Eccosorb® LS
Lossy, Flexible, Foam Microwave Absorber
LOSSY, FLEXIBLE FOAM ABSORBER
Eccosorb LS is the most widely known, used, and recommended polyurethane foam
absorber for both isolation/ insertion loss as well as cavity resonance purpose. Eccosorb LS
obtains its microwave properties via impregnation with a carbon black dispersion and is
therefore electrically conductive. It is a cost efficient solution for many applications over the
thinner rubber absorbers.
FEATURES AND BENEFITS
MARKETS
Flexible, foam material
High loss, low density
Tuned serie
Commercial Telecom
Test Boxes
Security and Defense
Sensor
SPECIFICATIONS
TYPICAL PROPERTIES
ECCOSORB LS
Max. Service Temperature °C (°F)
90 (194)
Frequency Range
≥ 1 GHz
Data for design engineer guidance only. Observed performance varies in application.
Engineers are reminded to test the material in application.
Attenuation
(dB/cm)
Relative Impedance
(|Z|/Z0)
3 GHz
10 GHz
3 GHz
10 GHz
LS-14
1.0
1.7
0.83
0.89
LS-16
1.5
2.3
0.78
0.87
LS-18
3.2
4.7
0.69
0.82
LS-20
4.2
7.0
0.61
0.78
LS-22
7.4
14.9
0.55
0.74
LS-24
11
24
0.25
0.44
Europe: +49.8031.24600
LS-26
16
34
0.18
0.31
Asia: +86.755.2714.1166
LS-28
0.16
0.27
www.laird.com
LS-30
24
46
0.13
0.22
USA: +1.866.928.8181
APPLICATIONS
Eccosorb LS is used to lower cavity Q’s in RF amplifiers, oscillators, cabinets containing
microwave devices, computer housings, LNB’s and isolation of antennas by insertion loss.
Eccosorb LS is also used to reduce surface currents on radiating elements and outer
ground-plane type surfaces.
Reflectivity of an object (metal or otherwise) can be reduced somewhat by applying one
or more layers of Eccosorb LS to its surface.
Eccosorb® LS
AVAILABILITY
Standard sheets are 610mm x 610mm (24”x24”).
Standard thicknesses are 3.2 mm (1/8”), 6.4 mm (1/4”), 9.5 mm (3/8”), 12.7 mm (1/2”),
19.1 mm (3/4”).
All Eccosorb LS types can be delivered in special sizes or customer specified configurations
upon request. This includes die-cut and kiss cut parts to reduce installation labor by
allowing quick assembly.
Usually Eccosorb LS is supplied with a pressure sensitive adhesive.
Upon special request, Eccosorb LS can be supplied with an anti-dust coating to prevent
carbon fallout.
It can also be supplied, upon request, with a coating to prevent moisture uptake in high
humidity to moderately wet environments.
INSTRUCTIONS FOR USE
For optimal performance, Eccosorb LS should be bonded to a metallic surface.
To obtain a strong bond, the surface should be thoroughly cleaned with a degreasing
solvent.
It can be securely bonded to itself or to other materials such as metal, wood and common
plastic composites. Our specific Eccostock® foam adhesive is recommended or the selfadhesive version can be used.
The material can be easily cut with a sharp knife, scissors or die.
dB Insertion Loss
Approximate Insertion Loss at 3 GHz and 45°
60
LS-30
LS-28
LS-26
LS-24
LS-22
LS-20
LS-18
LS-16
LS-14
50
40
30
6.4
9.5
12.7
19.1
Thickness (mm)
www.laird.com
RFP-DS-LS 070116
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the
end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or
consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird
Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be
the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
2
很抱歉,暂时无法提供与“78136078”相匹配的价格&库存,您可以联系我们找货
