C10687_EVA-WW
C10687_EVA-WW
    LEDIL(芬兰)
    LENS 1POS 35MM ROUND OD 16.4MM
C10687_EVA-WW 数据手册
PRODUCT DATASHEET C10909_EVA-WW EVA-WW ~55° wide beam TECHNICAL SPECIFICATIONS: Dimensions Height Ø 35.0 mm 16.4 mm Fastening ROHS compliant glue yes MATERIAL SPECIFICATIONS: Component Type Material Colour EVA-WW Single lens PMMA clear Finish ORDERING INFORMATION: Component C10909_EVA-WW » Box size: 480 x 280 x 300 mm Qty in box 540 MOQ MPQ 90 45 Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 6.0 1/9 PRODUCT DATASHEET C10909_EVA-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET C10909_EVA-WW PHOTOMETRIC DATA (MEASURED): LED CLU7A2 (LES 4.2mm) FWHM / FWTM 48.0° / 80.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED MC-E FWHM / FWTM 47.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED MHB-A/B FWHM / FWTM 52.0° / 84.0° Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 71.0° / 106.0° Efficiency 75 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET C10909_EVA-WW PHOTOMETRIC DATA (MEASURED): LED XM-L FWHM / FWTM 64.0° Efficiency 77 % LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 47.0° / 83.0° Efficiency 76 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 57.0° / 85.0° Efficiency 78 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 65.0° Efficiency 80 % LEDs/each optic 1 Light colour White Required components: Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET C10909_EVA-WW PHOTOMETRIC DATA (MEASURED): LED Duris S8 FWHM / FWTM 55.0° / 84.0° Efficiency 79 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y15 FWHM / FWTM 45.0° / 82.0° Efficiency 77 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y19 FWHM / FWTM 47.0° / 82.0° Efficiency 76 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET C10909_EVA-WW PHOTOMETRIC DATA (SIMULATED): LED CXA/B 13xx FWHM / FWTM 64.0° / 88.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L HVW FWHM / FWTM 58.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 57.0° / 84.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5258 FWHM / FWTM 50.0° / 72.0° Efficiency 93 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET C10909_EVA-WW PHOTOMETRIC DATA (SIMULATED): LED LUXEON 7070 FWHM / FWTM 54.0° / 83.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED CXM-3 FWHM / FWTM 49.0° / 78.0° Efficiency 95 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED CXM-4 FWHM / FWTM 50.0° / 78.0° Efficiency 95 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFMW48xA FWHM / FWTM 70.0° / 89.0° Efficiency 96 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET C10909_EVA-WW PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 56.0° / 78.0° Efficiency 93 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET C10909_EVA-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 07/10/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
C10687_EVA-WW 价格&库存
很抱歉,暂时无法提供与“C10687_EVA-WW”相匹配的价格&库存,您可以联系我们找货
