PBSS4041NZ,115
PBSS4041NZ,115
    NEXPERIA(安世)
    SOT-223
    三极管 NPN Ic=7A Vceo=60V hfe=500 P=2600mW SOT223-4
PBSS4041NZ,115 数据手册
PBSS4041NZ 60 V, 7 A NPN low VCEsat (BISS) transistor Rev. 2 — 8 August 2012 Product data sheet 1. Product profile 1.1 General description NPN low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT223 (SC-73) medium power Surface-Mounted Device (SMD) plastic package. PNP complement: PBSS4041PZ. 1.2 Features and benefits  Very low collector-emitter saturation voltage VCEsat  High energy efficiency due to less heat generation  High collector current capability IC and ICM  AEC-Q101 qualified  High collector current gain (hFE) at high IC  Smaller required PCB area than for conventional transistors 1.3 Applications  Loadswitch  Charging circuits  Battery-driven devices  Power switches (e.g. motors, fans)  Power management 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 60 V IC collector current - - 7 A ICM peak collector current single pulse; tp ≤ 1 ms - - 15 A RCEsat collector-emitter saturation resistance IC = 6 A; IB = 600 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 17.5 25 mΩ PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 C collector 3 E emitter 4 C collector Simplified outline Graphic symbol C 4 B 1 2 3 E SOT223 (SC-73) sym123 3. Ordering information Table 3. Ordering information Type number Package PBSS4041NZ Name Description Version SC-73 plastic surface-mounted package with increased heatsink; 4 leads SOT223 4. Marking Table 4. Marking codes Type number Marking code PBSS4041NZ PB4041NZ 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 60 V VCEO collector-emitter voltage open base - 60 V VEBO emitter-base voltage open collector - 5 V IC collector current - 7 A ICM peak collector current single pulse; tp ≤ 1 ms - 15 A IB base current Ptot total power dissipation PBSS4041NZ Product data sheet Tamb ≤ 25 °C All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 - 1 A [1] - 770 mW [2] - 1700 mW [3] - 2600 mW © Nexperia B.V. 2017. All rights reserved 2 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit Tj junction temperature Conditions - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C Unit [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aac060 3.0 (1) Ptot (W) 2.0 (2) 1.0 (3) 0 −75 −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 6 cm2 (3) FR4 PCB, standard footprint Fig 1. Power derating curves 6. Thermal characteristics Table 6. Symbol Rth(j-a) Rth(j-sp) Thermal characteristics Parameter thermal resistance from junction to ambient Conditions in free air thermal resistance from junction to solder point Min Typ Max [1] - - 160 K/W [2] - - 75 K/W [3] - - 50 K/W - - 11 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 3 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 006aac061 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.5 0.33 0.2 0.1 10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aac062 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 10 0.1 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 6 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 4 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 006aac063 102 duty cycle = 1 Zth(j-a) (K/W) 0.75 0.50 0.33 10 0.20 0.10 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 102 10 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 7. Characteristics Symbol Parameter ICBO collector-base cut-off current Conditions Min Typ Max Unit VCB = 60 V; IE = 0 A; Tamb = 25 °C - - 100 nA VCB = 60 V; IE = 0 A; Tj = 150 °C - - 50 µA ICES collector-emitter cut-off VCE = 48 V; VBE = 0 V; Tamb = 25 °C current - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A; Tamb = 25 °C - - 100 nA hFE DC current gain VCE = 2 V; IC = 500 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 300 500 - VCE = 2 V; IC = 1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 300 500 - VCE = 2 V; IC = 2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 300 500 - VCE = 2 V; IC = 4 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 250 400 - VCE = 2 V; IC = 6 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 100 200 - VCE = 2 V; IC = 7 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 50 100 - PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 5 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor Table 7. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit VCEsat collector-emitter saturation voltage IC = 1 A; IB = 50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 25 35 mV IC = 1 A; IB = 10 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 43 60 mV IC = 2 A; IB = 40 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 53 75 mV IC = 4 A; IB = 200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 78 110 mV IC = 4 A; IB = 40 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 115 160 mV IC = 7 A; IB = 350 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 130 195 mV RCEsat collector-emitter saturation resistance IC = 6 A; IB = 600 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 17.5 25 mΩ VBEsat base-emitter saturation IC = 1 A; IB = 100 mA; pulsed; voltage tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 0.83 0.9 V IC = 4 A; IB = 400 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 0.98 1.05 V VBEon base-emitter turn-on voltage VCE = 2 V; IC = 2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 0.72 0.85 V td delay time - 55 - ns tr rise time VCC = 12.5 V; IC = 1 A; IBon = 0.05 A; IBoff = -0.05 A; Tamb = 25 °C - 55 - ns ton turn-on time - 110 - ns ts storage time - 1220 - ns tf fall time - 230 - ns toff turn-off time - 1450 - ns fT transition frequency VCE = 10 V; IC = 100 mA; f = 100 MHz; Tamb = 25 °C - 105 - MHz Cc collector capacitance VCB = 10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C - 50 - pF PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 6 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 006aac156 1500 006aac157 16.0 IB (mA) = 120 108 IC (A) hFE 12.0 (1) 96 84 72 60 48 1000 (2) 36 24 8.0 12 500 (3) 4.0 0 10−1 1 10 102 103 0.0 0.0 104 105 IC (mA) 1.0 2.0 3.0 4.0 5.0 VCE (V) Tamb = 25 °C VCE = 2 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 5. DC current gain as a function of collector current; typical values Fig 6. 006aac158 1.2 VBE (V) Collector current as a function of collector-emitter voltage; typical values 006aac159 1.3 VBEsat (V) 0.8 0.9 (1) (1) (2) (2) (3) 0.4 0.0 10−1 Fig 7. 1 10 0.5 102 103 (3) 0.1 10−1 104 105 IC (mA) 1 10 VCE = 2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values PBSS4041NZ Product data sheet Fig 8. 102 103 104 105 IC (mA) Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 7 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 006aac160 1 006aac161 1 VCEsat (V) VCEsat (V) 10−1 10−1 (1) 10−2 10−2 (2) (1) (2) (3) (3) 10−3 10−1 Fig 9. 1 10 102 103 104 105 IC (mA) 10−3 10−1 1 10 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Collector-emitter saturation voltage as a function of collector current; typical values 006aac162 102 102 103 104 105 IC (mA) Fig 10. Collector-emitter saturation voltage as a function of collector current; typical values 006aac163 103 RCEsat (Ω) RCEsat (Ω) 102 10 10 1 10−1 (1) 1 (1) 10−1 (2) (2) (3) (3) 10−2 10−1 1 10 102 103 104 105 IC (mA) 10−2 10−1 1 10 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 11. Collector-emitter saturation resistance as a function of collector current; typical values PBSS4041NZ Product data sheet 102 103 104 105 IC (mA) Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 8 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 8. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig 13. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mlb826 Fig 14. Test circuit for switching times 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standardQ101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 9 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 9. Package outline 6.7 6.3 3.1 2.9 1.8 1.5 4 1.1 0.7 7.3 6.7 3.7 3.3 1 2 3 0.8 0.6 2.3 4.6 0.32 0.22 Dimensions in mm 04-11-10 Fig 15. SOT223 (SC-73) 10. Soldering 7 3.85 3.6 3.5 0.3 1.3 1.2 (4×) (4×) solder lands 4 solder resist 3.9 6.1 7.65 solder paste occupied area 1 2 3 Dimensions in mm 2.3 2.3 1.2 (3×) 1.3 (3×) 6.15 sot223_fr Fig 16. Reflow soldering footprint for SOT223 (SC-73) PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 10 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 8.9 6.7 1.9 solder lands 4 solder resist 6.2 8.7 occupied area Dimensions in mm 1 2 3 1.9 (3×) 2.7 preferred transport direction during soldering 2.7 1.1 1.9 (2×) sot223_fw Fig 17. Wave soldering footprint for SOT223 (SC-73) PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 11 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 11. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS4041NZ v.2 20120808 Product data sheet - PBSS4041NZ v.1 - - Modifications: PBSS4041NZ v.1 PBSS4041NZ Product data sheet • • 7 “Characteristics”: VCEsat corrected 12 “Legal information”: updated 20100331 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 12 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor 12. Legal information 12.1 Data sheet status Document status[1] [2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with theTerms and conditions of commercial sale of Nexperia. PBSS4041NZ Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 13 of 15 PBSS4041NZ Nexperia 60 V, 7 A NPN low VCEsat (BISS) transistor Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 13. Contact information For more information, please visit:http://www.nexperia.com For sales office addresses, please send an email to:salesaddresses@nexperia.com PBSS4041NZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia PBSS4041NZ 60 V, 7 A NPN low VCEsat (BISS) transistor 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 12.1 12.2 12.3 12.4 13 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . .9 Quality information . . . . . . . . . . . . . . . . . . . . . . .9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 August 2012
PBSS4041NZ,115 价格&库存
很抱歉,暂时无法提供与“PBSS4041NZ,115”相匹配的价格&库存,您可以联系我们找货
PBSS4041NZ,115
  • 1000+3.289791000+0.42733
  • 2000+3.007552000+0.39067
  • 3000+2.863743000+0.37199
  • 5000+2.702115000+0.35099
  • 7000+2.606397000+0.33856
  • 10000+2.5133710000+0.32648
PBSS4041NZ,115
  • 1+11.286471+1.46606
  • 10+7.0929810+0.92135
  • 100+4.66671100+0.60619
  • 500+3.62520500+0.47090
