BUK7M17-80E
N-channel 80 V, 17 mΩ standard level MOSFET in LFPAK33
19 September 2016
Product data sheet
1. General description
Standard level N-channel MOSFET in an LFPAK33 (Power33) package using
TrenchMOS technology. This product has been designed and qualified to AEC Q101
standard for use in high performance automotive applications.
2. Features and benefits
Q101 Compliant
Repetitive avalanche rated
Suitable for thermally demanding environments due to 175 °C rating
True standard level gate with VGS(th) rating of greater than 1 V at 175 °C
3. Applications
12 V, 24 V and 48 V automotive systems
Motors, lamps and solenoid control
Transmission control
Ultra high performance power switching
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
80
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 2
43
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
79
W
VGS = 10 V; ID = 10 A; Tj = 25 °C;
14
17
mΩ
9.7
nC
Static characteristics
RDSon
drain-source on-state
resistance
Fig. 11
Dynamic characteristics
QGD
gate-drain charge
ID = 10 A; VDS = 64 V; VGS = 10 V;
Tj = 25 °C; Fig. 13; Fig. 14
BUK7M17-80E
Nexperia
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
S
Source
2
S
Source
3
S
Source
4
G
Gate
mb
D
Mounting base; connected to
drain
Graphic symbol
D
G
mbb076
1
2
3
S
4
LFPAK33 (SOT1210)
6. Ordering information
Table 3.
Type number
Package
BUK7M17-80E
Name
Description
Version
LFPAK33
Plastic single ended surface mounted package
(LFPAK33); 8 leads
SOT1210
7. Marking
Table 4.
Marking codes
Type number
Marking code
BUK7M17-80E
71780E
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
80
V
VDGR
drain-gate voltage
RGS = 20 kΩ
80
V
VGS
gate-source voltage
DC; Tj ≤ 175 °C
-20
V
Ptot
Tmb = 25 °C; Fig. 1
79
W
ID
drain current
43
A
VGS = 10 V; Tmb = 100 °C; Fig. 2
30
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3
173
A
-55
175
°C
IDM
peak drain current
Tstg
storage temperature
BUK7M17-80E
Product data sheet
All information provided in this document is subject to legal disclaimers.
19 September 2016
Nexperia B.V. 2017. All rights reserved
2 / 13
BUK7M17-80E
Nexperia
Symbol
Parameter
Conditions
Tj
junction temperature
Min
Max
Unit
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
43
A
ISM
peak source current
173
A
47.4
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
ID = 43 A; Vsup ≤ 80 V; RGS = 50 Ω;
[1][2]
VGS = 10 V; Tj(init) = 25 °C; unclamped;
Fig. 4
[1]
[2]
Single-pulse avalanche rating limited by maximum junction temperature of 175 °C.
Refer to application note AN10273 for further information.
03aa16
120
ID
(A)
Pder
aaa-020893
50
40
80
30
10
Fig. 1.
100
150
Tmb (°C)
Normalized total power dissipation as a
function of mounting base temperature
BUK7M17-80E
Product data sheet
50
75
100
125
150 175
Tmb (°C)
200
VGS ≥ 10 V
Fig. 2.
Continuous drain current as a function of
19 September 2016
3 / 13
BUK7M17-80E
Nexperia
ID
(A)
aaa-020895
103
Limit RDSon = VDS / ID
102
tp = 10 us
10
100 us
DC
1
10-1
1 ms
10 ms
100 ms
1
102
10
103
VDS (V)
Tmb = 25 °C; IDM is a single pulse
Fig. 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
IAL
(A)
aaa-020894
102
(1)
10
(2)
1
(3)
10-1
10-2
10-3
10-2
10-1
1
tAL (ms)
10
(1) Tj (init) = 25 °C; (2) Tj (init) = 150 °C; (3) Repetitive Avalanche
Fig. 4.
Avalanche rating; avalanche current as a function of avalanche time
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 5
1.58
1.89
K/W
BUK7M17-80E
Product data sheet
19 September 2016
4 / 13
BUK7M17-80E
Nexperia
aaa-020896
10
Zth(j-mb)
(K/W)
1 δ = 0.5
0.2
0.1
10-1 0.05
0.02
P
single shot
δ=
10-2
Fig. 5.
10-5
10-4
10-3
10-2
T
t
tp
10-3
10-6
tp
T
10-1
1
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
80
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
72
V
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
2.4
3
4
V
4.5
V
1
V
VDS = 80 V; VGS = 0 V; Tj = 25 °C
0.01
1
µA
VDS = 80 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
14
17
mΩ
43
mΩ
V(BR)DSS
VGS(th)
Fig. 9; Fig. 10
ID = 1 mA; VDS = VGS; Tj = -55 °C;
Fig. 9
ID = 1 mA; VDS = VGS; Tj = 175 °C;
Fig. 9
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
resistance
Fig. 11
VGS = 10 V; ID = 10 A; Tj = 175 °C;
Fig. 12
QG(tot)
total gate charge
29.6
nC
QGS
gate-source charge
6.5
nC
QGD
gate-drain charge
9.7
nC
BUK7M17-80E
Product data sheet
19 September 2016
5 / 13
BUK7M17-80E
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Ciss
input capacitance
VDS = 25 V; VGS = 0 V; f = 1 MHz;
1527
2031
pF
Coss
output capacitance
Tj = 25 °C; Fig. 15
161
193
pF
Crss
reverse transfer
capacitance
97
133
pF
td(on)
turn-on delay time
VDS = 60 V; RL = 5 Ω; VGS = 10 V;
6.7
ns
tr
rise time
RG(ext) = 5 Ω; Tj = 25 °C
9.4
ns
td(off)
turn-off delay time
22.3
ns
tf
fall time
12
ns
IS = 10 A; VGS = 0 V; Tj = 25 °C; Fig. 16
0.81
1.2
V
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
IS = 10 A; dIS/dt = -100 A/µs; VGS = 0 V;
26
ns
recovered charge
VDS = 25 V; Tj = 25 °C
33.9
nC
Qr
ID
(A)
aaa-020897
50
20 V
6V
10 V
40
80
VGS = 5.5 V
7V
aaa-020898
100
RDSon
(mΩ)
30
60
5V
4.5 V
10
4V
Fig. 6.
2
3
VDS (V)
10
15
VGS (V)
Tj = 25 °C
Tj = 25 °C; ID = 10 A
Output characteristics; drain current as a
Fig. 7.
function of drain-source voltage; typical values
Drain-source on-state resistance as a function
of gate-source voltage; typical values
BUK7M17-80E
Product data sheet
19 September 2016
6 / 13
BUK7M17-80E
Nexperia
ID
(A)
aaa-020899
40
003aah027
5
VGS(th)
(V)
max
4
30
3
typ
2
min
175°C
2
3
1
Tj = 25°C
4
5
VGS (V)
6
VDS = 12 V
Fig. 8.
60
120
T j (°C)
180
ID = 1 mA ; VDS = VGS
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
003aah028
10-1
Fig. 9.
Gate-source threshold voltage as a function of
aaa-020900
100
RDSon
(mΩ)
ID
(A)
10-2
4.5 V
5V
5.5 V
80
min
10-3
typ
max
60
10-4
40
10-5
4
VGS (V)
Fig. 10. Sub-threshold drain current as a function of
gate-source voltage
Product data sheet
20 V
VGS = 10 V
8V
30
6.5 V
40
ID (A)
50
Tj = 25 °C
Tj = 25 °C; VDS = 5 V
BUK7M17-80E
6V
Fig. 11. Drain-source on-state resistance as a function
of drain current; typical values
19 September 2016
7 / 13
BUK7M17-80E
Nexperia
003aaj817
3
VGS
(V)
a
aaa-020901
10
8
2.4
VDS = 14 V
1.8
6
1.2
4
0.6
2
120
Tj ( °C)
Fig. 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
64 V
10
15
QG (nC)
Fig. 13. Gate-source voltage as a function of gate
charge; typical values
aaa-020902
104
C
(pF)
VDS
ID
30
Ciss
103
VGS(pl)
VGS(th)
VGS
Coss
QGS2
QGS1
QGS
102
Crss
QGD
QG(tot)
003aaa508
Fig. 14. Gate charge waveform definitions
10
10-1
1
10
VDS (V)
102
Fig. 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
BUK7M17-80E
Product data sheet
19 September 2016
8 / 13
BUK7M17-80E
Nexperia
IS
(A)
aaa-020903
80
60
40
175°C
0.4
0.6
Tj = 25°C
0.8
1
VSD (V)
1.2
VGS = 0 V
Fig. 16. Source-drain (diode forward) current as a function of source-drain (diode forward) voltage; typical values
11. Application information
For guidance on how to use and understand this datasheet, please refer to application
note AN11158 "Understanding power MOSFET datasheet parameters".
BUK7M17-80E
Product data sheet
19 September 2016
9 / 13
BUK7M17-80E
Nexperia
12. Package outline
Plastic single ended surface mounted package (LFPAK33); 8 leads
E
A
e1
A
c1
b1
L1
SOT1210
D2
mounting
base
D1
(D)
H
E1
L
1
4
b
e
w
A
A1
C
X
c
Lp
y C
detail X
5 mm
scale
Dimensions
Unit(1)
A
A1
b(1)
max 0.90 0.10 0.35
nom
min 0.80 0.00 0.25
mm
b1(1)
c
c1
2.4
0.20 0.30
2.2
0.10 0.20
D ref
2.60
D1
2.35
1.90
D2
0.50
E(1)
E1
3.40 2.45
3.20 2.00
e
e1
0.65 0.65
H
L
L1
Lp
3.40
0.65 0.25 0.50
3.20
0.45 0.13 0.30
w
0.20 0.10
Note
1. Plastic or metal protrusions of 0.15 mm per side are not included.
Outline
version
sot1210_po
References
IEC
JEDEC
y
JEITA
European
projection
Issue date
14-04-25
16-08-09
SOT1210
Fig. 17. Package outline LFPAK33 (SOT1210)
BUK7M17-80E
Product data sheet
19 September 2016
10 / 13
BUK7M17-80E
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
13. Legal information
13.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
13.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
BUK7M17-80E
Product data sheet
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
19 September 2016
11 / 13
BUK7M17-80E
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
13.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BUK7M17-80E
Product data sheet
19 September 2016
12 / 13
BUK7M17-80E
Nexperia
14. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................2
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 5
11
Application information .........................................9
12
Package outline ................................................... 10
13
13.1
13.2
13.3
13.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 19 September 2016
BUK7M17-80E
Product data sheet
19 September 2016
13 / 13
