PZT2222A,135
PZT2222A,135
    NEXPERIA(安世)
    SOT-223
    TRANS NPN 40V 0.6A SOT223
PZT2222A,135 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET handbook, halfpage M3D087 PZT2222A NPN switching transistor Product data sheet Supersedes data of 1997 Jun 02 1999 Apr 14 NXP Semiconductors Product data sheet NPN switching transistor PZT2222A FEATURES PINNING • High current (max. 600 mA) PIN • Low voltage (max. 40 V). DESCRIPTION 1 base 2, 4 APPLICATIONS collector 3 emitter • Switching and linear amplification. DESCRIPTION 4 handbook, halfpage 2, 4 NPN switching transistor in a SOT223 plastic package. PNP complement: PZT2907A. 1 3 1 2 3 Top view MAM287 Fig.1 Simplified outline (SOT223) and symbol. LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VCBO collector-base voltage open emitter − 75 V VCEO collector-emitter voltage open base − 40 V VEBO emitter-base voltage open collector − 6 V IC collector current (DC) − 600 mA ICM peak collector current − 800 mA IBM peak base current − 200 mA Ptot total power dissipation − 1.15 W Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Tamb operating ambient temperature −65 +150 °C Tamb ≤ 25 °C; note 1 Note 1. Device mounted on a printed-circuit board, single-sided copper, tinplated, mounting pad for collector 1 cm2. For other mounting conditions, see “Thermal considerations for SOT223 in the General Part of associated Handbook”. 1999 Apr 14 2 NXP Semiconductors Product data sheet NPN switching transistor PZT2222A THERMAL CHARACTERISTICS SYMBOL PARAMETER CONDITIONS Rth j-a thermal resistance from junction to ambient Rth j-s thermal resistance from junction to soldering point VALUE UNIT 109 K/W 28 K/W note 1 Note 1. Device mounted on a printed-circuit board, single-sided copper, tinplated, mounting pad for collector 1 cm2. For other mounting conditions, see “Thermal considerations for SOT223 in the General Part of associated Handbook”. CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL ICBO PARAMETER collector cut-off current CONDITIONS MIN. MAX. UNIT IE = 0; VCB = 60 V − 10 nA IE = 0; VCB = 60 V; Tamb = 125 °C − 10 µA nA IEBO emitter cut-off current IC = 0; VEB = 5 V − 10 hFE DC current gain IC = 0.1 mA; VCE = 10 V 35 − IC = 1 mA; VCE = 10 V 50 − IC = 10 mA; VCE = 10 V 75 − IC = 10 mA; VCE = 10 V; Tamb = −55 °C 35 − IC = 150 mA; VCE = 1 V; note 1 50 − IC = 150 mA; VCE = 10 V; note 1 100 300 IC = 500 mA; VCE = 10 V; note 1 40 − IC = 150 mA; IB = 15 mA − 300 mV IC = 500 mA; IB = 50 mA − 1 V IC = 150 mA; IB = 15 mA 0.6 1.2 V IC = 500 mA; IB = 50 mA − 2 V VCEsat collector-emitter saturation voltage VBEsat base-emitter saturation voltage Cc collector capacitance IE = ie = 0; VCB = 10 V; f = 1 MHz − 8 pF Ce emitter capacitance IC = ic = 0; VEB = 500 mV; f = 1 MHz − 25 pF fT transition frequency IC = 20 mA; VCE = 20 V; f = 100 MHz 300 − MHz − 35 ns − 10 ns Switching times (between 10% and 90% levels); (see Fig.2) ton turn-on time ICon = 150 mA; IBon = 15 mA; IBoff = −15 mA; Tamb = 25 °C td delay time tr rise time − 25 ns toff turn-off time − 250 ns ts storage time − 200 ns tf fall time − 60 ns Note 1. Pulse test: tp ≤ 300 µs; δ ≤ 0.02. 1999 Apr 14 3 NXP Semiconductors Product data sheet NPN switching transistor PZT2222A VBB handbook, full pagewidth RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω R2 Vi DUT R1 MLB826 Vi = 9.5 V; T = 500 µs; tp = 10 µs; tr = tf ≤ 3 ns. R1 = 68 Ω; R2 = 325 Ω; RB = 325 Ω; RC = 160 Ω. VBB = −3.5 V; VCC = 29.5 V. Oscilloscope input impedance Zi = 50 Ω. Fig.2 Test circuit for switching times. 1999 Apr 14 4 oscilloscope NXP Semiconductors Product data sheet NPN switching transistor PZT2222A PACKAGE OUTLINE Plastic surface mounted package; collector pad for good heat transfer; 4 leads D SOT223 E B A X c y HE v M A b1 4 Q A A1 1 2 3 Lp bp e1 w M B detail X e 0 2 4 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp b1 c D E e e1 HE Lp Q v w y mm 1.8 1.5 0.10 0.01 0.80 0.60 3.1 2.9 0.32 0.22 6.7 6.3 3.7 3.3 4.6 2.3 7.3 6.7 1.1 0.7 0.95 0.85 0.2 0.1 0.1 OUTLINE VERSION SOT223 1999 Apr 14 REFERENCES IEC JEDEC EIAJ SC-73 5 EUROPEAN PROJECTION ISSUE DATE 97-02-28 99-09-13 NXP Semiconductors Product data sheet NPN switching transistor PZT2222A DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions 1999 Apr 14 6 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content, except for package outline drawings which were updated to the latest version. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 115002/00/03/pp7 Date of release: 1999 Apr 14 Document order number: 9397 750 05636
PZT2222A,135
物料型号:PZT2222A
器件简介:PZT2222A是一款NPN开关晶体管,由Nexperia公司生产,适用于开关和线性放大应用。
引脚分配:1号引脚为基极(B),2号和4号引脚为集电极(C),3号引脚为发射极(E)。
参数特性: - 集电极-基极电压(VCBO):最大75V - 集电极-发射极电压(VCEO):最大40V - 发射极-基极电压(VEBO):最大6V - 直流集电极电流(Ic):最大600mA - 峰值集电极电流(ICM):最大800mA - 峰值基极电流(BM):最大200mA - 总功率耗散(Ptot):最大1.15W
功能详解: - 热特性:包括从结到环境的热阻(Rth j-a)和从结到焊接点的热阻(Rth j-s)。 - 电气特性:包括集电极截止电流(ICBO)、发射极截止电流(IEBO)、直流电流增益(hFE)、饱和电压(VCEsat)、基极-发射极饱和电压(VBEsat)、集电极电容(Cc)、发射极电容(Ce)和转换频率(fT)。 - 开关时间:包括开启时间(ton)、延迟时间(td)、上升时间(tr)、关闭时间(toff)、存储时间(ts)和下降时间(tf)。
应用信息:适用于开关和线性放大。
封装信息:SOT223塑料表面封装,具有用于良好热传递的集电极垫,共4个引脚。
PZT2222A,135 价格&库存
很抱歉,暂时无法提供与“PZT2222A,135”相匹配的价格&库存,您可以联系我们找货
PZT2222A,135
  • 1+5.122561+0.66592
  • 10+3.1503810+0.40954
  • 100+2.00335100+0.26043
  • 500+1.50823500+0.19607
  • 1000+1.348231000+0.17527
  • 2000+1.213432000+0.15775
PZT2222A,135
  • 4000+1.099934000+0.14299
  • 8000+1.004408000+0.13057
  • 12000+0.9557112000+0.12424
  • 20000+0.9010020000+0.11713
  • 28000+0.8686128000+0.11292
  • 40000+0.8371040000+0.10882
PZT2222A,135
