74LVC1G79-Q100
Single D-type flip-flop; positive-edge trigger
Rev. 3 — 1 February 2022
Product data sheet
1. General description
The 74LVC1G79-Q100 is a single positive-edge triggered D-type flip-flop. Data at the D-input that
meets the set-up and hold time requirements on the LOW-to-HIGH clock transition will be stored in
the flip-flop and appear at the Q output. Inputs can be driven from either 3.3 V or 5 V devices. This
feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times.
This device is fully specified for partial power down applications using IOFF. The IOFF circuitry
disables the output, preventing the potentially damaging backflow current through the device when
it is powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
Wide supply voltage range from 1.65 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
CMOS low power dissipation
±24 mA output drive (VCC = 3.0 V)
Direct interface with TTL levels
Latch-up performance exceeds 250 mA
IOFF circuitry provides partial Power-down mode operation
Complies with JEDEC standard:
• JESD8-7 (1.65 V to 1.95 V)
• JESD8-5 (2.3 V to 2.7 V)
• JESD8C (2.7 V to 3.6 V)
• JESD36 (4.5 V to 5.5 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
74LVC1G79-Q100
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC1G79GW-Q100
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
74LVC1G79GV-Q100
-40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
4. Marking
Table 2. Marking codes
Type number
Marking[1]
74LVC1G79GW-Q100
VP
74LVC1G79GV-Q100
V79
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1
D
Q
4
1
2
2
CP
D
4
CP
mna441
mna440
Fig. 1.
Q
Logic symbol
Fig. 2.
CP
IEC logic symbol
C
C
D
C
C
TG
TG
C
Fig. 3.
C
C
Q
C
TG
TG
C
C
mna442
Logic diagram
74LVC1G79_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2022. All rights reserved
2 / 14
74LVC1G79-Q100
Nexperia
6. Pinning information
6.1. Pinning
74LVC1G79
D
1
CP
2
GND
3
5
VCC
4
Q
001aaf188
Fig. 4.
Pin configuration SOT353-1 (TSSOP5) and SOT753 (SC-74A)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
D
1
data input
CP
2
clock pulse input
GND
3
ground (0 V)
Q
4
data output
VCC
5
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; ↑ = LOW-to-HIGH CP transition; X = don’t care;
q = lower case letter indicates the state of referenced input, one set-up time prior to the LOW-to-HIGH CP transition.
Output
Input
CP
D
Q
L
L
H
H
L
X
q
74LVC1G79_Q100
Product data sheet
3 / 14
74LVC1G79-Q100
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
VO
output voltage
Active mode
Power-down mode; VCC = 0 V
Min
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
V
±50
mA
[1]
-0.5
VCC + 0.5
V
[1]
-0.5
+6.5
V
±50
mA
VI < 0 V
[1]
IO
output current
ICC
supply current
100
mA
IGND
ground current
-100
mA
Ptot
total power dissipation
250
mW
Tstg
storage temperature
-65
+150
°C
[1]
[2]
VO = 0 V to VCC
mA
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT353-1 (TSSOP5) package: Ptot derates linearly with 3.3 mW/K above 74 °C.
For SOT753 (SC-74A) package: Ptot derates linearly with 3.8 mW/K above 85 °C.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
1.65
5.5
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
V
-40
+125
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74LVC1G79_Q100
Product data sheet
4 / 14
74LVC1G79-Q100
Nexperia
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Min
Typ[1]
Max
0.65 × VCC
V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 × VCC
V
VCC = 1.65 V to 1.95 V
Conditions
Unit
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
0.7
V
0.8
V
0.3 × VCC
V
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
V
IO = -8 mA; VCC = 2.3 V
1.9
V
IO = -12 mA; VCC = 2.7 V
2.2
V
IO = -24 mA; VCC = 3.0 V
2.3
V
IO = -32 mA; VCC = 4.5 V
3.8
V
IO = 100 μA; VCC = 1.65 V to 5.5 V
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
V
IO = 8 mA; VCC = 2.3 V
0.3
V
IO = 12 mA; VCC = 2.7 V
0.4
V
IO = 24 mA; VCC = 3.0 V
0.55
V
IO = 32 mA; VCC = 4.5 V
VI = VIH or VIL
IO = -100 μA; VCC = 1.65 V to 5.5 V
VOL
LOW-level output voltage
0.35 × VCC V
VI = VIH or VIL
0.55
V
II
input leakage current
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
±0.1
±1
μA
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 5.5 V
±0.1
±2
μA
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
μA
ΔICC
additional supply current
per pin; VCC = 2.3 V to 5.5 V;
VI = VCC - 0.6 V; IO = 0 A
5
500
μA
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
5
pF
74LVC1G79_Q100
Product data sheet
5 / 14
74LVC1G79-Q100
Nexperia
Symbol Parameter
Min
Typ[1]
Max
0.65 × VCC
V
1.7
V
2.0
V
0.7 × VCC
V
Conditions
Unit
VIH
VIL
VOH
0.7
V
0.8
V
0.3 × VCC
V
VCC - 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.1
V
0.70
V
0.45
V
0.60
V
0.80
V
VI = VIH or VIL
VOL
0.35 × VCC V
VI = VIH or VIL
0.80
V
II
±1
μA
IOFF
±2
μA
ICC
supply current
VI = 5.5 V or GND;
4
μA
ΔICC
500
μA
[1]
All typical values are measured at VCC = 3.3 V and Tamb = 25 °C.
74LVC1G79_Q100
Product data sheet
6 / 14
74LVC1G79-Q100
Nexperia
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 7.
Symbol Parameter
tpd
tsu
th
tW
fmax
CPD
[1]
[2]
[3]
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
1.0
3.6
9.9
1.0
12.5
ns
0.5
2.3
7.0
0.5
9.0
ns
VCC = 2.7 V
0.5
2.6
6.0
0.5
8.0
ns
VCC = 3.0 V to 3.6 V
0.5
2.2
5.0
0.5
6.5
ns
0.5
1.7
3.8
0.5
5.0
ns
2.5
1.4
2.5
ns
1.7
0.9
1.7
ns
VCC = 2.7 V
1.7
0.9
1.7
ns
1.3
0.6
1.2
ns
1.2
0.6
1.2
ns
ns
ns
VCC = 2.7 V
+0.5
-0.3
0.5
ns
+0.5
-0.3
0.5
ns
+0.5
-0.2
0.5
ns
3.0
1.1
3.0
ns
2.5
0.7
2.5
ns
VCC = 2.7 V
2.5
0.6
2.5
ns
2.5
0.6
2.5
ns
2.0
0.5
2.0
ns
160
250
160
MHz
160
300
160
MHz
VCC = 2.7 V
160
350
160
MHz
160
450
160
MHz
200
500
200
MHz
17
pF
propagation delay CP to Q; see Fig. 5
set-up time
hold time
pulse width
maximum
frequency
power dissipation
capacitance
-40 °C to +125 °C Unit
[2]
D to CP; see Fig. 6
D to CP; see Fig. 6
CP HIGH or LOW; see Fig. 6
CP; see Fig. 6
VI = GND to VCC; VCC = 3.3 V
[3]
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where:
fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF;
2
VCC = supply voltage in V; N = number of inputs switching; ∑(CL × VCC × fo) = sum of outputs.
74LVC1G79_Q100
Product data sheet
7 / 14
74LVC1G79-Q100
Nexperia
11.1. Waveforms and test circuit
VI
D input
GND
VI
CP input
VM
VM
GND
tPHL
tPLH
VOH
VM
Q output
VM
VOL
mna443
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output.
Fig. 5.
Clock (CP) to output (Q) propagation delay times
VI
VM
D input
GND
th
th
t su
1/fmax
t su
VI
CP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Q output
VOL
mna647
Fig. 6.
Clock (CP) to output (Q) propagation delay times, clock pulse width, D to CP set-up times, the CP to D
hold times and maximum clock pulse frequency
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5 × VCC
0.5 × VCC
2.3 V to 2.7 V
0.5 × VCC
0.5 × VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5 × VCC
0.5 × VCC
74LVC1G79_Q100
Product data sheet
8 / 14
74LVC1G79-Q100
Nexperia
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 7.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
74LVC1G79_Q100
Product data sheet
VEXT
Load
9 / 14
74LVC1G79-Q100
Nexperia
12. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
SOT353-1
E
B
A
X
c
(5x)
y
HE
v M A
e1
5
4
pin 1 index
A
1
2
A1
3
A3
θ
Lp
w M B
bp
(5x)
e
A2
detail X
e
3 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
min
A
A1
A2
A3
1.1
0.8
0.1
0.8
0.15
bp
c
0.30 0.25
0.15 0.08
D(1)
E(1)
2.2
1.8
1.35
0.65
1.15
e
e1
HE
Lp
v
w
y
θ
1.3
2.4
1.8
0.46
0.26
0.3
0.1
0.1
8°
0°
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
Outline
version
SOT353-1
Fig. 8.
References
IEC
JEDEC
JEITA
MO-203
SC-88A
sot353-1_po
European
projection
Issue date
21-12-15
21-12-16
Package outline SOT353-1 (TSSOP5)
74LVC1G79_Q100
Product data sheet
10 / 14
74LVC1G79-Q100
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
B
E
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
Fig. 9.
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Package outline SOT753 (SC-74A)
74LVC1G79_Q100
Product data sheet
11 / 14
74LVC1G79-Q100
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC1G79 _Q100 v.3
20220201
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 1 and Section 2 updated.
Table 5: Derating values for Ptot total power dissipation updated.
Fig. 8: Package outline drawing SOT353-1 (TSSOP5) has changed.
74LVC1G79 _Q100 v.2
20161212
Modifications:
74LVC1G79 _Q100 v.1
20150512
74LVC1G79_Q100
Product data sheet
74LVC1G79 _Q100 v.2
Product data sheet
74LVC1G79 _Q100 v.1
Table 7: The maximum limits for leakage current and supply current have changed.
Product data sheet
12 / 14
74LVC1G79-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74LVC1G79_Q100
Product data sheet
13 / 14
74LVC1G79-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 4
9. Recommended operating conditions..........................4
10. Static characteristics..................................................5
11. Dynamic characteristics.............................................7
11.1. Waveforms and test circuit........................................ 8
12. Package outline........................................................ 10
13. Abbreviations............................................................ 12
14. Revision history........................................................12
15. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 1 February 2022
74LVC1G79_Q100
Product data sheet
14 / 14
