Mini-Size Red Dot Laser
VLM-650-22 Series (Glass Lens)
FEATURES:
This module has integrated optic, laser diode, and APC driver circuit.
APC Driver Circuit enables the Laser output power safe and constant.
Glass lens provides Dot Laser.
Dimensions : Ø 4 x 15 mm (Ø 0.157" x 0.59")
Wavelength : 645~660nm
Laser power output : LPA - Class IIIa – less than 3.5mW.
LPT - Class II – less than 1mW.
Beam Divergence (Half Angle) : 2.5 mRad
3~6 VDC operation.
Connection type : Lead wire
APPLICATIONS:
Mini-Size Red Dot Laser Module - for positioning, measuring, pointing and laser
sighting device.
Wood processing.
Metal processing.
Stone processing.
Textile industry.
Food industry.
Automotive industry.
Medical science.
@Copyright 2021 Quarton inc.All Rights Reserved.
www.quarton.com
VLM-650-22 Series
OUTLINE DIMENSIONS (UNITS: mm)
Outline (Lead Wire type)
SPECIFICATIONS
SPECIFICATIONS
1 Dimensions
VLM-650-22
LPT
LPA
2 Operating voltage (Vop)
3 Operating current (Iop)
4 Laser power output
5 Laser class
6 Wavelength at peak emission (λp)
3~6 VDC
Less than 25mA
Less than 30mA
0.7±0.2mW
3±0.5mW
Class II
Class IIIa
645~660nm
7 Output aperture
2.1mm
8 Collimating lens
Aspherical glass lens
9 Beam shape
Ellipse
10 Spot size at 5M
10±1 mm
11 Divergence (Half Angle)
2.5 mRad
12 Beam alignment
Less than 3°
13 Operating temp. range*
-10°C ~+50°C
14 Storage temp. range
-20°C ~+65°C
15 Housing
Brass
16 Potential of housing**
17 Electrostatic discharge (ESD)
18 Moisture sensitivity level (MSL)
VDD(+)
20KV
Level 1 - acc to JEDEC J-STD-020E.
www.quarton.com
VLM-650-22 Series
19 Connection type
1007-26 AWG
20 Cable length
115±15mm
21 Mean time to failure (MTTF) 25°C
22 Application
5000hrs
Small size
23 Suggestion work distance
1~10 meters / 3~40 feet
* Operation temperature: it means within this temperature range, the laser spot/line will not be affected to change the spot size/line
width. It can still work over this range, but the laser spot size or laser line width will be larger.
** Laser module housing is an electrical positive surface, it is imperative that contact between the laser module and the machine be
avoided. This is to prevent damage from the machine electrical leakage. Surge protected power supply to the laser module is
strongly recommended.
ORDER CODE
Order Code
Wavelength
Laser Power Output
Laser Class
Connection Type
VLM-650-22 LPA
650 nm
Less than 3.5mW
Class IIIa
Lead Wire
VLM-650-22 LPT
650 nm
Less than 1mW
Class II
Lead Wire
SAFETY LABEL
LPT:
LPA:
www.quarton.com
很抱歉,暂时无法提供与“VLM-650-22-LPA”相匹配的价格&库存,您可以联系我们找货
