BCV63,215
BCV63,215
    NEXPERIA(安世)
    SOT-143B-4
    三极管 NPN Ic=100mA Vceo=30V hfe=800 P=250mW SOT143B-4
BCV63,215 数据手册
BCV63; BCV63B NPN general-purpose double transistors Rev. 4 — 4 August 2010 Product data sheet 1. Product profile 1.1 General description NPN general-purpose double transistors in a small SOT143B Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number BCV63 Package PNP complement Nexperia JEITA SOT143B - BCV63B BCV64B 1.2 Features and benefits     Low current (max. 100 mA) Low voltage (max. 30 V and 6 V) AEC-Q101 qualified Small SMD plastic package 1.3 Applications  General-purpose switching and amplification  For use in Schmitt trigger applications 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit - - 100 mA - - 30 V BCV63 110 - 800 BCV63B 200 - 450 Per transistor IC collector current Transistor TR1 VCEO collector-emitter voltage open base hFE DC current gain VCE = 5 V; IC = 2 mA BCV63; BCV63B Nexperia NPN general-purpose double transistors Table 2. Quick reference data …continued Symbol Parameter Conditions Min Typ Max Unit - - 6 V BCV63 110 - 800 BCV63B 200 - 450 Transistor TR2 VCEO DC current gain hFE [1] collector-emitter voltage open base VCE = 700 mV; IC = 2 mA [1] Group selection will be done on TR1. Due to matched dies, hFE values for TR2 are the same as for TR1. 2. Pinning information Table 3. Pinning Pin Description Simplified outline 1 collector TR2 and base TR1 2 collector TR1 4 3 emitter TR1 and TR2 4 base TR2 Graphic symbol 2 3 1 TR1 TR2 1 2 3 4 006aab228 3. Ordering information Table 4. Ordering information Type number BCV63 Package Name Description Version - plastic surface-mounted package; 4 leads SOT143B BCV63B 4. Marking Table 5. Marking codes Type number Marking code[1] BCV63 *D5 BCV63B *D6 [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China BCV63_63B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 2 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit open collector Per transistor VEBO emitter-base voltage - 6 V IC collector current - 100 mA ICM peak collector current - 200 mA IB base current - 100 mA Transistor TR1 VCBO collector-base voltage open emitter - 30 V VCEO collector-emitter voltage open base - 30 V Transistor TR2 VCBO collector-base voltage open emitter - 6 V VCEO collector-emitter voltage open base - 6 V Ptot total power dissipation Tamb  25 C - 250 mW Per device [1] Tj junction temperature - 150 C Tamb ambient temperature 65 +150 C Tstg storage temperature 65 +150 C [1] Device mounted on an FR4 Printed-Circuit Board (PCB). 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air [1] BCV63_63B Product data sheet [1] Min Typ Max Unit - - 500 K/W Device mounted on an FR4 PCB. All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 3 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors 7. Characteristics Table 8. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit collector-base cut-off current VCB = 30 V; IE = 0 A - - 15 nA VCB = 30 V; IE = 0 A; Tj = 150 C - - 5 A VCEsat collector-emitter saturation voltage IC = 10 mA; IB = 0.5 mA - 75 300 mV VBEsat base-emitter saturation voltage IC = 10 mA; IB = 0.5 mA - 700 - mV BCV63 110 - 800 BCV63B 200 - 450 - 250 650 mV Per transistor ICBO [2] Transistor TR1 DC current gain hFE VCE = 5 V; IC = 2 mA VCEsat collector-emitter saturation voltage IC = 100 mA; IB = 5 mA VBEsat base-emitter saturation voltage IC = 100 mA; IB = 5 mA [2] - 850 - mV VBE base-emitter voltage IC = 2 mA; VCE = 5 V [3] 600 650 750 mV IC = 10 mA; VCE = 5 V [3] - - 820 mV fT transition frequency VCE = 5 V; IC = 10 mA; f = 100 MHz 100 - - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 4 - pF Transistor TR2 DC current gain hFE BCV63_63B Product data sheet VCE = 700 mV; IC = 2 mA [1] BCV63 110 - 800 BCV63B 200 - 450 - 250 - mV - 700 - mV VCEsat collector-emitter saturation voltage IC = 100 mA; IB = 5 mA VBE base-emitter voltage IC = 2 mA; VCE = 700 mV [3] [1] Group selection will be done on TR1. Due to matched dies, hFE values for TR2 are the same as for TR1. [2] VBEsat decreases by about 1.7 mV/K with increasing temperature. [3] VBE decreases by about 2 mV/K with increasing temperature. All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 4 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors mgt727 600 VBE (mV) 1000 hFE (1) 500 mgt728 1200 (1) 400 800 (2) (2) 300 600 200 400 (3) (3) 100 200 0 10−1 1 10 102 0 10−2 103 10−1 1 102 103 I C (mA) 10 I C (mA) VCE = 5 V VCE = 5 V (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 1. BCV63B: DC current gain as a function of collector current; typical values mgt729 104 Fig 2. BCV63B: Base-emitter voltage as a function of collector current; typical values mgt730 1200 VBEsat (mV) 1000 VCEsat (mV) (1) 103 800 (2) 600 (3) 102 400 (1) 200 (3) (2) 10 10−1 1 10 102 0 10−1 103 1 10 102 IC/IB = 20 IC/IB = 10 (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 3. BCV63B: Collector-emitter saturation voltage as a function of collector current; typical values BCV63_63B Product data sheet 103 I C (mA) I C (mA) Fig 4. BCV63B: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 5 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors 8. Application information Rc Rc 1 R1 2 4 3 Vo TR1 TR2 R2 3 Vi mgd829 Fig 5. Schmitt trigger application 9. Test information 9.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BCV63_63B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 6 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors 10. Package outline 3.0 2.8 1.1 0.9 1.9 4 2.5 2.1 3 0.45 0.15 1.4 1.2 1 2 0.88 0.78 0.48 0.38 0.15 0.09 1.7 Dimensions in mm Fig 6. 04-11-16 Package outline SOT143B 11. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number BCV63 Package SOT143B Description 4 mm pitch, 8 mm tape and reel Packing quantity 3000 10000 -215 -235 BCV63B [1] BCV63_63B Product data sheet For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 7 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors 12. Soldering 3.25 0.6 (3×) 0.5 (3×) 1.9 solder lands 0.7 0.6 (3×) (3×) solder resist 2 solder paste 3 occupied area 0.7 0.6 Dimensions in mm 0.75 0.95 0.9 1 Fig 7. sot143b_fr Reflow soldering footprint SOT143B 4.45 2.2 1.2 (3×) 1.425 (3×) solder lands solder resist 4.6 2.575 occupied area Dimensions in mm 1.425 preferred transport direction during soldering 1 1.2 Fig 8. BCV63_63B Product data sheet sot143b_fw Wave soldering footprint SOT143B All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 8 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BCV63_63B v.4 20100804 Product data sheet - BCV63_BCV63B_3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • • • • • • Legal texts have been adapted to the new company name where appropriate. Section 1 “Product profile”: amended Section 3 “Ordering information”: added Section 4 “Marking”: updated Figure 1, 2, 3 and 4: added Section 8 “Application information”: added Section 9 “Test information”: added Figure 6: superseded by minimized package outline drawing Section 11 “Packing information”: added Section 12 “Soldering”: added Section 14 “Legal information”: updated BCV63_BCV63B_3 19990521 Product specification - BCV63_CNV_2 BCV63_CNV_2 19970310 Product specification - - BCV63_63B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 9 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. BCV63_63B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 10 of 12 BCV63; BCV63B Nexperia NPN general-purpose double transistors Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BCV63_63B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2010 © Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia BCV63; BCV63B NPN general-purpose double transistors 16. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Quality information . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Packing information . . . . . . . . . . . . . . . . . . . . . 7 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 04 August 2010
BCV63,215 价格&库存
很抱歉,暂时无法提供与“BCV63,215”相匹配的价格&库存,您可以联系我们找货
