 Fig. 11. Normalized drain-source on-state resistance as a function of junction temperature; typical values aaa-014712 103 max Tj (°C) C (pF) -2.4 102 Ciss typ -1.6 Coss 10 min -0.8 Crss 0 -60 0 60 120 Tj (°C) 1 -10-1 180 ID = -1 mA; VDS = VGS Product data sheet -10 VDS (V) -102 f = 1 MHz; VGS = 0 V Fig. 12. Gate-source threshold voltage as a function of junction temperature BSS192 -1 Fig. 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 8 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor aaa-014713 -10 VDS VGS (V) ID -8 VGS(pl) -6 VGS(th) VGS -4 QGS1 QGS2 QGS -2 QGD QG(tot) 017aaa137 0 0 0.5 1 1.5 QG (nC) Fig. 15. MOSFET transistor: Gate charge waveform definitions 2 ID = -0.25 A; VDS = -50 V; Tamb = 25 °C Fig. 14. Gate-source voltage as a function of gate charge; typical values aaa-014714 -1.0 IS (A) -0.8 Tj = 150 °C -0.6 -0.4 -0.2 0 Tj = 25 °C 0 -0.4 -0.8 -1.2 VSD (V) -1.6 VGS = 0 V Fig. 16. Source current as a function of source-drain voltage; typical values 11. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 17. Duty cycle definition BSS192 Product data sheet All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 9 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 12. Package outline Plastic surface-mounted package; exposed die pad for good heat transfer; 3 leads SOT89 B D A bp3 E 1 2 HE Lp 3 c bp2 w M B bp1 e1 e 0 2 4 mm scale DIMENSIONS (mm are the original dimensions) UNIT A bp1 bp2 bp3 c D E e e1 HE Lp w mm 1.6 1.4 0.48 0.35 0.53 0.40 1.8 1.4 0.44 0.23 4.6 4.4 2.6 2.4 3.0 1.5 4.25 3.75 1.2 0.8 0.13 OUTLINE VERSION REFERENCES IEC SOT89 JEDEC JEITA TO-243 SC-62 EUROPEAN PROJECTION ISSUE DATE 06-03-16 06-08-29 Fig. 18. Package outline SOT89 BSS192 Product data sheet All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 10 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 13. Soldering 4.75 2.25 2 1.9 1.2 0.2 0.85 solder lands 1.7 1.2 4.6 solder resist 0.5 1 (3×) 4.85 occupied area 1.1 (2×) 1.5 solder paste Dimensions in mm 1.5 0.6 (3×) 0.7 (3×) 3.95 sot089_fr Fig. 19. Reflow soldering footprint for SOT89 6.6 2.4 3.5 solder lands 7.6 0.5 solder resist occupied area 1.8 (2×) Dimensions in mm preferred transport direction during soldering 1.9 1.5 (2×) 1.9 0.7 5.3 sot089_fw Fig. 20. Wave soldering footprint for SOT89 BSS192 Product data sheet All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 11 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BSS192 v.4 20141212 Product data sheet - BSS192 v.3 Modifications: • • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors Legal texts have been adapted to the new company name where appropriate BSS192 v.3 20021120 - BSS192 v.2 BSS192 v.2 20020522 - BSS192 v.1 BSS192 v.1 19970620 BSS192 Product data sheet - All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 12 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 15. Legal information 15.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. BSS192 Product data sheet Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 13 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Bitsound, CoolFlux, CoReUse, DESFire, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, MIFARE, MIFARE Plus, MIFARE Ultralight, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP Semiconductors N.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. BSS192 Product data sheet All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 14 / 15 BSS192 NXP Semiconductors 240 V, P-channel vertical D-MOS transistor 16. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 6 11 Test information ..................................................... 9 12 Package outline ................................................... 10 13 Soldering .............................................................. 11 14 Revision history ................................................... 12 15 15.1 15.2 15.3 15.4 Legal information .................................................13 Data sheet status ............................................... 13 Definitions ...........................................................13 Disclaimers .........................................................13 Trademarks ........................................................ 14 © NXP Semiconductors N.V. 2014. All rights reserved For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 12 December 2014 BSS192 Product data sheet All information provided in this document is subject to legal disclaimers. 12 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 15 / 15
BSS192,135 价格&库存
很抱歉,暂时无法提供与“BSS192,135”相匹配的价格&库存,您可以联系我们找货
