GL3539(30-50K)
GL3539(30-50K)
    JCHL(晶创和立)
    PHOTORES_3.3X3MM_TM
    耐压:150V,功率:100mW,波长:540nm,响应时间20ms,工作温度:-30~+70°C
GL3539(30-50K) 数据手册
晶创和立科技 GL3539 MINIATURE CADMIUM SULPHIDE PHOTOCONDUCTIVE CELL LIGHT DEPENDENT RESISTOR FEATURES ● ● ● ● Miniature open frame package Epoxy coated Moisture resistant Spectral response similar to the human eye ● Applications include dusk-dawn lighting control Dimensions in millimetres SPECIFICATION AND PERFORMANCE Model Vmax (VDC) GL3539 150 Pmax Ambient (mW) temp(℃) 100 -30~+70 Light Gamm Response Time (ms) Dark Spectral Resistance a value Resistance peak at 10Lux at 100Decay (MΩ) (nm) Rise Time (KΩ) 10Lux time 540 30-60 10 0.7 20 30 Measuring Conditions 1. Light resistance: Measured at 10 Lux with standard light A (2854K color temperature) and 2hr illumination at 400-600 lux prior to testing. 2. Dark Resistance: Measured 10 senconds after closed 10 lux. 3. Gamma Characteristic: Between 10 lux ande 100 lux and given by γ = lg(R10/R100) R10、R100 Cell resistance at 10 lux and 100 lux. The error of γ is ± 0.1. 4. Pmax: Max. power dissipation at ambient temperature of 25 ℃. 5. Vmax: Max. voltage in darkness that may be applied to the cell continuously. 照度-阻值特性图 SHENZHEN JINGCHUANGHELI TECHNOLOGY CO., LTD. Http://www.szjchl.com Tel:+86-755-33693441 Fax:+86-755-33693443 E-mail:heli@szjchl.com PDF 文件使用 "pdfFactory Pro" 试用版本创建 www.fineprint.cn
GL3539(30-50K) 价格&库存
很抱歉,暂时无法提供与“GL3539(30-50K)”相匹配的价格&库存,您可以联系我们找货
GL3539(30-50K)
  • 5+0.84392
  • 50+0.66712
  • 200+0.57867
  • 400+0.51246
库存:431
