MIKE11/2M/SMAM/S/S/17 数据手册
GPS/GLONASS, IP67 Magnetic mount
antenna, 2M cable, SMA male connector
Features
GPS and GLONASS frequencies
Magnetic and/or adhesive mount
The Mike 11 is a compact Dual Mount GPS and GLONASS antenna, tuned to to be able to receive
both satellite systems. Its small footprint of 47 x 35mm allows this antenna to fit onto most surfaces
comfortably, and with a modest height of 17mm, it provides an unobtrusive profile.
Dual mounting: with its magnetic base and separate adhesive pad, the Mike 11 can be mounted onto a
diverse range of surfaces via the two methods available. The Mike 11’s IP67 rating makes this a well
suited outdoor GPS antenna that can be used for a host of different GPS applications including:
vehicle/fleet/asset tracking and mobile applications, amongst many other general positioning
applications.
The Mike 11 has a centre frequency of xx for GPS and GLONASS compatibility. The built in Low
Noise Amplifier (LNA) provides a 28dB gain that makes this a high performance antenna, necessary
The Mike 3A has a centre frequency of 1575.42MHz for GPS compatibility. The built in Low Noise
Amplifier (LNA) provides a 28dB gain that makes this a high performance antenna, necessary for a
strong signal reception from visible satellites, as well as influencing a shorter time to fix to the
satellites.
Specifications
Antenna Specifications
Operating Temperature: -40 to +85°C
Impedance: 50 ohm
Gain: 28dB
VSWR: 2 max
Polarization: RHCP
Operating Frequencies
MHz (GPS/GLONASS)
Dimensions
Length: 47 mm
Width: 35 mm
Height: 17 mm
Mounting Specifications
Cable: RG174
Mounting Method: Magnetic & Adhesive
http://www.siretta.co.uk/product.php?id=1219&rid=&rpage=search 7‐10‐17
MIKE11/2M/SMAM/S/S/17 价格&库存
很抱歉,暂时无法提供与“MIKE11/2M/SMAM/S/S/17”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+153.488511+19.85375
- 10+121.7832210+15.75267
- 25+113.8659325+14.72857
- 100+105.16031100+13.60249
- 250+101.01106250+13.06579
- 500+98.51018500+12.74230
