PMPB15XN,115
PMPB15XN,115
    NEXPERIA(安世)
    DFN2020MD-6
    MOS管 N-channel Id=10.4A VDS=20V DFN2020MD-6
PMPB15XN,115 数据手册
PMPB15XN 20 V, single N-channel Trench MOSFET 13 September 2012 Product data sheet 1. Product profile 1.1 General description N-channel enhancement mode Field-Effect Transistor (FET) in a leadless medium power DFN2020MD-6 (SOT1220) Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology. 1.2 Features and benefits • Trench MOSFET technology • Small and leadless ultra thin SMD plastic package: 2 x 2 x 0.65 mm • Exposed drain pad for excellent thermal conduction • Tin-plated 100 % solderable side pads for optical solder inspection 1.3 Applications • Charging switch for portable devices • DC-to-DC converters • Power management in battery-driven portable devices • Hard disk and computing power management 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj = 25 °C - - 20 V VGS gate-source voltage -12 - 12 V ID drain current - - 10.4 A - 18 21 mΩ VGS = 4.5 V; Tamb = 25 °C; t ≤ 5 s [1] Static characteristics RDSon drain-source on-state resistance [1] VGS = 4.5 V; ID = 7.3 A; Tj = 25 °C Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for 2 drain 6 cm . PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 D drain 2 D drain 3 G gate 4 S source 5 D drain 6 D drain 7 D drain 8 S source Simplified outline 1 Graphic symbol D 6 7 2 3 8 5 G 4 S 017aaa253 Transparent top view DFN2020MD-6 (SOT1220) 3. Ordering information Table 3. Ordering information Type number Package Name PMPB15XN Description Version DFN2020MD-6 plastic thermal enhanced ultra thin small outline package; no leads; 6 terminals SOT1220 4. Marking Table 4. Marking codes Type number Marking code PMPB15XN 1J 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - 20 V VGS gate-source voltage -12 12 V ID drain current VGS = 4.5 V; Tamb = 25 °C; t ≤ 5 s [1] - 10.4 A VGS = 4.5 V; Tamb = 25 °C [1] - 7.3 A VGS = 4.5 V; Tamb = 100 °C [1] - 4.6 A - 24 A - 1.7 W IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs Ptot total power dissipation Tamb = 25 °C PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 [1] © Nexperia B.V. 2017. All rights reserved 2 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET Symbol Parameter Conditions Tamb = 25 °C; t ≤ 5 s [1] Tsp = 25 °C Min Max Unit - 3.5 W - 12.5 W Tj junction temperature -55 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C - 2 A Source-drain diode IS source current [1] Tamb = 25 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for 2 drain 6 cm . 017aaa123 120 Pder (%) Ider (%) 80 80 40 40 0 - 75 Fig. 1. 017aaa124 120 - 25 25 75 125 Tj (°C) Normalized total power dissipation as a function of junction temperature PMPB15XN Product data sheet 0 - 75 175 Fig. 2. - 25 75 125 Tj (°C) 175 Normalized continuous drain current as a function of junction temperature All information provided in this document is subject to legal disclaimers. 13 September 2012 25 © Nexperia B.V. 2017. All rights reserved 3 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 017aaa794 102 ID (A) Limit RDSon = VDS/ID 10 tp = 100 µs tp = 1 ms 1 tp = 10 ms DC; Tsp = 25 °C tp = 100 ms DC; Tamb = 25 °C; drain mounting pad 6 cm2 10-1 10-2 10-2 10-1 1 10 102 VDS (V) IDM = single pulse Fig. 3. Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) in free air; t ≤ 5 s thermal resistance from junction to solder point [1] [2] PMPB15XN Product data sheet Min Typ Max Unit [1] - 235 270 K/W [2] - 67 74 K/W [2] - 33 36 K/W - 5 10 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm . All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 4 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 017aaa542 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.5 0.33 0.25 0.2 0.1 10 0.05 0.02 0.01 0 1 10-3 10-2 10-1 1 102 10 103 tp (s) FR4 PCB, standard footprint Fig. 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 017aaa543 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 10 0.25 0.2 0.1 0.05 0.02 0.01 0 1 10-3 10-2 10-1 FR4 PCB, mounting pad for drain 6 cm Fig. 5. 1 102 10 103 tp (s) 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 20 - - V VGSth gate-source threshold voltage ID = 250 µA; VDS = VGS; Tj = 25 °C 0.4 0.65 0.9 V IDSS drain leakage current VDS = 20 V; VGS = 0 V; Tj = 25 °C - - 1 µA IGSS gate leakage current VGS = -12 V; VDS = 0 V; Tj = 25 °C - - -100 nA PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 5 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET Symbol Parameter RDSon drain-source on-state resistance Conditions Min Typ Max Unit VGS = 12 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 7.3 A; Tj = 25 °C - 18 21 mΩ VGS = 4.5 V; ID = 7.3 A; Tj = 150 °C - 27 32 mΩ VGS = 2.5 V; ID = 6.4 A; Tj = 25 °C - 21 27 mΩ VGS = 1.8 V; ID = 2.1 A; Tj = 25 °C - 23 41 mΩ gfs forward transconductance VDS = 10 V; ID = 7.3 A; Tj = 25 °C - 30 - S RG gate resistance f = 1 MHz - 2 - Ω Dynamic characteristics QG(tot) total gate charge VDS = 10 V; ID = 7.3 A; VGS = 4.5 V; - 13.4 20.2 nC QGS gate-source charge Tj = 25 °C - 1.5 - nC QGD gate-drain charge - 2.6 - nC Ciss input capacitance VDS = 10 V; f = 1 MHz; VGS = 0 V; - 1240 - pF Coss output capacitance Tj = 25 °C - 145 - pF Crss reverse transfer capacitance - 125 - pF td(on) turn-on delay time VDS = 10 V; ID = 7.3 A; VGS = 4.5 V; - 9 - ns tr rise time RG(ext) = 6 Ω; Tj = 25 °C - 24 - ns td(off) turn-off delay time - 31 - ns tf fall time - 36 - ns - 0.7 1.2 V Source-drain diode VSD source-drain voltage 28 4.5 V ID (A) 24 IS = 2 A; VGS = 0 V; Tj = 25 °C 017aaa795 2.5 V 2.1 V 2V 017aaa796 10-2 ID (A) VGS = 1.8 V 10-3 20 1.6 V 16 min typ max 10-4 12 1.4 V 8 10-5 1.2 V 4 0 Fig. 6. 0 1 2 3 VDS (V) 4 10-6 0 0.4 0.8 VGS (V) 1.2 Tj = 25 °C Tj = 25 °C; VDS = 5 V Output characteristics: drain current as a Fig. 7. function of drain-source voltage; typical values Sub-threshold drain current as a function of gate-source voltage PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 6 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 017aaa797 0.1 1.5 V 1.6 V 1.7 V 1.8 V RDSon (Ω) RDSon (Ω) 0.8 0.08 0.6 0.06 0.4 0 0.04 2.2 V 2.5 V 0.2 8 16 ID (A) 0 24 Tj = 25 °C Fig. 8. Tj = 150 °C 0.02 VGS = 4.5 V 0 017aaa798 0.10 2V Tj = 25 °C 0 1 2 3 4 VGS (V) 5 ID = 6 A Drain-source on-state resistance as a function of drain current; typical values 017aaa799 24 Fig. 9. Drain-source on-state resistance as a function of gate-source voltage; typical values 017aaa800 1.50 a ID (A) 1.25 16 1.00 8 0.75 0 Tj = 150 °C Tj = 25 °C 1 2 0 VGS (V) 0.50 -60 3 VDS > ID × RDSon Fig. 10. Transfer characteristics: drain current as a function of gate-source voltage; typical values PMPB15XN Product data sheet 0 60 120 Tj (°C) 180 Fig. 11. Normalized drain-source on-state resistance as a function of junction temperature; typical values All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 7 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 017aaa801 1.5 017aaa802 104 C (pF) VGS(th) (V) Ciss 103 1.0 max typ 0.5 Coss 102 Crss min 0 -75 -25 25 75 125 Tj (°C) 10 10-1 175 ID = 0.25 mA; VDS = VGS 1 10 VDS (V) 102 f = 1 MHz; VGS = 0 V Fig. 12. Gate-source threshold voltage as a function of junction temperature Fig. 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 017aaa803 4.5 VDS VGS (V) ID 3.0 VGS(pl) VGS(th) VGS 1.5 QGS1 QGS2 QGS QGD QG(tot) 017aaa137 0 0 5 10 QG (nC) Fig. 15. Gate charge waveform definitions 15 ID = 6 A; VDS = 10 V; Tamb = 25 °C Fig. 14. Gate-source voltage as a function of gate charge; typical values PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 8 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 017aaa804 2.0 IS (A) 1.5 1.0 0.5 Tj = 150 °C 0 0 0.2 Tj = 25 °C 0.4 0.6 0.8 1.0 VDS (V) VGS = 0 V Fig. 16. Source current as a function of source-drain voltage; typical values 8. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 17. Duty cycle definition 9. Package outline 0.51 0.61 0.2 0.3 1.9 2.1 1.0 1.2 0.2 0.3 3 4 2 5 1 6 1.1 1.3 1.9 2.1 Dimensions in mm 0.25 0.35 0.65 12-04-30 Fig. 18. Package outline DFN2020MD-6 (SOT1220) PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 9 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 10. Soldering Footprint information for reflow soldering of DFN2020MD-6 package 0.33 (6×) SOT1220 0.76 0.43 (6×) 0.66 0.53 (6×) 0.56 0.25 0.35 0.45 0.775 0.65 2.06 0.285 1.25 1.35 0.35 (6×) 1.05 0.25 (6×) 0.65 0.45 (6×) 0.9 1.1 1.2 0.935 0.935 2.5 solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sot1220_fr Fig. 19. Reflow soldering footprint for DFN2020MD-6 (SOT1220) PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 10 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 11. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMPB15XN v.1 20120913 Product data sheet - - PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 11 / 12 PMPB15XN Nexperia 20 V, single N-channel Trench MOSFET 13. Contents 1 1.1 1.2 1.3 1.4 Product profile ....................................................... 1 General description .............................................. 1 Features and benefits ...........................................1 Applications .......................................................... 1 Quick reference data ............................................ 1 2 Pinning information ............................................... 2 3 Ordering information ............................................. 2 4 Marking ................................................................... 2 5 Limiting values .......................................................2 6 Thermal characteristics .........................................4 7 Characteristics ....................................................... 5 8 Test information ..................................................... 9 9 Package outline ..................................................... 9 10 Soldering .............................................................. 10 11 Revision history ................................................... 11 12 12.1 12.2 12.3 12.4 Legal information ............................................ Data sheet status ........................................... Definitions ...................................................... Disclaimers .................................................... Trademarks ................................................... © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 September 2012 PMPB15XN Product data sheet All information provided in this document is subject to legal disclaimers. 13 September 2012 © Nexperia B.V. 2017. All rights reserved 12 / 12
PMPB15XN,115 价格&库存
很抱歉,暂时无法提供与“PMPB15XN,115”相匹配的价格&库存,您可以联系我们找货
