Angle Position Sensors
AN1 Sensors
Intrinsically Linear Angle Position Sensor
Description
The AN1 Series sensors are one-piece, intrinsically linear contact angle position sensors. The sensors operate through the use of
Hall Effect technology with magnetic fields generated by permanent magnets. They provide a linear change in voltage output
(ratiometric to the input voltage) corresponding to an angular rotation of the input shaft.
Features
Typical Applications
Patented intrinsically linear angle position sensor (ILAPS)
Magnet/sensor orientation provides linear output from 5° to
85° of rotation without the need for electrical compensation
Return spring provides resistance to CCW motion
Fully encapsulated electronics
RoHS compliant
IP67
Implement (fork lift, agricultural trailer hitch,
etc.) position sensing
Steer, throttle by wire
Gear selection
Zero-contact encoder alternative
Environmental Specifications
1g RMS axial, 5g RMS horizontal, 8g RMS vertical; 20 Hz to 2 kHz
-40 °C to 125 °C (-40 °F to 257 °F)
-40 °C to 135 °C (-40 °F to 275 °F)
IP67
Vibration
Operating Temperature
Storage Temperature
Ingress Protection
Electrical Specifications
Input Voltage
Output Voltage vs. Rotation Angle
Input Current
Output Current
Output Linearity
5.0 VDC ± 10%
0° to 5° : 10% of Input Voltage, 5° to 85°: ratiometric (linear from 10%
to 90% of Input Voltage), 85° to 120°: 90% of Input Voltage (see chart)
8 mA @ 5 VDC
-1.25 mA to 1.25 mA
±2%
Mechanical Specifications
Housing Material
Mechanical Travel
Rotation Torque
Mass
Life
Glass Reinforced Plastic
120° maximum rotation
0.21 Nm (30 in oz) max with return spring
24 g (0.85 oz)
+10 million full cycles
Products
Part Number
Sensing Direction
Connector
Terminal
Housing
AN101101
Counter-clockwise
Delphi Metri-pack 150
12162185
Delphi 12124075
Delphi 12162185
www.cherryswitches.com
Page 1 of 2, last update 2014-10-29, Specifications subject to change without notice.
Output Voltage
Dimensions mm (inches)
Page 2 of 2, last update 2014-10-29, Specifications subject to change without notice.
很抱歉,暂时无法提供与“AN101101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+249.1883225+30.20021
