BF820W,115
BF820W,115
    NEXPERIA(安世)
    SOT-323
    NPN高压晶体管
BF820W,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET ge M3D102 BF820W NPN high-voltage transistor Product data sheet Supersedes data of 1997 Sep 03 2003 Sep 09 NXP Semiconductors Product data sheet NPN high-voltage transistor BF820W FEATURES PINNING • Low current (max. 50 mA) PIN • High voltage (max. 300 V). 1 base 2 emitter 3 collector APPLICATIONS DESCRIPTION • Telephony and professional communication equipment. DESCRIPTION 3 handbook, halfpage NPN high-voltage transistor in a SOT323 plastic package. 3 MARKING 1 MARKING CODE(1) TYPE NUMBER BF820W 2 1 1V* 2 Top view Notes 1. * = p : made in Hong Kong. * = t : made in Malaysia. * = W : made in China. MAM062 Fig.1 Simplified outline (SOT323) and symbol. QUICK REFERENCE DATA SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VCBO collector-base voltage open emitter − 300 V VCEO collector-emitter voltage open base − 300 V ICM peak collector current − 100 mA Ptot total power dissipation Tamb ≤ 25 °C − 200 mW hFE DC current gain IC = 25 mA; VCE = 20 V 50 − Cre feedback capacitance IC = ic = 0; VCB = 30 V; f = 1 MHz − 1.6 pF fT transition frequency IC = 10 mA; VCE = 10 V; f = 100 MHz 60 − MHz 2003 Sep 09 2 NXP Semiconductors Product data sheet NPN high-voltage transistor BF820W LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VCBO collector-base voltage open emitter − 300 V VCEO collector-emitter voltage open base − 300 V VEBO emitter-base voltage open collector − 5 V IC collector current (DC) − 50 mA ICM peak collector current − 100 mA IBM peak base current − 50 mA Ptot total power dissipation − 200 mW Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Tamb operating ambient temperature −65 +150 °C Tamb ≤ 25 °C; note 1 Note 1. Transistor mounted on an FR4 printed-circuit board. THERMAL CHARACTERISTICS SYMBOL Rth j-a PARAMETER CONDITIONS thermal resistance from junction to ambient note 1 VALUE UNIT 625 K/W Note 1. Transistor mounted on an FR4 printed-circuit board. CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT IE = 0; VCB = 200 V − 10 nA IE = 0; VCB = 200 V; Tj = 150 °C − 10 µA IC = 0; VEB = 5 V − 50 nA DC current gain IC = 25 mA; VCE = 20 V 50 − VCEsat collector-emitter saturation voltage IC = 30 mA; IB = 5 mA; note 1 − 600 mV Cre feedback capacitance IC = ic = 0; VCB = 30 V; f = 1 MHz − 1.6 pF fT transition frequency IC = 10 mA; VCE = 10 V; f = 100 MHz 60 − MHz ICBO collector cut-off current IEBO emitter cut-off current hFE Note 1. Pulse test: tp ≤ 300 µs; δ ≤ 0.02. 2003 Sep 09 3 NXP Semiconductors Product data sheet NPN high-voltage transistor BF820W PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT323 D E B A X HE y v M A 3 Q A A1 c 1 2 e1 bp Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w mm 1.1 0.8 0.1 0.4 0.3 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.23 0.13 0.2 0.2 OUTLINE VERSION SOT323 2003 Sep 09 REFERENCES IEC JEDEC EIAJ SC-70 4 EUROPEAN PROJECTION ISSUE DATE 97-02-28 NXP Semiconductors Product data sheet NPN high-voltage transistor BF820W DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions 2003 Sep 09 5 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613514/04/pp6 Date of release: 2003 Sep 09 Document order number: 9397 750 11651
BF820W,115
PDF文档中包含的物料型号是STM32F103C8T6,这是一款基于ARM Cortex-M3内核的32位微控制器,主要用于需要高性能和低成本的应用场景。
器件简介指出其具有多个I/O端口和外设,如ADC、定时器、CAN和USB接口。
引脚分配详细列出了所有引脚的功能,如电源、地、I/O端口、复用功能等。
参数特性包括工作电压、工作温度范围、存储器大小等。
功能详解提供了关于该芯片的外设和功能的详细描述,如ADC分辨率、定时器模式等。
应用信息讨论了该芯片可能的应用领域,如工业控制、医疗设备和消费电子产品。
封装信息说明了该芯片的物理封装类型,如LQFP48,以及其尺寸和引脚排列。
BF820W,115 价格&库存
很抱歉,暂时无法提供与“BF820W,115”相匹配的价格&库存,您可以联系我们找货
BF820W,115
  • 1+2.224501+0.28815
  • 10+1.6400210+0.21244
  • 25+1.0555525+0.13673
  • 100+0.89853100+0.11639
  • 250+0.80257250+0.10396
  • 500+0.75023500+0.09718
  • 1000+0.715331000+0.09266
  • 3000+0.645543000+0.08362
库存:1632
BF820W,115
  • 1+3.083031+0.39936
  • 10+1.8786210+0.24335
  • 100+1.17593100+0.15233
  • 500+0.86967500+0.11266
  • 1000+0.770691000+0.09983
库存:90
BF820W,115
