PSMN012-80PS,127
PSMN012-80PS,127
    NEXPERIA(安世)
    SOT78
    MOS管 N-channel Id=74A VDS=80V SOT78
PSMN012-80PS,127 数据手册
PSMN012-80PS N-channel 80 V 11 mΩ standard level MOSFET Rev. 02 — 25 June 2009 Product data sheet 1. Product profile 1.1 General description Standard level N-channel MOSFET in TO220 package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits „ High efficiency due to low switching and conduction losses „ Suitable for standard level gate drive sources 1.3 Applications „ DC-to-DC converters „ Motor control „ Load switching „ Server power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 80 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 - - 74 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 148 W VGS = 10 V; ID = 25 A; VDS = 40 V; see Figure 14; see Figure 15 - 9.4 - nC - 9 11 mΩ Dynamic characteristics QGD gate-drain charge Static characteristics RDSon [1] drain-source on-state resistance Measured 3 mm from package. VGS = 10 V; ID = 15 A; Tj = 25 °C; [1] PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 SOT78 (TO-220AB; SC-46) 3. Ordering information Table 3. Ordering information Type number Package Name Description PSMN012-80PS TO-220AB; SC-46 plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78 TO-220AB Version © PSMN012-80PS_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 2 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 80 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ VGS gate-source voltage ID drain current - 80 V -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 - 52 A VGS = 10 V; Tmb = 25 °C; see Figure 1 - 74 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 - 295 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 148 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 74 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 295 A - 100 mJ Avalanche ruggedness non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 74 A; Vsup ≤ 80 V; drain-source avalanche RGS = 50 Ω; unclamped energy EDS(AL)S 003aad009 80 ID (A) 03aa16 120 Pder (%) 60 80 40 40 20 0 0 0 Fig 1. 50 100 150 Tmb (°C) 200 0 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature © PSMN012-80PS_2 Product data sheet 50 Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 3 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 003aad300 103 ID (A) 10 μs Limit RDSon = VDS / ID 102 100 μs 10 1 ms 10 ms DC 1 10-1 1 Fig 3. 100 ms 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Rth(j-mb) thermal resistance from see Figure 4 junction to mounting base Min Typ Max Unit - 0.65 1 K/W 003aad007 1 Zth(j-mb) δ = 0.5 (K/W) 0.2 10-1 0.1 0.05 0.02 10-2 δ= P tp T 10-3 single shot t tp T 10 Fig 4. -4 10-6 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration; typical values © PSMN012-80PS_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 4 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon drain-source breakdown voltage gate-source threshold voltage drain leakage current gate leakage current drain-source on-state resistance ID = 250 µA; VGS = 0 V; Tj = -55 °C 73 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 80 - - V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 11; see Figure 12 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 11; see Figure 12 - - 4.6 V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 11; see Figure 12 2 3 4 V VDS = 80 V; VGS = 0 V; Tj = 25 °C - - 3 µA VDS = 80 V; VGS = 0 V; Tj = 125 °C - - 60 µA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 13 - - 18 mΩ - 9 11 mΩ - 0.97 - Ω ID = 0 A; VDS = 0 V; VGS = 10 V - 36 - nC ID = 25 A; VDS = 40 V; VGS = 10 V; see Figure 14; see Figure 15 - 43 - nC ID = 25 A; VDS = 40 V; VGS = 10 V; see Figure 14; see Figure 15 - 12 - nC - 8 - nC VGS = 10 V; ID = 15 A; Tj = 25 °C RG internal gate resistance f = 1 MHz (AC) [2] Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gate-source charge QGS(th-pl) post-threshold gate-source charge - 4 - nC QGD gate-drain charge - 9.4 - nC VGS(pl) gate-source plateau voltage VDS = 40 V - 4.5 - V Ciss input capacitance - 2782 - pF Coss output capacitance VDS = 12 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 16 - 384 - pF Crss reverse transfer capacitance - 162 - pF td(on) turn-on delay time - 19 - ns tr rise time - 16 - ns td(off) turn-off delay time - 33 - ns tf fall time - 6 - ns VDS = 12 V; RL = 0.5 Ω; VGS = 10 V; RG(ext) = 4.7 Ω © PSMN012-80PS_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 5 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 17 - 0.86 1.2 V trr reverse recovery time - 45 - ns Qr recovered charge IS = 50 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = 40 V - 64 - nC [1] Tested to JEDEC standards where applicable. [2] Measured 3 mm from package. 003aad029 250 ID (A) 200 10 003aad030 25 VGS (V) = 15 RDSon (mΩ) 7 6.5 5.5 5 6 10 7 20 6 150 5.5 15 100 5 10 50 VGS (V) = 15 4.5 5 0 0 Fig 5. 2 4 6 8 Output characteristics: drain current as a function of drain-source voltage; typical values 003aad031 100 0 10 VDS (V) Fig 6. 50 100 150 200 ID (A) 250 Drain-source on-state resistance as a function of drain current; typical values 003aad035 4000 ID (A) Ciss 80 C (pF) 60 3000 40 Tj = 175 °C 20 25 °C Crss 0 2000 0 Fig 7. 1 2 3 4 5 6 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; typical values 2 Fig 8. 6 8 VGS (V) 10 Input and reverse transfer capacitances as a function of gate-source voltage; typical values © PSMN012-80PS_2 Product data sheet 4 Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 6 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 003aad036 120 gfs (S) 100 003aad038 25 RDSon (mΩ) 20 80 60 15 40 10 20 0 5 0 Fig 9. 20 40 60 80 ID (A) 100 Forward transconductance as a function of drain current; typical values 03aa35 10−1 ID (A) 0 5 10 15 VGS (V) 20 Fig 10. Drain-source on-state resistance as a function of gate-source voltage; typical values 003aad280 5 VGS(th) (V) min 10−2 typ max 4 10−3 3 10−4 2 10−5 1 10−6 0 2 4 6 VGS (V) Fig 11. Sub-threshold drain current as a function of gate-source voltage 0 −60 typ min 0 60 120 180 Tj (°C) Fig 12. Gate-source threshold voltage as a function of junction temperature © PSMN012-80PS_2 Product data sheet max Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 7 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 003aad045 2.5 VDS a ID 2.0 VGS(pl) 1.5 VGS(th) VGS 1.0 QGS1 QGS2 QGS 0.5 QGD QG(tot) 003aaa508 0.0 -60 -30 0 30 60 90 120 150 180 Tj (°C) Fig 14. Gate charge waveform definitions Fig 13. Normalized drain-source on-state resistance factor as a function of junction temperature 003aad033 10 VGS (V) 8 003aad034 104 Ciss C (pF) VDS = 40 V 6 Coss 103 4 Crss 2 0 0 10 20 30 40 50 QG (nC) Fig 15. Gate-source voltage as a function of gate charge; typical values 102 10-1 10 VDS (V) 102 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values © PSMN012-80PS_2 Product data sheet 1 Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 8 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 003aad032 100 IS (A) 80 60 40 175 °C 20 Tj = 25 °C 0 0 0.3 0.6 0.9 VSD (V) 1.2 Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values © PSMN012-80PS_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 9 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 18. Package outline SOT78 (TO-220AB) © PSMN012-80PS_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 10 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN012-80PS_2 20090625 Product data sheet - PSMN012-80PS_1 - - Modifications: PSMN012-80PS_1 • Various changes to content. 20090609 Product data sheet © PSMN012-80PS_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 11 of 13 PSMN012-80PS Nexperia N-channel 80 V 11 mΩ standard level MOSFET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © PSMN012-80PS_2 Product data sheet Rev. 02 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia PSMN012-80PS N-channel 80 V 11 mΩ standard level MOSFET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 June 2009
PSMN012-80PS,127 价格&库存
很抱歉,暂时无法提供与“PSMN012-80PS,127”相匹配的价格&库存,您可以联系我们找货
PSMN012-80PS,127
  • 1+10.642691+1.37860
  • 10+10.1192810+1.31080
  • 25+9.1596925+1.18650
  • 50+8.7235250+1.13000
库存:165
PSMN012-80PS,127
  • 1+9.83394
  • 10+9.39075
  • 25+8.50438
  • 50+8.07317
库存:165
