33-0141-0
33-0141-0
    TALLYSMANWIRELESS
    SMA单排模块
    RF AMP 40 DB GPS L1 SMA JACK
33-0141-0 数据手册
TW141 1200 to 1800 MHz 40 dB Inline Amplifier The TW141 is a rugged, waterproof wideband 40dB gain in-line amplifier, specially designed to boost weak frequency signals from 1200 to 1800 MHz, including L-Band and all GNSS (GPS, GLONASS and Galileo) signals. The TW141 provides for much longer cable runs from antenna to receiver without degradation of system sensitivity, for applications such as mast-mount, large vehicle and timing systems. The TW141 passes DC directly from input to output to support centre conductor DC supply to the antenna, and so avoids the need for an additional bias source or bias “T”. It is enclosed in a robust weatherproof cylindrical nickel-plated brass housing (IP67 compliant) and is available with SMA and TNC female connectors. TW141 Dimensions (mm) IMPORTANT: Amplifiers are directional and must be installed in the orientation indicated on the product label. (Arrow points away from antenna) Applications • • • • Commercial and Military L-Band Satellite Systems Wireless Telecom & Cellular Base Station Timing Applications GNSS (GPS, GLONASS, Galileo), SBAS and Telematics Systems Commercial and Industrial Timing and Synchronization Applications Features Benefits • • • • • • • • • • • • • • Very low noise: 50 dB +7 dBm +20 dBm 3.3 to 10 VDC nominal
33-0141-0 价格&库存
很抱歉,暂时无法提供与“33-0141-0”相匹配的价格&库存,您可以联系我们找货
