RC2512JK-07100RL
RC2512JK-07100RL
    YAGEO(国巨)
    贴片电阻 2512 100Ω ±5% 1W ±100ppm/℃
RC2512JK-07100RL 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification – August 21, 2015 V.3 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 10 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L APPLICATIONS  All general purpose application (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ±0.1% D = ±0.5% F = ±1.0% J = ±5.0% (for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 13 =13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only.(Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Aug. 21, 2015 V.3 Product specification Chip Resistor Surface Mount RC_L SERIES 3 10 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking Fig. 1 RC0603 E24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 2 Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC2010 / RC2512 E24/E96 series: 4 digits First three digits for significant figure and 4th digit for number of zeros Fig. 3 Value = 10 KΩ RC1218 Fig. 4 Value = 10 KΩ E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added, as shown in Fig.4. Outlines For dimensions, please refer to Table 1 Fig. 4 Chip resistor outlines www.yageo.com Aug. 21, 2015 V.3 Product specification Chip Resistor Surface Mount RC_L SERIES 4 10 0075 to 2512 DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0075 0.30±0.01 0.15±0.01 0.10±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 3.10±0.10 2.60±0.15 0.50±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC2512(1W) 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 RC2512(2W) 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 1.15±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURE RANGE -55℃ to 125℃ Fig. RC0075 4 Chip resistor outlines 1/50 W MAXIMUM WORKING VOLTAGE 10V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 25V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA 5% (E24) 10Ω≦R
RC2512JK-07100RL
物料型号:YAGEO Phicomp RC系列贴片电阻,型号包括RC0075至RC2512。
器件简介:RC系列贴片电阻采用无铅端子,通过厚膜工艺制造,符合RoHS标准,无卤素,减少环境有害废物,提高组件和设备可靠性,节省PCB空间。
引脚分配:文档中未明确指出具体的引脚分配,但通常贴片电阻为两个端子,分别位于电阻的两端。
参数特性: - 尺寸范围:从0075到2512。 - 公差:±0.1%,±0.5%,±1%,±5%。 - 包装类型:包括纸质胶带卷、压花胶带卷和防静电安全卷。 - 温度系数:基于规格书。 - 电阻值:2到4位数字表示,使用R/K/M作为小数点。
功能详解:电阻器构建在高级陶瓷基板上,内部金属电极在两端接触厚膜电阻元件,电阻元件由嵌入玻璃中的贵金属组成,并通过激光修整至额定电阻值。
应用信息:适用于所有通用目的的应用。
封装信息:提供了不同尺寸的详细尺寸信息,包括长度、宽度、高度、内径和外径。
电气特性:包括功率、工作温度范围、最大工作电压、最大电压、耐电压、电阻范围、温度系数和跳线标准。
RC2512JK-07100RL 价格&库存
很抱歉,暂时无法提供与“RC2512JK-07100RL”相匹配的价格&库存,您可以联系我们找货
RC2512JK-07100RL
  • 1+2.211001+0.28640
  • 10+1.1663810+0.15109
  • 25+0.9361025+0.12126
  • 50+0.8019450+0.10388
  • 100+0.69695100+0.09028
  • 250+0.59178250+0.07666
  • 500+0.53120500+0.06881
  • 1000+0.483151000+0.06259
库存:2214
RC2512JK-07100RL
  • 20+0.24334
  • 400+0.19978
  • 1600+0.17553
RC2512JK-07100RL
    • 4000+0.23094
    库存:536000
