BSP60,115
BSP60,115
    NEXPERIA(安世)
    SOT-223
    达林顿三极管 PNP Ic=1A Vceo=45V hfe=1000 P=1.25W SOT223
BSP60,115 数据手册
BSP60 PNP Darlington transistor 2 May 2018 Product data sheet 1. General description PNP Darlington transistor in an SOT223 plastic package. NPN complement: BSP50 2. Features and benefits • • • • High current of -1 A Low voltage of -45 V Integrated diode and resistor AEC-Q101 qualified 3. Applications • Industrial switching applications such as: - Print hammer - Solenoid - Relay and lamp drivers 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCBO collector-base voltage open emitter - - -60 V VCES collector-emitter voltage base short-circuited to emitter - - -45 V IC collector current - - -1 A ICM peak collector current - - -2 A hFE DC current gain 1000 - - [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. VCE = -10 V; IC = -150 mA [1] BSP60 Nexperia PNP Darlington transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 C collector 3 E emitter 4 C collector Simplified outline Graphic symbol 4 C B 1 2 3 SC-73 (SOT223) E aaa-027605 6. Ordering information Table 3. Ordering information Type number BSP60 Package Name Description Version SC-73 plastic, surface-mounted package with increased heatsink; 4 leads; 4.6 mm pitch; 6.5 mm x 3.5 mm x 1.65 mm body SOT223 7. Marking Table 4. Marking codes Type number Marking code BSP60 BSP60 BSP60 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 2 / 10 BSP60 Nexperia PNP Darlington transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -60 V VCES collector-emitter voltage base short-circuited to emitter - -45 V VEBO emitter-base voltage open collector - -5 V IC collector current - -1 A ICM peak collector current - -2 A IBlim limiting base current - -100 mA Ptot total power dissipation - 1.25 W Tj junction temperature - 150 °C Tamb ambient temperature -65 150 °C Tstg storage temperature -65 150 °C [1] Tamb ≤ 25 °C [1] 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for collector 1 cm . 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point [1] Conditions [1] Min Typ Max Unit - - 98 K/W - - 17 K/W 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for collector 1 cm . BSP60 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 3 / 10 BSP60 Nexperia PNP Darlington transistor 10. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified Symbol Parameter Conditions Min Typ Max Unit V(BR)CBO collector-base breakdown voltage IC = -100 µA; IE = 0 A -60 - - V V(BR)CES collector-emitter breakdown voltage IC = -2 mA; VBE = 0 V -45 - - V V(BR)EBO emitter-base breakdown voltage IC = 0 A; IE = -100 µA -5 - - V ICES collector-emitter cut-off VBE = 0 V; VCE = -45 V current - - -50 nA IEBO emitter-base cut-off current VEB = -4 V; IC = 0 A - - -50 nA hFE DC current gain VCE = -10 V; IC = -150 mA [1] 1000 - - VCE = -10 V; IC = -500 mA [1] 2000 - - IC = -500 mA; IB = -0.5 mA - - -1.3 V IC = -500 mA; IB = -0.5 mA; Tj = 150 °C - - -1.3 V VCEsat collector-emitter saturation voltage VBEsat base-emitter saturation IC = -500 mA; IB = -0.5 mA voltage - - -1.9 V ton turn-on time - 400 - ns toff turn-off time IC = -500 mA; IBon = -0.5 mA; IBoff = 0.5 mA - 1500 - ns fT transition frequency VCE = -5 V; IC = -500 mA; f = 100 MHz - 200 - MHz [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. mgd839 6000 hFE 5000 4000 3000 2000 1000 0 - 10- 1 -1 - 10 - 102 IC (mA) - 103 VCE = -10 V Fig. 1. DC current gain; typical values BSP60 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 4 / 10 BSP60 Nexperia PNP Darlington transistor 11. Test information - IB input pulse (idealized waveform) 90 % - I Bon (100 %) 10 % - I Boff output pulse (idealized waveform) - IC 90 % - I C (100 %) 10 % t td ts tr t on Fig. 2. tf t off 006aaa266 Transistor switching time definition VBB RB VCC RC (probe) oscilloscope 450 Ω Vo (probe) 450 Ω R2 VI oscilloscope DUT R1 mgd624 VI = -10 V; T = 200 µs; tp = 6 µs; tr = tf ≤ 3 ns. R1 = 56 Ω; R2 = 10 kΩ; RB = 10 kΩ; RC = 18 Ω. VBB = 1.8 V; VCC = -10.7 V. Oscilloscope: input impedance Zi = 50 Ω. Fig. 3. Test circuit or switching times Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BSP60 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 5 / 10 BSP60 Nexperia PNP Darlington transistor 12. Package outline Plastic surface-mounted package with increased heatsink; 4 leads D SOT223 E B A X c y HE v M A b1 4 Q A A1 1 2 e1 3 Lp bp w M B detail X e 0 2 4 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp b1 c D E e e1 HE Lp Q v w y mm 1.8 1.5 0.10 0.01 0.80 0.60 3.1 2.9 0.32 0.22 6.7 6.3 3.7 3.3 4.6 2.3 7.3 6.7 1.1 0.7 0.95 0.85 0.2 0.1 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT223 Fig. 4. JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-10 06-03-16 SC-73 Package outline SC-73 (SOT223) BSP60 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 6 / 10 BSP60 Nexperia PNP Darlington transistor 13. Soldering 7 3.85 3.6 3.5 0.3 1.3 1.2 (4×) (4×) solder lands 4 solder resist 3.9 6.1 7.65 solder paste occupied area 1 2 3 Dimensions in mm 2.3 2.3 1.2 (3×) 1.3 (3×) 6.15 Fig. 5. sot223_fr Reflow soldering footprint for SC-73 (SOT223) 8.9 6.7 1.9 solder lands 4 solder resist 6.2 1 2 8.7 Dimensions in mm 3 1.9 (3×) 2.7 preferred transport direction during soldering 2.7 1.1 Fig. 6. occupied area 1.9 (2×) sot223_fw Wave soldering footprint for SC-73 (SOT223) BSP60 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 7 / 10 BSP60 Nexperia PNP Darlington transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BSP60 v.4 20180502 Product data sheet - BSP60 v.3 - BSP60_61_62 v.2 Modifications: BSP60 v.3 BSP60 Product data sheet • ICES values corrected. 20180216 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 8 / 10 BSP60 Nexperia PNP Darlington transistor for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BSP60 Product data sheet Trademarks All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 9 / 10 BSP60 Nexperia PNP Darlington transistor 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 4 11. Test information..........................................................5 12. Package outline.......................................................... 6 13. Soldering..................................................................... 7 14. Revision history..........................................................8 15. Legal information....................................................... 9 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 May 2018 BSP60 Product data sheet All information provided in this document is subject to legal disclaimers. 2 May 2018 © Nexperia B.V. 2018. All rights reserved 10 / 10
BSP60,115 价格&库存
很抱歉,暂时无法提供与“BSP60,115”相匹配的价格&库存,您可以联系我们找货
