2N7002PS,115
2N7002PS,115
    NEXPERIA(安世)
    SOT-363
    MOS管 双N-Channel VDS=60V VGS=±20V ID=320mA RDS(ON)=1.6Ω@10V SOT363-6
2N7002PS,115 数据手册
2N7002PS 60 V, 320 mA dual N-channel Trench MOSFET 23 November 2020 Product data sheet 1. General description Dual N-channel enhancement mode Field-Effect Transistor (FET) in a very small SOT363 (SC-88) Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology. 2. Features and benefits • • • • Logic-level compatible Very fast switching Trench MOSFET technology AEC-Q101 qualified 3. Applications • • • • Relay driver High-speed line driver Low-side load switch Switching circuits 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 °C - - 60 V -20 - 20 V - - 320 mA - 1 1.6 Ω Per transistor VDS drain-source voltage VGS gate-source voltage ID drain current VGS = 10 V; Tamb = 25 °C [1] Static characteristics (per transistor) RDSon [1] drain-source on-state resistance VGS = 10 V; ID = 500 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.01; Tj = 25 °C 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 1 cm . 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S1 source1 2 G1 gate1 3 D2 drain2 4 S2 source2 5 G2 gate2 6 D1 drain1 Simplified outline Graphic symbol 6 5 4 1 2 3 TSSOP6 (SOT363) D1 S1 D2 G1 S2 G2 msd901 6. Ordering information Table 3. Ordering information Type number Package 2N7002PS Name Description Version TSSOP6 plastic, surface-mounted package; 6 leads; 0.65 mm pitch; 2.1 mm x 1.25 mm x 0.95 mm body SOT363 7. Marking Table 4. Marking codes Type number Marking code[1] 2N7002PS M8% [1] % = placeholder for manufacturing site code 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 2 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tamb = 25 °C - 60 V VGS gate-source voltage ID drain current Per transistor -20 20 V VGS = 10 V; Tamb = 25 °C [1] - 320 mA VGS = 10 V; Tamb = 100 °C [1] - 240 mA - 1.2 A [2] - 280 mW [1] - 320 mW - 990 mW - 420 mW IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs Ptot total power dissipation Tamb = 25 °C Tsp = 25 °C Per device Ptot total power dissipation Tamb = 25 °C [2] Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C - 320 mA Source-drain diode IS [1] [2] source current Tamb = 25 °C [1] 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 1 cm . Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 017aaa001 120 Pder (%) Ider (%) 80 80 40 40 0 - 75 Fig. 1. 017aaa002 120 - 25 25 75 Normalized total power dissipation as a function of ambient temperature 2N7002PS Product data sheet 0 - 75 125 175 Tamb (°C) Fig. 2. - 25 75 125 175 Tamb (°C) Normalized continuous drain current as a function of ambient temperature All information provided in this document is subject to legal disclaimers. 23 November 2020 25 © Nexperia B.V. 2020. All rights reserved 3 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 017aaa033 10 ID (A) 1 (1) (2) 10- 1 (3) (4) (5) 10- 2 (6) 10- 3 10- 1 1 10 102 VDS (V) IDM = single pulse (1) tp = 100 μs (2) tp = 1 ms (3) tp = 10 ms (4) DC; Tsp = 25 °C (5) tp = 100 ms 2 (6) DC; Tamb = 25 °C; drain mounting pad 1 cm Fig. 3. Per transistor: Safe operating area; junction to ambient; continuous and peak drain currents as a function of drain-source voltage 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 4 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Per device Rth(j-a) thermal resistance from in free air junction to ambient [1] - - 300 K/W thermal resistance from in free air junction to ambient [1] - 390 445 K/W [2] - 340 390 K/W - - 130 K/W Per transistor Rth(j-a) Rth(j-sp) [1] [2] thermal resistance from junction to solder point Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 1 cm . 017aaa034 103 duty cycle = 1 Zth(j-a) (K/W) 0.5 0.25 102 10 0.75 0.33 0.2 0.1 0.05 0 0.02 0.01 1 10- 3 10- 2 10- 1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 4. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 017aaa035 103 duty cycle = 1 Zth(j-a) (K/W) 0.5 102 10 0.25 0.75 0.33 0.2 0.1 0.05 0 0.02 0.01 1 10- 3 10- 2 10- 1 FR4 PCB, mounting pad for drain 1 cm Fig. 5. 1 10 102 tp (s) 2 103 Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 5 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics (per transistor) V(BR)DSS drain-source breakdown voltage ID = 10 µA; VGS = 0 V; Tj = 25 °C 60 - - V VGSth gate-source threshold voltage ID = 250 µA; VDS=VGS; Tj = 25 °C 1.1 1.75 2.4 V IDSS drain leakage current VDS = 60 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 60 V; VGS = 0 V; Tj = 150 °C - - 10 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - -100 nA VGS = 5 V; ID = 50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.01; Tj = 25 °C - 1.3 2 Ω VGS = 10 V; ID = 500 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.01; Tj = 25 °C - 1 1.6 Ω VDS = 10 V; ID = 200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.01; Tj = 25 °C - 400 - mS - 0.6 0.8 nC - 0.2 - nC - 0.2 - nC - 30 50 pF - 7 - pF - 4 - pF - 3 6 ns - 4 - ns IGSS RDSon gfs gate leakage current drain-source on-state resistance forward transconductance Dynamic characteristics (per transistor) QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 10 20 ns tf fall time - 5 - ns 0.47 0.75 1.1 V VDS = 30 V; ID = 300 mA; VGS = 4.5 V; Tj = 25 °C VDS = 10 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C VDS = 50 V; RL = 250 Ω; VGS = 10 V; RG(ext) = 6 Ω; Tj = 25 °C Source-drain diode (per transistor) VSD source-drain voltage 2N7002PS Product data sheet IS = 115 mA; VGS = 0 V; Tj = 25 °C All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 6 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 017aaa017 0.7 VGS = 4.0 V ID (A) 0.6 017aaa018 10- 3 3.5 V ID (A) 0.5 10- 4 3.25 V (1) 0.4 0.3 (2) (3) 3.0 V 10- 5 0.2 2.75 V 0.1 2.5 V 0.0 0.0 1.0 2.0 3.0 VDS (V) 10- 6 4.0 Tamb = 25 °C Fig. 6. Fig. 7. 017aaa019 RDSon (Ω) 1 2 VGS (V) 3 Tamb = 25 °C; VDS = 5 V (1) minimum values (2) typical values (3) maximum values Output characteristics: drain current as a function of drain-source voltage; typical values 10.0 0 Sub-threshold drain current as a function of gate-source voltage 017aaa020 6.0 RDSon (Ω) (1) 7.5 (2) 4.0 5.0 (1) 2.0 2.5 (2) (3) (4) (5) 0.0 0.0 0.2 0.4 0.6 0.8 ID (A) 0.0 0.0 1.0 Tamb = 25 °C (1) VGS = 3.25 V (2) VGS = 3.5 V (3) VGS = 4 V (4) VGS = 5 V (5) VGS = 10 V Fig. 8. 2.0 4.0 6.0 8.0 10.0 VGS (V) ID = 500 mA (1) Tamb = 150 °C (2) Tamb = 25 °C Fig. 9. Drain-source on-state resistance as a function of gate-source voltage; typical values Drain-source on-state resistance as a function of drain current; typical values 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 7 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 017aaa021 1.0 017aaa022 2.4 ID (A) a 0.8 (1) 1.8 (2) 0.6 1.2 0.4 0.6 0.2 0.0 0.0 (2) 1.0 (1) 2.0 3.0 0.0 - 60 4.0 5.0 VGS (V) VDS > ID × RDSon (1) Tamb = 25 °C (2) Tamb = 150 °C Fig. 10. Transfer characteristics: drain current as a function of gate-source voltage; typical values 017aaa023 3.0 VGS(th) (V) 0 60 120 180 Tamb (°C) Fig. 11. Normalized drain-source on-state resistance as a function of ambient temperature; typical values 017aaa024 102 (1) (1) C (pF) 2.0 (2) (2) 10 (3) (3) 1.0 0.0 - 60 0 60 1 10- 1 120 180 Tamb (°C) ID = 0.25 mA; VDS = VGS (1) maximum values (2) typical values (3) minimum values Product data sheet 10 VDS (V) 102 f = 1 MHz; VGS = 0 V (1) Ciss (2) Coss (3) Crss Fig. 12. Gate-source threshold voltage as a function of ambient temperature 2N7002PS 1 Fig. 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 8 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 017aaa025 5.0 VGS (V) VDS 4.0 ID 3.0 VGS(pl) 2.0 VGS(th) VGS 1.0 0.0 0.0 QGS2 QGS1 0.2 0.4 0.6 QG (nC) QGS 0.8 QGD QG(tot) ID = 300 mA; VDS = 30 V; Tamb = 25 °C 003aaa508 Fig. 15. Gate charge waveform definitions Fig. 14. Gate-source voltage as a function of gate charge; typical values 017aaa026 1.2 IS (A) 0.8 (1) (2) 0.4 0.0 0.0 0.4 0.8 VSD (V) 1.2 VGS = 0 V (1) Tamb = 150 °C (2) Tamb = 25 °C Fig. 16. Source current as a function of source-drain voltage; typical values 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 9 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 11. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 17. Duty cycle definition Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 10 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 12. Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig. 18. Package outline TSSOP6 (SOT363) 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 11 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 13. Soldering 2.65 solder lands 2.35 1.5 0.4 (2×) 0.6 0.5 (4×) (4×) solder resist solder paste 0.5 (4×) 0.6 (2×) occupied area 0.6 (4×) Dimensions in mm 1.8 sot363_fr Fig. 19. Reflow soldering footprint for TSSOP6 (SOT363) 1.5 solder lands 0.3 2.5 4.5 1.5 solder resist occupied area Dimensions in mm 1.3 preferred transport direction during soldering 1.3 2.45 5.3 sot363_fw Fig. 20. Wave soldering footprint for TSSOP6 (SOT363) 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 12 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes 2N7002PS v.2 20201123 Product data sheet - 2N7002PS v.1 Modifications: • • • 2N7002PS v.1 2N7002PS Product data sheet The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Chapter "Characteristics": Typo correction for IGSS and switching times. 20100701 Product data sheet - All information provided in this document is subject to legal disclaimers. 23 November 2020 - © Nexperia B.V. 2020. All rights reserved 13 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 14 / 15 2N7002PS Nexperia 60 V, 320 mA dual N-channel Trench MOSFET Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 5 10. Characteristics............................................................ 6 11. Test information........................................................ 10 12. Package outline........................................................ 11 13. Soldering................................................................... 12 14. Revision history........................................................13 15. Legal information......................................................14 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 November 2020 2N7002PS Product data sheet All information provided in this document is subject to legal disclaimers. 23 November 2020 © Nexperia B.V. 2020. All rights reserved 15 / 15
2N7002PS,115 价格&库存
很抱歉,暂时无法提供与“2N7002PS,115”相匹配的价格&库存,您可以联系我们找货
