GLP-KIT-ANTUFL18-02
GLP-KIT-ANTUFL18-02
    SYNAPSE
    STRAIGHT ANGLE ANTENNA KIT: 18"
GLP-KIT-ANTUFL18-02 数据手册
REVISIONS ZONE ALL ITEM 1 2 3 PN 326043-01A ANT019 CON369 REV. CHANGE DESCRIPTION APPROVED A000 CREATE EMJ DATE 11/30/16 DESCRIPTION CABLE, u.FL TO RP-SMA FEMALE, 18 INCH ANTENNA, 2.4GHZ, OUTDOOR, STRAIGHT, RP-SMA MALE,1.5dBi CONN O-RING FOR SMA CONNECTORS QTY. 1 1 1 7.1 .28 RECOMMENDED PANEL OPENING PANEL THICKNESS 0.25" MAX [457.2] 18 130.3 5.1 TO CONTROLLER 9.9 .4 2 NUT PART OF ITEM 1 1 BULKHEAD (REFERENCE) THIRD ANGLE PROJECTION 3 LOCK WASHER PART OF ITEM 1 COMMENTS: SYNAPSE WIRELESS INC. 6723 ODYSSEY DR HUNTSVILLE, AL 35806 TITLE: UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: MACH 1 BEND 3 TWO PLACE DECIMAL .01 INTERPRET GEOMETRIC THREE PLACE DECIMAL .005 TOLERANCING PER: ANSI PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SYNAPSE WIRELESS, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SYNAPSE WIRELESS, INC IS PROHIBITED. MATERIAL OUTDOOR KIT, U.FL TO STRAIGHT, GLP-KITANTUFL18-02 SIZE DWG. NO. A FINISH DO NOT SCALE DRAWING REV 120-035051-000 ENGR: EMJ A000 SHEET 1 OF 1
GLP-KIT-ANTUFL18-02 价格&库存
很抱歉,暂时无法提供与“GLP-KIT-ANTUFL18-02”相匹配的价格&库存,您可以联系我们找货
