CC2220KKX7R9BB105
CC2220KKX7R9BB105
    YAGEO(国巨)
    贴片电容(MLCC) 2220 1µF ±10% 50V X7R
CC2220KKX7R9BB105 数据手册
Product Specification RoHS compliant & Halogen Free Surface-mount Ceramic Multilayer Capacitors Part Description : X7R/2220/1.0uF/50V/±10% Yageo Part number : CC2220KKX7R9BB105 Page.1 SCOPE This product specification is applied to Multi-layer Ceramic Capacitor used for General Electronic equipment. Description The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved nickel electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn).The terminations are lead-free. A cross section of the structure is shown in Fig.1. MECHANICAL DATA Fig. 2 Component outline Physical dimensions (all in mm) Size L1 2220 5.7 ±0.40 W T 5.0 ±0.30 1.15±0.1 L2/L3 Max Min 0.25 0.75 L4 Min 3.40 Thickness classification and packaging quantities: Thickness Classification 1.15±0.1 mm Tape Width Embossed plastic tape reel 7" Amount 1,500 Page.2 ELECTRICAL CHARACTERISTICS Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions for testing as given in 5.3 of IEC 60068-1: --temperature: 15℃ to 35℃ --relative humidity: 25% to 75% --air pressure: 86 kPa to 106 kPa Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time sufficient to allow the entire capacitor to reach this temperature. The period as prescribed for recovery at the end of a test is normally sufficient for this purpose. Capacitance range Temperature range Tolerance on capacitance after 1000 hours Rated voltage UR(DC) Tan δ Insulation resistance after 1 minute at U R (DC) Maximum capacitance change as a function of temperature Terminations Resistance to soldering heat 1.0uF -55°C to +125°C ±10% 50V ≦2.5% Rins. ≧ 10GOhm or Rins. x C≧ 500 s whichever is less. ±15% Ni/Sn Barrier 260°C, 10 sec STORAGE CONDITIONS The products must be stored and shipping in an ambient temperature of less than 40°C with a relative humidity of less than 70%. Page.3 METHOD OF MOUNTING For normal use the capacitors may be mounted on printed-circuit boards or ceramic substrates by applying wave soldering, reflow soldering or conductive adhesive in accordance with “IEC 61760-1” (Standard method for the specification of surface mounting components). Page.4 SOLDERING RECOMMENDATION Soldering Method Reflow Reflow / Wave Size 0402 0603 ≧ 0.1 uF ≧ 1.0 uF ≧ 2.2 uF ≧ 4.7 uF Reflow only < 0.1 uF < 1.0 uF < 2.2 uF 0805 1206 ≧ 1210 < 4.7 uF ---- Page.5 Test procedures and requirements. TEST PROCEDURE REQUIREMENTS Mounting The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage Visual inspection and Any applicable method using x10 magnification dimension check In accordance with specification Capacitance Within specified tolerance Class1: C ≤1nF, f = 1 MHz; C >1nF, f = 1 KHz; NP0: measuring voltage 1 V at 20℃ Class 2: Precondition: 150 +0/-10 ℃/1 hr , then keep for 24±1 hrs at room temp C ≤10uF, f = 1 KHz; measuring voltage 1 V at 20℃ C >10uF, f = 120Hz; measuring voltage 0.5V at 20℃ Dissipation Factor (D.F.) Class1: C ≤ 1nF, f = 1 MHz; C >1nF, f = 1 KHz; NP0: measuring voltage 1 V at 20 ℃ In accordance with specification Class 2: Precondition: 150 +0/-10 ℃/1 hr , then keep for 24±1 hrs at room temp C ≤ 10uF, f = 1 KHz; measuring voltage 1 V at 20℃ C >10uF, f = 120Hz; measuring voltage 0.5V at 20℃ Insulation resistance At Ur (DC) for 1 minute Voltage proof In accordance with specification No breakdown or flashover Specified stress voltage applied for 1~5 seconds Ur≤100V: series applied 2.5Ur 1001206:100 to 120 °C for 1 minute and 170 to 200°C for 1 minute. Solder bath temperature: 260 ± 5°C; Dipping time 10±0.5 s Recovery time 24±2 Hours. REQUIREMENTS Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned. ΔC/C: Class1: NP0: within ±0.5% or 0.5 pF whichever is greater Class2: X7R/X5R: ±10% Y5V: ±20% D.F.: within initial specified value Solderability Rapid change of temperature Rins: within initial specified value The specimen shall be preheated to a temperature of (80 to 140) The solder should cover over 95% of the critical ℃ and maintained for 30s to 60s. area of each termination. 1. Temperature: 235±5°C / Dipping time: 2 ±0.5 s 2. Temperature: 245±5°C / Dipping time: 3 ±0.5 s (lead free) Depth of immersion: 10mm Preconditioning; 150 +0/-10℃/1 hr, then keep for24±1 hrs at room temp 5 cycles with following detail: 30 minutes at Lower Category Temperature; 30 minutes at Upper Category Temperature; Recovery time 24±2 Hours. No visual damage ΔC/C: Class1: NP0:within 1% or 1 pF, whichever is greater Class2: X7R/X5R:±15% Y5V:±20% D.F.: meet initial specified value Rins: meet initial specified value Test procedures and requirements. TEST PROCEDURE REQUIREMENTS Damp heat, with Ur load 1. Preconditioning, class 2 only: 150 +0/-10℃ /1 hr , then keep for 24±1hrs at room temp No visual damage after recovery 2. Initial measure Spec: refer Initial spec (C, D, IR) 3. Damp heat test: 500±12 hours at 40±2°C; 90 to 95% R.H.; 1.0Ur applied. 4. Recovery. Class 1:6 to 24 hours Class 2:24±2 hours 5. Final measure: C, D, IR P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to IEC 60384 4.1 and then the requirement shall be met. Endurance 1. Precondition, class 2 only: 150 +0/-10 ℃/1 hr , then keep for 24±1 hrs at room temp 2. Initial measure Spec: refer Initial spec C, D, IR 3. Endurance test: Temperature: NP0/X7R: 125℃ X5R/Y5V:85 ℃ Specified stress voltage applied for 1000 hrs Applied 2.0 x Ur for general product. ΔC/C: NP0:within ±2% or 1 pF, whichever is greater X7R/X5R:±15% Y5V:±30% D.F.: NP0:2 × specified value X7R/X5R: ≦16V:≦7% ≧25V:≦5% Y5V:≦15% Rins: NP0: ≧2,500MΩ or RxC≧25s whichever is less X7R/X5R/Y5V: ≧500MΩ or RxC≧25s whichever is less No visual damage ΔC/C: NP0:within ±2% or 1 pF, whichever is greater X7R/X5R:± 15% Y5V:± 30% D.F.: NP0:2 × specified value X7R/X5R: ≦16V:≦7% ≧25V:≦5% Y5V:≦15% 4. Recovery time: 24±2 hours Rins: NP0: ≧4,000MΩ or RxC≧40s whichever is less P.S. If the capacitance value is less than the minimum value X7R/Y5V/X5R: permitted, then after the other measurements have been made the capacitor shall be precondition according to IEC 60384 4.1 ≧1000MΩ or RxC≧50s whichever is less and then the requirement shall be met. 5. Final measure: C ,D, IR
CC2220KKX7R9BB105 价格&库存
很抱歉,暂时无法提供与“CC2220KKX7R9BB105”相匹配的价格&库存,您可以联系我们找货
