PH2520U
N-channel TrenchMOS ultra low level FET
Rev. 03 — 2 March 2009
Product data sheet
1. Product profile
1.1 General description
Ultra low level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Higher operating power due to low
thermal resistance
Low conduction losses due to low
on-state resistance
Interfaces directly with low voltage
gate drivers
1.3 Applications
DC-to-DC convertors
Portable equipment
Notebook computers
Switched-mode power supplies
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C
V
ID
drain current
Tmb = 25 °C; VGS = 4.5 V;
see Figure 1; see Figure 3
100
A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
62.5
W
VGS = 4.5 V; ID = 50 A;
VDS = 10 V; Tj = 25 °C;
see Figure 11; see Figure 12
18
nC
VGS = 4.5 V; ID = 25 A;
Tj = 25 °C; see Figure 9;
see Figure 10
2.1
2.7
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
drain-source
on-state resistance
PH2520U
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
S
source
2
S
source
3
S
source
4
G
gate
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
S
mbb076
1 2 3 4
SOT669
(LFPAK)
3. Ordering information
Table 3.
Type number
Package
Name
Description
PH2520U
LFPAK
plastic single-ended surface-mounted package (LFPAK); 4 leads
Version
SOT669
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
V
VDGR
drain-gate voltage
Tj ≥ 25 °C; Tj ≤ 150 °C; RGS = 20 kΩ
V
VGS
gate-source voltage
-10
10
V
ID
drain current
VGS = 4.5 V; Tmb = 100 °C; see Figure 1
73
A
VGS = 4.5 V; Tmb = 25 °C; see Figure 1;
see Figure 3
100
A
300
A
IDM
peak drain current
tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3
Ptot
total power dissipation
62.5
W
Tstg
storage temperature
-55
150
°C
Tj
junction temperature
-55
150
°C
Source-drain diode
IS
source current
Tmb = 25 °C
52
A
ISM
peak source current
150
A
250
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive
VGS = 10 V; Tj = 25 °C; ID = 70.7 A; RGS = 50 Ω;
drain-source avalanche Vsup ≤ 20 V; tp = 0.1 ms; unclamped
energy
PH2520U_3
Product data sheet
2 of 12
Nexperia B.V. 2017. All rights reserved
PH2520U
Nexperia
003aab131
120
03aa15
120
Ider
Pder
80
80
40
40
Fig 1.
50
100
150
Tmb (°C)
200
100
150
200
Tmb (°C)
Normalized continuous drain current as a
function of mounting base temperature
Fig 2.
Normalized total power dissipation as a
003aaa345
103
ID
(A)
Limit RDSon = VDS/ID
102
tp = 100 μ s
1 ms
10 ms
10
DC
100 ms
1s
1
10-1
10-1
Fig 3.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PH2520U_3
Product data sheet
3 of 12
PH2520U
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Rth(j-mb)
thermal resistance from see Figure 4
junction to mounting
base
Min
Typ
Max
Unit
2
K/W
003aaa346
10
Zth(j-mb)
(K/W)
δ = 0.5
1
δ=
P
0.2
tp
T
0.1
0.05
0.02
single pulse
t
tp
T
10-1
10-4
Fig 4.
10-3
10-2
10-1
1
10
tp (s)
102
Transient thermal impedance from junction to mounting base as a function of pulse duration
PH2520U_3
Product data sheet
4 of 12
PH2520U
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
RG
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
drain-source on-state
resistance
ID = 250 µA; VGS = 0 V; Tj = -55 °C
18
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 7; see Figure 8
1.2
V
ID = 1 mA; VDS = VGS; Tj = 150 °C;
0.25
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
0.45
0.7
0.95
V
VDS = 20 V; VGS = 0 V; Tj = 25 °C
0.06
1
µA
VDS = 20 V; VGS = 0 V; Tj = 150 °C
500
µA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
nA
VGS = 2.5 V; ID = 25 A; Tj = 25 °C;
see Figure 9; see Figure 10
2.8
3.9
mΩ
VGS = 4.5 V; ID = 25 A; Tj = 150 °C;
3.3
4.3
mΩ
VGS = 4.5 V; ID = 25 A; Tj = 25 °C;
2.1
2.7
mΩ
1.65
Ω
78
nC
17
nC
18
nC
internal gate resistance f = 1 MHz; Tj = 25 °C
(AC)
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
VGS(pl)
gate-source plateau
voltage
ID = 50 A; VDS = 10 V; Tj = 25 °C;
2.2
V
Ciss
input capacitance
5850
pF
Coss
output capacitance
VDS = 10 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 13
1190
pF
Crss
reverse transfer
capacitance
831
pF
td(on)
turn-on delay time
34
ns
tr
rise time
240
ns
td(off)
turn-off delay time
318
ns
tf
fall time
234
ns
ID = 50 A; VDS = 10 V; VGS = 4.5 V;
Tj = 25 °C; see Figure 11;
see Figure 12
VDS = 10 V; RL = 1 Ω; VGS = 4.5 V;
RG(ext) = 4.7 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 14
0.85
1.2
V
trr
reverse recovery time
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 20 V; Tj = 25 °C
65
ns
PH2520U_3
Product data sheet
5 of 12
PH2520U
Nexperia
003aaa347
50
4.5
2.5
ID
(A)
ID
(A)
1.4
1.8
40
003aaa348
30
1.6
Tj = 150 °C
1.3
25 °C
VGS (V) = 1.2
10
Fig 5.
0.2
0.4
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
03aj65
1.2
VGS(th)
(V)
Fig 6.
0.5
1
1.5
VGS (V)
2
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03aj64
10−3
ID
(A)
0.9
max
10−4
typ
0.6
min
10−5
min
typ
max
0.3
−60
Fig 7.
10−6
120
180
0.4
0.6
0.8
Tj (°C)
Gate-source threshold voltage as a function of
Fig 8.
1
VGS (V)
Sub-threshold drain current as a function of
gate-source voltage
PH2520U_3
Product data sheet
6 of 12
PH2520U
Nexperia
003aaa349
10
RDSon
(mΩ)
VGS (V) = 1.3
03af18
2
1.4
a
8
1.5
6
1
1.6
4
1.8
2.5
4.5
2
0.5
Fig 9.
10
40
ID (A)
50
Drain-source on-state resistance as a function
of drain current; typical values
120
Tj (°C)
180
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
003aaa352
5
VGS
(V)
VDS
ID
4
VGS(pl)
3
VGS(th)
VGS
2
QGS1
QGS2
QGS
1
QGD
QG(tot)
003aaa508
50
75
QG (nC)
100
Fig 12. Gate charge waveform definitions
Fig 11. Gate-source voltage as a function of gate
charge; typical values
PH2520U_3
Product data sheet
7 of 12
PH2520U
Nexperia
003aaa350
105
C
(pF)
003aaa351
40
IS
(A)
30
104
Ciss
150 °C
Tj = 25 °C
10
Coss
3
Crss
102
10-1
1
10
VDS (V)
10
102
Fig 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
0.4
0.6
0.8
VSD (V)
1
Fig 14. Source current as a function of source-drain
PH2520U_3
Product data sheet
8 of 12
PH2520U
Nexperia
7. Package outline
Plastic single-ended surface-mounted package (LFPAK); 4 leads
A2
A
E
SOT669
C
c2
b2
E1
b3
L1
mounting
base
b4
D1
D
H
L2
1
2
3
e
4
w M A
b
1/2
X
c
e
A
(A 3)
A1
C
θ
L
detail X
y C
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
mm
A
A1
A2
A3
b
b2
1.20 0.15 1.10
0.50 4.41
0.25
1.01 0.00 0.95
0.35 3.62
b3
b4
2.2
2.0
0.9
0.7
c
D (1)
c2
D1(1)
E(1) E1(1)
max
0.25 0.30 4.10
4.20
0.19 0.24 3.80
5.0
4.8
3.3
3.1
e
H
L
L1
L2
w
y
θ
1.27
6.2
5.8
0.85
0.40
1.3
0.8
1.3
0.8
0.25
0.1
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT669
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-10-13
06-03-16
MO-235
Fig 15. Package outline SOT669 (LFPAK)
PH2520U_3
Product data sheet
9 of 12
PH2520U
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PH2520U_3
20090302
Product data sheet
PH2520U_2
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
PH2520U_2
20051115
Product data sheet
PH2520U-01
PH2520U-01
(9397 750 11406)
20030502
Product data
PH2520U_3
Product data sheet
10 of 12
PH2520U
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PH2520U_3
Product data sheet
11 of 12
Nexperia
PH2520U
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 02 March 2009
很抱歉,暂时无法提供与“PH2520U,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1500+5.795261500+0.74712
