PMCXB1000UEZ
PMCXB1000UEZ
    NEXPERIA(安世)
    DFN1010B-6
    MOS管 N-channel,P-channel Id=0.59A VDS=30V DFN1010B-6
PMCXB1000UEZ 数据手册
PMCXB1000UE 30 V, complementary N/P-channel Trench MOSFET 27 June 2016 Product data sheet 1. General description Complementary N/P-channel enhancement mode Field-Effect Transistor (FET) in a leadless ultra small DFN1010B-6 (SOT1216) Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology. 2. Features and benefits • • • • Trench MOSFET technology Very low threshold voltage for portable applications: VGS(th) = 0.7 V Leadless ultra small and ultra thin SMD plastic package: 1.1 × 1.0 × 0.37 mm ElectroStatic Discharge (ESD) protection > 2 kV HBM 3. Applications • • • • Relay driver High-speed line driver Level shifter Power management in battery-driven portables 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VGS = 4.5 V; ID = 590 mA; Tj = 25 °C - 550 670 mΩ VGS = -4.5 V; ID = -410 mA; Tj = 25 °C - 1.2 1.4 Ω - - 30 V - - 590 mA - - -30 V - - -410 mA TR1 (N-channel), Static characteristics RDSon drain-source on-state resistance TR2 (P-channel), Static characteristics RDSon drain-source on-state resistance TR1 (N-channel) VDS drain-source voltage Tj = 25 °C ID drain current VGS = 4.5 V; Tamb = 25 °C [1] TR2 (P-channel) VDS drain-source voltage Tj = 25 °C ID drain current VGS = -4.5 V; Tamb = 25 °C [1] [1] 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 1 cm . PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S1 Simplified outline Graphic symbol source TR1 2 G1 gate TR1 3 D2 drain TR2 4 S2 source TR2 5 G2 gate TR2 6 D1 drain TR1 7 D1 drain TR1 8 D2 drain TR2 D2 D1 1 7 2 3 6 G1 5 8 G2 4 S1 Transparent top view S2 017aaa262 DFN1010B-6 (SOT1216) 6. Ordering information Table 3. Ordering information Type number Package PMCXB1000UE Name Description Version DFN1010B-6 DFN1010B-6: plastic thermal enhanced ultra thin small outline package; no leads; 6 terminals SOT1216 7. Marking Table 4. Marking codes Type number Marking code PMCXB1000UE B 101 MARKING CODE (EXAMPLE) READING DIRECTION MARK-FREE AREA PIN 1 INDICATION MARK READING EXAMPLE: YEAR DATE CODE A 110 VENDOR CODE Fig. 1. aaa-019766 DFN1010B-6 (SOT1216) binary marking code description PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 2 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - 30 V VGS gate-source voltage -8 8 V ID drain current TR1 (N-channel) VGS = 4.5 V; Tamb = 25 °C [1] - 590 mA VGS = 4.5 V; Tamb = 100 °C [1] - 370 mA - 2.3 A [2] - 285 mW [1] - 410 mW Tsp = 25 °C - 4 W Tj = 25 °C - -30 V -8 8 V IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs Ptot total power dissipation Tamb = 25 °C TR2 (P-channel) VDS drain-source voltage VGS gate-source voltage ID drain current VGS = -4.5 V; Tamb = 25 °C [1] - -410 mA VGS = -4.5 V; Tamb = 100 °C [1] - -260 mA - -1.7 A [2] - 285 mW [1] - 410 mW - 4 W IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs Ptot total power dissipation Tamb = 25 °C Tsp = 25 °C Per device Tj junction temperature -55 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C TR1 (N-channel), Source-drain diode IS source current Tamb = 25 °C [1] - 380 mA Tamb = 25 °C [1] - -410 mA TR2 (P-channel), Source-drain diode IS [1] [2] source current 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 1 cm . Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 3 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 017aaa123 120 017aaa124 120 Pder (%) Ider (%) 80 80 40 40 0 - 75 Fig. 2. - 25 25 75 125 Tj (°C) 0 - 75 175 MOSFET transistor: Normalized total power dissipation as a function of junction temperature Fig. 3. - 25 25 75 125 Tj (°C) 175 MOSFET transistor: Normalized continuous drain current as a function of junction temperature aaa-017279 10 ID (A) tp = 10 µs Limit RDSon = VDS/ID 1 100 µs 1 ms 10-1 DC; Tsp = 25 °C 100 ms DC; Tamb = 25 °C; drain mounting pad 1 cm2 10-2 10-3 10-1 Fig. 4. 10 ms 1 10 102 VDS (V) TR1: Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 4 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-017288 -10 ID (A) Limit RDSon = VDS/ID tp = 10 µs -1 100 µs 1 ms -10-1 DC; Tsp = 25 °C DC; Tamb = 25 °C; drain mounting pad 1 cm2 -10-2 -10-3 -10-1 Fig. 5. 10 ms 100 ms -1 -10 -102 VDS (V) TR2: Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit [1] - 380 440 K/W [2] - 275 305 K/W - 27 31 K/W [1] - 380 440 K/W [2] - 275 305 K/W - 27 31 K/W TR1 (N-channel) Rth(j-a) Rth(j-sp) thermal resistance from junction to ambient in free air thermal resistance from junction to solder point TR2 (P-channel) Rth(j-a) Rth(j-sp) [1] [2] thermal resistance from junction to ambient in free air thermal resistance from junction to solder point Device mounted on an FR4 PCB, single-sided copper; tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 1 cm . PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 5 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-015677 103 Zth(j-a) (K/W) duty cycle = 1 0.75 0.50 0.33 102 0.20 0.25 0.10 0.05 0 0.01 0.02 10 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 6. TR1 and TR2: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-015678 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.50 0.33 0.25 0.20 0.10 0.05 0 0.01 10 10-3 0.02 10-2 10-1 FR4 PCB, mounting pad for drain 1 cm Fig. 7. 1 10 102 tp (s) 103 2 TR1 and TR2: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 6 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit TR1 (N-channel), Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V VGSth gate-source threshold voltage ID = 250 µA; VDS=VGS; Tj = 25 °C 0.45 0.7 0.95 V IDSS drain leakage current VDS = 30 V; VGS = 0 V; Tj = 25 °C - - 1 µA IGSS gate leakage current VGS = 8 V; VDS = 0 V; Tj = 25 °C - - 5 µA VGS = -8 V; VDS = 0 V; Tj = 25 °C - - -5 µA VGS = 4.5 V; VDS = 0 V; Tj = 25 °C - - 1 µA VGS = -4.5 V; VDS = 0 V; Tj = 25 °C - - -1 µA VGS = 2.5 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -2.5 V; VDS = 0 V; Tj = 25 °C - - -100 nA VGS = 4.5 V; ID = 590 mA; Tj = 25 °C - 550 670 mΩ VGS = 4.5 V; ID = 590 mA; Tj = 150 °C - 960 1170 mΩ VGS = 2.5 V; ID = 590 mA; Tj = 25 °C - 660 900 mΩ VGS = 1.8 V; ID = 80 mA; Tj = 25 °C - 770 1120 mΩ VGS = 1.5 V; ID = 10 mA; Tj = 25 °C - 890 1500 mΩ VDS = 10 V; ID = 590 mA; Tj = 25 °C - 600 - mS RDSon gfs drain-source on-state resistance forward transconductance TR2 (P-channel), Static characteristics V(BR)DSS drain-source breakdown voltage ID = -250 µA; VGS = 0 V; Tj = 25 °C -30 - - V VGSth gate-source threshold voltage ID = -250 µA; VDS=VGS; Tj = 25 °C -0.45 -0.7 -0.95 V IDSS drain leakage current VDS = -30 V; VGS = 0 V; Tj = 25 °C - - -1 µA IGSS gate leakage current VGS = 8 V; VDS = 0 V; Tj = 25 °C - - 5 µA VGS = -8 V; VDS = 0 V; Tj = 25 °C - - -5 µA VGS = 4.5 V; VDS = 0 V; Tj = 25 °C - - 1 µA VGS = -4.5 V; Tj = 25 °C - - -1 µA VGS = 2.5 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -2.5 V; VDS = 0 V; Tj = 25 °C - - -100 nA VGS = -4.5 V; ID = -410 mA; Tj = 25 °C - 1.2 1.4 Ω VGS = -4.5 V; ID = -410 mA; Tj = 150 °C - 2 2.4 Ω VGS = -2.5 V; ID = -320 mA; Tj = 25 °C - 1.7 2.3 Ω VGS = -1.8 V; ID = -80 mA; Tj = 25 °C - 2.1 3.1 Ω VGS = -1.5 V; ID = -10 mA; Tj = 25 °C - 3 5.1 Ω RDSon drain-source on-state resistance PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 7 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET Symbol Parameter Conditions Min Typ Max Unit gfs forward transconductance VDS = -10 V; ID = -410 mA; Tj = 25 °C - 820 - mS - 0.6 1.05 nC - 0.1 - nC - 0.1 - nC - 30.3 - pF - 5.8 - pF - 4.2 - pF - 4 - ns - 7 - ns TR1 (N-channel), Dynamic characteristics QG(tot) total gate charge VDS = 15 V; ID = 590 mA; VGS = 4.5 V; Tj = 25 °C QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 12 - ns tf fall time - 3 - ns - 0.7 1.2 nC - 0.17 - nC - 0.16 - nC - 43.2 - pF - 5.9 - pF - 4.2 - pF - 3 - ns - 4 - ns VDS = 15 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C VDS = 15 V; ID = 590 mA; VGS = 4.5 V; RG(ext) = 6 Ω; Tj = 25 °C TR2 (P-channel), Dynamic characteristics QG(tot) total gate charge VDS = -15 V; ID = -410 mA; VGS = -4.5 V; Tj = 25 °C QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 14 - ns tf fall time - 5 - ns - 0.86 1.2 V - -0.95 -1.2 V VDS = -15 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C VDS = -15 V; ID = -410 mA; VGS = -4.5 V; RG(ext) = 6 Ω; Tj = 25 °C TR1 (N-channel), Source-drain diode characteristics VSD source-drain voltage IS = 380 mA; VGS = 0 V; Tj = 25 °C TR2 (P-channel), Source-drain diode characteristics VSD source-drain voltage PMCXB1000UE Product data sheet IS = -410 mA; VGS = 0 V; Tj = 25 °C All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 8 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-017177 3 VGS = 4.5 V ID (A) ID (A) 3.0 V 2.5 V 2 aaa-017178 10-3 10-4 2.0 V 1.8 V (1) 10-5 1 (2) (3) 1.5 V 1.2 V 0 0 1 2 3 VDS (V) 10-6 4 Tj = 25 °C Fig. 8. Fig. 9. aaa-017179 1.2 V RDSon (Ω) 1.8 V 1.5 V 2.5 V 2.0 V 1 TR1: Sub-threshold drain current as a function of gate-source voltage aaa-017180 1.5 1.0 Tj = 150 °C VGS = 4.5 V 0.5 Tj = 25 °C 0.5 0 1 2 ID (A) 0 3 Tj = 25 °C Product data sheet 0 1 2 3 4 VGS (V) 5 ID = 1 A Fig. 10. TR1: Drain-source on-state resistance as a function of drain current; typical values PMCXB1000UE 1.5 RDSon (Ω) 1.0 0 VGS (V) 2.0 3.0 V 1.5 0.5 Tj = 25 °C; VDS = 5 V (1) minimum values (2) typical values (3) maximum values TR1: Output characteristics: drain current as a function of drain-source voltage; typical values 2.0 0 Fig. 11. TR1: Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 9 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-017181 1.0 aaa-017182 2.0 ID (A) a 0.8 1.5 0.6 0.4 0.5 0.2 0 1.0 Tj = 150 °C Tj = 25 °C 0 1 2 3 VGS (V) 0 -60 4 0 60 120 Tj (°C) 180 VDS > ID × RDSon Fig. 12. TR1: Transfer characteristics: drain current as a function of gate-source voltage; typical values Fig. 13. TR1: Normalized drain-source on-state resistance as a function of junction temperature; typical values aaa-017183 1.5 VGS(th) (V) aaa-017184 102 C (pF) 1.0 (1) (1) 10 (2) 0.5 (2) (3) 0 -60 0 60 (3) 120 Tj (°C) 1 10-1 180 ID = 0.25 mA; VDS = VGS (1) maximum values (2) typical values (3) minimum values Product data sheet 10 VDS (V) 102 f = 1 MHz; VGS = 0 V (1) Ciss (2) Coss (3) Crss Fig. 14. TR1: Gate-source threshold voltage as a function of junction temperature PMCXB1000UE 1 Fig. 15. TR1: Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 10 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-017185 5 VDS VGS (V) ID 4 VGS(pl) 3 VGS(th) VGS 2 QGS1 QGS2 QGS 1 QGD QG(tot) aaa-023663 0 0 0.2 0.4 0.6 QG (nC) Fig. 17. TR1: Gate charge waveform definitions 0.8 ID = 0.6 A; VDS = 15 V; Tamb = 25 °C Fig. 16. TR1: Gate-source voltage as a function of gate charge; typical values aaa-017186 2.0 aaa-017220 -2.0 VGS = -4.5 V ID (A) IS (A) 1.5 -3.0 V -1.5 -2.5 V 1.0 -1.0 Tj = 150 °C -2.0 V 0.5 -1.8 V -0.5 Tj = 25 °C -1.5 V -1.2 V 0 0 0.4 0.8 1.2 VSD (V) 0 1.6 VGS = 0 V Product data sheet -1 -2 -3 VDS (V) -4 Tj = 25 °C Fig. 18. TR1: Source current as a function of sourcedrain voltage; typical values PMCXB1000UE 0 Fig. 19. TR2: Output characteristics: drain current as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 11 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-017221 -10-3 aaa-017222 10 VGS = -1.5 V RDS(on) (Ω) ID (A) 8 -2.0 V -1.8 V -10-4 6 -2.5 V (1) -10-5 (2) 4 (3) -3.0 V -4.5 V 2 -10-6 0 -0.5 -1.0 VGS (V) 0 -1.5 VDS = -5 V Tj = 25 °C (1) minimum values (2) typical values (3) maximum values 0 -0.5 -1.0 -1.5 ID (A) -2.0 Tj = 25 °C Fig. 21. TR2: Drain-source on-state resistance as a function of drain current; typical values Fig. 20. TR2: Sub-threshold drain current as a function of gate-source voltage aaa-017223 10 aaa-017224 -1.0 ID (A) RDS(on) (Ω) 8 -0.8 6 -0.6 4 -0.4 Tj = 150 °C 2 -0.2 Tj = 150 °C Tj = 25 °C Tj = 25 °C 0 0 -1 -2 -3 -4 VGS (V) 0 -5 ID = -0.4 A Product data sheet -1 -2 -3 VGS (V) -4 VDS > ID x RDSon Fig. 22. TR2: Drain-source on-state resistance as a function of gate-source voltage; typical values PMCXB1000UE 0 Fig. 23. TR2: Transfer characteristics: drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 12 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-017225 2.0 a aaa-017226 -1.5 VGS(th) (V) 1.5 -1.0 (1) 1.0 (2) -0.5 (3) 0.5 0 -60 0 60 120 Tj (°C) 0 -60 180 Fig. 24. TR2: Normalized drain-source on-state resistance as a function of ambient temperature; typical values 60 120 Tj (°C) 180 ID = -250 μA; VDS = VGS (1) maximum values (2) typical values (3) minimum values Fig. 25. TR2: Gate-source threshold voltage as a function of junction temperature aaa-017227 102 0 aaa-017228 -5 VGS (V) (1) -4 C (pF) -3 10 (2) -2 (3) -1 1 -10-1 -1 -10 VDS (V) 0 -102 f = 1 MHz; VGS = 0 V (1) Ciss (2) Coss (3) Crss 0 0.2 0.4 0.6 QG (nC) 0.8 VDS = -15 V; ID = -410 mA Tamb = 25 °C Fig. 27. TR2: Gate-source voltage as a function of gate charge; typical values Fig. 26. TR2: Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 13 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET aaa-017229 -2.0 VDS IS (A) ID -1.5 VGS(pl) VGS(th) -1.0 VGS QGS1 QGS2 QGS -0.5 QGD QG(tot) Tj = 150 °C Tj = 25 °C aaa-023664 0 Fig. 28. TR2: Gate charge waveform definitions 0 -0.4 -0.8 -1.2 VSD (V) -1.6 VGS = 0 V Fig. 29. TR2: Source current as a function of sourcedrain voltage; typical values 11. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 30. Duty cycle definition PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 14 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 12. Package outline DFN1010B-6: plastic thermal enhanced ultra thin small outline package; no leads; 6 terminals; body: 1.1 x 1.0 x 0.37 mm pin 1 index area SOT1216 visible depend upon used manufacturing technology (6x) e e b (6x) 1 2 3 L (6x) E1 (2x) E D 6 A1 e1 A 0 A A1 b D D1 4 D1 (2x) e1 1 mm scale Dimensions (mm are the original dimensions) Unit 5 E E1 e e1 L min 0.34 0.15 1.05 0.32 0.95 0.22 0.125 nom 0.37 0.18 1.10 0.35 1.00 0.25 0.35 0.275 0.155 max 0.40 0.04 0.23 1.15 0.40 1.05 0.30 0.205 mm Note 1. Dimension A is including plating thickness. Outline version sot1216_po References IEC JEDEC JEITA European projection Issue date 13-03-05 13-03-06 SOT1216 Fig. 31. Package outline DFN1010B-6 (SOT1216) PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 15 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 13. Soldering Footprint information for reflow soldering of DFN1010B-6 package SOT1216 0.9 0.35 0.35 0.15 0.2 (6x) 0.15 1.3 1.2 0.35 0.25 0.5 0.6 0.35 0.25 1.1 0.3 (6x) 1 1.35 solder land solder land plus solder paste occupied area solder resist Dimensions in mm Issue date 13-03-06 14-07-28 sot1216_fr Fig. 32. Reflow soldering footprint for DFN1010B-6 (SOT1216) PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 16 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMCXB1000UE v.1 20160627 Product data sheet - - PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 17 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. PMCXB1000UE Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 18 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 19 / 20 PMCXB1000UE Nexperia 30 V, complementary N/P-channel Trench MOSFET 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 5 10. Characteristics............................................................ 7 11. Test information....................................................... 14 12. Package outline........................................................ 15 13. Soldering................................................................... 16 14. Revision history........................................................17 15. Legal information..................................................... 18 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 June 2016 PMCXB1000UE Product data sheet All information provided in this document is subject to legal disclaimers. 27 June 2016 © Nexperia B.V. 2017. All rights reserved 20 / 20
PMCXB1000UEZ
物料型号:PMCXB1000UE
器件简介:该器件是一款30V互补N/P沟道沟槽MOSFET,采用无引脚超小型DFN1010B-6 (SOT1216)表面贴装设备(SMD)塑料封装,使用沟槽MOSFET技术。
引脚分配:共8个引脚,1号引脚为N通道的源极(S1),2号引脚为N通道的栅极(G1),以此类推,4号引脚为P通道的源极(S2),5号引脚为P通道的栅极(G2),6和7号引脚分别为N通道的漏极(D1),8号引脚为P通道的漏极(D2)。
参数特性: - 非常低的阈值电压,适用于便携式应用:VGS(th) = 0.7V - 无引脚超小型和超薄SMD塑料封装:1.1 × 1.0 × 0.37 mm - 静电放电(ESD)保护 > 2 kV HBM
功能详解:适用于继电器驱动器、高速线驱动器、电平转换器以及电池驱动便携式设备的电源管理。
应用信息:适用于继电器驱动、高速线驱动、电平转换和电池供电便携设备的电源管理。
封装信息:DFN1010B-6 (SOT1216)塑料热增强超薄小型封装;无引脚;6个终端。
PMCXB1000UEZ 价格&库存
很抱歉,暂时无法提供与“PMCXB1000UEZ”相匹配的价格&库存,您可以联系我们找货
PMCXB1000UEZ
库存:4978
PMCXB1000UEZ
  • 1+5.742721+0.74530
  • 10+3.5224910+0.45716
  • 50+2.5652350+0.33292
  • 100+2.25269100+0.29236
  • 500+1.70203500+0.22090
库存:744
PMCXB1000UEZ
  • 5000+1.159415000+0.15047
  • 15000+1.0133315000+0.13151
库存:744
