BC857,215
BC857,215
    NEXPERIA(安世)
    SOT-23
    通用三极管 50V 100mA PNP SOT23 125~800
BC857,215 数据手册
BC856; BC857; BC858 65 V, 100 mA PNP general-purpose transistors Rev. 9 — 1 July 2022 Product data sheet 1. General description PNP general-purpose transistors in a small SOT23 (TO-236AB), Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package BC856 NPN complement Nexperia JEDEC SOT23 TO-236AB BC846 BC856A BC846A BC856B BC846B BC857 BC847 BC857A BC847A BC857B BC847B BC857C BC847C BC858B BC848B 2. Features and benefits • • Low current (max. 100 mA) Low voltage (max. 65 V) 3. Applications • General-purpose switching and amplification BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 4. Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base BC856; BC856A; BC856B - - -65 V BC857; BC857A; BC857B; BC857C - - -45 V BC858B - - -30 V IC collector current - - -100 mA ICM peak collector current - - -200 mA hFE DC current gain BC856 125 - 475 BC857 125 - 800 125 - 250 BC856B; BC857B; BC858B 220 - 475 BC857C 420 - 800 BC856A; BC857A VCE = 5 V; IC = 2 mA 5. Pinning information Table 3. Pinning information Pin Symbol Descrition 1 B base 2 E emitter 3 C collector Simlified outline Graphic symbol 3 C B E 1 sym132 2 6. Ordering information Table 4. Ordering information Type number Package BC856 Name Description Version TO-236AB plastic surface-mounted package; 3 leads SOT23 BC856A BC856B BC857 BC857A BC857B BC857C BC858B BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 2 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 7. Marking Table 5. Marking codes Type number Marking code BC856 [1] 3D% BC856A [1] 3A% BC856B [1] 3B% BC857 [1] 3H% BC857A [1] 3E% BC857B [1] 3F% BC857C [1] 3G% BC858B [1] 3K% [1] % = placeholder for manufacturing site code 8. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VCBO collector-base voltage open emitter Min Max Unit BC856; BC856A; BC856B - -80 V BC857; BC857A; BC857B; BC857C - -50 V - -30 V BC856; BC856A; BC856B - -65 V BC857; BC857A; BC857B; BC857C - -45 V BC858B - -30 V - -5 V BC858B VCEO collector-emitter voltage open base VEBO emitter-base voltage open collector IC collector current - -100 mA ICM peak collector current - -200 mA IBM peak base current - Ptot total power dissipation Tj -200 mA [1] - 250 mW junction temperature - 150 °C Tamb ambient temperature -65 150 °C Tstg storage temperature -65 150 °C [1] Tamb ≤ 25 °C Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided, 35 μm copper, tin-plated and standard footprint. BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 3 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 9. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air [1] thermal resistance from junction to ambient Min [1] - Typ Max Unit - 500 K/W Device mounted on an FR4 PCB; single-sided, 35 µm copper; tin-plated and standard footprint. aaa-028968 103 duty cycle = 1 Zth(j-a) (K/W) 0.5 102 0.75 0.33 0.2 0.1 0.05 10 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, single-sided, 35 μm copper, tin-plated and standard footprint Fig. 1. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 4 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 10. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions V(BR)CBO collector-base breakdown voltage BC856; BC856A; BC856B BC857; BC857A; BC857B; BC857C IC = -100 µA; IE = 0 A BC858B V(BR)CEO Min Typ Max Unit -80 - - V -50 - - V -30 - - V -65 - - V -45 - - V -30 - - V collector-emitter breakdown voltage BC856; BC856A; BC856B BC857; BC857A; BC857B; BC857C IC = -2 mA; IB = 0 A BC858B V(BR)EBO emitter-base breakdown voltage IC = 0 A; IE = -100 µA -5 - - V ICBO collector-base cut-off current VCB = -30 V; IE = 0 A - -1 -15 nA VCB = -30 V; IE = 0 A; Tj = 150 °C - - -4 µA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A - - -100 nA hFE DC current gain BC856 125 - 475 BC857 125 - 800 125 - 250 220 - 475 BC856A; BC857A BC856B; BC857B; BC858B VCE = -5 V; IC = -2 mA BC857C VCEsat VBEsat VBE 420 - 800 IC = -10 mA; IB = -0.5 mA - -75 -300 mV IC = -100 mA; IB = -5 mA [1] - -250 -650 mV base-emitter saturation IC = -10 mA; IB = -0.5 mA voltage IC = -100 mA; IB = -5 mA [1] - -700 - mV [1] - -850 - mV collector-emitter saturation voltage base-emitter voltage VCE = -5 V; IC = -2 mA -600 -650 -750 mV VCE = -5 V; IC = -10 mA - - -820 mV Cc collector capacitance VCB = -10 V; IE = ie = 0 A; f = 1 MHz - 4.5 - pF fT transition frequency VCE = -5 V; IC = -10 mA; f = 100 MHz 100 - - MHz NF noise figure IC = -200 µA; VCE = -5 V; RS = 2 kΩ; f = 1 kHz; B = 200Hz - 2 10 dB [1] pulsed; tp ≤ 300 μs; δ ≤ 0.02 BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 5 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors aaa-028117 400 mgt712 - 1200 VBE (mV) - 1000 hFE (1) 300 (1) - 800 (2) 200 100 (2) - 600 (3) - 400 (3) - 200 0 -10-1 Fig. 2. -1 -10 -102 IC (mA) 0 - 10- 2 -103 - 10- 1 -1 VCE = -5 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C VCE = -5 V (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC856A; BC857A: DC current gain as a function Fig. 3. of collector current; typical values BC856A; BC857A: Base-emitter voltage as a function of collector current; typical values mgt713 - 104 mgt714 - 1200 VBEsat (mV) - 1000 VCEsat (mV) - 103 (1) (2) - 800 (3) - 600 - 102 - 400 (1) - 200 (3) (2) - 10 - 10- 1 -1 - 10 - 102 IC (mA) 0 - 10- 1 - 103 IC/IB = 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 4. - 102 - 103 IC (mA) - 10 Product data sheet - 10 - 102 IC (mA) - 103 IC/IB = 20 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC856A; BC857A: Collector-emitter saturation voltage as a function of collector current; typical values BC856_BC857_BC858 -1 Fig. 5. BC856A; BC857A: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 6 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors aaa-028118 600 mgt716 - 1200 VBE (mV) - 1000 (1) hFE 400 (1) - 800 (2) (2) - 600 200 (3) - 400 (3) - 200 0 -10-1 -1 -10 -102 IC (mA) 0 - 10- 2 -103 VCE = -5 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 6. - 10- 1 -1 - 102 - 103 IC (mA) - 10 VCE = -5 V (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC856B; BC857B; BC858B: DC current gain as a function of collector current; typical values mgt717 - 104 Fig. 7. BC856B; BC857B; BC858B: Base-emitter voltage as a function of collector current; typical values mgt718 - 1200 VBEsat (mV) - 1000 VCEsat (mV) - 103 - 800 (1) (2) - 600 (3) - 102 - 400 (1) - 200 (3) (2) - 10 - 10- 1 -1 - 10 - 102 IC (mA) 0 - 10- 1 - 103 IC/IB = 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 8. Product data sheet - 10 - 102 IC (mA) - 103 IC/IB = 20 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC856B; BC857B; BC858B: Collector-emitter saturation voltage as a function of collector current; typical values BC856_BC857_BC858 -1 Fig. 9. BC856B; BC857B; BC858B: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 7 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors aaa-028119 1000 hFE mgt720 - 1200 VBE (mV) - 1000 (1) 800 (1) - 800 600 (2) (2) - 600 400 200 0 -10-1 (3) - 400 (3) - 200 -1 -10 -102 IC (mA) -103 0 - 10- 1 VCE = -5 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C -1 - 10 - 102 - 103 IC (mA) VCE = -5 V (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Fig. 10. BC857C: DC current gain as a function of collector current; typical values mgt721 - 104 Fig. 11. BC857C: Base-emitter voltage as a function of collector current; typical values mgt722 - 1200 VBEsat (mV) - 1000 VCEsat (mV) - 103 - 800 (1) (2) - 600 (3) - 102 - 400 (1) - 200 (3) (2) - 10 - 10- 1 -1 - 10 - 102 IC (mA) - 103 0 - 10- 1 IC/IB = 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C -1 - 10 - 102 IC (mA) - 103 IC/IB = 20 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Fig. 12. BC857C: Collector-emitter saturation voltage as Fig. 13. BC857C: Base-emitter saturation voltage as a a function of collector current; typical values function of collector current; typical values BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 8 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 11. Package outline Table 9. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 Dimensions in mm 0.15 0.09 18-03-12 Fig. 14. Package outline SOT23 (TO-236AB) BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 9 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 12. Soldering Table 10. Soldering 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig. 15. Reflow soldering footprint SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig. 16. Wave soldering footprint SOT23 (TO-236AB) BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 10 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BC856_BC857_BC858 v.9 20220701 - BC856_BC857_BC858 v.8 Modifications: • BC856_BC857_BC858 v.8 20210221 Product data sheet - BC856_BC857_BC858 v.7 BC856_BC857_BC858 v.7 20180416 Product data sheet - BC856_BC857_BC858 v.6 BC856_BC857_BC858 v.6 20040106 Product data sheet - BC856_BC857_BC858 v.5 BC856_BC857_BC858 Product data sheet Product data sheet Product(s) changed to non-automotive qualification. Please refer to nexperia.com for automotive (-Q) product alternative(s). All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 11 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BC856_BC857_BC858 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 12 / 13 BC856; BC857; BC858 Nexperia 65 V, 100 mA PNP general-purpose transistors Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................2 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 3 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Package outline.......................................................... 9 12. Soldering................................................................... 10 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 1 July 2022 BC856_BC857_BC858 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 13 / 13
BC857,215 价格&库存
很抱歉,暂时无法提供与“BC857,215”相匹配的价格&库存,您可以联系我们找货
BC857,215
  • 20+0.12858
库存:26
BC857,215
