CS15761_STRADA-2X2MX-8-SCL
    LEDIL(芬兰)
CS15761_STRADA-2X2MX-8-SCL 数据手册
PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL STRADA-2X2MX-8-SCL Type II/III (Long) beam for very wide pole to pole distances. Ideal for pedestrian walkways and residential roads. EN13201 P-classes. New revision. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening 90.0 x 90.0 mm 13.2 mm screw Ingress protection classes ROHS compliant IP67 yes MATERIAL SPECIFICATIONS: Component Type Material Colour STRADA-2X2MX-8-SCL Multi-lens PMMA clear STRADA-2X2MX-8-SEAL Seal Silicone clear Finish ORDERING INFORMATION: Component CS15761_STRADA-2X2MX-8-SCL » Box size: 480 x 280 x 300 mm Qty in box Multi-lens 156 MOQ MPQ 52 52 Box weight (kg) 7.9 Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL See also our general installation guide: www.ledil.com/installation_guide Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (MEASURED): LED CXA/B 15xx FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 441 Typ 2x2MX HV LED XHP50.2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70.2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E HE FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (MEASURED): LED LUXEON M/MX FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-7070 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM SC16 (LH181B) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED PAL-LK-4950-740-48 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (MEASURED): LED XLE-S22C4XD16 (XD16) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 4 Light colour White Required components: LED XLE-S22C4XTEHE (XT-E HE) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XLE-S22XHP50B (XHP50.2) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED WICOP 5050 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (MEASURED): LED Z8Y22 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (SIMULATED): LED Bridgelux SMD 5050 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED CLU700/701/702 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 434 Typ 2x2MX HV LED XHP70.2 FWHM / FWTM Asymmetric Efficiency 78 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XHP70.3 HD FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (SIMULATED): LED LUXEON 5050 Round LES FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 7070 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFMW48xA FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (SIMULATED): LED NV4x144A FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 9 Light colour White Required components: LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL PHOTOMETRIC DATA (SIMULATED): LED LH181B FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y19 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour White Required components: Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/11 PRODUCT DATASHEET CS15761_STRADA-2X2MX-8-SCL GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 17/08/2022 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/11
CS15761_STRADA-2X2MX-8-SCL 价格&库存
很抱歉,暂时无法提供与“CS15761_STRADA-2X2MX-8-SCL”相匹配的价格&库存,您可以联系我们找货
