CS15763_STRADA-2X2MX-8-VSM 数据手册
PRODUCT
DATASHEET
STRADA-2X2MX-8-VSM
IESNA Type V (square) for wide areas lighting
such as car parks. New revision.
TECHNICAL SPECIFICATIONS:
Dimensions
Height
Fastening
90.0 x 90.0 mm
13.1 mm
screw
Ingress protection classes
ROHS compliant
IP67
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
STRADA-2X2MX-8-VSM
Multi-lens
PMMA
clear
STRADA-2X2MX-8-SEAL
Seal
Silicone
clear
Finish
ORDERING INFORMATION:
Component
» Box size: 480 x 280 x 300 mm
Qty in box
Multi-lens
156
MOQ
MPQ
52
52
Box weight (kg)
8.6
Last update: 17/08/2022
Subject to change without prior notice
Published: 12/07/2019
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/11
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/11
PRODUCT
DATASHEET
PHOTOMETRIC DATA (MEASURED):
LED
XHP50.2
FWHM / FWTM
151.0° / 159.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XT-E HE
FWHM / FWTM
148.0° / 156.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON M/MX
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON XR-7070
FWHM / FWTM
147.0° / 156.0°
Efficiency
97 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
3/11
PRODUCT
DATASHEET
LED
NV9W149AM
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
PrevaLED Brick HP 2x2MX
FWHM / FWTM
145.0° / 153.0°
Efficiency
96 %
Peak intensity
0.4 cd/lm
LEDs/each optic
4
Light colour
White
LED
HiLOM SC16 (LH181B)
FWHM / FWTM
140.0° / 147.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
PAL-LK-4950-740-48
FWHM / FWTM
150.5 + 151.0° / 159.5 + 159.0°
Efficiency
97 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
4/11
PRODUCT
DATASHEET
LED
XLE-S22C4XD16 (XD16)
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
4
Light colour
White
LED
XLE-S22C4XTEHE (XT-E HE)
FWHM / FWTM
148.0° / 156.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XLE-S22XHP50B (XHP50.2)
FWHM / FWTM
151.0° / 159.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
WICOP 5050
FWHM / FWTM
150.0° / 159.0°
Efficiency
96 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
5/11
PRODUCT
DATASHEET
LED
Z8Y22
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
4
Light colour
White
6/11
PRODUCT
DATASHEET
PHOTOMETRIC DATA (SIMULATED):
LED
Bridgelux SMD 5050
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
CLU700/701/702
FWHM / FWTM
Asymmetric
Efficiency
93 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 434 Typ 2x2MX HV
LED
MHB-A/B
FWHM / FWTM
152.0° / 160.0°
Efficiency
95 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XHP70.3 HD
FWHM / FWTM
152.0° / 160.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
7/11
PRODUCT
DATASHEET
LED
XT-E
FWHM / FWTM
148.0° / 180.0°
Efficiency
93 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON 5050 Round LES
FWHM / FWTM
146.0° / 154.0°
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON 7070
FWHM / FWTM
150.0° / 158.0°
Efficiency
95 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
NFMW48xA
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
45 cd/lm
LEDs/each optic
1
Light colour
White
8/11
PRODUCT
DATASHEET
LED
NV4WB35AM
FWHM / FWTM
148.0° / 162.0°
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxE21A
FWHM / FWTM
148.0° / 156.0°
Efficiency
95 %
Peak intensity
0.4 cd/lm
LEDs/each optic
9
Light colour
White
LED
NVSxE21A
FWHM / FWTM
146.0° / 154.0°
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
4
Light colour
White
LED
OSCONIQ P 7070
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
9/11
PRODUCT
DATASHEET
LED
Z8Y19
FWHM / FWTM
Asymmetric
Efficiency
93 %
Peak intensity
0.5 cd/lm
LEDs/each optic
4
Light colour
White
10/11
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
Due to use of high power COB's with this product, special attention to proper
thermal design is highly recommended. LEDiL has no liability for direct,
indirect or consecutive damages arising from the LEDiL products being used
outside of the recommended temperature range.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
11/11
CS15763_STRADA-2X2MX-8-VSM 价格&库存
很抱歉,暂时无法提供与“CS15763_STRADA-2X2MX-8-VSM”相匹配的价格&库存,您可以联系我们找货
