Product
Document
Published by
ams OSRAM Group
Datasheet
DS000522
CMV50000
47.5MP CMOS Machine Vision Image Sensor
v3-01 • 2019-Dec-20
Document Feedback
CMV50000
Content Guide
Content Guide
1
General Description....................... 3
7.8
Additional Features .................................... 92
1.1
1.2
1.3
Key Benefits & Features .............................. 3
Applications .................................................. 4
Block Diagram .............................................. 4
8
Register Description ................. 102
8.1
8.2
Register Overview .................................... 102
Detailed Register Description .................. 106
2
Ordering Information ..................... 5
9
Application Information ............ 130
3
Pin Assignment ............................. 6
3.1
3.2
Pin Diagram .................................................. 6
Pin Description ............................................. 6
9.1
9.2
9.3
Color Filter ................................................ 130
Socket ...................................................... 130
Pin Layout ................................................ 131
4
Absolute Maximum Ratings ........ 11
10
Package Drawings & Markings. 132
5
Electrical Characteristics ............ 12
11
Packing Information .................. 135
6
Typical Operating
Characteristics ............................. 14
12
Soldering Information ............... 136
13
Revision Information ................. 137
6.1
6.2
Electro-Optical Characteristics ................... 14
Spectral Characteristics ............................. 16
14
Legal Information ...................... 138
7
Functional Description ................ 19
7.1
7.2
7.3
7.4
7.5
7.6
7.7
Sensor Architecture .................................... 19
Operating the Sensor ................................. 22
Sensor Readout Format ............................. 49
Configuring the Sensor .............................. 57
Configuring Readout and Exposure ........... 73
Configuring the Output Data Format .......... 85
Configuring the On-Chip Data Processing . 89
Datasheet • PUBLIC
DS000522 • v3-01 • 2019-Dec-20
138 │ 2
Document Feedback
1
CMV50000
General Description
General Description
The CMV50000 is a high speed CMOS image sensor with 7920 × 6004 effective pixels (47.5Mp)
developed for machine vision and video applications. The image array consists of 4.6µm pipelined 8T
global shutter pixels which allow exposure during read out, while performing true CDS (Correlated
Double Sampling) operation. The image sensor also integrates a programmable analog gain amplifier
and offset regulation. The image sensor has 22 digital sub-LVDS data output channels. Each output
channel runs up to 830 Mbit/s, which results in a frame rate of 30 fps at full resolution. Higher frame
rates can be achieved in row-windowing mode or row-subsampling mode. These modes are all
programmable using the SPI interface. All internal exposure and read out timings are generated by a
programmable on-chip sequencer. External triggering and exposure programming is also possible.
Extended optical dynamic range can be achieved by a dual exposure HDR mode.
1.1
The benefits and features of CMV50000, 47.5MP CMOS Machine Vision Image Sensor, are listed
below:
Figure 1:
Added Value of Using CMV50000
Benefits
Features
Designed for high performance applications
Resolution of 7920x6004 at 30 frames per
second
Capture fast moving objects
8T global shutter pixel with true Correlated
Double Sampling (true-CDS)
Use in low light conditions
Low noise (8.8e) and high sensitivity (QE=60%),
with on-chip noise reduction.
Use in bright light conditions
In binning mode the full well capacity reaches
58000e- with an SNR of 47.6dB and DR=68dB
Standard optics can be used
35mm Full Frame optical format
Easy to operate
On-chip digital sequencer which handles all the
sensor controls, over SPI
Datasheet • PUBLIC
138 │ 3
Document Feedback
1.2
Applications
1.3
CMV50000
General Description
Machine vision
Video/Broadcast
Security
High-end inspection
Aerial mapping
Document scanning
ITS
Scientific
3D imaging
Block Diagram
The functional blocks of this device are shown below:
Figure 2 :
Functional Blocks of CMV50000
98 OB +
22 buffer
pixels
SPI, sensor control
CLK in
Datasheet • PUBLIC
98 OB +
22 buffer
pixels
AFE
AFE
AFE
AFE
ADC
ADC
ADC
ADC
DPP
DPP
DPP
DPP
sLVDS
sLVDS
sLVDS
sLVDS
sLVDS
sLVDS
CTR_OUT
channel
OBL _OUT
channel
OBR_OUT
channel
CLK_OUT
channel
Digital sequencer
Thermal
sensor
Pixel array
7920 x 6004 (effective) active pixels
PLL
22 DATAx_OUT
channels
138 │ 4
Document Feedback
2
CMV50000
Ordering Code
Package
Chroma
CMV50000-1E3M1PA
PGA
Mono
10 Pcs / Tray
CMV50000-1E3C1PA
PGA
Color
10 Pcs / Tray
CMV50000-1E3M1PN
PGA
Mono
Datasheet • PUBLIC
Options
windowless
Delivery Quantity
10 Pcs / Tray
138 │ 5
Document Feedback
3
Pin Assignment
3.1
Pin Diagram
CMV50000
Pin Assignment
Figure 3 :
Pin Numbering (bottom view)
3.2
Pin Description
Figure 4:
Pin Description of CMV50000
Pin Number
Pin Name
Pin Type
Description
A2
SPI_CSN
Digital input
SPI Chip Select
A3
VSSA
Analog ground
Analog ground
A5
REQ_FRAME
Digital input
Request frame (stop exposure)
A6
VDDARRAY
Analog supply
Pixel array supply
A7
VDDARRAY
Analog supply
Pixel array supply
A8
NC1
Analog
Do Not Connect
Datasheet • PUBLIC
138 │ 6
Document Feedback
CMV50000
Pin Assignment
Pin Number
Pin Name
Pin Type
Description
A9
NC2
Analog
Do Not Connect
A10
CTRL_P
sub-LVDS
Control channel output
A11
CTRL_N
sub-LVDS
A13
VSSA
Analog ground
Main analog ground
A14
DOBL_P
sub-LVDS
Left Optical Black output
A15
DOBL_N
sub-LVDS
B1
SPI_MISO
Digital output
SPI Master In/Slave Out data
B2
SPI_MOSI
Digital input
SPI Master Out/Slave In data
B3
SPI_CLK
Digital input
SPI clock
B4
CLK_IN
Digital input
Sensor input clock
B5
RST_N
Digital input
Asynchronous hard reset input pin
B6
VDD33
Analog supply
On-chip regulators supply
B7
VSELHREG
Analog
On-chip regulator output
B8
VS2HREG
Analog
B9
VS1HREG
Analog
B10
VTXHREG
Analog
B11
VRESHREG
Analog
B12
VDD27
Analog supply
Main analog supply
B13
D00_P
sub-LVDS
Channel 0 output
B14
D00_N
sub-LVDS
Channel 0 output
B15
D02_P
sub-LVDS
Channel 2 output
C1
VDDD12PLL1
Digital supply
Digital supply for PLL1
C2
VDDD12PLL2
Digital supply
Digital supply for PLL2
C3
REQ_EXP
Digital input
Request exposure (start exposure)
C4
VDD27
Analog supply
Main analog supply
C5
VSSD
Digital ground
Digital ground
C6
VSSD
Digital ground
Digital ground
C7
VSELH
Analog
Bias
C8
VS2H
Analog
Bias
C9
VS1H
Analog
Bias
C10
VTXH
Analog
Bias
C11
VRESH
Analog
Bias
C12
D01_P
sub-LVDS
Channel 1 output
C13
D01_N
sub-LVDS
Channel 1 output
C14
D03_P
sub-LVDS
Channel 3 output
Datasheet • PUBLIC
138 │ 7
Document Feedback
CMV50000
Pin Assignment
Pin Number
Pin Name
Pin Type
Description
C15
D02_N
sub-LVDS
Channel 2 output
D1
VDD12C
Digital supply
Logic supply for ADC
D2
VSSD
Digital ground
Main digital ground
D14
D03_N
sub-LVDS
Channel 3 output
D15
D04_P
sub-LVDS
Channel 4 output
E1
VSSDPLL1
Digital ground
Digital ground for PLL1
E2
VSSDPLL2
Digital ground
Digital ground for PLL2
E14
D05_P
sub-LVDS
Channel 0 output
E15
D04_N
sub-LVDS
Channel 0 output
F1
VSSAPLL1
Analog ground
Analog ground for PLL1
F2
VSSAPLL2
Analog ground
Analog ground for PLL2
F14
D05_N
sub-LVDS
Channel 5 output
F15
D06_P
sub-LVDS
Channel 6 output
G1
VDDA12PLL1
Analog supply
Analog supply for PLL1
G2
VDDA12PLL2
Analog supply
Analog supply for PLL2
G14
D07_P
sub-LVDS
Channel 7 output
G15
D06_N
sub-LVDS
Channel 6 output
H1
VDD12
Digital supply
Logic supply for core logic
H2
VSSD
Digital ground
Main digital ground
H14
D07_N
sub-LVDS
Channel 7 output
H15
D08_P
sub-LVDS
Channel 8 output
J1
VDD12
Digital supply
J2
VSSA
Analog ground
Main analog ground
J14
D09_P
sub-LVDS
Channel 9 output
J15
D08_N
sub-LVDS
Channel 8 output
K1
VDD12C
Digital supply
K2
VSSA
Analog ground
Main analog ground
K14
D09_N
sub-LVDS
Channel 9 output
K15
D10_P
sub-LVDS
Channel 10 output
L1
VSSDC
Digital ground
Digital ground for ADC
L2
VDDARRAY
Analog supply
Pixel array supply
L14
D11_P
sub-LVDS
Channel 11 output
L15
D10_N
sub-LVDS
Channel 10 output
M1
VSSDC
Digital ground
M2
VDDARRAY
Analog supply
Pixel array supply
Datasheet • PUBLIC
138 │ 8
Document Feedback
CMV50000
Pin Assignment
Pin Number
Pin Name
Pin Type
Description
M14
D11_N
sub-LVDS
Channel 11 output
M15
D12_P
sub-LVDS
Channel 12 output
N1
VSSDC
Digital ground
Digital ground
N2
VSSD
Digital ground
Digital ground
N14
D13_P
sub-LVDS
Channel 13 output
N15
D12_N
sub-LVDS
Channel 12 output
P1
VDD18
Digital supply
I/O supply for CMOS and I/O’s
P2
VDD27
Analog supply
Main analog supply
P14
D13_N
sub-LVDS
Channel 13 output
P15
D14_P
sub-LVDS
Channel 14 output
R1
VDD18
Digital supply
R2
VDD27
Analog supply
Main analog supply
R14
D15_P
sub-LVDS
Channel 15 output
R15
D14_N
sub-LVDS
Channel 14 output
S1
VDD27CP
Analog supply
Connect to VDD27
S2
VSSACP
Analog ground
Analog ground
S14
D15_N
sub-LVDS
Channel 15 output
S15
D16_P
sub-LVDS
Channel 16 output
T1
VDD12C
Digital supply
T2
VSSD
Digital ground
Main digital ground
T14
D17_P
sub-LVDS
Channel 17 output
T15
D16_N
sub-LVDS
Channel 16 output
U1
EXTRA1
Analog ground
Connect to analog ground
U2
TDIGO1
Digital output
Digital test output
U3
TANAI1
Analog
Do Not Connect
U4
TANAI2
Analog
Do Not Connect
U5
VSELLNEG12
Analog
U6
VS2LNEG12
Analog
U7
VPCLNEG12
Analog
U8
VS1LNEG12
Analog
U9
VABNEG12
Analog
U10
VRESLNEG12
Analog
U11
VRESL
Analog
Bias
U12
D19_N
sub-LVDS
Channel 19 output
U13
D19_P
sub-LVDS
Channel 19 output
Datasheet • PUBLIC
138 │ 9
Document Feedback
CMV50000
Pin Assignment
Pin Number
Pin Name
Pin Type
Description
U14
D17_N
sub-LVDS
Channel 17 output
U15
D18_P
sub-LVDS
Channel 18 output
V1
REF2
Analog
Do Not Connect
V2
JTAG_MODE
Digital input
JTAG Mode select. Connect to VSSD if
JTAG is not used.
V3
REF3
Analog
Bias
V4
TANAO
Analog
Do Not Connect
V5
VSELL
Analog
Bias
V6
VS2L
Analog
Bias
V7
VPCL
Analog
Bias
V8
VS1L
Analog
Bias
V9
VABREG
Analog
V10
VRESLREG
Analog
V11
DOBR_P
sub-LVDS
Right Optical Black output
V12
DOBR_N
sub-LVDS
V13
D20_N
sub-LVDS
Channel 20 output
V14
D20_P
sub-LVDS
Channel 20 output
V15
D18_N
sub-LVDS
Channel 18 output
W1
REF1
Analog
Do Not Connect
W2
REF0
Analog
Bias
W3
VSSA
Analog ground
Analog ground
W5
VSELLREG
Analog
W6
VS2LREG
Analog
W7
VPCLREG
Analog
W8
VS1LREG
Analog
W9
VAB
Analog
Bias
W10
CLK_N
sub-LVDS
Clock output
W11
CLK_P
sub-LVDS
Clock output
W13
VSSA
Analog ground
Main analog ground
W14
D21_N
sub-LVDS
Channel 21 output
W15
D21_P
sub-LVDS
Channel 21 output
Datasheet • PUBLIC
138 │ 10
Document Feedback
4
CMV50000
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to
the device. These are stress ratings only. Functional operation of the device at these or any other
conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect device reliability.
Figure 5:
Absolute Maximum Ratings of CMV50000
Symbol
Parameter
Min
Max
Unit
Comments
±100
mA
JEDEC JESD78D Nov
2011
Electrical Parameters
ISCR
Input Current (latch-up
immunity)
Electrostatic Discharge
ESDHBM
Electrostatic Discharge HBM
±2000
V
JEDEC JS-001-2014
ESDCDM
Electrostatic Discharge CDM
±250
V
JEDEC JS-002-2014
Temperature Ranges and Storage Conditions
TJ
Operating Junction Temperature
-30
70
°C
TSTRG
Storage Temperature Range
-30
70
°C
RHNC
Relative Humidity (noncondensing)
30
60
Datasheet • PUBLIC
Storage condition
138 │ 11
Document Feedback
5
CMV50000
All limits are guaranteed. The parameters with Min and Max values are guaranteed with production
tests or SQC (Statistical Quality Control) methods.
Figure 6:
Electrical Characteristics of CMV50000
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Power Supplies
VDD12
Logic Supply Voltage of digital core,
PLL
1.10
1.20
1.30
V
VDD12C
Logic Supply Voltage of ADC
1.10
1.20
1.30
V
VDD18
I/O Supply Voltage for sub-LVDS,
CMOS I/O’s
1.70
1.80
1.90
V
2.60
2.70
2.80
V
2.60
2.70
2.80
V
3.20
3.30
3.40
V
VDD27
Main Analog Supply Voltage;
Supply Voltage for negative regulators
VDDARRAY
Pixel Array Supply Voltage
VDD33
Internal Regulator Supply Voltage
IDD12
Supply Current
IDD12C
Supply Current
IDD18
Supply Current
IDD27
Supply Current
IDDARRAY
Supply Current
IDD33
Supply Current
Ptot
Total Power Consumption
Idle
350
Running
375
Idle
10
Running
410
Idle
130
Running
115
Idle
550
Running
550
Idle
130
Running
130 (1)
Idle
Running
Idle
2.5
Running
3.0
mA
mA
mA
mA
mA
mA
W
Digital I/O
VIH
High level input voltage
0.7 × VDD18
VDD18 +0.5
V
VIL
Low level input voltage
-0.5
0.3 × VDD18
V
VOH
High level output voltage
IOH=4mA
VDD18 -0.15
V
VOL
Low level output voltage
IOL=4mA
0.15
V
CI
Input load
10
pF
CO
Output load
pF
Ttran
Input transition time
0.1
5.0
ns
fCLK_IN
CLK_IN frequency
6
96
MHz
DCCLK_IN
CLK_IN duty cycle
40
60
Datasheet • PUBLIC
138 │ 12
Document Feedback
Symbol
Parameter
Conditions
fSPI_CLK
SPI input clock frequency
tsetup
CMV50000
Min
Typ
Max
Unit
10
MHz
SPI setup time
0.25 × TSPI_CLK
ns
thold
SPI hold time
ns
tREQ
REQ_FRAME/EXP pulse width
2 × TCLK_PIX
ns
Sub-LVDS Interface
VCM
Common mode voltage
0.8
0.9
1.0
V
VOD
Differential voltage swing
100
150
200
mV
240
Ohm
10
55
415
MHz
2
mA
15
(2)
RO
Output impedance
DR0
Impedance mismatch
DC
Clock duty cycle
45
f
Operating frequency
60
IOD
Drive current
1
∆IOD
IOD variation over Temp.
IDC
DC current consumption
3.7
mA
IAC
AC current consumption
7.2
µA/MHz
(1)
(2)
40
50
1.5
VDDARRAY draws high peak currents (>1A) during GLOB. Enough decoupling is needed to suppress these peaks.
Unused sub-LVDS channels must be terminated the same way as the used channels.
Datasheet • PUBLIC
138 │ 13
Document Feedback
CMV50000
Typical Operating Characteristics
6
6.1
Below are the typical electro-optical specifications of the CMV50000. These are typical values for the
whole operating temperature range.
Figure 7:
Electro-Optical Characteristics of CMV50000
Parameter
Value
Remark
Effective pixels
7920 × 6004
Pixel pitch
4.6 × 4.6 µm2
Optical format
35mm full frame
Pixel type
Global shutter with true CDS
Allows fixed pattern noise correction and
reset (kTC) noise canceling by true
correlated double sampling (true-CDS).
Shutter type
Pipelined global shutter
Exposure of next image during readout of
the previous image.
Full well charge
14500 e-
Normal mode
58000 eConversion gain
Responsivity
0.27 DN/e
Binning mode
Normal mode, unity gain
0.068 DN/ e-
Binning mode, unity gain
0.16 DN/photon
@ 510nm (with micro-lenses)
0.25 A/W
Temporal noise
Dynamic range
SNRMAX
Shutter efficiency
8.8 e-
Normal mode
22 e-
Binning mode
64 dB
Normal mode
68 dB
Binning mode
41.6 dB
Normal mode
47.6dB
Binning mode
1/18000
At 520nm, f/8.
0.24 e-/s
@ 20°C sensor temperature
66.2 e-/s
@ 60°C sensor temperature
1/PLS
DC
Dark Current doubles every 5.1°C
increase
DCNU
0.72 e-/s
14.2 e-/s
DC Non-Uniformity doubles every 10°C
increase
DSNU
24.5 e-
Dark Signal Non Uniformity (FPN)
6025
Bottom buffer rows
0 -> 21
Top buffer rows
6026 -> 6047
Datasheet • PUBLIC
138 │ 78
Document Feedback
CMV50000
Vertical ROI Settings
The sensor allows up to 10 vertical windows to be concatenated in one single frame readout.
Each of these windows is enabled by setting their bit in YWIN_ENA to ‘1’ (bit [0] = YWIN0, [1] =
YWIN1 …).
Each of these windows is configured with an YWINi register that defines the position, size and subsampling of the window. The 29 bits of each YWINi register span 4 physical SPI addresses. In the
table below, only the start address is given (the upper address being 35+4×j).
Figure 97:
Vertical Windows Registers
Register Name
Bank
Addr
Bits
Description
YWIN_ENA
[9:0]
One bit per window
0: Disable
1: Enable
YWIN_BLACK
[9:0]
One bit per window to control the ‘Electrical Black’ mode
0: Disable
1: Enable
YWINi.SIZE
32+4×i
[12:0]
Number of read out rows in window i
YWINi.START
32+4×i
[25:13]
Physical address of first row in window i
YWINi.SUBS
32+4×i
[28:26]
Row subsampling in window i
Ratio = 1/(2SUBS)
The START address of a window should comply with the values in Figure 96.
Only windows for which the respective bit in YWIN_ENA is set high are actually read out. This way
multiple relevant Y-window specifications can be stored in the register map at the same time, enabling
only the relevant ones.
All enabled windows are concatenated together (the first row of a new window is read immediately
after the last row of the previous). The number of rows actually read in one frame (= # of DVAL within
one FVAL) is the sum of the SIZE fields of all windows enabled by YWIN_ENA.
The figure below shows an example of using multiple windows.
Datasheet • PUBLIC
138 │ 79
Document Feedback
CMV50000
Figure 98 :
Vertical ROI Example (monochrome)
YWIN_ENA
0000001011
YWIN0
100
3
1
YWIN1
YWIN2
200
5
3
YWIN3
50
4
FVAL
DVAL
YADDR
100
101
102
50
58
66
74
Electrical Black Windows
With the YWIN_BLACK register, windows can be made 'electrical black' (setting a fixed voltage at the
read out path instead of the pixel voltage). If the respective bit of the YWIN_BLACK register is set high
(same mapping as YWIN_ENA), then all signal information in the window is suppressed. This results
in a black window containing only readout FPN information. This feature could be used for column
FPN correction.
Window Overlap
Several vertical windows may overlap, although this is only useful in subsampling mode. If the same
row is read multiple times within one frame, it will only contain valid data the first time (destructive read
out).
One possibility is to create an interleaved readout scheme by:
1.
Defining two vertical windows with identical size and SUBS set to 1
2.
Giving START of the second window an offset so it starts at a row skipped by the sub sampling
scheme of the first window
3.
Alternating the respective YWIN_ENA bits between every frame.
Figure 99 :
Interleaved Readout
Datasheet • PUBLIC
1
YWIN0
1
YWIN1
1
1080
Even frames
Odd frames
YWIN_ENA = 1
YWIN_ENA = 2
138 │ 80
Document Feedback
7.5.4
CMV50000
Vertical Subsampling
Figure 100:
Vertical Subsampling Registers
Register Name
Bank
Addr
Bits
Description
YWINi.SUBS
32+4×i
[28:26]
COLOR_MODE
[0]
0: Monochrome
1: Color
The sensor supports vertical subsampling (skipping rows), which can be set per window. The register
YWINi.SUBS defines the ratio of the accessed rows in window i as 1 out of every 2SUBS rows.
When COLOR_MODE register is set to 1, the rows are grouped per 2 to follow the Bayer pattern, as
illustrated in Figure 101. It is recommended to only use even window sizes in color mode to keep the
Bayer filter pattern intact. ROI0 in the example below demonstrates the effect of an odd window size.
Figure 101 :
Vertical ROI Example (color mode)
Read out
row 67
row 66
row 65
row 64
row 63
row 62
row 61
row 60
row 59
row 58
row 57
row 56
row 55
row 54
row 53
row 52
row 51
row 50
row 104
row 103
row 102
row 101
row 100
ROI 3
row read out
row skipped
ROI 0
YWIN_ENA
0000001001
1
YWIN0
100
3
1
YWIN1
YWIN2
200
5
3
YWIN3
50
6
Datasheet • PUBLIC
FVAL
DVAL
YADDR
100
101
104
50
51
58
59
66
67
138 │ 81
Document Feedback
7.5.5
CMV50000
Horizontal Subsampling
Figure 102:
Horizontal Subsampling Registers
Register Name
Bank
Addr
Bits
Description
XSUBS
[1:0]
Horizontal subsampling setting
Ratio = 1/(2XSUBS)
COLOR_MODE
[0]
0: Mono
1: Color
The sensor supports horizontal subsampling, reducing the amount of pixels per line to 1:2 XSUBS. This
horizontal subsampling is applied to the whole array and not per ROI like vertical subsampling.
Depending on COLOR_MODE, pixel grouping is done to preserve the Bayer pattern.
7.5.6
Subsampling Mode
Combining both horizontal and vertical subsampling will divide the resolution of the image by 2 in both
dimensions as illustrated in Figure 103.
2
4
Figure 103 :
XY-Subsampling for Color and Mono Sensors
4
2
In color mode, only 4 out of 4x4 neighboring pixels are read out. The output data is still Bayer
patterned.
In monochrome mode, only 1 out of 2x2 neighboring pixels is read out.
The amount of pixels per channel mentioned in Figure 111 scales accordingly when combining
horizontal subsampling with the readout over a reduced number of data channels.
Datasheet • PUBLIC
138 │ 82
Document Feedback
7.5.7
CMV50000
Binning Mode
Figure 104:
Binning Mode Registers
Register Name
Bank
Addr
Bits
Description
BIN_MODE
[0]
0: Binning disabled
1: Binning enabled
COLOR_MODE
[0]
0: Mono
1: Color
The sensor supports both color and mono-chrome binning modes. In this mode, the values of 4 pixels
will be summed, before the ADC. This will reduce the read out resolution with x4, but increases full
well charge, dynamic range and SNR. In color mode, the Bayer pattern is preserved.
In binning mode, the summed value of 4 pixels is readout on the bottom-left position of each binning
square. For every row N read at the output, two internal rows are accessed. As seen in Figure 105 in
square. This means only 1 out 2 columns will be read out.
N+3
N+3
N+2
N+3
N+3
N+2
N+2
N+2
N+1
N+1
N
N+1
N+1
2
4
Figure 105 :
Color and Monochrome Binning Modes
N
N
4
N
2
Setting YWINi.SUBS to 0 will output binned rows N, N+1, N+2 and N+3.
YWINi.SIZE refers to the number of physical rows in the array. The number of binned rows at the
output will be half of this number.
Binning mode cannot be combined with horizontal subsampling. For correct operation of the sensor,
XSUBS must be set to 0 when binning mode is enabled.
Binning mode may be combined with vertical subsampling.
E.g. setting YWINi.SUBS to 1 will readout binned rows N, N+1, N+4, N+5 … in color mode and binned
rows N, N+2, N+4 … in mono-chrome mode.
Datasheet • PUBLIC
138 │ 83
Document Feedback
CMV50000
In binning mode, the start of a pipelined exposure must occur during an internal even row access.
Depending on the control mode a distinction must be made on how to achieve this.
In full external mode, the edges of REQ_EXP must be timed after the edge of REQ_FRAME in one of
the discrete windows given by the equations below:
Equation 13:
𝑡𝑅𝐸𝑄_𝐸𝑋𝑃 − 𝑡𝑅𝐸𝑄_𝐹𝑅𝐴𝑀𝐸 > 𝑇𝑃𝐼𝑋 × ((2 × 𝑛 × 𝑅𝑂𝑊_𝐿𝐸𝑁𝐺𝑇𝐻) + 2)
𝑡𝑅𝐸𝑄_𝐸𝑋𝑃 − 𝑡𝑅𝐸𝑄_𝐹𝑅𝐴𝑀𝐸 < 𝑇𝑃𝐼𝑋 × ((2 × (𝑛 + 1) × 𝑅𝑂𝑊_𝐿𝐸𝑁𝐺𝑇𝐻) − 2)
For positive n and with TPIX = 1/fCLK_PIX
Information
In dual exposure mode, the equations must be satisfied for both edges of REQ_EXP.
In programmed external mode, the time between two sequential REQ_EXP pulses must be timed
according to the equations:
Equation 14:
𝑡𝑅𝐸𝑄_𝐸𝑋𝑃 − 𝑡𝑅𝐸𝑄_𝐸𝑋𝑃_𝑝𝑟𝑒𝑣 > 𝑇𝑃𝐼𝑋 × (𝑇𝐼𝑀𝐸_𝑈𝑁𝐼𝑇 × 𝐸𝑋𝑃_𝑇𝐼𝑀𝐸_𝑖 + (2 × 𝑛 × 𝑅𝑂𝑊_𝐿𝐸𝑁𝐺𝑇𝐻) + 2)
𝑡𝑅𝐸𝑄_𝐸𝑋𝑃 − 𝑡𝑅𝐸𝑄_𝐸𝑋𝑃_𝑝𝑟𝑒𝑣 < 𝑇𝑃𝐼𝑋 × (𝑇𝐼𝑀𝐸_𝑈𝑁𝐼𝑇 × 𝐸𝑋𝑃_𝑇𝐼𝑀𝐸_𝑖 + (2 × (𝑛 + 1) × 𝑅𝑂𝑊_𝐿𝐸𝑁𝐺𝑇𝐻) − 2)
For both EXP_TIME_L and EXP_TIME_S register settings (in dual exposure mode) and with
tREQ_EXP_prev = the time of the previous REQ_EXP.
The EXP_TIME_i register settings are the ones at tREQ_EXP_prev in case they are updated between
frames.
In Triggered internal and streaming modes, the EXP_TIME_i registers must be programmed to satisfy
the equations:
Equation 15:
2 × 𝑛 × 𝑅𝑂𝑊_𝐿𝐸𝑁𝐺𝑇𝐻 < 𝑇𝐼𝑀𝐸_𝑈𝑁𝐼𝑇 × (𝐹𝑅𝐴𝑀𝐸_𝑇𝐼𝑀𝐸 − 𝐸𝑋𝑃_𝑇𝐼𝑀𝐸_𝑖)
< 2 × (𝑛 + 1) × 𝑅𝑂𝑊_𝐿𝐸𝑁𝐺𝑇𝐻
Datasheet • PUBLIC
138 │ 84
Document Feedback
7.6
7.6.1
Main Output Format
CMV50000
Using the register OUTP_FORMAT one of the data readout formats introduced in section 7.3 can be
selected.
Figure 106:
Output Format Register
Reg. Name
Bank
Addr
Bits
OUTP_FORMAT
[1:0]
Description
0: Pixel-based
1: Packet-based.
A soft reset is required after changing OUTP_FORMAT. Refer to the flow chart in section 7.4.2.
7.6.2
Word Alignment
Depending on the selected output format, word alignment must be done in a different way.
Pixel-Based Word Alignment
Figure 107:
Training Word Register
Reg. Name
Bank
Addr
Bits
Description
TRAINING_WORD
[13:0]
See below. Default value is 85
Whenever a data channel is not sending valid data (*), a training word is being transmitted
continuously. The content of the training word can be set with the TRAINING_WORD register. As the
sensor operates in 12-bit mode, only the lowest 12 bits of the register are sent as training word.
On all DATAx_OUT channels, the last word cycle before DVAL, the training word is inverted. If the
overhead time between two DVAL cycles is only 1 word wide, only the inverted training word is sent.
(*) Valid data is:
DATAx_OUT: Valid pixel data (DVAL = '1')
OBL_OUT: Valid OB pixel data (LOBVAL = '1')
OBR_OUT: Valid OB pixel data (ROBVAL = '1')
The figure below shows illustrates this timing (drawn in the parallel domain).
Datasheet • PUBLIC
138 │ 85
Document Feedback
CMV50000
Figure 108 :
Training Pattern
DVAL
DATAx_OUT
TP
TP
TP
TP
P0
P1
Pn
TP
TP
TP
P0
P1
Pn
TP
When the sensor is not transmitting valid data, the training word can be used by the external controller
to do word alignment (in other words: finding the position of bit [0]). Detecting the inverted training
word will alert the presence of valid pixel data 1 pixel cycle in advance.
When the sensor is IDLE, all control word bits except the LSB (SYNC) are '0'. Detecting the SYNC bit
allows for easy word alignment at the receiver side. Since all channels are bit and word aligned by
default, finding the LSB of 1 channel means the LSB of all channels has been found.
Packet-Based Word Alignment
As detailed in section 7.3.3, word-alignment is done using the fixed SYNC code.
The HEADER field will alert the presence of valid pixel data in advance.
7.6.3
Packet Formatting
Figure 109:
Data Packet Formatting Registers
Reg. Name
Bank
Addr
Bits
Description
NOHDR_EMPTYPKT
[0]
See below
FEC_HEADER
[1]
See below
Depending on the requirements of the application, a trade-off can be made between data packet
overhead (i.e. data throughput) and robustness.
When register NOHDR_EMPTYPKT is set to 1, the empty packet type described in section 7.3.3, will
consist only of a SYNC code, without header. When register NOHDR_EMPTYPKT is set to 0, the
empty packet type will consist of SYNC+HEADER.
When register FEC_HEADER is set to 1, the HEADER field will be sent as 96 bit using the 1/3 FEC
described in section 7.6.3. This 1/3 FEC allows bit error corrections on the receiving side. When
register FEC_HEADER is set to 0, the HEADER field will be sent in the short form (32 bit) and not be
protected against bit-errors.
Datasheet • PUBLIC
138 │ 86
Document Feedback
CMV50000
The register DATA_PKT_CTRL has no effect in pixel-based readout mode.
7.6.4
Outputs
As illustrated in Figure 52 the sensor has 22 output channels to transfer valid image data. This means
that in the fastest configuration, the sensor can output 22 pixels at the same time. As the valid image
width is 7920 columns, a complete row is transferred in 370 word cycles when utilizing all outputs.
Reduced Number of Data Channels
In many applications, it is not mandatory to use all data channels (for example when reading a limited
horizontal ROI or when operating the sensor below its nominal frame rate). In these cases, it could be
interesting to use less data channels to save power consumption.
The number of DATAx_OUT channels used is programmable with the NR_OUTP register.
Figure 110:
Number of Outputs Registers
Reg. Name
Bank
Addr
Bits
Description
NR_OUTP
[4:0]
See above. By default all channels are used
NR_OUTP_SCHEME
[0]
0: The first N channels are used
1: Channels are distributed evenly
When NR_OUTP_SCHEME is set to 1, the N channels are distributed evenly, starting at
DATA0_OUT. The exact mapping details are given in the table below.
Figure 111:
Reduced Number of Output Settings (NR_OUTP_SCHEME=1)
NR_OUTP
Used DATAx_OUT Channels
Nr. of Pixels per Channel
Nr. of Padding Pixels
1
0,11
3960
0,8,16
2880
720
4
0,6,12,18
2160
720
5
0,5,10,15,20
1800
1080
6
0,4,8,12,16,20
1440
720
8
0,3,6,9,12,15,18,21
1080
720
11
0,2,4,6,8,10,12,14,16,18,20
720
All (0 to 21)
360
When NR_OUTP_SCHEME is set to 0, the first N channels starting at DATA0_OUT are used.
Datasheet • PUBLIC
138 │ 87
Document Feedback
CMV50000
For example, when setting NR_OUTP to 5, DATA0_OUT to DATA4_OUT channels are used.
DATA5_OUT to DATA21_OUT are disabled. All other values in table above are still applicable.
It is not allowed to set NR_OUTP to any value not listed in Figure 111 (i.e. 0, 7, 9 to 10 or 12 to 21.)
All unused DATAx_OUT channels are automatically disabled (powered down).
The last (or rightmost) channel of the used DATAx_OUT channels pads dummy pixels after the valid
pixels when needed. Every channel sends an equal amount of pixels.
Pixel Order
The selected ROI (or full image width) is divided over 1 or more output channels. On each output,
pixels are presented in-order.
The figure below shows the timing of the readout of a single row for NR_OUTP set to 4 (each box
represents the physical column address of the pixel). Here pixels 7920 to 8639 are dummy padding
pixels and must be discarded.
Figure 112 :
Multiplexed Sub-LVDS Timing Example
A similar example for packet-based readout format is given in Figure 113.
Datasheet • PUBLIC
138 │ 88
Document Feedback
CMV50000
Figure 113 :
Multiplexed Sub-LVDS Timing Example in Packet Mode
Pixel data packet 1
Pixel data packet 2
Pixel data packet 6
DATA0_OUT
SYNC
HEADER PIXELS 0 to 359
CRC
SYNC
SYNC
SYNC
Pixel data packet 7
HEADER PIXELS 360 to 719
CRC
SYNC
HEADER PIXELS 1800 to 2159
Pixel data packet 8
SYNC
HEADER PIXELS 2160 to 2519
CRC
SYNC
SYNC
SYNC
Pixel data packet 13
HEADER PIXELS 2520 to 2879
CRC
SYNC
HEADER PIXELS 3960 to 4319
Pixel data packet 14
SYNC
HEADER PIXELS 4320 to 4679
CRC
SYNC
SYNC
SYNC
Pixel data packet 19
HEADER PIXELS 4680 to 4999
CRC
SYNC
CRC
SYNC
SYNC
CRC
SYNC
SYNC
Pixel data packet 18
DATA2_OUT
SYNC
Pixel data packet 12
DATA1_OUT
CRC
SYNC
HEADER PIXELS 6120 to 6479
Pixel data packet 20
DATA3_OUT
SYNC
HEADER PIXELS 6480 to 6839
CRC
SYNC
SYNC
SYNC
HEADER PIXELS 6840 to 7159
CRC
SYNC
SYNC
SYNC
SYNC
SYNC
SYNC
SYNC
SYNC
Every used data output channel outputs 6 data packets per line, separated by a number of empty
packets.
DATA3_OUT transmits only 4 data packets per line, the last being #22 which contains pixels 7560 to
7919. After that, empty packets are sent on DATA3_OUT.
In packet-base mode, the word alignment between subsequent data packets might vary (depending
on subsampling …). In the example above, this may be the case if the data packet is not a multiple of
4 bytes.
This translates into the need to redo word alignment between two packets on the same channel when
reading out over a reduced number of data channels.
7.7
7.7.1
Optical Black Clamping
Figure 114:
Optical Black Registers
Reg. Name
Bank
Addr
Bits
Description
EOB_TARGET
[13:0]
Sets the target black level value in DN
EOB_BYPASS
1
42
[0]
0: OBC on (recommended)
1: OBC off
EOB_BYPASS_VALUE
Datasheet • PUBLIC
1
43-44
[13:0]
Sets the ideal black level at the ADC (when OBC off).
138 │ 89
Document Feedback
CMV50000
This section explains how to set and correct the black levels.
Black Level Mapping
The black level at a certain point in the pixel data path on the sensor is the analog level or digital word
that corresponds to the level of an ideal dark pixel (zero illumination). In practice, it is the average of
all real dark pixels (optically shielded) at that point in the data path.
The black level at the output of the ADC does not equal the desired black level in the output images
for several reasons including the ADC architecture, fixed pattern and temporal noise (row noise, frame
noise), dark current…
As illustrated in the figure below, the black level at the ADC output needs to be mapped on the target
black level at the sensor output.
Figure 115 :
Black Level Mapping
ADC_OUT
^15
2 -1
white
DATA_OUT
VALID
RANGE
OUTPUT
RANGE
black
row noise
frame noise
BLACK
LEVEL
target
The mapping is done using the equation:
Equation 16:
𝑃𝐼𝑋𝐷𝐴𝑇𝐴_𝑂𝑈𝑇 = 𝑐𝑙𝑖𝑝[𝑃𝐼𝑋𝐴𝐷𝐶_𝑂𝑈𝑇 − 𝐵𝐿𝐴𝐶𝐾_𝐿𝐸𝑉𝐸𝐿𝐴𝐷𝐶_𝑂𝑈𝑇 + 𝐵𝐿𝐴𝐶𝐾_𝐿𝐸𝑉𝐸𝐿𝐷𝐴𝑇𝐴_𝑂𝑈𝑇 ]
BLACK_LEVELDATA_OUT is the target black level at the output of the sensor. It is specified with the
register EOB_TARGET. The recommended minimal setting is 128 (lower settings may decrease the
quality of the resulting image), which means the level at the output for black pixels will be around
128DN.
BLACK_LEVELADC_OUT is the black level at the output of the ADC. Its value is set differently depending
on how the black level correction is done. This is detailed in the next two sections.
Datasheet • PUBLIC
138 │ 90
Document Feedback
CMV50000
On-Chip OBC
Setting EOB_BYPASS to 0 enables the automatic on-chip black level correction (clamping). In this
mode, BLACK_LEVELADC_OUT is calculated on-chip, based on OB pixels, for every row allowing to
correct for row and frame noise in the image.
This is the recommended mode of operation.
Off-Chip OBC
Setting EOB_BYPASS to 1 disables the automatic OBC. BLACK_LEVELADC_OUT is now specified with
register EOB_BYPASS_VALUE. This value is constant and cannot correct for row noise in the image.
Equation 17:
𝑃𝐼𝑋𝐷𝐴𝑇𝐴_𝑂𝑈𝑇 = 𝑐𝑙𝑖𝑝[𝑃𝐼𝑋𝐴𝐷𝐶_𝑂𝑈𝑇 − 𝐸𝑂𝐵_𝐵𝑌𝑃𝐴𝑆𝑆_𝑉𝐴𝐿𝑈𝐸 + 𝐸𝑂𝐵_𝑇𝐴𝑅𝐺𝐸𝑇]
Further external or off-chip OBC can be achieved by reading out the OB pixel data (refer to
section 7.8.5).
7.7.2
Analog and Digital Gain
Register GANA is used to set the analog gain. When changing the analog gain, the OB black level
also has to be fine-tuned to have optimal black level clamping.
Figure 116:
Analog Gain Registers
Reg. Name
Bank
Addr
Bits
Description
GANA
[7:0]
See settings in 7.4.2
EOB_OFFSET_FINE
1
38-39
[15:0]
Digital gain can be specified for the 4 color channels individually (even/odd columns, even/odd rows).
E.g. GDIG_RE_CO relates to Rows Even and Columns Odd.
The digital gain for each channel is defined by a similar equation:
Equation 18:
𝐷𝑖𝑔𝑖𝑡𝑎𝑙 𝑔𝑎𝑖𝑛 (𝑅𝑥_𝐶𝑦) = (𝐺𝐷𝐼𝐺_𝑅𝑥_𝐶𝑦 + 1)/16
Base (default) digital gain is set by uploading a value of 15 to GDIG_Rx_Cy. The maximum digital
gain is 16x with GDIG_Rx_Cy at 256. The lowest digital gain is 1/16x with GDIG_Rx_Cy at 0.
Datasheet • PUBLIC
138 │ 91
Document Feedback
CMV50000
Figure 117:
Digital Gain Registers
Reg. Name
Bank
Addr
Bits
Description
GDIG_RE_CE
[7:0]
Even Rows & Even Columns
See equation above
GDIG_RE_CO
[7:0]
Even Rows & Odd Columns
See equation above
GDIG_RO_CE
[7:0]
Odd Rows & Even Columns
See equation above
GDIG_RO_CO
[7:0]
Odd Rows & Odd Columns
See equation above
If possible, using analog gain is preferred to using digital gain because it will improve SNR.
Analog gain is applied in the data path before the ADC and digital gain is applied after the black level
correction. This means that changing the digital gain setting does not require any of the offset
correction settings to be updated.
7.7.3
Color versus Monochrome Mode
Figure 118:
Color Mode Register
Register Name
Bank
Addr
Bits
COLOR_MODE
[0]
Description
0: Mono
1: Color
As introduced in sections 7.5.6 and 7.5.7, sub sampling and binning modes behave differently for color
and monochrome sensors. Set COLOR_MODE 1 for color sensors and 0 for monochrome sensors.
7.8
Additional Features
7.8.1
Digital Test Output
Figure 119:
Digital Test Output Register
Reg. Name
Bank
Addr
Bits
Description
DMUX1_SEL
1
99
[4:0]
Sets pin TDIGO1
function
Datasheet • PUBLIC
138 │ 92
Document Feedback
CMV50000
A number of digital signals of the chip can be monitored in real-time during normal sensor operation
via the sensor output pin TDIGO1. This can be very helpful for testing and debugging the system
without having to rely on the sub-LVDS implementation of the control channel, so a test pad or
connection to the FPGA is recommended.
Selecting which signal to be monitored is done with DMUX1_SEL.
7.8.2
OTP Memory
OTP Registers
The anti-fuse memory cells are organized in 128 rows (addresses) of 16 bits each.
It contains the Device Serial Number, which is the unique serial number that matches with the one
printed on the package. This serial number is in ASCII, so every address contains two characters. The
Device Serial Number has two retry registers in case it had to be rewritten. So, the last retry register
which contains a value other than zero, contains the correct sensor serial number.
Next to the serial number, the memory has the Temperature (wafer test 1) register. It contains the
value of the TSENS1_OUTPUT SPI register during our wafer test with the device at 70°C.
Below you can find the positions of the OTP registers which can be read out.
Figure 120:
OTP Registers
OTP Register Name
Description
Addr
Length
Device serial nr
Unique serial number of device
2
8
Device serial nr (retry 1)
Retry 1
10
8
Device serial nr (retry 2)
Retry 2
18
8
TSENS1_OUTPUT value at 70°C
38
1
Read Access via the SPI Interface
The OTP addresses are read out via the SPI interface through a predefined protocol as indicated in
the table below.
Figure 121:
Read Access (read from address Ai)
Step
Description
Register Access
1
Init
OTP_CONTROL = "001”
wait 20µs
Datasheet • PUBLIC
138 │ 93
Document Feedback
CMV50000
Step
Description
Register Access
2
Set up address
OTP_A = Ai
3
Read
OTP_CONTROL = "101”
wait 5µs
OTP_CONTROL = "001”
wait 10µs
Read value from OTP_DOUT
4
Exit
OTP_CONTROL = “000”
The address Ai needs to be replaced by the desired OTP register. For multiple reads, steps 2 and 3
can be repeated consecutively for every address Ai. In the table below the addresses of the registers
used during the protocol are given.
Figure 122:
Registers Used during Read Access
7.8.3
Register Name
Bit Name
Bank
Addr
Pos
OTP_CONTROL
OTP_PDN
[0]
OTP_CONTROL
OTP_READBPROG
[1]
OTP_CONTROL
OTP_SELECTWLBL
[2]
OTP_A
[6:0]
OTP_DOUT
[15:0]
Temperature Sensor
Figure 123:
Temperature Sensor Registers
Reg. Name
Bank
Addr
Bits
Description
TSENS1_PDN
[0]
Power down not
TSENS1_RSTN
[1]
Reset not
TSENS1_DCORRECT
[7:2]
Offset value
TSENS1_OUTPUT
[9:0]
Read-only code
The sensor has a temperature sensor placed at the top side of the sensor. In the range of -40°C to
125°C, the temperature sensor has a maximum error of ±12°C without calibration. After a one-point
calibration at 25°C, the maximum error is ±5°C, after a two-point calibration, the maximum error
becomes ±3°C.
To disable the temperature sensor, both TSENS1_PDN and TSENS1_RSTN must be set to ‘0’.
Datasheet • PUBLIC
138 │ 94
Document Feedback
CMV50000
To enable the temperature sensor, both TSENS1_PDN and TSENS1_RSTN must be set to ‘1’ and a
settling time of 0.5ms must be respected before reading TSENS1_OUTPUT.
The bit [9] of TSENS1_OUTPUT is high when an overflow condition has occurred in the temperature
sensor. If this condition occurs, the temperature is either out of range, or a wrong offset was
programmed in the TSENS1_DCORRECT register.
No Calibration
In order to get the uncalibrated temperature of the die (±12°C), follow this procedure:
1.
Write value 131 to TSENS1_CONTROL
2.
Wait 0.5ms (settling time)
3.
Read TSENS1_OUTPUT
4.
Calculate the measured die temperature according to the equation:
Tm = (TSENS1_OUTPUT[8:0] / 2) – 100
1-Point Calibration
The procedure below describes how to calculate and set the calibration value for the temperature
sensor to output the correct sensor temperature (±5°C) using one measurement.
1.
Let the sensor reach a known temperature (T j) around 25°C and let it settle so that the die
temperature (which equals the package temperature) is stable.
2.
3.
4.
Read TSENS1_OUTPUT
5.
Calculate the uncalibrated die temperature according to the equation
Tu = (TSENS1_OUTPUT[8:0] / 2) – 100
6.
Calculate the calibration error: Te = Tj - Tu
7.
Update TSENS1_DCORRECT to 32 + (2 × Te)
From now on, to measure the die temperature within ±5°C accuracy in the range from -40°C to 125°C:
1.
Read TSENS1_OUTPUT
2.
Calculate the measured die temperatures according to the equation
An example:
We let the sensor settle unpowered to a known ambient temperature of 28°C. We power up the
sensor and immediately read out TSENS1_OUTPUT[8:0]. This way the junction temperature
will be very close to the ambient temperature. TSENS1_OUTPUT[8:0] contains 260.
So now Tu = (260/2) – 100 = 30 and Te = 28 – 30 = -2.
Datasheet • PUBLIC
138 │ 95
Document Feedback
CMV50000
Upload TSENS1_DCORRECT with the value 32 + (2 × Te) = 28.
Reading out TSENS1_OUTPUT[8:0] now gives a value of 256, which corresponds to the
correct temperature Tm = (256/2) – 100 = 28.
When during operation, you read out TSENS1_OUTPUT[8:0] as, for example, 338, you know
that the junction temperature is equal to Tj = Tm = (338/2) – 100 = 69°C (±5°C)
It is possible to take the TSENS1_OUTPUT value obtained during the wafer test at Tj = 70°C
described in section 7.8.2. With those two values the procedure above can be executed immediately
instead of measuring the temperature first.
2-Point Calibration
A 2-point calibration will correct for the offset as well as the slope over temperature.
sensor to output the correct sensor temperature (±3°C) using two measurements.
1.
Let the sensor reach a known temperature (T j1) and let it settle so that the die temperature
2.
Write value 131 to TSENS1_CONTROL, which will
3.
4.
Read TSENS1_OUTPUT[8:0] and save it as B1.
5.
Change the temperature to Tj2 (preferably more than 30°C difference with T j1) and let it settle.
6.
Read out TSENS1_OUTPUT[8:0] and save it as B2.
7.
Calculate the slope as: M = (Tj2 – Tj1)/(B2-B1). For an ideal and perfect temperature sensor the
slope will be 0.5.
8.
Calculate the offset as: C = Tj1 - M*B1 = Tj2 – M×B2
9.
Store the values M and C, which define a straight line.
From now on, to measure the die temperature within ±3oC accuracy in the range from -40°C to 125°C:
1.
Read TSENS1_OUTPUT
2.
Tm = M ×TSENS1_OUTPUT[8:0] + C
Information
For 2-point calibration TSENS1_DCORRECT must be left at its default value (32).
Datasheet • PUBLIC
138 │ 96
Document Feedback
7.8.4
CMV50000
Version ID
Figure 124:
Version ID Register
Reg. Name
Bank
Addr
Bits
Description
VERSION_ID
[7:0]
Read only
The read-only register VERSION_ID contains the revision number of the sensor.
7.8.5
Enable Optical Black Outputs
By default, the OBx_OUT channels are disabled.
To enable (or disabling again) the OB channels, use the following SPI sequence:
Figure 125:
Enable OB Outputs Sequence
Upload #
Bank
Address
Write Value
1
1
107
1
2
1
106
16
3
1
106
24
4
1
106
16
5
1
106
16
6
1
106
16
7
1
106
16
8
1
106
16
9
1
106
16
10
1
106
16
11
1
106
16
12
1
106
16
13
1
106
16
14
1
106
16
15
1
106
16
16
1
106
16
17
1
106
16
18
1
106
16
19
1
106
16
Datasheet • PUBLIC
138 │ 97
Document Feedback
Upload #
Bank
Address
Write Value
106
16
21
1
106
16
22
1
106
16
23
1
106
16
24
1
106
16
25
1
106
16
26
1
106
16
27
1
106
24
28
1
106
16
29
1
107
CMV50000
The OB data is read out 1 row before the image data row it refers to. See also section 7.3.2.
OB channel enabling/disabling can only be done when the PLL’s are locked, enabled and reset is
released.
7.8.6
Test Images
Right before the sub-LVDS output drivers, the data stream can be replaced with a number of test
patterns. Selection of test mode is made with the TEST_LVDS register as indicated in the table below.
Figure 126:
Test Images Registers
Reg. Name
Bank
Addr
Bits
Description
TEST_LVDS
[2:0]
See table below
TRAINING_WORD
[13:0]
Choose a value
Figure 127:
Sub-LVDS Test Modes
TEST_LVDS
DATAx_OUT
OBx_OUT
CTR_OUT
CLK_OUT
Normal
Normal
Normal
Normal
1
Force training word
continuously
Force training word
continuously
Force training word
continuously
Normal
2
Test image: gradient
Drive constant 0
Normal
Normal
3
Test image: LFSR
Drive constant 0
Normal
Normal
Datasheet • PUBLIC
138 │ 98
Document Feedback
CMV50000
In test mode 1, the data and OB output channels are forced to output register TRAINING_WORD and
the control channel outputs its own training word.
In test modes 2 and 3, a fixed test image is created. The CLK_OUT and CTR_OUT channels drive
their normal values, so only the actual pixel data is replaced. This is useful to debug the camera
system before grabbing real images.
In sub-LVDS test mode 2, the data of pixel N is replaced by the value:
Equation 19:
𝐷𝑇𝐸𝑆𝑇 = 𝑁𝐶𝑂𝐿 + 𝑁𝑅𝑂𝑊 + 𝑁𝐾𝐸𝑅𝑁𝐸𝐿 + 1
With:
NCOL is the running number of pixel N in the DVAL pulse (0 for first valid pixel on each output)
NROW is the running number of the DVAL pulse within FVAL (0 for first valid row in each FVAL)
NKERNEL is the number of the channel from which pixel N originates
The result is a 2D gradient (per channel), with a starting offset depending on the kernel number. The
figure below shows an example using NR_OUTP = 4 (NKERNEL is resp. 0, 6, 12, 18).
Figure 128 :
Gradient Test Image Pixel Data
FVAL
DVAL
DATA0_OUT
TP
1
(0 + 0 + 0 + 1)
2
(1 + 0 + 0 + 1)
2160
(2159 + 0 + 0 + 1)
TP
2
(0 + 1 + 0 + 1)
DATA1_OUT
TP
7
(0 + 0 + 6 +1)
8
(1 + 0 + 6 +1)
2166
(2159 + 0 + 6 +1)
TP
8
(0 + 1 + 6 + 1)
DATA2_OUT
TP
13
(0 + 0 + 12 + 1)
14
(1 + 0 + 12 + 1)
2172
(2159 + 0 +12 +1)
TP
14
(0 + 1 + 12 +1)
DATA3_OUT
TP
19
(0 + 0 + 18 + 1)
2178
(2159 + 0 +18 +1)
TP
Datasheet • PUBLIC
138 │ 99
Document Feedback
CMV50000
Figure 129 :
Gradient Test Image Example
In sub-LVDS test mode 3, the actual data of every pixel is replaced by the output of a pseudo-random
generator. The value of the first valid pixel of a frame is 4095. All outputs drive the same output value
(unlike test mode 2, where the NKERNEL generates an offset between outputs).
Datasheet • PUBLIC
138 │ 100
Document Feedback
CMV50000
Figure 130 :
LSFR Test Image Example
Datasheet • PUBLIC
138 │ 101
Document Feedback
8
8.1
Register Overview
CMV50000
Figure 131:
Register Overview Bank Select
Addr
Name
PARAM_
HOLD
DISABLE_
FRAMESYNC
BANK_SEL
BANK_SEL [1:0]
Figure 132:
Register Overview Bank 0
Addr
1
2
Name
PARAM_HOLD
DISABLE_
FRAMESYNC
3
CMD_REGS
HALT_
NBLOCK
HALT_
BLOCK
REQ_
FRAME
REQ_
EXP
RST_
SOFT_N
4
COLOR_MODE
COLOR_
MODE
5
6
OUTP_FORMAT
7
DATA_PKT_
CTRL
NOHDR_
EMPTYPKT
FEC_
HEADER
8
9
CTRL_MODE
10
TIME_UNIT
11
TIME_UNIT
12
NROF_FRAMES
13
FRAME_TIME
FRAME_TIME [7:0]
14
FRAME_TIME
FRAME_TIME [15:8]
15
DUAL_
EXPOSURE
16
EXP_TIME_L
EXP_TIME_L [7:0]
17
EXP_TIME_L
EXP_TIME_L [15:8]
18
EXP_TIME_S
EXP_TIME_S [7:0]
19
EXP_TIME_S
EXP_TIME_S [15:8]
22
ROW_LENGTH
Datasheet • PUBLIC
OUTP_FORMAT [1:0]
CTRL_MODE [2:0]
TIME_UNIT [7:0]
TIME_UNIT [13:8]
NROF_FRAMES [7:0]
DUAL_
EXPOSURE
ROW_LENGTH [7:0]
138 │ 102
Document Feedback
Addr
Name
CMV50000
23
ROW_LENGTH
24
XSUBS
25
BIN_MODE
26
NR_OUTP
27
NR_OUTP_
SCHEME
28
YWIN_ENA
29
YWIN_ENA
30
YWIN_BLACK
31
YWIN_BLACK
32
YWIN0
33
YWIN0
34
YWIN0
35
YWIN0
36
YWIN1
37
YWIN1
38
YWIN1
START [10:3]
39
YWIN1
SIZE [7:0]
40
YWIN2
41
YWIN2
42
YWIN2
SUBS [2:0]
START [12:11]
43
YWIN2
SUBS [2:0]
START [12:11]
44
YWIN3
45
YWIN3
46
YWIN3
47
YWIN3
48
YWIN4
49
YWIN4
50
YWIN4
51
YWIN4
52
YWIN5
53
YWIN5
54
YWIN5
55
YWIN5
56
YWIN6
57
YWIN6
58
YWIN6
59
YWIN6
60
YWIN7
61
YWIN7
62
YWIN7
Datasheet • PUBLIC
ROW_LENGTH [13:8]
XSUBS [1:0]
BIN_MODE
NR_OUTP_
SCHEME
NR_OUTP [4:0]
YWIN_ENA [7:0]
YWIN_ENA [9:8]
YWIN_BLACK [9:8]
YWIN_BLACK [7:0]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
SUBS [2:0]
START [12:11]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [2:0]
SIZE [12:8]
START [10:3]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
SUBS [2:0]
START [12:11]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
SUBS [2:0]
START [12:11]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
SUBS [2:0]
START [12:11]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
SUBS [2:0]
START [12:11]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
138 │ 103
Document Feedback
Addr
Name
CMV50000
63
YWIN7
64
YWIN8
65
YWIN8
66
YWIN8
67
YWIN8
68
YWIN9
69
YWIN9
70
YWIN9
71
YWIN9
72
GDIG_RE_CE
GDIG_RE_CE [7:0]
73
GDIG_RE_CO
GDIG_RE_CO [7:0]
74
GDIG_RO_CE
GDIG_RO_CE [7:0]
75
GDIG_RO_CO
GDIG_RO_CO [7:0]
76
EOB_TARGET
EOB_TARGET [7:0]
77
EOB_TARGET
78
GANA
79
TRAINING_
WORD
80
TRAINING_
WORD
81
TEST_LVDS
82
- 100
101
OTP_DOUT
OTP_DOUT [7:0]
102
OTP_DOUT
OTP_DOUT [15:8]
103
TSENS1_
CONTROL
104
TSENS1_
OUTPUT
105
TSENS1_
OUTPUT
106
PLL1_ENABLE
107
PLL1_PRE_DIV
PLL1_PRE_DIV [1:0]
108
PLL1_NDIV
109
PLL1_
CLKOUT_SEL
PLL1_CLKOUT_SEL [1:0]
110
PLL2_ENABLE
PLL2_
ENABLE
111
112
PLL2_NDIV
113
114
PLL_CLKDIV_
RSTN
PLL_
CLKDIV_
RSTN
115
PLL_LOCK
PLL2_LOCK
PLL1_LOCK
Datasheet • PUBLIC
SUBS [2:0]
START [12:11]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
SUBS [2:0]
START [12:11]
SIZE [7:0]
START [2:0]
SIZE [12:8]
START [10:3]
SUBS [2:0]
START [12:11]
EOB_TARGET [13:8]
GANA [7:0]
TRAINING_WORD [7:0]
TRAINING_WORD [13:8]
TEST_LVDS [2:0]
DCORRECT [5:0]
RSTN
PDN
TSENS1_OUTPUT [7:0]
TSENS1_OUTPUT [9:8]
PLL1_
ENABLE
PLL1_NDIV [7:0]
PLL2_NDIV [7:0]
138 │ 104
Document Feedback
Addr
Name
CMV50000
116
VERSION_ID
117
NO_
SHUTTER_LAG
NO_
SHUTTER_
LAG
118
DUAL_EXP_
GROUPING
DUAL_EXP_
GROUPING
VERSION_ID [7:0]
Figure 133:
Register Overview Bank 1
Addr
Name
1-4
5
GRAN_GLOB
6
CLKGEN_CFG
7 - 98
99
GRAN_GLOB [7:0]
TDIG
[2:0]
[2:0]
100
- 109
110
TG_LENGTH
111
TG_LENGTH
112
- 113
114
SHUTTER_LAG
115
SHUTTER_LAG
116
- 119
CLKGEN_PHASE [1:0]
DMUX1_SEL [4:0]
TG_LENGTH [7:0]
TG_LENGTH [13:8]
SHUTTER_LAG [7:0]
SHUTTER_LAG [13:8]
Figure 134:
Register Overview Bank 2
Addr
1
- 127
Name
Figure 135:
Register Overview Bank 3
Addr
Name
1
- 48
49
PLL1_DISABLE
_CLKOUT
PLL1_
DISABLE_
CLKOUT
Datasheet • PUBLIC
138 │ 105
Document Feedback
Addr
50
- 57
Name
CMV50000
8.2
8.2.1
BANK_SEL Register (Address 0)
Figure 136:
BANK_SEL Register
Addr: 0
Bit
[1:0]
8.2.2
BANK_SEL
Bit Name
BANK_SEL
Default
Access
Bit Description
0: Bank 0
1: Bank 1
2: Bank 2
3: Bank 3
PARAM_HOLD Register (Bank 0, Address 1)
Figure 137:
PARAM_HOLD Register
Bank: 0 Addr: 1
PARAM_HOLD
Bit
Bit Name
Default
Access
Bit Description
PARAM_HOLD
0: Frame sync
1: During SPI upload
Datasheet • PUBLIC
138 │ 106
Document Feedback
8.2.3
CMV50000
DISABLE_FRAMESYNC Register (Bank 0, Address 2)
Figure 138:
8.2.4
Bank: 0 Addr: 2
DISABLE_FRAMESYNC
Bit
Bit Name
Default
Access
Bit Description
[0]
DISABLE_FRAMESYNC
0: Enable frame sync
1: Disable frame sync
CMD_REGS Register (Bank 0, Address 3)
Figure 139:
CMD_REGS Register
Bank: 0 Addr: 3
CMD_REGS
Bit
Bit Name
Default
Access
Bit Description
[0]
RST_SOFT_N
0: Assert soft reset
1: Release soft reset
[1]
REQ_EXP
0: 1: Sensor in EXPOSURE
state
[2]
REQ_FRAME
0: 1: Sensor in GLOB state
[3]
HALT_BLOCK
0: 1: Finish active READOUT
state and go to IDLE state
[4]
HALT_NBLOCK
0: 1: Immediately stop sensor
Datasheet • PUBLIC
138 │ 107
Document Feedback
8.2.5
CMV50000
COLOR_MODE Register (Bank 0, Address 4)
Figure 140:
COLOR_MODE Register
8.2.6
Bank: 0 Addr: 4
COLOR_MODE
Bit
Bit Name
Default
Access
Bit Description
[0]
COLOR_MODE
DC
0: Monochrome mode
1: Color mode
OUTP_FORMAT Register (Bank 0, Address 6)
Figure 141:
8.2.7
Bank: 0 Addr: 6
OUTP_FORMAT
Bit
Bit Name
Default
Access
Bit Description
[1:0]
OUTP_FORMAT
RST
0: Pixel based format
1: Packet based format
DATA_PKT_CTRL Register (Bank 0, Address 7)
Figure 142:
Bank: 0 Addr: 7
DATA_PKT_CTRL
Bit
Default
Bit Name
Access
Bit Description
[0]
NOHDR_EMPTYPKT
1
DC
0: SYNC + HEADER in
empty packet.
1: Only SYNC in empty
packet
[1]
FEC_HEADER
1
DC
0: 32b HEADER
1: 96b HEADER with 1/3
FEC
Datasheet • PUBLIC
138 │ 108
Document Feedback
8.2.8
CMV50000
CTRL_MODE Register (Bank 0, Address 9)
Figure 143:
CTRL_MODE Register
Bank: 0 Addr: 9
CTRL_MODE
Bit
Default
[2:0]
8.2.9
Bit Name
CTRL_MODE
1
Access
Bit Description
DC
0: Full External (FE)
1: Programmed External
(PE)
2: Triggered Internal (TI)
3: Streaming (S)
TIME_UNIT Register (Bank 0, Address 10-11)
Figure 144:
TIME_UNIT Register
8.2.10
Bank: 0 Addr: 10-11
TIME_UNIT
Bit
Bit Name
Default
Access
Bit Description
[13:0]
TIME_UNIT
69
FRAME
Sets unit for frame and
exposure time
NROF_FRAMES Register (Bank 0, Address 12)
Figure 145:
Bank: 0 Addr: 12
NROF_FRAMES
Bit
Bit Name
Default
Access
Bit Description
[7:0]
NROF_FRAMES
1
Sets sequence length for TI
control mode
Datasheet • PUBLIC
138 │ 109
Document Feedback
8.2.11
CMV50000
FRAME_TIME Register (Bank 0, Address 13-14)
Figure 146:
FRAME_TIME Register
8.2.12
Bank: 0 Addr: 13-14
FRAME_TIME
Bit
Bit Name
Default
Access
Bit Description
[15:0]
FRAME_TIME
33000
DC
Sets the frame time in time
units
DUAL_EXPOSURE Register (Bank 0, Address 15)
Figure 147:
Bank: 0 Addr: 15
DUAL_EXPOSURE
Bit
Default
[0]
8.2.13
Bit Name
DUAL_EXPOSURE
Access
Bit Description
DC
0: Disable dual exposure
HDR
1: Enable dual exposure
HDR
EXP_TIME_L Register (Bank 0, Address 16-17)
Figure 148:
EXP_TIME_L Register
Bank: 0 Addr: 16-17
EXP_TIME_L
Bit
Bit Name
Default
Access
Bit Description
[15:0]
EXP_TIME_L
10000
FRAME
Sets the exposure time of
pixels in group L in time units
Datasheet • PUBLIC
138 │ 110
Document Feedback
8.2.14
CMV50000
EXP_TIME_S Register (Bank 0, Address 18-19)
Figure 149:
EXP_TIME_S Register
8.2.15
Bank: 0 Addr: 18-19
EXP_TIME_S
Bit
Bit Name
Default
Access
Bit Description
[15:0]
EXP_TIME_S
FRAME
pixels in group S in time units
ROW_LENGTH Register (Bank 0, Address 22-23)
Figure 150:
ROW_LENGTH Register
8.2.16
Bank: 0 Addr: 16-17
ROW_LENGTH
Bit
Bit Name
Default
Access
Bit Description
[13:0]
ROW_LENGTH
380
SYNC
Sets the row time
XSUBS Register (Bank 0, Address 24)
Figure 151:
XSUBS Register
Bank: 0 Addr: 24
XSUBS
Bit
Bit Name
Default
Access
Bit Description
[1:0]
XSUBS
SYNC
Set horizontal subsampling
ratio to 1/(2XSUBS)
Datasheet • PUBLIC
138 │ 111
Document Feedback
8.2.17
CMV50000
BIN_MODE Register (Bank 0, Address 25)
Figure 152:
BIN_MODE Register
8.2.18
Bank: 0 Addr: 25
BIN_MODE
Bit
Bit Name
Default
Access
Bit Description
[0]
BIN_MODE
SYNC
0: Disable binning
1: Enable binning
NR_OUTP Register (Bank 0, Address 26)
Figure 153:
NR_OUTP Register
8.2.19
Bank: 0 Addr: 26
NR_OUTP
Bit
Bit Name
Default
Access
Bit Description
[4:0]
NR_OUTP
22
DC
Sets the number of data
outputs used to 1, 2, 3, 4, 5,
6, 8, 11 or 22.
NR_OUTP_SCHEME Register (Bank 0, Address 27)
Figure 154:
Bank: 0 Addr: 27
NR_OUTP_SCHEME
Bit
Default
[0]
Bit Name
NR_OUTP_SCHEME
Datasheet • PUBLIC
Access
Bit Description
DC
0: Use the first NR_OUTP
data outputs
1: Used channels are
distributed evenly
138 │ 112
Document Feedback
8.2.20
CMV50000
YWIN_ENA Register (Bank 0, Address 28-29)
Figure 155:
YWIN_ENA Register
Bank: 0 Addr: 28-29
YWIN_ENA
Bit
Default
[9:0]
8.2.21
Bit Name
YWIN_ENA
1
Access
Bit Description
SYNC
Enables/disables one
window per bit
0: Disable window N
1: Enable window N
YWIN_BLACK Register (Bank 0, Address 30-31)
Figure 156:
YWIN_BLACK Register
Bank: 0 Addr: 30-31
YWIN_BLACK
Bit
Default
[9:0]
8.2.22
Bit Name
YWIN_BLACK
Access
Bit Description
SYNC
Enables/disables Electrical
Black for one window per bit
0: Disable EB of window N
1: Enable EB of window N
YWIN0 Register (Bank 0, Address 32-35)
Figure 157:
YWIN0 Register
Bank: 0 Addr: 32-35
YWIN0
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
6004
SYNC
Number of rows in this
window
[25:13]
START
22
SYNC
Physical start address of the
first row of this window
[28:26]
SUBS
SYNC
Set row subsampling in this
window with ratio 1/(2SUBS)
Datasheet • PUBLIC
138 │ 113
Document Feedback
8.2.23
CMV50000
YWIN1 Register (Bank 0, Address 36-39)
Figure 158:
YWIN1 Register
8.2.24
Bank: 0 Addr: 36-39
YWIN1
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
[28:26]
SUBS
SYNC
YWIN2 Register (Bank 0, Address 40-43)
Figure 159:
YWIN2 Register
8.2.25
Bank: 0 Addr: 40-43
YWIN2
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
[28:26]
SUBS
SYNC
YWIN3 Register (Bank 0, Address 44-47)
Figure 160:
YWIN3 Register
Bank: 0 Addr: 44-47
YWIN3
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
Datasheet • PUBLIC
138 │ 114
Document Feedback
8.2.26
CMV50000
Bank: 0 Addr: 44-47
YWIN3
Bit
Bit Name
Default
Access
Bit Description
[28:26]
SUBS
SYNC
YWIN4 Register (Bank 0, Address 48-51)
Figure 161:
YWIN4 Register
8.2.27
Bank: 0 Addr: 48-51
YWIN4
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
[28:26]
SUBS
SYNC
YWIN5 Register (Bank 0, Address 52-55)
Figure 162:
YWIN5 Register
Bank: 0 Addr: 52-55
YWIN5
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
[28:26]
SUBS
SYNC
Datasheet • PUBLIC
138 │ 115
Document Feedback
8.2.28
CMV50000
YWIN6 Register (Bank 0, Address 56-59)
Figure 163:
YWIN6 Register
8.2.29
Bank: 0 Addr: 56-59
YWIN6
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
[28:26]
SUBS
SYNC
YWIN7 Register (Bank 0, Address 60-63)
Figure 164:
YWIN7 Register
8.2.30
Bank: 0 Addr: 60-63
YWIN7
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
[28:26]
SUBS
SYNC
YWIN8 Register (Bank 0, Address 64-67)
Figure 165:
YWIN8 Register
Bank: 0 Addr: 64-67
YWIN8
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
Datasheet • PUBLIC
138 │ 116
Document Feedback
8.2.31
CMV50000
Bank: 0 Addr: 64-67
YWIN8
Bit
Bit Name
Default
Access
Bit Description
[28:26]
SUBS
SYNC
YWIN9 Register (Bank 0, Address 68-71)
Figure 166:
YWIN9 Register
8.2.32
Bank: 0 Addr: 68-71
YWIN9
Bit
Bit Name
Default
Access
Bit Description
[12:0]
SIZE
SYNC
window
[25:13]
START
SYNC
[28:26]
SUBS
SYNC
GDIG_RE_CE Register (Bank 0, Address 72)
Figure 167:
GDIG_RE_CE Register
Bank: 0 Addr: 72
GDIG_RE_CE
Bit
Bit Name
Default
Access
Bit Description
[7:0]
GDIG_RE_CE
15
SYNC
Sets the digital gain for the
pixels in the even rows and
even columns
Datasheet • PUBLIC
138 │ 117
Document Feedback
8.2.33
CMV50000
GDIG_RE_CO Register (Bank 0, Address 73)
Figure 168:
GDIG_RE_CO Register
8.2.34
Bank: 0 Addr: 73
GDIG_RE_CO
Bit
Bit Name
Default
Access
Bit Description
[7:0]
GDIG_RE_CO
15
SYNC
odd columns
GDIG_RO_CE Register (Bank 0, Address 74)
Figure 169:
GDIG_RO_CE Register
8.2.35
Bank: 0 Addr: 74
GDIG_RO_CE
Bit
Bit Name
Default
Access
Bit Description
[7:0]
GDIG_RO_CE
15
SYNC
pixels in the odd rows and
even columns
GDIG_RO_CO Register (Bank 0, Address 75)
Figure 170:
GDIG_RO_CO Register
Bank: 0 Addr: 75
GDIG_RO_CO
Bit
Bit Name
Default
Access
Bit Description
[7:0]
GDIG_RO_CO
15
SYNC
odd columns
Datasheet • PUBLIC
138 │ 118
Document Feedback
8.2.36
CMV50000
EOB_TARGET Register (Bank 0, Address 76-77)
Figure 171:
EOB_TARGET Register
8.2.37
Bank: 0 Addr: 76-77
EOB_TARGET
Bit
Bit Name
Default
Access
Bit Description
[13:0]
EOB_TARGET
32
SYNC
value in DN
128: 128DN
Access
Bit Description
SYNC
Sets the analog gain.
Non-binning / binning mode:
255 / 223: x1
243 / 211: x2
241 / 209: x4
GANA Register (Bank 0, Address 78)
Figure 172:
GANA Register
Bank: 0 Addr: 78
GANA
Bit
Default
[7:0]
8.2.38
Bit Name
GANA
TRAINING_WORD Register (Bank 0, Address 79-80)
Figure 173:
Bank: 0 Addr: 79-80
TRAINING_WORD
Bit
Bit Name
Default
Access
Bit Description
[13:0]
TRAINING_WORD
85
The training word on the data
outputs
Datasheet • PUBLIC
138 │ 119
Document Feedback
8.2.39
CMV50000
TEST_LVDS Register (Bank 0, Address 81)
Figure 174:
TEST_LVDS Register
Bank: 0 Addr: 81
TEST_LVDS
Bit
Default
[2:0]
8.2.40
Bit Name
TEST_LVDS
Access
Bit Description
Sets the output test mode.
0: Normal data output
1: Continuous training word
2: Gradient test image
3: LFSR test image
OTP_CONTROL Register (Bank 0, Address 97)
Figure 175:
8.2.41
Bank: 0 Addr: 97
OTP_CONTROL
Bit
Bit Name
Default
Access
Bit Description
[3:0]
OTP_CONTROL
OTP control input
OTP_A Register (Bank 0, Address 98)
Figure 176:
OTP_A Register
Bank: 0 Addr: 98
OTP_A
Bit
Bit Name
Default
Access
Bit Description
[6:0]
OTP_A
OTP address input
Datasheet • PUBLIC
138 │ 120
Document Feedback
8.2.42
CMV50000
OTP_DOUT Register (Bank 0, Address 101-102)
Figure 177:
OTP_DOUT Register
8.2.43
Bank: 0 Addr: 101-102
OTP_DOUT
Bit
Bit Name
Default
Access
Bit Description
[15:0]
OTP_DOUT
RO
OTP data output
TSENS1_CONTROL Register (Bank 0, Address 103)
Figure 178:
Bank: 0 Addr: 103
TSENS1_CONTROL
Bit
Default
[0]
8.2.44
Bit Name
PDN
Access
Bit Description
Temperature sensor power
state:
0: Down
1: Up
[1]
RSTN
Temperature sensor reset
state:
0: Assert reset
1: Release reset
[7:2]
DCORRECT
32
Temperature sensor
correction value
TSENS1_OUTPUT Register (Bank 0, Address 104-105)
Figure 179:
Bank: 0 Addr: 104-105
TSENS1_OUTPUT
Bit
Bit Name
Default
Access
Bit Description
[9:0]
TSENS1_OUTPUT
RO
Temperature sensor output
Datasheet • PUBLIC
138 │ 121
Document Feedback
8.2.45
CMV50000
PLL1_ENABLE Register (Bank 0, Address 106)
Figure 180:
8.2.46
Bank: 0 Addr: 106
PLL1_ENABLE
Bit
Bit Name
Default
Access
Bit Description
[0]
PLL1_ENABLE
RST
0: Disable PLL1
1: Enable PLL1
PLL1_PRE_DIV Register (Bank 0, Address 107)
Figure 181:
Bank: 0 Addr: 107
PLL1_PRE_DIV
Bit
Default
[1:0]
8.2.47
Bit Name
PLL1_PRE_DIV
Access
Bit Description
RST
Set by CLK_IN frequency:
0: 6MHz – 12MHz
1: 12MHz – 24MHz
2: 24MHz – 48MHz
3: 48MHz – 96MHz
PLL1_NDIV Register (Bank 0, Address 108)
Figure 182:
PLL1_NDIV Register
Bank: 0 Addr: 108
PLL1_NDIV
Bit
Bit Name
Default
Access
Bit Description
[7:0]
PLL1_NDIV
RST
PLL1 divider parameter
Datasheet • PUBLIC
138 │ 122
Document Feedback
8.2.48
CMV50000
PLL1_CLKOUT_SEL Register (Bank 0, Address 109)
Figure 183:
Bank: 0 Addr: 109
PLL1_CLKOUT_SEL
Bit
Default
[1:0]
8.2.49
Bit Name
PLL1_CLKOUT_SEL
Access
Bit Description
RST
Set by target output data
rate:
0: 460 – 830Mbit/s
1: 230 – 460Mbit/s
2: 120 – 230Mbit/s
PLL2_ENABLE Register (Bank 0, Address 110)
Figure 184:
8.2.50
Bank: 0 Addr: 110
PLL2_ENABLE
Bit
Bit Name
Default
Access
Bit Description
[0]
PLL2_ENABLE
RST
0: Disable PLL1
1: Enable PLL1
PLL2_NDIV Register (Bank 0, Address 112)
Figure 185:
PLL2_NDIV Register
Bank: 0 Addr: 112
PLL2_NDIV
Bit
Bit Name
Default
Access
Bit Description
[7:0]
PLL2_NDIV
RST
PLL2 divider parameter
Datasheet • PUBLIC
138 │ 123
Document Feedback
8.2.51
CMV50000
Register Description
PLL_CLKDIV_RSTN Register (Bank 0, Address 114)
Figure 186:
Bank: 0 Addr: 114
PLL_CLKDIV_RSTN
Bit
Default
[0]
8.2.52
Bit Name
PLL_CLKDIV_RSTN
Access
Bit Description
0: Assert CLK_IN divider
reset
1: Release CLK_IN divider
reset
PLL_LOCK Register (Bank 0, Address 115)
Figure 187:
PLL_LOCK Register
8.2.53
Bank: 0 Addr: 115
PLL_LOCK
Bit
Bit Name
Default
Access
Bit Description
[0]
PLL1_LOCK
RO
0: PLL1 out of lock
1: PLL1 in lock
[1]
PLL2_LOCK
RO
0: PLL2 out of lock
1: PLL2 in lock
VERSION_ID Register (Bank 0, Address 116)
Figure 188:
VERSION_ID Register
Bank: 0 Addr: 116
VERSION_ID
Bit
Bit Name
Default
Access
Bit Description
[7:0]
VERSION_ID
1
RO
Sensor revision number
Datasheet • PUBLIC
138 │ 124
Document Feedback
8.2.54
CMV50000
NO_SHUTTER_LAG Register (Bank 0, Address 117)
Figure 189:
8.2.55
Bank: 0 Addr: 117
NO_SHUTTER_LAG
Bit
Bit Name
Default
Access
Bit Description
[0]
NO_SHUTTER_LAG
DC
0: Enable shutter lag
1: Disable shutter lag
DUAL_EXP_GROUPING Register (Bank 0, Address 118)
Figure 190:
Bank: 0 Addr: 118
DUAL_EXP_GROUPING
Bit
Default
[0]
8.2.56
Bit Name
DUAL_EXP_GROUPING
Access
DC
Bit Description
Dual exposure column
grouping:
0: Default (monochrome)
1: Paired (color)
GRAN_GLOB Register (Bank 1, Address 5)
Figure 191:
GRAN_GLOB Register
Bank: 1 Addr: 5
GRAN_GLOB
Bit
Bit Name
Default
Access
Bit Description
[7:0]
GRAN_GLOB
1
Sets shutter timing
granularity
Datasheet • PUBLIC
DS000522 • v3-01 • 2019-Dec-20
138 │ 125
Document Feedback
8.2.57
CMV50000
CLKGEN_CFG Register (Bank 1, Address 6)
Figure 192:
CLKGEN_CFG Register
8.2.58
Bank: 1 Addr: 6
CLKGEN_CFG
Bit
Bit Name
Default
Access
[0]
RST
[2:1]
PHASE
1
RST
[3]
1
RST
[6:4]
RST
Bit Description
Sets the phase of the output
clock to the data.
0: 0°
1: 90°
2: 180°
3: 270°
EOB_OFFSET_FINE Register (Bank 1, Address 38-39)
Figure 193:
Bank: 1 Addr: 38-39
EOB_OFFSET_FINE
Bit
Default
[15:0]
Bit Name
EOB_OFFSET_FINE
Datasheet • PUBLIC
Access
Bit Description
Fine tunes the OB offset
depending on gain:
32920: Analog gain x1
33083: Analog gain x2
33418: Analog gain x4
138 │ 126
Document Feedback
8.2.59
CMV50000
EOB_BYPASS Register (Bank 1, Address 42)
Figure 194:
EOB_BYPASS Register
Bank: 1 Addr: 42
EOB_BYPASS
Bit
Default
[0]
8.2.60
Bit Name
EOB_BYPASS
Access
Bit Description
Enables Optical Black
Correction (OBC)
1: OBC off
EOB_BYPASS_VALUE Register (Bank 1, Address 43-44)
Figure 195:
8.2.61
Bank: 1 Addr: 43-44
EOB_BYPASS_VALUE
Bit
Bit Name
Default
Access
Bit Description
[13:0]
EOB_BYPASS_VALUE
Sets the black level at the
ADC (with OBC off)
NR_DUMMIES Register (Bank 1, Address 46)
Figure 196:
NR_DUMMIES Register
Bank: 1 Addr: 46
NR_DUMMIES
Bit
Bit Name
Default
Access
Bit Description
[3:0]
NR_DUMMIES
Sets the number of dummy
rows in pipeline mode
Datasheet • PUBLIC
138 │ 127
Document Feedback
8.2.62
CMV50000
TDIG Register (Bank 1, Address 99)
Figure 197:
TDIG Register
Bank: 1 Addr: 99
TDIG
Bit
Default
[4:0]
8.2.63
Bit Name
DMUX1_SEL
Access
Bit Description
Sets pin TDIGO1 function:
0: None
1: PLL_1_LOCK
2: PLL_2_LOCK
5: CLK_PIX
6: INT_REQ_FRAME
7: INT_REQ_EXP(L)
12: GLOB start
14: CTR_EXP(L)
TG_LENGTH Register (Bank 1, Address 110-111)
Figure 198:
TG_LENGTH Register
8.2.64
Bank: 1 Addr: 110-111
TG_LENGTH
Bit
Bit Name
Default
Access
Bit Description
[13:0]
TG_LENGTH
DC
Sets shutter timing
SHUTTER_LAG Register (Bank 1, Address 114-115)
Figure 199:
Bank: 1 Addr: 114-115
SHUTTER_LAG
Bit
Bit Name
Default
Access
Bit Description
[13:0]
SHUTTER_LAG
DC
Sets the shutter lag
Datasheet • PUBLIC
138 │ 128
Document Feedback
8.2.65
CMV50000
PLL1_DISABLE_CLKOUT Register (Bank 3, Address 49)
Figure 200:
Bank: 1 Addr: 49
SHUTTER_LAG
Bit
Default
[0]
Bit Name
PLL1_DISABLE_CLKOUT
Datasheet • PUBLIC
Access
Bit Description
RST
Disables the PLL1 clock
output for soft-reset.
0: Enabled
1: Disabled
138 │ 129
Document Feedback
9
Application Information
9.1
Color Filter
CMV50000
A color version of the CMV50000 has color filters applied with a Bayer pattern. The first pixel read-out,
pixel(0, 0), is the bottom left one and has a blue filter.
Figure 201 :
Bayer Color Filter
9.2
Socket
To avoid putting the sensor through the soldering heat (stressing the color filters and micro-lenses), it
is advised to use a socket and place the sensor after the solder stage. Sockets for this device are
available from Andon Electronics (www.andonelectronics.com) in both SMD (p/n: 575-20-19A-14193M-R27-L14) and TH (p/n: 575-20-19A-141-01M-R27-L14) configuration.
Contact Andon Electronics directly for more information.
Datasheet • PUBLIC
138 │ 130
Document Feedback
9.3
CMV50000
Pin Layout
Figure 202 :
Pin Layout from Top View
Datasheet • PUBLIC
138 │ 131
Document Feedback
10
CMV50000
Package Drawings & Markings
Figure 203:
141-PGA Package Outline Drawing
RoHS
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
Green
All dimensions are in millimeters. Angles in degrees.
Au plate 0.75µm min. over 2.0µm min Ni
Unplated are on tip shall be less than Ø0.30 within 0.50 max from pin tip
Materials: 1. Package: Alumina ceramic; 2. Pin: Alloy42; 3: Standoff pin: Alloy42
Unless otherwise specified tolerances are ±1%; N.L.T: x.x ±0.25; x.xx ±0.13
The package has a marking on top, in the left bottom corner, at pin A1 position
This package contains no lead (Pb).
This drawing is subject to change without notice.
Datasheet • PUBLIC
138 │ 132
Document Feedback
CMV50000
Figure 204:
141-PGA Assembly Outline Drawing
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
(11)
(12)
(13)
(14)
(15)
(16)
(17)
Die size: 39.4mm x 31.1mm, relative to the die SEAL ring edge, the dimensions after dicing will be typically larger.
Optical center to die and package center offset: in X = 0, in Y = 628µm
Die positioned in the middle of the package cavity
Die placement accuracy: ±100µm
Die rotation in package: max ±0.2°
Die tilt towards cavity bottom: max ±0.1°
Distance from the cavity bottom to the photosensitive pixel layer (top of the die): 0.86 ±0.06mm
Distance from the top of the glass to the photosensitive pixel layer (top of the die): 1.65 ±0.20mm
Glass lid positioned in the middle of the package;
Glass size tolerance: ±0.1mm
Glass thickness: 0.7 ±0.05mm
Glass lid placement accuracy: ±200µm
The devices come covered with a heat resistant protective tape
The 4 notches are not to be mechanically stressed! They can be used to measure the level and tilt of the cavity bottom
(die attach surface).
Datasheet • PUBLIC
138 │ 133
Document Feedback
CMV50000
Figure 205 :
141-PGA Package Marking/Code
Datasheet • PUBLIC
138 │ 134
Document Feedback
11
CMV50000
Packing Information
Packing Information
The devices are shipped in JEDEC PGA matrix trays.
Datasheet • PUBLIC
138 │ 135
Document Feedback
12
CMV50000
Soldering Information
Attention
Image sensors with color filter arrays (CFA) and micro lenses are especially sensitive to high
temperatures. Prolonged heating at elevated temperatures may result in deterioration of the optical
performance of the sensor.
A socket (see 9.2) is the safest way to avoid any thermal stress. When not using a socket, to avoid
heating up the device we recommend to use manual hand soldering. Wave soldering can be used
with precautions (see below). Reflow soldering is not recommended.
Manual soldering: Use partial heating method and use a soldering iron with temperature control. The
soldering iron tip temperature is not to exceed 350°C with a 270°C maximum pin temperature. Touch
for a 2 seconds maximum duration per pin. Avoid touching and global heating of the ceramic package
during soldering. Failure to do so may alter device performance and reliability.
Wave soldering: Wave solder dipping can cause damage to the glass and harm the imaging capability
of the device. Avoid the solder to come in contact with the glass or ceramic body.
Datasheet • PUBLIC
138 │ 136
Document Feedback
13
CMV50000
Revision Information
Document Status
Product Status
Definition
Product Preview
Pre-Development
Information in this datasheet is based on product ideas in the planning phase
of development. All specifications are design goals without any warranty and
are subject to change without notice
Preliminary Datasheet
Pre-Production
Information in this datasheet is based on products in the design, validation or
qualification phase of development. The performance and parameters shown
in this document are preliminary without any warranty and are subject to
Datasheet
Production
Information in this datasheet is based on products in ramp-up to full production
or full production which conform to specifications in accordance with the terms
of ams AG standard warranty as given in the General Terms of Trade
Datasheet
(discontinued)
Discontinued
Information in this datasheet is based on products which conform to
specifications in accordance with the terms of ams AG standard warranty as
given in the General Terms of Trade, but these products have been
superseded and should not be used for new designs
Changes from previous version to current revision v3-01
Page
Update Assembly Outline Drawing details 7, 8 (no physical change)
131
OTP Memory added
92-94
Remove IO logic level for sublvds
15
Part nr added
5
Page and figure numbers for the previous version may differ from page and figure numbers in the current revision.
Correction of typographical errors is not explicitly mentioned.
Datasheet • PUBLIC
138 │ 137
Document Feedback
14
CMV50000
Legal Information
Legal Information
Copyrights & Disclaimer
Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved.
The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the
copyright owner.
Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of
Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams
AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this
product into a system, it is necessary to check with ams AG for current information. This product is intended for use in
commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high
reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended
without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or
implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are
disclaimed.
ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property
damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any
kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability
to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services.
RoHS Compliant & ams Green Statement
RoHS Compliant: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our
semiconductor products do not contain any chemicals for all 6 substance categories plus additional 4 substance categories (per
amendment EU 2015/863), including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where
designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes.
ams Green (RoHS compliant and no Sb/Br/Cl): ams Green defines that in addition to RoHS compliance, our products are free
of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material)
and do not contain Chlorine (Cl not exceed 0.1% by weight in homogeneous material).
Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that
it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or
warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG
has taken and continues to take reasonable steps to provide representative and accurate information but may not have
conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers
consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for
release.
Headquarters
Please visit our website at www.ams.com
ams AG
Buy our products or get free samples online at www.ams.com/Products
Technical Support is available at www.ams.com/Technical-Support
8141 Premstaetten
Provide feedback about this document at www.ams.com/Document-Feedback
Austria, Europe
For sales offices, distributors and representatives go to www.ams.com/Contact
Tel: +43 (0) 3136 500 0
For further information and requests, e-mail us at ams_sales@ams.com
Datasheet • PUBLIC
138 │ 138
