AS5161-HSOP
AS5161-HSOP
    AMSOSRAM(艾迈斯半导体)
    SOIC-8_150mil
    POS SENSOR ROTARY 12-BIT 8-SOIC
AS5161-HSOP 数据手册
Product Document Published by ams OSRAM Group AS5161 12-Bit Magnetic Angle Position Sensor General Description The AS5161 is a contactless magnetic angle position sensor for accurate angular measurement over a full turn of 360°. A sub range can be programmed to achieve the best resolution for the application. It is a system-on-chip, combining integrated Hall elements, analog front end, digital signal processing and best in class automotive protection features in a single device. To measure the angle, only a simple two-pole magnet, rotating over the center of the chip, is required. The magnet may be placed above or below the IC. The absolute angle measurement provides instant indication of the magnet’s angular position with a resolution of 0.022° = 16384 positions per revolution. According to this resolution the adjustment of the application specific mechanical positions are possible. The angular output data is available over a 12 bit pulse width modulated (PWM) output. The AS5161 operates at a supply voltage of 5V and the supply and output pins are protected against overvoltage up to +20V. In addition the supply pins are protected against reverse polarity up to –20V. Figure 1: Typical Arrangement of AS5161 and Magnet Ordering Information and Content Guide appear at end of datasheet. ams Datasheet [v1-04] 2015-Dec-07 Page 1 Document Feedback AS5161 − General Description Key Benefits & Features The benefits and features of AS5161, 12-Bit Magnetic Angle Position Sensor are listed below: Figure 2: Added Value of Using AS5161 Benefits Features • Great flexibility on angular excursion • 360º contactless high resolution angular position sensing • Simple programming • User programmable start and end point of the application region • Saw tooth mode 1-4 slopes per revolution • Clamping levels • Transition point • Failure diagnostics • Broken GND and VDD detection for all external load cases • High-resolution output signal • 12-Bit pulse width modulated (PWM) output • Ideal for applications in harsh environments due to contactless position sensing • Wide temperature range: - 40°C to 150°C Applications The AS5161 is ideal for automotive applications like: • Throttle and valve position sensing • Gearbox position sensor • Tumble flap • Chassis height level • Pedal position sensing • Contactless potentiometers Page 2 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − General Description Block Diagram The functional blocks of this device are shown below: Figure 3: AS5161 Block Diagram VDD3V3 VDD High Voltage/ Reverse Polarity Protection Hall Array Frontend Amplifier ADC AS5161 Sin Cos DSP CORDIC Controller 12 PWM OUT LS Driver Single Pin Interface (UART) OTP Register (Programming Parameters) GND ams Datasheet [v1-04] 2015-Dec-07 Page 3 Document Feedback AS5161 − Pin Assignment Pin Assignment VDD 1 TP1 2 VDD3V3 3 GND 4 AS5161 Figure 4: SOIC-8 Pin Configuration 8 OUT 7 S 6 TP3 5 TP2 Figure 5: Pin Description Pin Number Pin Name 1 VDD Supply pin Positive supply pin. This pin is over voltage protected. 2 TP1 DIO/AIO multi purpose pin Test pin for fabrication. Connected to ground in the application board. 3 VDD3V3 AIO Output of the internal voltage regulator 4 GND Supply pin Ground pin. Connected to ground in the application. 5 TP2 DIO/AIO multi purpose pin Test pin for fabrication. Connected to ground in the application board. 6 TP3 DIO/AIO multi purpose pin Test pin for fabrication. Open in the application. 7 S AIO Test pin for fabrication. Connected to OUT in the application board. 8 OUT DIO/AIO multi purpose pin Digital PWM output pin. Over this pin the programming is possible. Open drain configuration. Page 4 Document Feedback Pin Type Description ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 6: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD DC supply voltage at pin VDD Overvoltage -20 20 V No operation VOUT Output voltage OUT -0.3 20 V Permanent Vdiff Voltage difference at pin VDD and OUT -20 20 V VDD3V3 DC supply voltage at pin VDD3V3 -0.3 5 V Input current (latchup immunity) -100 100 mA Norm: AEC-Q100-004 kV Norm: AEC-Q100-002 Iscr Electrostatic Discharge ESD Electrostatic discharge ±2 Temperature Ranges and Storage Conditions Tstrg Storage temperature TBody Body temperature RHNC Relative humidity non-condensing MSL Moisture Sensitivity Level ams Datasheet [v1-04] 2015-Dec-07 -55 150 5 3 ºC Min -67ºF; Max 302ºF 260 ºC The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). 85 % Represents a maximum floor life time of 168h Page 5 Document Feedback AS5161 − Electrical Characteristics Electrical Characteristics Operating Conditions In this specification, all the defined tolerances for external components need to be assured over the whole operation conditions range and also over lifetime. Figure 7: Operating Conditions Symbol Parameter TAMB Ambient temperature Isupp Supply current VDD Supply voltage at pin VDD Conditions Min Typ -40 4.5 5.0 Max Units 150 ºC 10 mA 5.5 V Magnetic Input Specification TAMB = -40ºC to 150ºC, VDD = 4.5V to 5.5V (5V operation), unless otherwise noted. Two-Pole Cylindrical Diametrically Magnetized Source Figure 8: Magnetic Input Specification Symbol Bpk Bpkext Boff Disp Parameter Conditions Min Magnetic input field amplitude Required vertical component of the magnetic field strength on the die’s surface, measured along a concentric circle with a radius of 1.25 mm Magnetic input field amplitude (extended) default setting Required vertical component of the magnetic field strength on the die’s surface, measured along a concentric circle with a radius of 1.25 mm. Increased sensor output noise. Magnetic offset Constant magnetic stray field Displacement radius Offset between defined device center and magnet axis including eccentricity. Dependent on the selected magnet. Page 6 Document Feedback Typ Max Units 30 70 mT 10 90 mT ±5 mT 1 mm ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Electrical Characteristics Electrical System Specifications TAMB = -40ºC to 150ºC, V DD = 4.5V to 5.5V (5V operation), Magnetic Input Specification, unless otherwise noted. Figure 9: Electrical System Specifications Symbol RES Parameter Conditions Min Typ Max Units Resolution PWM Output Range > 90º 12 bit INLopt Integral non-linearity (optimum) Best aligned reference magnet at 25ºC over full turn 360º 0.5 deg INLtemp Integral non-linearity (optimum) Best aligned reference magnet over temperature -40º to 150º over full turn 360º 0.9 deg INL Integral non-linearity Best aligned reference magnet over temperature -40º to 150º over full turn 360º and displacement 1.4 deg DNL Differential non-linearity Monolitic 0.05 deg ON Output noise (360º segment) 1 LSB after filter peak/peak rms value 0.2 % DC tPwrUp Power-up time 0-5V See Figure 10 10 ms tdelay System propagation delay absolute output: delay of ADC, DSP and absolute interface 10kΩ, 100 μF RC filter 300 μs Figure 10: Power-Up Timing Diagram VDD 4.5V OUT pin in HiZ First Valid Data on OUT pin tPwrUp ams Datasheet [v1-04] 2015-Dec-07 Page 7 Document Feedback AS5161 − Electrical Characteristics Timing Characteristics Figure 11: Timing Conditions Symbol Parameter TDETWD WachDog error detection time Conditions Min Typ Max Units 12 ms Power Management - Supply Monitor Figure 12: Power Management - Supply Monitor Conditions Symbol Parameter Conditions Min Typ Max Units VDDUVTH VDD undervoltage upper threshold 3.5 4.0 4.5 V VDDUVTL VDD undervoltage lower threshold 3.0 3.5 4.0 V VDDUVHYS VDD undervoltage hysteresis 300 500 900 mV VDDUVDET VDD undervoltage detection time 10 50 250 μs VDDUVREC VDD undervoltage recovery time 10 50 250 μs VDDOVTH VDD overvoltage upper threshold 6.0 6.5 7.0 V VDDOVTL VDD overvoltage lower threshold 5.5 6 6.5 V VDDOVHYS VDD overvoltage hysteresis 300 500 900 mV ANATOVDET VDD overvoltage detection time (analog path) 10 50 250 μs ANATOVREC VDD overvoltage recovery time (analog path) 10 50 250 μs Page 8 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Detailed Description Detailed Description The AS5161 is manufactured in a CMOS process and uses a spinning current Hall technology for sensing the magnetic field distribution across the surface of the chip. The integrated Hall elements are placed around the center of the device and deliver a voltage representation of the magnetic field at the surface of the IC. Through Sigma-Delta Analog / Digital Conversion and Digital Signal-Processing (DSP) algorithms, the AS5161 provides accurate high-resolution absolute angular position information. For this purpose a Coordinate Rotation Digital Computer (CORDIC) calculates the angle and the magnitude of the Hall array signals. The DSP is also used to provide digital information at the outputs that indicate movements of the used magnet towards or away from the device’s surface. A small low cost diametrically magnetized (two-pole) standard magnet provides the angular position information. The AS5161 senses the orientation of the magnetic field and calculates a 14-bit binary code. This code is mapped to a programmable output characteristic in a PWM duty cycle format. This signal is available at the pin (OUT). The application angular region can be programmed in a user friendly way. The start angle position T1 and the end point T2 can be set and programmed according the mechanical range of the application with a resolution of 14 bits. In addition the T1Y and T2Y parameter can be set and programmed according the application. The transition point 0 to 360 degree can be shifted using the break point parameter BP. The voltage for clamping level low CLL and clamping level high CLH can be programmed with a resolution of 9 bits. Both levels are individually adjustable. The output parameters can be programmed in an OTP register. No additional voltage is required to program the AS5161. The setting may be overwritten at any time and will be reset to default when power is cycled. To make the setting permanent, the OTP register must be programmed by using a lock bit the content could be frozen for ever. The AS5161 is tolerant to magnet misalignment and unwanted external magnetic fields due to differential measurement technique and Hall sensor conditioning circuitry. ams Datasheet [v1-04] 2015-Dec-07 Page 9 Document Feedback AS5161 − Detailed Description Operation VDD Voltage Monitor VDD Over Voltage Management. If the supply voltage at pin VDD exceeds the over-voltage upper threshold for longer than the detection time the output is turned off. When the over voltage event has passed and the voltage applied to pin VDD falls below the over-voltage lower threshold for longer than the recovery time the device enters the normal mode and the output is enabled. VDD Under Voltage Management. When the voltage applied to the VDD pin falls below the under-voltage lower threshold for longer than the detection time the output is turned off. When the voltage applied to the VDD pin exceeds the under-voltage upper threshold for longer than the detection time the device enters the normal mode and the output is enabled. PWM Output By default (after programmed CUST_LOCK OTP bit) the PWM output mode is selected. The pin OUT provides a modulated signal that is proportional to the angle of the rotating magnet. Due to an intelligent approach a permanent short circuit will not damage the device. This is also feasible in a high voltage condition up to 20 V and at the highest specified ambient temperature. After the digital signal processing (DSP) a PWM engine provides the output signal. The DSP maps the application range to the output characteristic. An inversion of the slope is also programmable to allow inversion of the rotation direction. An on-chip diagnostic feature handles the error state at the output. Depending on the failure the output is in HiZ condition or indicates a PWM signal within the failure bands of 4 –96% duty cycle (see Figure 20). Page 10 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Detailed Description Programming Parameters The PWM output characteristic is programmable by OTP. Depending on the application, the output can be adjusted. The user can program the following application specific parameters. Figure 13: Programming Parameters Parameter Description T1 Mechanical angle start point T2 Mechanical angle end point T1Y % duty cycle level at the T1 position T2Y % duty cycle level at the T2 position CLL Clamping Level Low CLH Clamping Level High BP Break point (transition point 0 to 360º) These parameters are input parameters. Using the available programming software and programmer these parameters are converted and finally written into the AS5161 128 bit OTP memory. ams Datasheet [v1-04] 2015-Dec-07 Page 11 Document Feedback AS5161 − Detailed Description Application Specific Angular Range Programming The application range can be selected by programming T1 with a related T1Y and T2 with a related T2Y into the AS5161. The clamping levels CLL and CLH can be programmed independent from the T1 and T2 position and both levels can be separately adjusted. Figure 14: Programming of an Individual Application Range 90 degree Application range electrical range T2 mechanical range T1 100%DC clamping range high CLH CLL 0 degree T2Y 180 degree CLH T1Y BP CLL 0 clamping range low T1 T2 270 degree Figure 14 shows a simple example of the selection of the range. The mechanical starting point T1 and the mechanical end point T2 are defining the mechanical range. A sub range of the internal CORDIC output range is used and mapped to the needed output characteristic. The PWM output signal has 12 bit, hence the level T1Y and T2Y can be adjusted with this resolution. As a result of this level and the calculated slope the clamping region low is defined. The break point BP defines the transition between CLL and CLH. In this example the BP is set to 0 degree. The BP is also the end point of the clamping level high CLH. This range is defined by the level CLH and the calculated slope. Both clamping levels can be set independently form each other. Page 12 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Detailed Description Application Specific Programming of the Break Point The break point BP can be programmed as well with 14 bits. This is important when the default transition point is inside the application range. In such a case the default transition point must be shifted out of the application range. The parameter BP defines the new position. Figure 15: Individual Programming of the Break Point BP 90 degree Application range electrical range T2 mechanical range T1 100%DC CLH clamping range high CLH 0 degree T2Y 180 degree CLL T1Y CLL BP 0 clamping range low T1 T2 clamping range low 270 degree ams Datasheet [v1-04] 2015-Dec-07 Page 13 Document Feedback AS5161 − Detailed Description Multiple Slope Output The AS5161 can be programmed to multiple slopes. Where one programmed reference slope characteristic is copied to multiple slopes. Two, three and four slopes are selectable by the user OTP bits QUADEN (1:0). In addition to the steepness of the slope the clamping levels can be programmed as well. Duty Cycle Figure 16: Two Slope Mode 0 Duty Cycle Figure 17: Four Slope Mode 0 Page 14 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Detailed Description Resolution of Parameters The programming parameters have a wide resolution of up to 14 bits. Figure 18: Resolution of the Programming Parameters Symbol Parameter Resolution T1 Mechanical angle start point 14 bits T2 Mechanical angle stop point 14 bits T1Y Mechanical start voltage level 12 bits T2Y Mechanical stop voltage level 12 bits CLL Clamping level low 9 bits CLH Clamping level high 9 bits Break point 14 bits BP Note Figure 19: Overview of the Output Range 100 96 Failure Band High Clamping Region High CLH Duty Cycle T2Y Application Region T1Y CLL Clamping Region Low 4 0 Failure Band Low Figure 19 gives an overview of the different ranges. The failure bands are used to indicate a wrong operation of the AS5161. This can be caused due to a broken supply line. By using the ams Datasheet [v1-04] 2015-Dec-07 Page 15 Document Feedback AS5161 − Detailed Description specified load resistors, the output level will remain in these bands during a fail. It is recommended to set the clamping level CLL above the lower failure band and the clamping level CLH below the higher failure band. Figure 20: Different Failure Cases of AS5161 Type Failure Mode Symbol Failure Band MAGRng High/Low Programmable by OTP bit DIAG_HIGH CORDIC overflow COF High/Low Programmable by OTP bit DIAG_HIGH Offset compensation finished OCF High/Low Programmable by OTP bit DIAG_HIGH Watchdog fail WDF High/Low Programmable by OTP bit DIAG_HIGH Oscillator fail OF High/Low Programmable by OTP bit DIAG_HIGH Overvoltage condition OV Out of magnetic range (too less or too high magnetic input) Internal alarms (failures) Application related failures Broken VDD BVDD Broken VSS BVSS Short circuit output SCO Note High Dependant on the load resistor Pull up → failure band high High Switch off → short circuit dependent For efficient use of diagnostics, it is recommended to program to clamping levels CLL and CLH. Page 16 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Detailed Description PWM Output Driver Parameters The output stage is configured in a open drain output. The PWM duty cycle represents the angular output data. All programming features are available for the PWM mode as well. The PWM period is programmable in four steps and can be programmed by PWMF. C LOAD≤ 33 nF, R PU= 1kΩ to 10kΩ Figure 21: PWM Parameters Output Driver Symbol Parameter Conditions Min Typ Max Units PWMF1 PWM frequency 7 PWMF=111 109.86 122 134.28 Hz PWMF2 PWM frequency 6 PWMF=110 179.78 200 219.73 Hz PWMF3 PWM frequency 5 PWMF=101 219.73 244 268.55 Hz PWMF4 PWM frequency 4 PWMF=100 329.59 366 402.83 Hz PWMF5 PWM frequency 3 PWMF=011 494.38 549 604.25 Hz PWMF6 PWM frequency 2 PWMF=010 659.18 732 805.66 Hz PWMF7 PWM frequency 1 PWMF=001 988.77 1100 1208.50 Hz PWMF8 PWM frequency 0 PWMF=000 1977.54 2197 2416.2 Hz PWMDC PWM duty cycle range info parameter 4 96 % PWMVOL Output voltage low IOUT=5mA 0 0.4 V PWMSRF PWM slew rate (falling edge) Between 75% and 25% RPUOUT=4KΩ; CLOUT=1nF VDD=5V 1 4 V / μs 2 Hysteresis Function AS5161 device includes a hysteresis function to avoid sudden jumps from CLH to CLL and vice versa caused by noise in the full turn configuration. The hysteresis amplitude can be selected via the OTP bits HYSTSEL. ams Datasheet [v1-04] 2015-Dec-07 Page 17 Document Feedback AS5161 − Application Information Application Information Recommended Application Schematic Figure 22 shows the recommended schematic in the application. All components marked with (*) are optional and can be used to further increase the EMC. Figure 22: Recommended Schematic of Pull-Up Configuration Sensor PCB Electric Control Unit VDD RLPU R1* VDD TP1 VDD3V3 OUT AS5161 GND C1 C2 OUT S TP3 TP2 C3 C4* CL GND Figure 23: External Components Symbol Parameter Min Typ Max Units Note C1 VDD buffer capacitor 0.8 1 1.2 μF Low ESR 0.3 Ω C2 VDD3V3 regulator capacitor 0.8 1 1.2 μF Low ESR 0.3 Ω C3 OUT load capacitor (sensor PCB) 4.7 nF C4* VDD capacitor (optional) 4.7 nF R1* VDD serial resistor (optional) 10 Ω CL OUT load capacitor (ECU) 0 33 nF OUT pull-up resistance 1 10 kΩ RLPU Page 18 Document Feedback 0 Do not increase due to programming over output. ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Application Information Programming the AS5161 The AS5161 programming is a one-time-programming (OTP) method, based on polysilicon fuses. The advantage of this method is that no additional programming voltage is needed. The internal LDO provides the current for programming. The OTP consists of 128 bits; several bits are available for user programming. In addition factory settings are stored in the OTP memory. Both regions are independently lockable by build in lock bits. A single OTP cell can be programmed only once. Per default, the cell is “0”; a programmed cell will contain a “1”. While it is not possible to reset a programmed bit from “1” to “0”, multiple OTP writes are possible, as long as only unprogrammed “0”-bits are programmed to “1”. Independent of the OTP programming, it is possible to overwrite the OTP register temporarily with an OTP write command. This is possible only if the user lock bit is not programmed. Due to the programming over the output pin the device will initially start in the communication mode. In this mode the digital angle value can be read with a specific protocol format. It is a bidirectional communication possible. Parameters can be written into the device. A programming of the device is triggered by a specific command. With another command (pass2func) the device can be switched into operation mode. In case of a programmed user lock bit the AS5161 automatically starts up in the functional operation mode. No communication of the specific protocol is possible after this. A standard half duplex UART protocol is used to exchange data with the device in the communication mode. UART Interface for Programming The AS5161 uses a standard UART interface with an address byte and two data bytes. The read or write mode is selected with bit R/Wn in the first byte. The timing (baudrate) is selected by the AS5161 over a synchronization frame. The baud rate register can be read and overwritten (optional). Every start bit is used for synchronization. A time out function detects not complete commands and resets the AS5161 UART after the timeout period. ams Datasheet [v1-04] 2015-Dec-07 Page 19 Document Feedback AS5161 − Application Information Frame Organization Each frame is composed by 24 bits. The first byte of the frame specifies the read/write operation with the register address. 16 data bits contains the communication data. There will be no operation in case of the usage of a not specified CMD. The UART programming interface block of the AS5161 can operate in slave communication or master communication mode. In the slave communication mode the AS5161 receives the data. The programming tool is the driver of the single communication line. In case of the master communication mode the AS5161 transmits data in the frame format. The single communication line can be pulled down by the AS5161. The UART frame consists of 1 start bit (low level), 8 data bit, 1 even-parity bit and 1 stop bit (high level). Data are transferred from LSB to MSB. Figure 24: General UART Frame start D0 D1 D2 D3 D4 D5 D6 D7 par stop Figure 25: Bit Timing Symbol Parameter Min Typ Max Unit START Start bit 1 TBIT Dx Data bit 1 TBIT PAR Parity bit 1 TBIT STOP Stop bit TSW Slave/Master Switch Time Page 20 Document Feedback 1 Note TBIT 7 TBIT ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Application Information Each communication starts with the reception of a request from the external controller. The request consists of two frames: one synchronization frame and the command frame. The synchronization frame contains the data 0x55 and allows the UART to measure the external controller baud rate. Figure 26: Synchronization Frame start D0 D1 D2 D3 D4 D5 D6 D7 par stop The second frame contains the command Read/ Write (1 bit) and the address (7 bits). Figure 27: Address and Command Frame start AD 0 AD 1 AD 2 AD 3 AD 4 AD 5 AD R/Wn 6 par stop Only two commands are possible. In case of read command the idle phase between the command and the answer is the time TSW. In case of parity error command is not executed. Figure 28: Possible Commands Possible Interface Commands Description AS5X63 Communication Mode Command CMD WRITE Write data to the OTP memory or Registers SLAVE 0 READ Read data to the OTP memory or Registers SLAVE & MASTER 1 Note(s) and/or Footnote(s): 1. In case of Write command the request is followed by the frames containing the data to write. 2. In case of Read command the communication direction will change and the AS5161 will answer with the frames containing the requested data. ams Datasheet [v1-04] 2015-Dec-07 Page 21 Document Feedback AS5161 − Application Information WRITE (Command Description) Figure 29: Full Write Command Synchronization frame start D0 D1 D2 D3 D4 D5 AD0 AD1 AD2 AD3 AD4 AD5 D6 D7 par stop par stop Write command frame start AD6 R/ Wn Data0 frame (data to write on address AD) start D00 D01 D03 D04 D05 D06 D07 par stop D03 D04 D05 D06 D07 par stop D02 Data1 frame (data to write on address AD+1) start D00 D01 D02 • Writing the AS5161 KEY in the fuse register (address 0x41) triggers the transfer of the data from the OTP RAM into the Poly Fuse cell. • Writing the AS5161 KEY in the Pass2Func Register (address 0x60) forces the device into normal mode. Page 22 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Application Information READ (Command Description) Figure 30: Full Read Command Synchronization frame: start D0 D1 D2 D3 D4 D5 D6 D7 par stop AD0 AD1 AD2 AD3 AD4 AD5 AD6 R/Wn par stop Read command frame: start Data0 frame (data read from address AD) (MASTER): start D00 D01 D02 D03 D04 D05 D06 D07 par stop D04 D05 D06 D07 par stop Data1 frame (data read from address AD+1) (MASTER): start D00 D01 D02 D03 Baud-Rate Automatic Detection The UART includes a built-in baud-rate monitor that uses the synchronization frame to detect the external controller baud-rate. This baud-rate is used after the synchronization byte to decode the following frame and to transmit the answer and it is stored in the BAUDREG register. Baud-Rate Manual Setting (Optional) The BAUDREG register can be read and over-written for a possible manual setting of the baud-rate: in case the register is overwritten with a value different from 0, this value will be used for the following UART communications and the synchronization frame must be removed from the request. ams Datasheet [v1-04] 2015-Dec-07 Page 23 Document Feedback AS5161 − Application Information High Byte Even Parity Stop S 0 0 0 0 0 0 0 0 0 P IDLE Start Even Parity Stop S 0 1 0 1 1 1 0 0 0 P IDLE MSB LSB Low Byte MSB LSB P IDLE Start 0 R/n Even Parity Stop S MSB LSB WR BAUDREG Address Start R/n Even Parity Stop S 1 0 1 0 1 0 1 0 0 P IDLE Start IDLE synch frame MSB LSB Figure 31: Manual Baud-Rate Setting AS5161 in Receiving Mode (Write Access) AS5161 in Receiving Mode Page 24 Document Feedback MSB High Byte Even Parity IDLE Stop P Start S High Byte S P IDLE Stop IDLE Even Parity P MSB LSB Low Byte Start S Even Parity Stop LSB IDLE Start P Stop 1 IDLE AS5161 in Receiving Mode (Write Access) MSB Reg. Address R/Wn Even Parity LSB Start S LSB P Even Parity Stop S AS5161 in Receiving Mode IDLE Low Byte MSB LSB IDLE MSB R/n Even Parity P Start 0 Stop Reg. Address S Start IDLE MSB LSB Figure 32: Simple Read and Write AS5161 in transmitting mode (Read Access) ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Application Information OTP Programming Data Figure 33: OTP Memory Map Data Byte Bit Number Symbol Default 0 0 1 0 2 0 3 0 4 0 5 0 6 0 7 0 Description DATA15 (0x0F) 1 Factory Settings 0 ams (reserved) 0 2 0 3 0 4 0 5 0 6 0 7 0 0 0 1 0 Factory Settings 0 DATA14 (0x0E) DATA13 (0x0D) ams Datasheet [v1-04] 2015-Dec-07 Page 25 Document Feedback AS5161 − Application Information Bit Number Symbol Default 2 CUSTID 0 3 CUSTID 0 4 CUSTID 0 5 CUSTID 0 6 CUSTID 0 7 CUSTID 0 DATA12 (0x0C) 0 CUSTID 0 DATA11 (0x0B) 7 CLH 0 0 CLH 0 1 CLH 0 2 CLH 0 3 CLH 0 4 CLH 0 5 CLH 0 6 CLH 0 7 CLH 0 Data Byte Description DATA13 (0x0D) Customer Identifier Customer Settings Clamping Level High DATA10 (0x0A) Page 26 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Application Information Data Byte Bit Number Symbol Default 0 CLL 0 1 CLL 0 2 CLL 0 3 CLL 0 4 CLL 0 5 CLL 0 6 CLL 0 7 CLL 0 0 CLL 0 1 OFFSET 0 2 OFFSET 0 3 OFFSET 0 4 OFFSET 0 5 OFFSET 0 6 OFFSET 0 7 OFFSET 0 0 OFFSET 0 1 OFFSET 0 2 OFFSET 0 3 OFFSET 0 4 OFFSET 0 5 OFFSET 0 6 OFFSET 0 7 OFFSET 0 Description DATA9 (0x09) Clamping Level Low Customer Settings DATA8 (0x08) Offset DATA7 (0x07) ams Datasheet [v1-04] 2015-Dec-07 Page 27 Document Feedback AS5161 − Application Information Data Byte Bit Number Symbol Default 0 OFFSET 0 1 OFFSET 0 2 OFFSET 0 3 OFFSET 0 4 OFFSET 0 5 GAIN 0 6 GAIN 0 7 GAIN 0 0 GAIN 0 1 GAIN 0 2 GAIN 0 3 GAIN 0 4 GAIN 0 5 GAIN 0 6 GAIN 0 7 GAIN 0 0 GAIN 0 1 GAIN 0 2 GAIN 0 3 GAIN 0 4 GAIN 0 5 GAIN 0 6 BP 0 7 BP 0 Description Offset DATA6 (0x06) Scale Factor Customer Settings DATA5 (0x05) DATA4 (0x04) Break Point Page 28 Document Feedback ams Datasheet [v1-04] 2015-Dec-07 AS5161 − Application Information Data Byte Bit Number Symbol Default 0 BP 0 1 BP 0 2 BP 0 3 BP 0 4 BP 0 5 BP 0 6 BP 0 7 BP 0 0 BP 0 1 BP 0 2 BP 0 3 BP 0 Description DATA3 (0x003) Break Point ANGLERNG 0 5 DIAG_HIGH 0 Failure Band Selection 0=Failure Band Low 1=Failure Band High 6 QUADEN 0 7 QUADEN 0 DATA2 (0x02) ams Datasheet [v1-04] 2015-Dec-07 Customer Settings 4 Sector selection 0=Angular Sector≥22.5 degrees; 1=Angular Sector
AS5161-HSOP
物料型号:AS5161
器件简介: - AS5161是一款无接触式磁性角度位置传感器,能够实现360°范围内的精确角度测量。 - 该传感器为系统级芯片,集成了霍尔元件、模拟前端、数字信号处理和汽车级保护特性。 - 通过简单的两极磁铁在芯片中心上方或下方旋转即可测量角度。
引脚分配: - VDD:供电引脚,具有过压保护。 - OUT:数字PWM输出引脚,用于编程,配置为开漏。 - TP1、TP2、TP3、VDD3V3:多功能测试/应用引脚,具体功能取决于应用。
参数特性: - 绝对角度测量,分辨率为0.022°,即每圈16384个位置。 - PWM输出,12位分辨率。 - 工作温度范围宽,从-40°C到150°C。
功能详解: - 传感器通过霍尔元件感应磁场分布,并通过DSP算法提供高精度的绝对角度位置信息。 - 应用角度区域可编程,用户可以根据机械范围设置起始和结束角度。 - 具有故障诊断功能,能够检测GND和VDD的断裂。
应用信息: - 适用于汽车应用,如油门和阀门位置感应、变速箱位置传感器、翻板、底盘高度、踏板位置感应等。
封装信息: - AS5161采用SOIC-8封装,具有特定的机械和电气特性。
AS5161-HSOP 价格&库存
很抱歉,暂时无法提供与“AS5161-HSOP”相匹配的价格&库存,您可以联系我们找货
