2PD601ART,235
2PD601ART,235
    NEXPERIA(安世)
    SOT-23
    通用三极管 NPN Ic=100mA Vceo=50V hfe=210~340 P=250mW SOT23
2PD601ART,235 数据手册
2PD601ART 50 V, 100 mA NPN general-purpose transistor Rev. 01 — 15 March 2007 Product data sheet 1. Product profile 1.1 General description NPN general-purpose transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. PNP complement: 2PB709ART. 1.2 Features n General-purpose transistor n Small SMD plastic package 1.3 Applications n General-purpose switching and amplification 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 50 V IC collector current - - 100 mA hFE DC current gain 210 - 340 VCE = 10 V; IC = 2 mA 2. Pinning information Table 2. Pinning Pin Description 1 base 2 emitter 3 collector Simplified outline Symbol 3 3 1 1 2 2 sym021 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 3. Ordering information Table 3. Ordering information Type number 2PD601ART Package Name Description Version - plastic surface-mounted package; 3 leads SOT23 4. Marking Table 4. Marking codes Type number Marking code[1] 2PD601ART C3* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 60 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 6 V IC collector current - 100 mA ICM peak collector current single pulse; tp ≤ 1 ms - 200 mA IBM peak base current single pulse; tp ≤ 1 ms - 100 mA Ptot total power dissipation Tamb ≤ 25 °C - 250 mW Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2PD601ART Product data sheet [1] © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 2 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 006aaa990 300 Ptot (mW) 200 100 0 −75 −25 25 75 125 175 Tamb (°C) FR4 PCB, standard footprint Fig 1. Power derating curve 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point [1] in free air Min Typ Max Unit - - 500 K/W - - 140 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2PD601ART Product data sheet [1] © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 3 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 006aaa991 103 δ=1 0.75 0.50 0.33 Zth(j-a) (K/W) 102 0.20 0.10 0.05 10 0.02 0.01 0 1 10−5 10−4 10−3 10−2 10−1 1 102 10 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration for SOT23 (TO-236AB); typical values 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 60 V; IE = 0 A - - 10 nA VCB = 60 V; IE = 0 A; Tj = 150 °C - - 5 µA nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 10 hFE DC current gain VCE = 2 V; IC = 100 mA 90 - - VCE = 10 V; IC = 2 mA 210 - 340 - - 250 mV collector-emitter saturation voltage IC = 100 mA; IB = 10 mA fT transition frequency VCE = 10 V; IC = 2 mA; f = 100 MHz 100 - - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - - 3 pF [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. 2PD601ART Product data sheet [1] VCEsat © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 4 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 006aaa992 500 006aaa993 0.1 IB (mA) = 0.56 IC (A) hFE (1) 400 0.50 0.44 0.08 0.38 0.32 300 0.26 0.06 (2) 0.20 200 0.04 0.14 (3) 100 0.08 0.02 0.02 0 10−1 1 102 10 0 0 2 4 6 8 IC (mA) 10 VCE (V) Tamb = 25 °C VCE = 10 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 3. DC current gain as a function of collector current; typical values 006aaa994 1.3 VBEsat (V) Fig 4. Collector current as a function of collector-emitter voltage; typical values 006aaa995 1 VCEsat (V) 0.9 (1) (2) 0.5 10−1 (3) (1) (2) (3) 0.1 10−1 1 102 10 10−2 10−1 IC (mA) 102 10 IC (mA) IC/IB = 10 IC/IB = 10 (1) Tamb = −55 °C (1) Tamb = 150 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 150 °C (3) Tamb = −55 °C Fig 5. Base-emitter saturation voltage as a function of collector current; typical values Fig 6. Collector-emitter saturation voltage as a function of collector current; typical values 2PD601ART Product data sheet 1 © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 5 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 8. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 Dimensions in mm 0.48 0.38 0.15 0.09 04-11-04 Fig 7. Package outline SOT23 (TO-236AB) 9. Packing information Please refer to packing information on www.nexperia.com. 2PD601ART Product data sheet © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 6 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 10. Soldering 2.90 2.50 0.85 2 1 solder lands 1.30 3.00 2.70 0.85 solder resist solder paste 3 occupied area 0.60 (3x) Dimensions in mm 0.50 (3x) 0.60 (3x) 1.00 3.30 sot023 Fig 8. Reflow soldering footprint SOT23 (TO-236AB) 3.40 1.20 (2x) solder lands solder resist occupied area 2 1 4.60 4.00 1.20 3 Dimensions in mm 2.80 preferred transport direction during soldering 4.50 sot023 Fig 9. Wave soldering footprint SOT23 (TO-236AB) 2PD601ART Product data sheet © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 7 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes 2PD601ART_1 20070315 Product data sheet - - 2PD601ART Product data sheet © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 8 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http:// www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 2PD601ART Product data sheet © Nexperia B.V. 2007. All rights reserved. Rev. 01 — 15 March 2007 9 of 10 2PD601ART Nexperia 50 V, 100 mA NPN general-purpose transistor 13. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description. . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data. . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics. . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information. . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 1 2 2 2 3 4 6 6 7 8 9 9 9 9 9 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Nexperia B.V. 2007. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 March 2007 Document identifier: 2PD601ART
2PD601ART,235 价格&库存
很抱歉,暂时无法提供与“2PD601ART,235”相匹配的价格&库存,您可以联系我们找货
