VLM-650-02-SPA
VLM-650-02-SPA
    QUARTONINC.(夸顿)
    Module
    VLM-650-02-SPA
VLM-650-02-SPA 数据手册
Adjustable Laser VLM-650-02 Series Lead Wire Type Spring Type FEATURES:             Industrial Red Dot Laser. Adjustable focus (Focus range 100mm ~ Infinity) Laser module with APC Driver Circuit inside, ideal for industrial Laser application. This module has integrated optic, laser diode, and APC driver circuit. APC Driver Circuit enables the Laser output power safe and constant. Includes patented solid brass structure for the best shock resistance and better heat transfer consideration. Aspherical plastic lens provides Dot Laser. Dimensions : Ø 10.5 x 26 mm (Ø 0.413" x 1.023"). Wavelength : 650 nm Laser power output : LPT - Class II – less than 1mW LPA - Class IIIa – less than 3mW. Beam Divergence (Half Angle) : 0.5 mRad 2.6~6 VDC operation. Connection type : Lead wire / Spring. APPLICATIONS:         Industrial Red Dot Laser –Adjustable focus function. Ideal for Industrial positioning, measuring, pointing which would need an focusable beam at specific distances. Wood processing. Metal processing. Stone processing. Textile industry. Food industry. Automotive industry. Medical science. @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com VLM-650-02 Series OUTLINE DIMENSIONS (UNITS: mm) Outline (Lead Wire type) Outline (Spring type) SPECIFICATIONS VLM-650-02 SPECIFICATIONS LPT 1 Dimensions LPA SPT SPA Ø 10.5 x 26 mm (Ø 0.413" x 1.023") 2 Operating voltage (Vop) 2.6~6 VDC 3 Operating current (Iop) Less than 35mA Less than 50mA Less than 35mA Less than 50mA 4 Laser power output 5 Laser class 6 Wavelength at peak emission (λp) Less than 1mW Less than 3mW Less than 1mW Less than 3mW Class II Class IIIa Class II Class IIIa 645~665nm 7 Collimating lens Aspherical plastic lens 8 Output aperture 4mm 9 Beam shape Ellipse 10 Focus range 100mm ~ Infinity 11 Spot size at 5M 12 Divergence (Half Angle) 13 Beam alignment 14 Operating temp. range* 5±1 mm 0.5 mRad Less than 3° +10°C ~+40°C @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com VLM-650-02 Series 15 Storage temp. range -20°C ~+65°C 16 Housing material Brass 17 Potential housing** VDD(+) 18 Electrostatic discharge (ESD) 19 Moisture sensitivity level (MSL) 20 Connection type 21 Cable length 30KV Level 1 - acc to JEDEC J-STD-020E. 1007-26 AWG Spring 115±15mm 6.5±1mm 22 Mean time to failure (MTTF) 25°C 10000hrs 23 Application Focus adjustable 24 Suggestion work distance 1~30 meters / 3~100 feet * Operation temperature: it means within this temperature range, the laser spot/line will not be affected to change the spot size/line width. It can still work over this range, but the laser spot size or laser line width will be larger. ** Laser module housing is an electrical positive surface, it is imperative that contact between the laser module and the machine be avoided. This is to prevent damage from the machine electrical leakage. Surge protected power supply to the laser module is strongly recommended. ORDER CODE Order Code Wavelength Laser Power Output Laser Class Connection Type VLM-650-02 LPA 650 nm Less than 3mW Class IIIa Lead Wire VLM-650-02 LPT 650 nm Less than 1mW Class II Lead Wire VLM-650-02 SPA 650 nm Less than 3mW Class IIIa Spring VLM-650-02 SPT 650 nm Less than 1mW Class II Spring SAFETY LABEL @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com
VLM-650-02-SPA 价格&库存
很抱歉,暂时无法提供与“VLM-650-02-SPA”相匹配的价格&库存,您可以联系我们找货
