SDD32A05L01
制修订履历表
版本 页码
日期
制修订内容
核准
审核
制修订人
A0
1-5 2015/07/16
新制订
刘志强 招景丰
徐文凤
A1
1-5 2019/06/26
增加焊接推荐和包装方式
刘志强 招景丰
龚小艺
A2
1-5 2019/12/16
更新文件版式
刘志强 招景丰
龚小艺
A3
1-5
2021/3/14 H 由 2.60 修改为 2.70, 增加 IPP 最大值规格
类别
签收日期
执行日期
龚小艺
主管签名确认
外发回签栏
Revision:ESD-SDD32A05L01-001(A3)
1/5
http://brightking.yageo.com
SDD32A05L01
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
Brightking’s SDD32A05L01 is designed to protect low voltage
sensitive components from ESD and transient voltage events.
Excellent clamping capability, low leakage, and fast response
time, make these parts ideal for ESD protection on designs
where board space is at a premium. Because of its small size,
it is suited for use in cellular phones, portable devices, digital
cameras, power supplies and many other portable applications.
It is designed to protect sensitive semiconductor components
from damage or upset due to electrostatic discharge(ESD),
electrical fast transients(EFT), and cable discharge events(CDE).
Features
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
SOD-323 surface mount package
Protects one I/O line
Peak power dissipation of 320W under 8/20μs waveform
Working voltage: 5V
Low leakage current
Low clamping voltage
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Marking: 05W
Pin Configuration
Applications
Cellular handsets & Accessories
Cordless phones
Personal digital assistants (PDAs)
Notebooks & Handhelds
● Portable instrumentation
● Digital cameras
● Peripherals
Maximum Ratings
Rating
Peak pulse power (tp=8/20μs waveform)
Symbol
Value
Unit
PPP
320
W
ESD voltage (Contact discharge)
±30
VESD
ESD voltage (Air discharge)
Storage & operating temperature range
kV
±30
TSTG ,TJ
2/5
-55~+150
SDD32A05L01
Electrical Characteristics (TJ=25℃)
Parameter
Symbol
Reverse stand-off voltage
Condition
Min.
Typ.
VRWM
Reverse breakdown voltage
Max.
Unit
5
V
VBR
IBR=1mA
6
V
Reverse leakage current
IR
VR=5V
1
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
9.8
V
Peak pulse current (tp=8/20μs)
IPP
19
A
Off state junction capacitance
CJ
350
pF
0Vdc,f=1MHz
Typical Characteristics Curves
Figure 1. Power Derating Curve
Figure 2. Pulse Waveform
110
100
90
% of Peak Power Current
Peak Power Dissipation (%)
100
80
70
60
50
40
30
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
70
60
50
40
td=t|PP/2
30
50
100
75
125
150
175
10
15
30
t-Time (μs)
TA-Ambient Temperature (℃)
Figure 3. Capacitance vs. Reverse Voltage
500
Junction Capacitance (pF)
F=1MHz
400
300
200
100
2
3
4
5
Reverse Voltage (V)
3/5
SDD32A05L01
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Condition
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
4/5
SDD32A05L01
Dimensions (SOD-323)
G
E
Dimension
Symbol
Millimeters
X
H
1
2
A
F
D
B
C
detail X
0.50
(2X)
0.60
(2X)
2.3
Recommended Soldering Pad Layout
Inches
Min.
Max.
Min.
Max.
A
0.80
1.10
0.031
0.043
B
0.10
0.004
C
0.20
0.008
D
0.11
0.20
0.004
0.008
E
1.15
1.35
0.045
0.053
F
0.35
0.014
G
1.60
1.80
0.063
0.071
H
2.40
2.70
0.094
0.102
Packaging
Tape
P0
P1
P2
K
F
B0
B
W
E
øD0
A0
øD1
t
A
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.00±0.05
E
1.75±0.10
F
3.50±0.10
A
1.48±0.10
A0
0.80±0.10
B
3.00±0.10
B0
1.80±0.10
K
1.05±0.10
t
0.25±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Reel
D2
D
W1
Quantity: 3000PCS
5/5
很抱歉,暂时无法提供与“SDD32A05L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.24218
- 20+0.22055
- 100+0.19893
- 500+0.17730
- 1000+0.16721
- 2000+0.16000
