FP14998_FLORENTINA-HLD-WW
    LEDIL(芬兰)
    HOLDER RECTANG 12 POS 285.6+19.5
FP14998_FLORENTINA-HLD-WW 数据手册
PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW FLORENTINA-HLD-WW ~45° wide beam TECHNICAL SPECIFICATIONS: Dimensions Height 285.6 x 19.5 mm 9.5 mm Fastening screw ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour TINA-WW-XP Single lens PMMA clear FLORENTINA-HLD Holder PC black Finish ORDERING INFORMATION: Component FP14998_FLORENTINA-HLD-WW » Box size: 398 x 298 x 140 mm Qty in box Single lens 160 MOQ MPQ 32 16 Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 5.2 1/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW PHOTOMETRIC DATA (MEASURED): LED QUICK FLUX LED FL-XG 1x12 xxx FWHM / FWTM 56.0° / 84.0° Efficiency 75 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED XP-E2 FWHM / FWTM 52.0° / 82.0° Efficiency 77 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED XP-G2 FWHM / FWTM 59.0° / 86.0° Efficiency 78 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED XP-G3 FWHM / FWTM 50.0° / 81.0° Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW PHOTOMETRIC DATA (MEASURED): LED LUXEON Rebel ES FWHM / FWTM 46.0° / 80.0° Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED LUXEON Rebel Plus FWHM / FWTM 40.0° / 78.0° Efficiency 79 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED LUXEON TX FWHM / FWTM 41.0° / 77.0° Efficiency 78 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED LUXEON Z ES FWHM / FWTM 33.0° / 75.0° Efficiency 80 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW PHOTOMETRIC DATA (MEASURED): LED NCSxx19B FWHM / FWTM 38.0° / 76.0° Efficiency 76 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED NVSxx19B/NVSxx19C FWHM / FWTM 46.0° / 80.0° Efficiency 74 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED OSLON Square EC FWHM / FWTM 57.0° / 84.0° Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED OSLON SSL 150 FWHM / FWTM 32.0° / 76.0° Efficiency 85 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW PHOTOMETRIC DATA (MEASURED): LED OSLON SSL 150 FWHM / FWTM 37.0° / 75.0° Efficiency 79 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED OSLON SSL 80 FWHM / FWTM 47.0° / 80.0° Efficiency 75 % LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED LH351B FWHM / FWTM 64.0° / 87.0° Efficiency 77 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED TL1L4 FWHM / FWTM 48.0° / 80.0° Efficiency 78 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW PHOTOMETRIC DATA (SIMULATED): LED NCSxE17A FWHM / FWTM 29.0° / 73.0° Efficiency 94 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED NCSxE17A FWHM / FWTM 25.0° / 73.0° Efficiency 94 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 33.0° / 73.0° Efficiency 94 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD LED NVSxE21A FWHM / FWTM 28.0° / 74.0° Efficiency 94 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW PHOTOMETRIC DATA (SIMULATED): LED NWSx229A FWHM / FWTM 60.0° / 85.0° Efficiency 77 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C14446_FLORENTINA-SHD Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET FP14998_FLORENTINA-HLD-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 20/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
FP14998_FLORENTINA-HLD-WW 价格&库存
很抱歉,暂时无法提供与“FP14998_FLORENTINA-HLD-WW”相匹配的价格&库存,您可以联系我们找货
        库存:91
