CA14942_MINNIE-LT-W-PIN
    LEDIL(芬兰)
    REFLECTORROUND1POS35MM(D)1
CA14942_MINNIE-LT-W-PIN 数据手册
PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN MINNIE-LT-W-PIN ~35° wide beam. Assembly with location pins and installation tape. TECHNICAL SPECIFICATIONS: Dimensions Ø 35.0 mm Height 15.6 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour MINNIE-LT-W-PIN Reflector PC metal SPUTNIK-TAPE3 Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA14942_MINNIE-LT-W-PIN » Box size: 480 x 280 x 300 mm Qty in box Reflector 720 MOQ MPQ 90 45 Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 3.6 1/8 PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN PHOTOMETRIC DATA (MEASURED): LED XHP70.2 FWHM / FWTM 35.0° / 87.0° Efficiency 91 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 29.0° / 84.0° Efficiency 93 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 30.0° / 90.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 30.0° / 84.0° Efficiency 91 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN PHOTOMETRIC DATA (MEASURED): LED LUXEON MZ FWHM / FWTM 27.0° / 83.0° Efficiency 93 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V FWHM / FWTM 24.0° / 83.0° Efficiency 92 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFMW48xA FWHM / FWTM 29.0° / 83.0° Efficiency 92 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S10 FWHM / FWTM 34.0° / 84.0° Efficiency 91 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN PHOTOMETRIC DATA (MEASURED): LED OSCONIQ P 7070 FWHM / FWTM 29.0° / 84.0° Efficiency 92 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED WICOP 5050 FWHM / FWTM 27.0° / 81.0° Efficiency 91 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN PHOTOMETRIC DATA (SIMULATED): LED MK-R FWHM / FWTM 40.0° / 89.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.3 HD FWHM / FWTM 30.0° / 79.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70.3 HD FWHM / FWTM 36.0° / 84.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 34.0° / 85.0° Efficiency 90 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN PHOTOMETRIC DATA (SIMULATED): LED XT-E FWHM / FWTM 30.0° / 83.0° Efficiency 90 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 7070 FWHM / FWTM 32.0° / 75.0 + 74.0° Efficiency 96 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET CA14942_MINNIE-LT-W-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
CA14942_MINNIE-LT-W-PIN 价格&库存
很抱歉,暂时无法提供与“CA14942_MINNIE-LT-W-PIN”相匹配的价格&库存,您可以联系我们找货
