33-0154-0
33-0154-0
    TALLYSMANWIRELESS
    SMA单排模块
    RF AMP BIAS-TEE W/SMA JACK
33-0154-0 数据手册
TW154 Regulated 0.5 to 3GHz, 3.3V Bias-Tee The TW154 is a professional grade wideband Bias-Tee for injecting DC voltages onto coaxial lines. The regulated output voltage and the high output current makes this bias-tee highly suitable for many active antennas and amplifiers. It is useable at higher frequencies with higher insertion loss (see data below). DC In 3.3V Regulator 50 Ohm Line Port A DC Block The TW154 is housed in a robust RF sealed, weatherproof (IP67) clear anodized aluminum enclosure and is available with 3 x SMA or TNC Jack connectors. TW154 Dimensions (mm) Applications   L-Band Signal Distribution GNSS (GPS/GLONASS) Signal Distribution Features Benefits             Low insertion loss: less than 1 dB at 3 GHz. Regulated output voltage: 3.3 VDC VSWR:
33-0154-0 价格&库存
很抱歉,暂时无法提供与“33-0154-0”相匹配的价格&库存,您可以联系我们找货
