BUK9K134-100EX
BUK9K134-100EX
    NEXPERIA(安世)
    LFPAK56D
    MOS管 Dual N-channel Id=8.5A VDS=100V SOT1205
BUK9K134-100EX 数据手册
BUK9K134-100E Dual N-channel 100 V, 159 mΩ logic level MOSFET 10 December 2013 Product data sheet 1. General description Dual logic level N-channel MOSFET in an LFPAK56D (Dual Power-SO8) package using TrenchMOS technology. This product has been designed and qualified to AEC Q101 standard for use in high performance automotive applications. 2. Features and benefits • • • • • Dual MOSFET Q101 Compliant Repetitive avalanche rated Suitable for thermally demanding environments due to 175 °C rating True logic level gate with VGS(th) rating of greater than 0.5 V at 175 °C 3. Applications • • • • 12 V, 24 V and 48 V Automotive systems Motors, lamps and solenoid control Transmission control Ultra high performance power switching 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V ID drain current VGS = 5 V; Tmb = 25 °C; Fig. 1 - - 8.5 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - - 32 W VGS = 5 V; ID = 5 A; Tj = 25 °C; Fig. 11 - 127 159 mΩ - 3.6 - nC Static characteristics FET1 and FET2 RDSon drain-source on-state resistance Dynamic characteristics FET1 and FET2 QGD gate-drain charge ID = 5 A; VDS = 80 V; VGS = 5 V; Tj = 25 °C; Fig. 13; Fig. 14 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S1 source1 2 G1 gate1 3 S2 source2 4 G2 gate2 5 D2 drain2 6 D2 drain2 7 D1 drain1 8 D1 drain1 Simplified outline 8 7 6 Graphic symbol 5 D1 D1 S1 D2 D2 G1 S2 G2 mbk725 1 2 3 4 LFPAK56D (SOT1205) 6. Ordering information Table 3. Ordering information Type number Package BUK9K134-100E Name Description Version LFPAK56D Plastic single ended surface mounted package (LFPAK56D); 8 leads SOT1205 7. Marking Table 4. Marking codes Type number Marking code BUK9K134-100E 913410E 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage RGS = 20 kΩ - 100 V VGS gate-source voltage Tj ≤ 175 °C; DC -10 10 V -15 15 V Tmb = 25 °C; VGS = 5 V; Fig. 1 - 8.5 A Tmb = 100 °C; VGS = 5 V; Fig. 1 - 6 A Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 4 - 34 A Tj ≤ 175 °C; Pulsed ID IDM drain current peak drain current BUK9K134-100E Product data sheet All information provided in this document is subject to legal disclaimers. 10 December 2013 [1][2] © Nexperia B.V. 2017. All rights reserved 2 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET Symbol Parameter Conditions Min Max Unit Ptot total power dissipation Tmb = 25 °C; Fig. 2 - 32 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode FET1 and FET2 IS source current Tmb = 25 °C - 8.5 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 34 A - 12.6 mJ Avalanche Ruggedness FET1 and FET2 EDS(AL)S non-repetitive drain-source avalanche energy [1] [2] [3] [4] ID (A) ID = 8.5 A; Vsup ≤ 100 V; VGS = 10 V; [3][4] Tj(init) = 25 °C; Fig. 3 Accumulated Pulse duration up to 50 hours delivers zero defect ppm Significantly longer life times are achieved by lowering Tj and or VGS. Refer to application note AN10273 for further information Single-pulse avalanche rating limited by maximum junction temperature of 175 °C 003aak400 15 03aa16 120 Pder (%) 12 80 9 6 40 3 0 Fig. 1. 0 30 60 90 120 150 Tj (°C) Continuous drain current as a function of mounting base temperature BUK9K134-100E Product data sheet 0 180 Fig. 2. 0 100 150 Tmb (°C) 200 Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 10 December 2013 50 © Nexperia B.V. 2017. All rights reserved 3 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET IAL (A) 003aak401 102 10 (1) 1 (2) (3) 10-1 10-3 Fig. 3. 10-2 10-1 1 tAL (ms) 10 Avalanche rating; avalanche current as a function of avalanche time ID (A) 003aak399 102 Limit RDSon = VDS / ID tp = 10 us 10 100 us 1 DC 1 ms 10 ms 100 ms 10-1 10-2 Fig. 4. 1 102 10 VDS (V) 103 Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 5 - - 4.68 K/W Rth(j-a) thermal resistance from junction to ambient Minimum footprint; mounted on a printed circuit board - 95 - K/W BUK9K134-100E Product data sheet All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 4 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET 003aaj557 10 Zth(j-mb) (K/W) δ = 0.5 0.2 1 0.1 0.05 0.02 10 P -1 single shot t tp T 10-2 10-6 Fig. 5. 10-5 10-4 10-3 10-2 tp T δ= 10-1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 90 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 100 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; 1.4 1.7 2.1 V 0.5 - - V - - 2.45 V VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA VDS = 100 V; VGS = 0 V; Tj = 175 °C - - 500 µA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 5 V; ID = 5 A; Tj = 25 °C; Fig. 11 - 127 159 mΩ VGS = 5 V; ID = 5 A; Tj = 175 °C; - 351 439 mΩ - 122 154 mΩ Static characteristics FET1 and FET2 V(BR)DSS VGS(th) Fig. 9; Fig. 10 ID = 1 mA; VDS = VGS; Tj = 175 °C; Fig. 9; Fig. 10 ID = 1 mA; VDS = VGS; Tj = -55 °C; Fig. 9; Fig. 10 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 11; Fig. 12 VGS = 10 V; ID = 5 A; Tj = 25 °C; Fig. 11 Dynamic characteristics FET1 and FET2 QG(tot) total gate charge ID = 5 A; VDS = 80 V; VGS = 5 V; - 7.4 - nC QGS gate-source charge Tj = 25 °C; Fig. 13; Fig. 14 - 1.4 - nC QGD gate-drain charge - 3.6 - nC BUK9K134-100E Product data sheet All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 5 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET Symbol Parameter Conditions Min Typ Max Unit Ciss input capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; - 566 755 pF Coss output capacitance Tj = 25 °C; Fig. 15 - 55 66 pF Crss reverse transfer capacitance - 38 53 pF td(on) turn-on delay time VDS = 80 V; RL = 16 Ω; VGS = 5 V; - 6.2 - ns tr rise time RG(ext) = 5 Ω; ID = 5 A; Tj = 25 °C - 11.3 - ns td(off) turn-off delay time - 12 - ns tf fall time - 10.3 - ns IS = 5 A; VGS = 0 V; Tj = 25 °C; Fig. 16 - 0.83 1.2 V Source-drain diode FET1 and FET2 VSD source-drain voltage trr reverse recovery time IS = 5 A; dIS/dt = -100 A/µs; VGS = 0 V; - 32.3 - ns recovered charge VDS = 50 V; Tj = 25 °C - 39.9 - nC Qr ID (A) 003aak393 16 10 V 4.5 V 3.5 V 3V 400 12 300 VGS = 2.8 V 8 003aak392 500 RDSon 200 2.6 V 4 100 2.4 V 0 0 1 2 3 4 VDS (V) Tj = 25 °C; tp = 300 μs Fig. 6. 0 5 Fig. 7. Output characteristics; drain current as a function of drain-source voltage; typical values BUK9K134-100E Product data sheet 0 8 12 VGS (V) 16 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 10 December 2013 4 © Nexperia B.V. 2017. All rights reserved 6 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET ID (A) 003aak391 20 16 003aah025 3 VGS(th) (V) 2.5 max 2 12 typ 1.5 8 min 1 4 0 Fig. 8. 175°C 0 1 0.5 Tj = 25°C 2 3 VGS (V) 0 -60 4 Transfer characteristics; drain current as a function of gate-source voltage; typical values Fig. 9. 003aah026 10-1 0 60 180 003aak398 2.6 V RDSon 10-2 Tj (° C) Gate-source threshold voltage as a function of junction temperature 400 ID (A) 120 2.8 V 300 min 10-3 typ 3V 3.5 V 4.5 V max 200 10-4 10-6 VGS = 10 V 100 10-5 0 1 2 V GS (V) 0 3 Fig. 10. Sub-threshold drain current as a function of gate-source voltage BUK9K134-100E Product data sheet 0 2 4 6 8 ID (A) 10 Tj = 25 °C; tp = 300 μs Fig. 11. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 7 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET 003aaj820 3 VDS a ID 2.4 VGS(pl) 1.8 VGS(th) VGS 1.2 QGS1 QGS2 QGS 0.6 QGD QG(tot) 003aaa508 0 -60 0 60 120 Tj ( °C) Fig. 13. Gate charge waveform definitions 180 Fig. 12. Normalized drain-source on-state resistance factor as a function of junction temperature VGS (V) 003aak395 10 003aak396 103 C (pF) Ciss 8 VDS = 14 V 6 102 80 V 4 Coss 2 0 Crss 0 3 6 9 12 QG (nC) Fig. 14. Gate-source voltage as a function of gate charge; typical values BUK9K134-100E Product data sheet 10 10-1 15 1 10 VDS (V) 102 Fig. 15. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 8 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET IS (A) 003aak397 20 16 12 8 4 0 175°C 0 0.2 0.4 Tj = 25°C 0.6 0.8 1 VSD (V) 1.2 Fig. 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values BUK9K134-100E Product data sheet All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 9 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET 11. Package outline Plastic single ended surface mounted package (LFPAK56D); 8 leads E A SOT1205 A b1 c1 L1 mounting base D H D1 D2 L 1 2 3 e b (8x) 4 w X c A E1 E2 A1 C θ Lp detail X 0 2.5 A max 1.05 nom min mm 5 mm scale Dimensions Unit y C c c1 D(1) D1(1) A1 b b1 0.1 0.50 4.4 0.25 0.30 4.70 0.0 0.35 4.1 0.19 0.24 4.45 4.8 D2 (ref) 3.5 E(1) E1(1) 5.30 1.8 4.95 1.6 E2 0.85 e 1.27 H L L1 Lp 6.2 1.3 0.55 0.85 5.9 0.8 0.30 0.40 w y 0.25 0.1 Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. Outline version References IEC JEDEC JEITA θ 8° 0° sot1205_po European projection Issue date 13-02-19 13-02-21 SOT1205 Fig. 17. Package outline LFPAK56D (SOT1205) BUK9K134-100E Product data sheet All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 10 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. BUK9K134-100E Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 11 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BUK9K134-100E Product data sheet All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 12 / 13 BUK9K134-100E Nexperia Dual N-channel 100 V, 159 mΩ logic level MOSFET 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ................................................... 10 12 12.1 12.2 12.3 12.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 December 2013 BUK9K134-100E Product data sheet All information provided in this document is subject to legal disclaimers. 10 December 2013 © Nexperia B.V. 2017. All rights reserved 13 / 13
BUK9K134-100EX 价格&库存
很抱歉,暂时无法提供与“BUK9K134-100EX”相匹配的价格&库存,您可以联系我们找货
BUK9K134-100EX
  • 1+11.219141+1.45120
  • 10+7.0157110+0.90749
  • 100+4.61171100+0.59653
  • 500+3.57910500+0.46296
库存:791
BUK9K134-100EX
  • 1+7.26517
  • 10+5.24978
  • 100+3.61633
  • 500+3.51882
BUK9K134-100EX
  • 1500+3.077141500+0.39803
  • 3000+2.824273000+0.36532
  • 4500+2.695424500+0.34866
  • 7500+2.550647500+0.32993
  • 10500+2.4649110500+0.31884
  • 15000+2.3816015000+0.30806
库存:791
BUK9K134-100EX
    BUK9K134-100EX
