2PC4081
NPN general-purpose transistor
Rev. 06 — 17 November 2009
Product data sheet
1. Product profile
1.1 General description
NPN transistor in a SOT323 (SC-70) plastic package. The PNP complement is 2PA1576.
1.2 Features
Low current (max. 150 mA)
Low voltage (max. 50 V)
1.3 Applications
General-purpose switching
Small signal amplification
2. Pinning information
Table 1.
Pinning
Pin
Description
1
base
2
emitter
3
collector
Simplified outline
Symbol
3
3
1
1
2
2
sym021
3. Ordering information
Table 2.
Type number
2PC4081Q
2PC4081R
2PC4081S
Package
Name
Description
Version
SC-70
plastic surface mounted package; 3 leads
SOT323
2PC4081
Nexperia
4. Marking
Table 3.
Marking codes
Type number
Marking code[1]
2PC4081Q
Z*Q
2PC4081R
Z*R
2PC4081S
Z*S
[1]
* = -: made in Hong Kong
* = t: made in Malaysia
5. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Conditions
Min
Max
Unit
VCBO
Symbol Parameter
collector-base voltage
open emitter
60
V
VCEO
collector-emitter voltage
open base
50
V
VEBO
emitter-base voltage
open collector
7
V
IC
collector current (DC)
150
mA
ICM
peak collector current
200
mA
IBM
peak base current
200
mA
200
mW
Ptot
total power dissipation
Tamb ≤ 25 °C
[1]
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
[1]
Transistor mounted on an FR4 printed-circuit board, single-sided copper, tin-plated and standard footprint.
6. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-a)
thermal resistance from
junction to ambient
[1]
Conditions
Min
Typ
Max
Unit
625
K/W
2PC4081
Product data sheet
[1]
© Nexperia B.V. 2009. All rights reserved.
2 of 7
2PC4081
Nexperia
7. Characteristics
Table 6.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base
cut-off current
IE = 0 A; VCB = 30 V
100
nA
IE = 0 A; VCB = 30 V;
Tj = 150 °C
5
μA
IEBO
emitter-base
cut-off current
IC = 0 A; VEB = 4 V
100
nA
hFE
DC current gain
IC = 1 mA; VCE = 6 V
2PC4081Q
120
270
2PC4081R
180
390
270
560
400
mV
2PC4081S
collector-emitter
saturation
voltage
IC = 50 mA; IB = 5 mA
Cc
collector
capacitance
IE = ie = 0 A;
VCB = 12 V; f = 1 MHz
2
3.5
pF
fT
transition
frequency
IC = 2 mA; VCE = 12 V;
f = 100 MHz
100
MHz
[1]
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
2PC4081
Product data sheet
[1]
VCEsat
3 of 7
2PC4081
Nexperia
8. Package outline
Plastic surface-mounted package; 3 leads
SOT323
D
E
B
A
X
HE
y
v M A
3
Q
A
A1
c
1
2
e1
bp
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.8
0.1
0.4
0.3
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.23
0.13
0.2
0.2
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT323
Fig 1.
JEITA
SC-70
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
Package outline SOT323 (SC-70)
2PC4081
Product data sheet
4 of 7
2PC4081
Nexperia
9. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
2PC4081_6
20091117
Product data sheet
2PC4081_5
Modifications:
This data sheet was changed to reflect the new company name NXP
Semiconductors, including new legal definitions and disclaimers. No changes were
made to the technical content.
Figure 1 “Package outline SOT323 (SC-70)”: updated
2PC4081_5
20041125
Product data sheet
2PC4081_4
2PC4081_4
19990408
Product specification
2PC4081_3
2PC4081_3
19970704
2PC4081_2
2PC4081_2
19931213
n.a.
n.a.
2PC4081
Product data sheet
5 of 7
2PC4081
Nexperia
10. Legal information
10.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Definition
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
10.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included
herein and shall have no liability for the consequences of use of such
information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data
sheet, the full data sheet shall prevail.
10.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in medical, military, aircraft, space or life
support equipment, nor in applications where failure or malfunction of an
Nexperia product can reasonably be expected to result in personal injury,
death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore such inclusion
and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold subject to the
general terms and conditions of commercial sale, as published at https://
www.nexperia.com/about/terms-and-policies/terms-and-conditions.html,
including those pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly otherwise agreed to in
writing by Nexperia. In case of any inconsistency or conflict between
information in this document and such terms and conditions, the latter will
prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s)
described herein may be subject to export control regulations. Export
might require a prior authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
10.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
2PC4081
Product data sheet
6 of 7
2PC4081
Nexperia
11. Contents
1
1.1
1.2
1.3
2
3
4
5
6
7
8
9
10
10.1
10.2
10.3
10.4
11
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . .
General description . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . .
Pinning information . . . . . . . . . . . . . . . . . . . . . .
Ordering information . . . . . . . . . . . . . . . . . . . . .
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . .
Thermal characteristics . . . . . . . . . . . . . . . . . .
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . .
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .
Legal information. . . . . . . . . . . . . . . . . . . . . . . .
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1
1
1
1
1
1
2
2
2
3
4
5
6
6
6
6
6
7
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to:
salesaddresses@nexperia.com
Date of release: 17 November 2009
Document identifier: 2PC4081
很抱歉,暂时无法提供与“2PC4081R,135”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.676721+0.21756
- 10+1.0338010+0.13414
- 100+0.63673100+0.08262
- 500+0.46314500+0.06010
- 1000+0.406701000+0.05277
- 2000+0.359142000+0.04660
- 5000+0.307425000+0.03989
- 国内价格 香港价格
- 10000+0.2753510000+0.03573
- 20000+0.2483420000+0.03223
- 30000+0.2345530000+0.03044
- 50000+0.2190750000+0.02843
- 70000+0.2098970000+0.02724
- 100000+0.20097100000+0.02608
