AS5043-ASSM
AS5043-ASSM
    AMSOSRAM(艾迈斯半导体)
    Hall Effect Sensor Angle External Magnet, Not Included
AS5043-ASSM 数据手册
Product Document Published by ams OSRAM Group AS5043 Programmable 360° Magnetic Angle Encoder with Absolute SSI and Analog Outputs General Description The AS5043 is a contactless magnetic angle encoder for accurate measurement up to 360°. It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing in a single device. The AS5043 provides a digital 10-bit as well as a programmable analog output that is directly proportional to the angle of a magnet, rotating over the chip. The analog output can be configured in many ways, including user programmable angular range, adjustable output voltage range, voltage or current output, etc... An internal voltage regulator allows operation of the AS5043 from 3.3V or 5.0V supplies. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS5043, Programmable 360° Magnetic Angle Encoder with Absolute SSI and Analog Outputs are listed below: Figure 1: Added Value of Using AS5043 Benefits Features • Highest reliability and durability • Contactless high resolution rotational position encoding over a full turn of 360 degrees • Simple programming • Simple user-programmable zero position • Multiple interfaces • Serial communication interface (SSI) • Programmable 10-bit analog output • Ideal for robotic and motor applications • Input mode for optimizing noise vs. speed • Failure diagnostics • Failure detection mode for magnet placement monitoring and loss of power supply • Easy setup • Serial read-out of multiple interconnected AS5043 devices using Daisy Chain mode • Small form factor • SSOP 16 (5.3mm x 6.2mm) • Robust environmental tolerance • Wide temperature range: -40°C to 125°C ams Datasheet [v1-83] 2017-Jul-18 Page 1 Document Feedback AS5043 − General Description Applications AS5043, Programmable 360° Magnetic Angle Encoder with Absolute SSI and Analog Outputs is ideal for applications with an angular travel range from a few degrees up to a full turn of 360°, such as: • Industrial applications: • Contactless rotary position sensing • Robotics • Valve controls • Automotive applications: • Throttle position sensors • Gas/brake pedal position sensing • Headlight position control • Front panel rotary switches • Replacement of potentiometers Figure 2: Typical Arrangement of AS5043 and Magnet Page 2 Document Feedback ams Datasheet [v1-83] 2017-Jul-18 AS5043 − General Description Block Diagram The functional blocks of this device are shown below: Figure 3: AS5043 Block Diagram MagRNGn Mode Sin DSP Hall Array & Frontend Amplifier Cos DO Absolute Interface (SSI) CSn CLK OTP Register DACref FB 10 Programming Parameters Vout 10bit DAC + DACout Prog_DI ams Datasheet [v1-83] 2017-Jul-18 Page 3 Document Feedback AS5043 − Pin Assignment Pin Assignment Figure 4: AS5043 Pin Configuration SSOP16 MagRngn 1 16 VDD5V Mode 2 15 VDD3V3 CSn 3 14 NC CLK 4 13 NC NC 5 12 Vout DO 6 11 FB VSS 7 10 DACout Prog_DI 8 9 DACref Package = SSOP16 (16 lead Shrink Small Outline Package) Figure 5: Pin Description SSOP16 Pin Symbol Type 1 MagRngn DO_OD Magnet Field Magnitude RaNGe warning; active low, indicates that the magnetic field strength is outside of the recommended limits. 2 Mode DI_PD, ST Mode input. Select between low noise (low, connect to VSS) and high speed (high, connect to VDD5V) mode at power up. Internal pull-down resistor. 3 CSn DI_PU, ST Chip Select, active low; Schmitt-Trigger input, internal pull-up resistor (~50kΩ) 4 CLK DI,ST 5 NC - 6 DO DO_T 7 VSS S 8 Prog_DI DI_PD 9 DACref AI DAC Reference voltage input for external reference 10 DACout AO DAC output (unbuffered, Ri ~8kΩ) 11 FB AI Feedback, OPAMP inverting input Page 4 Document Feedback Description Clock Input of Synchronous Serial Interface; Schmitt-Trigger input Must be left unconnected Data Output of Synchronous Serial Interface Negative Supply Voltage (GND) OTP Programming Input and Data Input for Daisy Chain mode. Internal pull-down resistor (~74kΩ). Should be connected to VSS if programming is not used ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Pin Assignment Pin Symbol Type Description 12 Vout AO OPAMP output 13 NC - Must be left unconnected 14 NC - Must be left unconnected 15 VDD3V3 S 3V-Regulator Output for internal core, regulated from VDD5V.Connect to VDD5V for 3V supply voltage. Do not load externally. 16 VDD5V S Positive Supply Voltage, 3.0 to 5.5 V Abbreviations for Pin Types in Figure 5: DO_OD : Digital output open drain DI_PD : Digital input pull-down DI_PU : Digital input pull-up S : Supply pin DO_T : Digital output /tri-state ST : Schmitt-Trigger input AI : Analog input AO : Analog output D1 : Digital input Pin Description Pins 7, 15 and 16 are supply pins, pins 5, 13 and 14 are for internal use and must be left open. Pin 1 is the magnetic field strength indicator, MagRNGn. It is an open-drain output that is pulled to VSS when the magnetic field is out of the recommended range (45mT to 75mT). The chip will still continue to operate, but with reduced performance, when the magnetic field is out of range. When this pin is low, the analog output at pins #10 and #12 will be 0V to indicate the out-of-range condition. Pin 2 MODE allows switching between filtered (slow) and unfiltered (fast mode). This pin must be tied to VSS or VDD5V, and must not be switched after power up. Pin 3 Chip Select (CSn; active low) selects a device for serial data transmission over the SSI interface. A “logic high” at CSn forces output DO to digital tri-state. Pin 4 CLK is the clock input for serial data transmission over the SSI interface. ams Datasheet [v1-83] 2017-Jul-18 Page 5 Document Feedback AS5043 − Pin Assignment Pin 6 DO (Data Out) is the serial data output during data transmission over the SSI interface. Pin 8 PROG_DI is used to program the different operation modes, as well as the zero-position in the OTP register. This pin is also used as a digital input to shift serial data through the device in Daisy Chain Mode. Pin 9 DACref is the external voltage reference input for the Digital-to-Analog Converter (DAC). If selected, the analog output voltage on pin 12 (Vout) will be ratiometric to the voltage on this pin. Pin10 DACout is the unbuffered output of the DAC. This pin may be used to connect an external OPAMP, etc. to the DAC. Pin 11 FB (Feedback) is the inverting input of the OPAMP buffer stage. Access to this pin allows various OPAMP configurations. Pin 12 Vout is the analog output pin. The analog output is a DC voltage, ratiometric to VDD5V (3.0 – 5.5V) or an external voltage source and proportional to the angle. Page 6 Document Feedback ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in Operating Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 6: Absolute Maximum Ratings Symbol VDD5V VDD3V3 Vin Parameter DC supply voltage at pin VDD5V Input pin voltage Iscr Input current (latchup immunity) ESD Electrostatic discharge Tstrg Storage temperature TBody Body temperature RHNC Relative humidity (non condensing) MSL Moisture sensitivity level ams Datasheet [v1-83] 2017-Jul-18 Min Max Units -0.3 7 V Pin VDD5V 5 V Pin VDD3V3 -0.3 VDD5V +0.3 -0.3 5 -0.3 7.5 -100 100 5 3 Pins MagRngn, Mode, CSn, CLK, DO, DACout, FB, Vout V Pin DACref Pin PROG_DI mA JEDEC 78 kV MIL 883 E method 3015 125 ºC Min – 67°F; Max 257°F 260 ºC t=20s to 40s, IPC/JEDEC J-Std-020C Lead finish 100% Sn “matte tin” 85 % ±2 -55 Note Maximum floor life time of 168h Page 7 Document Feedback AS5043 − Electrical Characteristics Electrical Characteristics Operating Conditions Figure 7: Operating Conditions Symbol Parameter Min Tamb Ambient temperature -40 Isupp Supply current VDD5V Supply voltage at pin VDD5V Typ Max Unit 125 °C 16 21 mA 4.5 5.0 5.5 V Note -40°F to 257°F 5V operation VDD3V3 Voltage regulator output voltage at pin VDD3V3 3.0 3.3 3.6 V VDD5V Supply voltage at pin VDD5V 3.0 3.3 3.6 V VDD3V3 Supply voltage at pin VDD3V3 3.0 3.3 3.6 V 3.3V operation (pins VDD5V and VDD3V3 connected) DC Characteristics for Digital Inputs and Outputs CMOS Schmitt-Trigger Inputs: CLK, CSn (Internal Pull-Up), Mode (Internal Pull-Down) (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted) Figure 8: CMOS Schmitt-Trigger Inputs: CLK, CSn (CSn = Internal Pull-Up), Mode (Internal Pull-Down) Symbol Parameter VIH High level input voltage VIL Low level input voltage VIon-VIoff ILEAK IiL IiH Min Max 0.7 * VDD5V V 0.3 * VDD5V Schmitt Trigger hysteresis 1 Input leakage current -1 1 -30 30 -100 100 Page 8 Document Feedback Note Normal operation V V Pull-up low level input current Pull-down high level input current Unit Pin CLK, VDD5V = 5.0V μA Pin CSn, VDD5V= 5.0V Pin Mode, VDD5V= 5.0V ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Electrical Characteristics CMOS Input: Program Input (Prog) (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted) Figure 9: CMOS Input: Program Input (Prog) Symbol Parameter VIH High level input voltage VPROG High level input voltage VIL Low level input voltage IiL Pull-down high level input current Min Max Unit 0.7 * VDD5V 5 V See Programming Conditions V 0.3 * VDD5V V 100 μA Note During programming VDD5V: 5.5V CMOS Output Open Drain: MagRngn (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted). Figure 10: CMOS Output Open Drain: MagRngn Symbol VOL Parameter Low level output voltage Min Max Unit VSS+0.4 V IO Output current 4 2 mA IOZ Open drain leakage current 1 μA ams Datasheet [v1-83] 2017-Jul-18 Note VDD5V: 4.5V VDD5V: 3V Page 9 Document Feedback AS5043 − Electrical Characteristics Tristate CMOS Output: DO (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted). Figure 11: Tristate CMOS Output: DO Symbol Parameter VOH High level output voltage VOL Low level output voltage Min Max VDD5V-0.5 Unit Note V VSS+0.4 V IO Output current 4 2 mA IOZ Tri-state leakage current 1 μA VDD5V: 4.5V VDD5V: 3V Digital-to-Analog Converter Figure 12: Digital-to-Analog Converter Symbol Parameter Min Resolution VOUTM1 Output range VOUTM2 ROut,DAC Vref Max 10 Unit Note bit Vref V 0% …100% Vref (default) ClampMdEn = 0 (default) 0.10 *Vref 0.90 *Vref V 10% …90% Vref ClampMdEn = 1 8 kΩ Unbuffered Pin DACout (#10) VDD3V3 - 0.2 V DAC reference = external: Pin: DACref (#9) RefExt EN = 1 VDD5V / 2 V DAC reference = internal RefExtEn = 0 (default) 0.2 INLDAC Integral non-linearity ±1.5 LSB DNLDAC Differential non-linearity ±0.5 LSB 1 LSB All analog modes 2 LSB At 360°-0° transition, 360° mode only Hyst Analog output hysteresis Page 10 Document Feedback OTP Setting 0 Output resistance DAC reference voltage (DAC full scale range) Typ Non-Linearity of DAC and OPAMP; -40°C to 125°C, for all analog modes: 1LSB = Vref / 1024 OR1,OR0 = 00 (default) ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Electrical Characteristics OPAMP Output Stage Figure 13: OPAMP Output Stage Symbol Parameter Min VDD5V Power Supply Range 3.0 CL Parallel Load Capacitance RL Parallel Load Resistance 4.7 A0 Open Loop Gain 92 VosOP Offset Voltage RTI -5 VoutL Output Range Low Typ Max Unit 5.5 V 100 pF kΩ 130 144 dB 5 mV 0.05 * VDD5V V Note 3.3V operation 3 sigma Linear range of analog output VoutH Output Range High 0.95 * VDD5V Isink Current capability sink 4.8 50 mA Permanent short circuit current: Vout to VDD5V Isource Current capability source 4.6 66 mA Permanent short circuit current: Vout to VSS Vnoise Output noise 160 V 220 490 2 Gain ams Datasheet [v1-83] 2017-Jul-18 OPAMP gain (non-inverting) 1 μVrms Over full temperature range; BW= 1Hz …10MHz, Gain = 2x Internal; OTP: FB_int EN = 1 4 External OTP: FB_int EN = 0 (default) With external resistors, pins Vout [#12] and FB [#11]: see Figure 33 Page 11 Document Feedback AS5043 − Electrical Characteristics Magnetic Input Specification (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted). Two-pole cylindrical diametrically magnetized source: Figure 14: Magnetic Input Specification Symbol Parameter Min Typ 6 dmag Diameter 4 tmag Thickness 2.5 Bpk Magnetic input field amplitude Boff Magnetic offset 45 fmag_abs Disp Input frequency (rotational speed of magnet) Displacement radius Recommended magnet material and temperature drift Page 12 Document Feedback Unit mm mm Field non-linearity fmag_inc Max Note Recommended magnet: Ø 6mm x 2.5mm for cylindrical magnets 75 mT Required vertical component of the magnetic field strength on the die’s surface, measured along a concentric circle with a radius of 1.1mm ± 10 mT Constant magnetic stray field 5 % Including offset gradient 10 Hz Absolute mode: 600 rpm @ readout of 1024 positions (see Figure 48) 166 Hz Incremental mode: no missing pulses at rotational speeds of up to 10,000 rpm (see Figure 48) 0.25 mm Max. offset between defined device center and magnet axis -0.12 NdFeB (Neodymium Iron Boron) %/K -0.035 SmCo (Samarium Cobalt) ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Electrical Characteristics Electrical System Specifications (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted). Figure 15: Electrical System Specifications Symbol RES Parameter Min Typ Resolution (1) INLopt Integral non-linearity (optimum)(1) INLtemp Integral non-linearity (optimum) (1) INL Integral non-linearity (1) DNL Differential non-linearity (1) Max Unit 10 bit 0.352 deg deg Maximum error with respect to the best line fit. Verified at optimum magnet placement, Tamb =25 °C. deg Maximum error with respect to the best line fit. Verified at optimum magnet placement, Tamb = -40°C to 125°C ± 1.4 deg Best line fit = (Errmax – Errmin) / 2 Over displacement tolerance with 6mm diameter magnet, Tamb = -40°C to 125°C ± 0.176 deg 10bit, no missing codes ± 0.5 ± 0.9 0.06 TN deg RMS Transition noise (1) 0.03 Note 1 sigma, fast mode (pin MODE = 1) 1 sigma, slow mode (pin MODE=0 or open) Von Power-ON reset threshold ON voltage; 300mV typ. hysteresis 1.37 2.2 2.9 V DC supply voltage 3.3V (VDD3V3) Voff Power-ON reset threshold OFF voltage; 300mV typ. hysteresis 1.08 1.9 2.6 V DC supply voltage 3.3V (VDD3V3) tPwrUp Power-up time, Until offset compensation finished, OCF = 1, Angular Data valid tdelay System propagation delay absolute output : delay of ADC and DSP ams Datasheet [v1-83] 2017-Jul-18 20 Fast mode (pin MODE=1) ms 80 Slow mode (pin MODE=0 or open) 96 Fast mode (pin MODE=1) μs 384 Slow mode (pin MODE=0 or open) Page 13 Document Feedback AS5043 − Electrical Characteristics Symbol fS, mode 0 fS, mode 1 CLK Parameter Min Typ Max 2.48 2.61 2.74 Internal sampling rate for absolute output Note Tamb = 25°C, slow mode (pin MODE = 0 or open) kHz 2.35 2.61 2.87 Tamb = -40°C to 125°C, slow mode (pin MODE = 0 or open) 9.90 10.4 2 10.94 Tamb = 25°C, fast mode (pin MODE = 1) 9.38 10.4 2 Internal sampling rate for absolute output Read-out frequency Unit kHz >0 Tamb = -40°C to 125°C, fast mode (pin MODE = 1) 11.46 1 MHz Max. clock frequency to read out serial data Note(s) and/or Footnote(s): 1. Digital interface Figure 16: Integral and Differential Non-Linearity Example (exaggerated curve) 1023 D 10bit code 1023 Actual curve 2 TN 1 0 512 Ideal curve DNL+1LSB INL 0.35° 512 0 0q q 360 q D [degrees] Integral Non-Linearity (INL) is the maximum deviation between actual position and indicated position. Differential Non-Linearity (DNL) is the maximum deviation of the step length from one position to the next. Transition Noise (TN) is the repeatability of an indicated position. Page 14 Document Feedback ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Electrical Characteristics Timing Characteristics Synchronous Serial Interface (SSI) (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted). Figure 17: Synchronous Serial Interface (SSI) Symbol Parameter t DO active Data output activated (logic high) tCLK FE First data shifted to output register T CLK / 2 Start of data output t DO valid Data output valid t DO tristate Data output tristate t CSn Pulse width of CSn fCLK Read-out frequency ams Datasheet [v1-83] 2017-Jul-18 Min Typ Max Unit 100 ns Time between falling edge of CSn and data output activated 500 ns Time between falling edge of CSn and first falling edge of CLK 500 ns Rising edge of CLK shifts out one bit at a time 413 ns Time between rising edge of CLK and data output valid 100 ns After the last bit DO changes back to “tristate” ns CSn = high; To initiate read-out of next angular position MHz Clock frequency to read out serial data 500 >0 1 Note Page 15 Document Feedback AS5043 − Electrical Characteristics Programming Conditions (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted). Figure 18: Programming Conditions Symbol Parameter Min Typ Max Unit Note Time between rising edge at Prog pin and rising edge of CSn Programming enable time 2 μs t Data in Write data start 2 μs t Data in valid Write data valid 250 ns t Load PROG Load programming data 3 μs t PrgR Rise time of VPROG before CLKPROG 0 μs t PrgH Hold time of VPROG after CLKPROG 0 t Prog enable CLK PROG t PROG t PROG finished Write data – programming CLKPROG CLK pulse width Hold time of VPROG after programming 1.8 2 Write data at the rising edge of CLKPROG 5 μs 250 kHz 2.2 μs During programming; 16 clock cycles μs Programmed data is available after next power-on 7.5 V Must be switched OFF after zapping 1 V Line must be discharged to this level 2 V PROG Programming voltage 7.3 V ProgOff Programming voltage OFF level 0 I PROG Programming current 130 mA During programming Analog read CLK 100 kHz Analog readback mode Programmed Zener voltage (log.1) 100 mV VRef-VPROG during analog readback mode (see Analog Readback Mode) CLKAread Vprogrammed Vunprogrammed Unprogrammed Zener voltage (log. 0) Page 16 Document Feedback 1 7.4 V ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Functional Description Functional Description The AS5043 is manufactured in a CMOS standard process and uses a spinning current Hall technology for sensing the magnetic field distribution across the surface of the chip. The integrated Hall elements are placed in a circle around the center of the device and deliver a voltage representation of the magnetic field perpendicular to the surface of the IC. Through Sigma-Delta Analog / Digital Conversion and Digital Signal-Processing (DSP) algorithms, the AS5043 provides accurate high-resolution absolute angular position information. For this purpose a Coordinate Rotation Digital Computer (CORDIC) calculates the angle and the magnitude of the Hall array signals. The DSP is also used indicate movements of the magnet towards or away from the chip and to indicate, when the magnetic field is outside of the recommended range (status bits = MagInc, MagDec; hardware pin = MagRngn). A small low cost diametrically magnetized (two-pole) standard magnet, centered over the chip, is used as the input device. The AS5043 senses the orientation of the magnetic field and calculates a 10-bit binary code. This code can be accessed via a Synchronous Serial Interface (SSI). In addition, the absolute angular representation is converted to an analog signal, ratiometric to the supply voltage. The analog output can be configured in many ways, such as 360°/180°/90° or 45° angular range, external or internal DAC reference voltage, 0-100%*VDD or 10-90% *VDD analog output range, external or internal amplifier gain setting. The various output modes as well as a user programmable zero position can be programmed in an OTP register. As long as no programming voltage is applied to pin PROG, the new setting may be overwritten at any time and will be reset to default when power is cycled. To make the setting permanent, the OTP register must be programmed by applying a programming voltage. The AS5043 is tolerant to magnet misalignment and unwanted external magnetic fields due to differential measurement technique and Hall sensor conditioning circuitry. It is also tolerant to airgap and temperature variations due to Sin-/Cos- signal evaluation. ams Datasheet [v1-83] 2017-Jul-18 Page 17 Document Feedback AS5043 − 3.3V / 5V Operation 3.3V / 5V Operation The AS5043 operates either at 3.3V ±10% or at 5V ±10%. This is made possible by an internal 3.3V Low-Dropout (LDO) Voltage regulator. The core supply voltage is always taken from the LDO output, as the internal blocks are always operating at 3.3V. For 3.3V operation, the LDO must be bypassed by connecting VDD3V3 with VDD5V (see Figure 19). For 5V operation, the 5V supply is connected to pin VDD5V, while VDD3V3 (LDO output) must be buffered by a 1 to10μF capacitor, which should be placed close to the supply pin. The VDD3V3 output is intended for internal use only. It should not be loaded with an external load. The voltage levels of the digital interface I/O’s correspond to the voltage at pin VDD5V, as the I/O buffers are supplied from this pin (see Figure 19). Figure 19: Connections for 5V / 3.3V Supply Voltages A buffer capacitor of 100nF is recommended in both cases close to pin VDD5V. Note that pin VDD3V3 must always be buffered by a capacitor. It must not be left floating, as this may cause an instable internal 3.3V supply voltage which may lead to larger than normal jitter of the measured angle. Page 18 Document Feedback ams Datasheet [v1-83] 2017-Jul-18 10-Bit Absolute Synchronous Serial Interface (SSI) The serial data transmission timing is outlined in Figure 21: if CSn changes to logic low, Data Out (DO) will change from high impedance (tri-state) to logic high and the read-out sequence will be initiated. After a minimum time t CLK FE, data is latched into the output shift register with the first falling edge of CLK. Each subsequent rising CLK edge shifts out one bit of data.The serial word contains 16 bits, the first 10 bits are the angular information D[9:0], the subsequent 6 bits contain system information, about the validity of data such as OCF, COF, LIN, Parity and Magnetic Field status (increase / decrease / out of range). A subsequent measurement is initiated by a logic “high” pulse at CSn with a minimum duration of t CSn. Data transmission may be terminated at any time by pulling CSn = high. Serial Data Contents D9:D0 absolute angular position data (MSB is clocked out first). OCF (Offset Compensation Finished), logic high indicates that the Offset Compensation Algorithm has finished and data is valid. COF (CORDIC Overflow), logic high indicates an out of range error in the CORDIC part. When this bit is set, the data at D9:D0 is invalid. The absolute output maintains the last valid angular value. This alarm may be resolved by bringing the magnet within the X-Y-Z tolerance limits. LIN (Linearity Alarm), logic high indicates that the input field generates a critical output linearity. When this bit is set, the data at D9:D0 may still be used, but may contain invalid data. This warning may be resolved by bringing the magnet within the X-Y-Z tolerance limits. Data D9:D0 is valid, when the status bits have the following configurations: Figure 20: Status Bit Outputs OCF 1 COF 0 ams Datasheet [v1-83] 2017-Jul-18 LIN 0 Mag INC Mag DEC 0 0 0 1 1 0 Parity Even checksum of bits 1:15 Page 19 Document Feedback AS5043 − 10-Bit Absolute Synchronous Serial Inter face (SSI) MagInc, (Magnitude Increase) becomes HIGH, when the magnet is pushed towards the IC, thus the magnetic field strength is increasing. MagDec, (Magnitude Decrease) becomes HIGH, when the magnet is pulled away from the IC, thus the magnetic field strength is decreasing. Both signals HIGH indicate a magnetic field that is out of the allowed range (see Figure 22). Note(s): Pin 1 (MagRngn) is a combination of MagInc and MagDec. It is active low via an open drain output and requires an external pull-up resistor. If the magnetic field is in range, this output is turned OFF. (logic “high”). Even Parity bit for transmission error detection of bits 1 …15 (D9 …D0, OCF, COF, LIN, MagInc, MagDec) The absolute angular output is always set to a resolution of 10 bit / 360°. Placing the magnet above the chip, angular values increase in clockwise direction by default. Figure 21: Synchronous Serial Interface with Absolute Angular Position Data CSn t CLK FE T CLK / 2 t CSn 1 CLK DO D9 t DO active Page 20 Document Feedback t DO valid 8 D8 D7 D6 D5 D4 D3 Angular Position Data D2 1 16 D1 D0 OCF COF LIN Mag INC Status Bits Mag DEC t CLK FE Even PAR D9 t DO Tristate ams Datasheet [v1-83] 2017-Jul-18 AS5043 − 10-Bit Absolute Synchronous Serial Interface (SSI) Z-Axis Range Indication (Push Button Feature, Red/Yellow/Green Indicator) The AS5043 provides several options of detecting movement and distance of the magnet in the vertical (Z-) direction. Signal indicators MagINC, MagDEC and LIN are available as status bits in the serial data stream, while MagRngn is an open-drain output that indicates an out-of range status (On in YELLOW or RED range). Additionally, the analog output provides a safety feature in the form that it will be turned OFF when the magnetic field is too strong or too weak (RED range). The serial data is always available, the red/yellow/green status is indicated by the status bits as shown below: Figure 22: Magnetic Field Strength Indicators SSI Status Bits Hardware Pins Description Mag INC Mag DEC LIN Mag Rngn Analog Output 0 0 0 OFF Enabled No distance change Magnetic Input Field OK (GREEN range, ~45mT … 75mT) 0 1 0 OFF Enabled Distance increase, GREEN range; Pull-function. This state is dynamic and only active while the magnet is moving away from the chip. 1 0 0 OFF Enabled Distance decrease, GREEN range; Push- function. This state is dynamic and only active while the magnet is moving towards the chip. 1 1 0 ON Enabled YELLOW Range: Magnetic field is ~ 25mT …45mT or ~75mT …135mT. The AS5043 may still be operated in this range, but with slightly reduced accuracy. Disabled RED Range: Magnetic field is ~~135mT. The analog output will be turned OFF in this range by default. It can be enabled permanently by OTP programming (see Diagnostic Output Mode). It is still possible to use the absolute serial interface in the red range, but not recommended. 1 1 ams Datasheet [v1-83] 2017-Jul-18 1 ON Page 21 Document Feedback AS5043 − Mode Input Pin Mode Input Pin The absolute angular position is sampled at a rate of 10.4kHz (t=96μs) in fast mode and at a rate of 2.6kHz (t=384μs) in slow mode. These modes are selected by pin MODE (#2) during the power up of the AS5043. This pin activates or deactivates an internal filter, which is used to reduce the digital jitter and consequently the analog output noise. Activating the filter by pulling Mode = LOW reduces the transition noise to 90% VDD(2) SSI Digital Output #0 - #1023 (0°-360°), MagRngn = 1 #0 - #1023 (0°-360°) Out of range is signaled in status bits: MagInc=MagDec=LIN=1, MagRngn= 0 With pull down resistor at DO (receiving side), all bits read by the SSI will be “0”-s, indicating a non-valid output Note(s) and/or Footnote(s): 1. Vref = internal: ½ * VDD5V (pin #16) or external: V DACref (pin#9), depending on Ref_extEN bit in OTP (0=int., 1=ext.). 2. VDD = positive supply voltage at receiving side (3.0 – 5.5V). ams Datasheet [v1-83] 2017-Jul-18 Page 27 Document Feedback AS5043 − Programming the AS5043 Programming the AS5043 After power-on, programming the AS5043 is enabled with the rising edge of CSn and Prog = logic high. 16 bit configuration data must be serially shifted into the OTP register via the Prog-pin. The first “CCW” bit is followed by the zero position data (MSB first) and the Analog Output Mode setting as shown in Figure 38. Data must be valid at the rising edge of CLK (see Figure 29). Following this sequence, the voltage at pin Prog must be raised to the programming voltage V PROG (see Figure 29). 16 CLK pulses (t PROG) must be applied to program the fuses. To exit the programming mode, the chip must be reset by a power-on-reset. The programmed data is available after the next power-up. Note(s): During the programming process, the transitions in the programming current may cause high voltage spikes generated by the inductance of the connection cable. To avoid these spikes and possible damage to the IC, the connection wires, especially the signals PROG and VSS must be kept as short as possible. The maximum wire length between the VPROG switching transistor and pin PROG (see Figure 31) should not exceed 50mm (2 inches). To suppress eventual voltage spikes, a 10nF ceramic capacitor should be connected close to pins PROG and VSS. This capacitor is only required for programming, it is not required for normal operation. The clock timing t clk must be selected at a proper rate to ensure that the signal PROG is stable at the rising edge of CLK (see Figure 29). Additionally, the programming supply voltage should be buffered with a 10μF capacitor mounted close to the switching transistor. This capacitor aids in providing peak currents during programming. The specified programming voltage at pin PROG is 7.3 –7.5V (see Programming Conditions). To compensate for the voltage drop across the V PROG switching transistor, the applied programming voltage may be set slightly higher (7.5 - 8.0V, see Figure 31). OTP Register Contents: Page 28 Document Feedback CCW Counter Clockwise Bit • ccw=0 – angular value increases in clockwise direction • ccw=1 – angular value increases in counterclockwise direction Z [9:0] Programmable Zero / Index Position FB_intEN OPAMP gain setting: 0=external, 1=internal RefExtEN DAC reference: 0=internal, 1=external ClampMd EN Analog output span: 0=0-100%, 1=10-90%*VDD Output Range (OR0, OR1) [1:0] Analog Output Range Selection 00 = 360°; 01 = 180°; 10 = 90°; 11 = 45° ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Programming the AS5043 Figure 29: Programming Access – OTP Write Cycle CSn tDatain Prog CCW Z9 Z8 Z7 Z6 Z5 1 CLKPROG tProg enable Z4 Z3 Z2 Z1 Z0 FB_int EN RefExt EN Clamp Md En Output Range1 Output Range0 8 tDatain valid 16 tclk see text Analog Modes Zero Position Figure 30: Complete OTP Programming Sequence Write Data Programming Mode Power Off CSn Prog 7.5V VDD VProgOff 0V Data 1 16 CLKPROG tLoad PROG ams Datasheet [v1-83] 2017-Jul-18 tPrgH tPrgR tPROG tPROG finished Page 29 Document Feedback AS5043 − Programming the AS5043 USB Figure 31: OTP Programming Hardware Connection of AS5043 (shown with AS5043 demoboard) Zero Position Programming The AS5043 allows easy assembly of the system, as the actual angle of the magnet does not need to be considered. By OTP programming, any position can be assigned as the new permanent zero position with an accuracy of 0.35° (all modes). Using the same procedure, the AS5043 can be calibrated to assign a given output voltage to a given angle. With this approach, all offset errors (DAC + OPAMP) are also compensated for the calibrated position. Essentially, for a given mechanical position, the angular measurement system is electrically rotated (by changing the Zero Position value in the OTP register), until the output matches the desired mechanical position. The example in Figure 32 below shows a configuration for 5V supply voltage and 10%-90% output voltage range. It adjusted by Zero Position Programming to provide an analog output voltage of 2.0 Volts at an angle of 180°. The slope of the curve may be further adjusted by changing the gain of the OPAMP output stage and by selecting the desired angular range (360°/180°/90°/45°). Page 30 Document Feedback ams Datasheet [v1-83] 2017-Jul-18 AS5043 − Programming the AS5043 Figure 32: Zero Position Programming (shown for 360° mode) VDD5V 5V analog output voltage the output can be electrically rotated to match a given output voltage to any mechanical position 2V 0V 0° 90° 180° 270° Mechanical 360° angle Analog Mode Programming The analog output can be configured in many ways: It consists of three major building blocks, • A digital range preselector, • A 10-bit Digital-to-Analog-Converter (DAC), • An OP-AMP buffer stage. In the default configuration (all OTP bits = 0), the analog output is set for 360° operation, internal DAC reference (VDD5V/2), external OPAMP gain, 0-100% ratiometric to VDD5V. Shown below is a typical example for a 0°-360° range, 0-5V output. The complete application requires only one external component, a buffer capacitor at VDD3V3 and has only 3 connections VDD, VSS and Vout (connectors 1-3). Note(s): The default setting for the OPAMP feedback path is:FB_intEn=0=external. The external resistors Rf and Rg must be installed. In the programmed state (FB_intEn=1=internal), these resistors do not need to be installed as the feedback path is internal (Rf_int and Rg_int). ams Datasheet [v1-83] 2017-Jul-18 Page 31 Document Feedback AS5043 − Programming the AS5043 Figure 33: Analog Output Block Diagram Magnetic field range alarm. Active lo . Leave open or connect to VSS if not used Mode pin. Default = open ( low noise) 1 AS 5043 External DAC reference pin. Leave open or connect to VSS if not used VDD5V 15 LDO 3.3V REF_extEN VDD3V3 + 1=ext 0 0 1 1 OR1 fro DSP 360° 180° 90° 45° 1-10µF VDD5 V / 2 0 1 0 1 0=int 10 Vref OR0 Range Selector VDD Connect pins 15 and 16 for VDD= 3.0-3.6V . Do NOT connect for VDD = 4. 5-5.5V ! 16 DACref Mode MagRng 1 9 2 10bit digital DAC DACout 0 - 100% VDD5V /2 10bit analog + VOUT - ClampMdEN DAC output pin. Leave open if not used 0=ext 0= 0-100% * Vref (def.) 1= 10-9 0% * Vref FB_intEN Vout 12 Rf_int 30k 2 Rf RLmin = 4k7 CL
AS5043-ASSM 价格&库存
很抱歉,暂时无法提供与“AS5043-ASSM”相匹配的价格&库存,您可以联系我们找货
