GL3637(20-30K)
GL3637(20-30K)
    JCHL(晶创和立)
    PHOTORES_3.3X3MM_TM
    光谱峰值(波长):540nm 最大电压:90V 亮电阻 @ 10Lux:20kΩ~30kΩ 暗电阻:3MΩ
GL3637(20-30K) 数据手册
GL3637 MINIATURE CADMIUM SULPHIDE PHOTOCONDUCTIVE CELL LIGHT DEPENDENT RESISTOR FEATURES ● Miniature open frame package ● Epoxy coated ● Moisture resistant ● Spectral response similar to the human eye ● Applications include dusk-dawn lighting control Dimensions in millimetres SPECIFICATION AND PERFORMANCE Model Vmax (VDC) Pmax (mW) Ambient temp(℃) GL3637 90 100 -30~+70 Light Gamm Response Time (ms) Spectral Dark Resistance a value peak Resistance at 10Lux at 100Decay (nm) (MΩ) (KΩ) 10Lux Rise Time time 540 20-30 3 0.7 20 30 Measuring Conditions 1. Light resistance: Measured at 10 Lux with standard light A (2854K color temperature) and 2hr illumination at 400-600 lux prior to testing. 2. Dark Resistance: Measured 10 senconds after closed 10 lux. 3. Gamma Characteristic: Between 10 lux ande 100 lux and given by γ = lg(R10/R100) R10、R100 Cell resistance at 10 lux and 100 lux. The error of γ is ± 0.1. 4. Pmax: Max. power dissipation at ambient temperature of 25 ℃. 5. Vmax: Max. voltage in darkness that may be applied to the cell continuously. 照度-阻值特性图
GL3637(20-30K) 价格&库存
很抱歉,暂时无法提供与“GL3637(20-30K)”相匹配的价格&库存,您可以联系我们找货
GL3637(20-30K)
  • 5+0.84143
  • 50+0.66518
  • 200+0.57705
  • 400+0.51095
库存:816
